Today I tested the 6.80 firmware for the first time.
In the last year I had a sustained download rate between 108~111 Mbit/s
In that time I had various different firmwares.
Now my download speed is 84 Mbit/s
The upload speed went down from 32 Mbit/s to 31 Mbit/s
I may be going back soon if this doesn't change. (It is possible this is something automatic at the provider's side after a few LoS's.
Will report here if that's the case (could need a recover of 24 hours)
edit: 20-02-2017
I just tried "previous DSL version", but the speed stays at 84 Mbit/s
The only thing to test now is reverting to 6.52int
BTW... This is strange:
FRITZ!BoxConnectionDSL Central Exchange
83.166 kbit/s
32.512 kbit/s
DSL version
1.100.133.44DSL active since:
13 minutes
VDSL2 17a G.Vector (ITU G.993.5)Unknown (00000000)
0.0
Negotiated Connection Properties
I just flashed another 7490 connected to another VDSL2 line with similar speeds.
It took a long while (5 minutes after getting access using the webif) before the line was trained, but it went straight up to 111 Mbit/s and there's no difference in the 2 DSL pages.
I tested the connection that reports to have 84 Mbit/s with http://speedtest.net and it reported a throughput of 102 Mbit/s.
It seems there's something wrong with the reporting of the speed. Not the speed itself.
Even stranger and worrying is that it's only 1 modem and not the other.
For now I'm assuming I have a 109 Mbit/s connection.
edit: 20-02-2017
32.512 kbit/s
13 minutes
0.0
Receive Direction | Send Direction | ||
Max. DSLAM throughput | kbit/s | 111216 | 33032 |
Min. DSLAM throughput | kbit/s | 784 | 0 |
Attainable throughput | kbit/s | 114402 | 45176 |
Current throughput | kbit/s | 109241 | 32512 |
Seamless rate adaptation | on | off | |
Latency | fast | fast | |
Impulse Noise Protection (INP) | 73 | 79 | |
G.INP | on | on | |
Signal-to-noise ratio | dB | 6 | 5 |
Bitswap | on | on | |
Line attenuation | dB | 3 | 3 |
Profile | 17a | ||
G.Vector | full | full | |
Carrier record | A43 | A43 |
