IPTV Kasachstan an FB7170 aka W900V
almaty1707
9 Okt 2015
Liebes Forum,
versuche hier in Kasachstan verzweifelt das hiesige IPTV auf meine Box zum Laufen zu bringen.
Das Inet läuft soweit auf der Box (PVC 0, VPI/VCI 0/40, Encap PPPoe, MUX LLC). Das IPTV (PVC 1, VPI/VCI 0/42, Encap RFC1483. Bridge Mode) bekomme ich nicht hin. Die Anpassung in der Ar7.cfg habe ich soweit vorgenommen.
Auf der Box läuft ein W900V_7170_04.88-freetz-2.0-13689.de Image. An ihr hängt fürs IPTV eine STB ZXV10 B700 von ZTE vom hiesigen Provider.
Würde mich freuen, wenn ihr mir helfen könntet.
Bester Gruß und schon mal Danke:D:D:D
Hallo thtomate 12,
wie folgt angepasst:
vccs {
VPI = 0;
VCI = 40;
traffic_class = atm_traffic_class_UBR;
pcr = 0;
scr = 0;
priority = 0;
dsl_encap = dslencap_pppoe;
ipbridgeing = no;
ipbridgeing_igmp = no;
pppoeforwarding = no;
connections = "internet";
VPI = 0;
VCI = 42;
pcr = 0;
scr = 0;
priority = 1;
dsl_encap = dslencap_ether;
ipbridgeing = no;
connections = "mstv";
mcupstream = "internet", "mstv";
#weiter
enabled = yes;
name = "mstv";
dslinterfacename = "dsl";
no_masquerading = no;
no_firewall = no;
pppoevlanauto = no;
pppoevlanauto_startwithvlan = no;
ppptarget = "mstv";
etherencapcfg {
use_dhcp = yes;
use_dhcp_if_not_encap_ether = no;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = yes;
stay_always_online = yes;
disable_ondemand = no;
only_route_when_connected = no;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 10m;
redial_after_limit_reached_variance = 5m;
redial_delay_after_low_error = 10s;
redial_delay_after_ppp_timeout = 10s;
redial_delay_after_ppp_error = 0w;
routes_only_for_local = no;
tcclassroutes = "iptv";
disable_staticroutes_on_dhcproutes = no;
ripv2receiver_enabled = no;
dsldpconfig {
security = dpsec_firewall;
filter_teredo = yes;
filter_netbios = yes;
lowinput {
policy = "permit";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
#weiter bei targets
type = pppcfg_target_internet;
name = "mstv";
only_crypt_auth = no;
local {
username = "";
passwd = "";
remoteauth = pppcfg_authtype_chap;
remoteauth_only_on_incoming = yes;
remote {
inactivity_timeout = 0w;
bUseChargeInterval = no;
nChargeInterval = 1m;
lcpecho_disconnect_mode = lcpecho_auto;
logicaldisconnect_with_physical = yes;
disconnect_timeout = 0w;
finaldisconnectcall = no;
ipnetbiosspoofing = no;
dnsfilter_for_active_directory = no;
no_outgoing_calls = no;
coso = pppcfg_coso_caller;
callback_delay = 1s;
icbmode = pppcfg_icbmode_none;
ocbmode = pppcfg_ocbmode_none;
mscbprefered = no;
multilink {
extra_static_channels = 0;
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
header_compression = yes;
data_compression = pppcfg_datacomp_auto;
stac_reset_with_history_number = no;
encryption = pppcfg_crypt_none;
inactivity_prevention_interval = 0w;
new_ipaddr_on_connect = no;
my_ipaddr = 0.0.0.0;
his_ipaddr = 0.0.0.0;
overwrite_dns1 = 0.0.0.0;
overwrite_dns2 = 0.0.0.0;
bVolumeRoundUp = no;
VolumeRoundUpBytes = 0;
bProviderDisconnectPrevention = no;
ProviderDisconnectPreventionInterval = 1d;
ProviderDisconnectPreventionHour = 5;
bProviderDisconnectPreventionHourSet = yes;
passiv_on_outgoing = no;
mode6 = mode6_off;
#sowie
dslglobalconfig {
autodetect = no;
Bester Gruss
Man müsste mal wissen was da vorher für ein Router dran war und wie der das IPTV so zur Verfügung gestellt hat.
Dann müsste man die Fritte dazu bringen, dass die wie der Original-Router IPTV zur Verfügung stellt.
Ich habe mal so was ähnliches in Weißrussland (erfolglos) versucht - mich würde die Lösung also wirklich interessieren.
Alternativ kann ich dir eine komplett andere Lösung vorschlagen (die funktioniert dann aber ohne Probleme).
Irgendeiner deiner Bekannte oder du selbst haben doch mit Sicherheit ein Abo von kartina.tv und einen VDSL-Anschluss mit mindestens 5mbit/s upload.
Verbinde diesen Anschluss per VPN mit deiner 7170er und lass die in Kasachstan einfach kartina.tv gucken.
Danke erst mal für Dein Feedback. Sorry, dass ich die Ar7.cfg ins Reply gepostet habe, aber ich bekomme irgendwie keine Anhänge ins Board hochgeladen. Zum Einsatz kommt üblicherweise ein TP-Link TD-W8901G. Hier auch mal der Link der Anleitung des Providers zur Info. http://tp-link.kz/content/instrukci...01g_td-w8901g_td-w8151n_td-w8951nd_td-w8961nd Dieses geraet habe ich vom Provider und es funzt auch. Umstellen will ich auf die FB, da ich in D auch eine stehen habe und u.a. aufs Entertain via Tunnel Zugriff haben wollte.
Jetzt nicht noch mehr Verwirrung stiften, eins nach dem anderen.
Wegen dieser Anleitung http://www.megahelp.kz/general.htm#idtv denke ich, dass es IGMPv2 ist.
- - - Aktualisiert - - -
Ich habe mal deinen ar7.cfg angeschaut. Du hast DHCP auf dem Interface eingestellt, doch laut der Anleitung gibt es kein DHCP, kannst du mal bitte schauen, ob das Interface überhaupt hochkommt?
Hallo thtomate12,
http://tp-link.kz/content/instrukci...1g_td-w8951nd_td-w8961nd_dlya_megaline_i_idtv
Diese Anleitung des Providers ist exakt die für den Router, der auch vom Provider vertrieben wird und funktioniert auch. Die gestrige Anleitung ist m.E. etwas irritierend. Die FB sollte m.W. kein Problem mit IGMPv2 haben. Mich wundert, dass bei ifconfig, auf der FB kein IPTV IFace zu sehen ist! Muss hier in der cpmaccfg noch etwas angepasst werden und wenn was?
Hier noch die route & if config dazu.
porcupine
