[Frage] Fritz box 7490 resp. 7390 and Terratec H6 USB TV Card as TV Server possible?
a123a123
6 Mrz 2013
Hello!
I'm a Freetz newbie and I wonder if it is already possible to use a fritz box 7490 (or my old fritz box 7390) as a TV server backend for Kodi for live TV from cable and recording to USB stick plugged into fritzbox.
My TV hardware is a Terratec H6 USB TV card.
I found a few related discussions online therefore I'd like to know if this is already possible.
In case of yes do I need to:
- install and configure Freetz or is there a more lightweight approach possible?
- have to install VPD or even MythTV? Any suggestions for another lightweight TV software?
- are there any step-by-step tutorials for beginners available?
I'd be really happy to replace my separate old P4-desktop with a solution using fritz.box.
Thank you for your reply in English or German!
KR H.
Is your current system running linux etc.?
A quick research does not give any suitable driver.
The USB driver for the FritzBox doesn't support isochronous transfer, therefore it won't work even when you find a driver for the TV stick.
@Whoopie:
Is this still valid for the USB3 driver for the new 3.10.73 kernel?
It's really a serious question ... I don't have the spare time to test it and/or to investigate the kernel sources for this driver - at least not in a timely manner.
I'm using this TV card on Windows. However if there is no unix support for the Terratec H6 - not even with default drivers - I'd buy a substitute USB TV card that is supported according to the board's suggestions
@PeterPawn: your remark is valid, I should have checked the latest sources before making such a statement. I haven't and I won't.
So this should be the first task to verify if the USB drivers support it.
#Kuddel#
