mISDN V2 is needed for using an old ISDN hardware (Eicon Diva, AVM, HFC chip ISDN cards etc).
I need help with mISDN V2 on:
Elastix 4 on CentOS7
Asterix: 11.20.0
Kernel: 3.10.0
DAHDI: 2.10.2
I can not install LCR, I got error, and I can't make mISDN module automaticaly start with LCR script.
Procedure before error, steps:
Please help about last step!
Start services/drivers with some automatic start script or LCR.
I tryed LCR and I can't instal LCR.
LCR is latest. Procedure is:
but i get errors:
Configure seems OK,:
but "make" not:
Solutions for automaticaly start mISDN and ISDn drivers are:
1. made patch for LCR, because there is no patch here http://git.misdn.eu/?p=repositories/lcr.git;a=summary
2. find version of distro/kernel/module which can process this without any syntax error discover (and with that probably also all other errors)
3. manualy made changes instead using LCR script
Asterix: 11.20.0
Kernel: 3.10.0
DAHDI: 2.10.2
[root@localhost ~]# systemctl stop firewalld.service
[root@localhost ~]# systemctl disable firewalld.service
[root@localhost ~]# yum install nano (This is optionaly)
[root@localhost ~]# yum -y groupinstall 'Development Tools'
[root@localhost ~]# git clone git://git.misdn.eu/mISDN.git/ mISDN download
[root@localhost ~]# git clone git://git.misdn.eu/mISDNuser.git/ mISDNuser download
[root@localhost ~]# cd mISDN
[root@localhost ~]# ./configure
[root@localhost ~]# cp mISDN.cfg.default standalone/mISDN.cfg
[root@localhost ~]# make modules
[root@localhost ~]# make modules_install
mISDNuser
cd mISDNuser
[root@localhost ~]# make install
make modules
After this procedure, one more step with mISDNuser. To compile and install the mISDN user lib and tools, just switch to the mISDNuser dir and run:
[CODE]cd mISDNuser
make
make install
cd /usr/src
git clone git://git.misdn.eu/lcr.git/
cd /usr/src/lcr
#If compile from GIT, run "./autogen.sh" first.
./autogen.sh
./configure
make
make install
[root@Elastix4 lcr]# ./autogen.sh
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `build-aux'.
libtoolize: copying file `build-aux/ltmain.sh'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.ac and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
[root@Elastix4 lcr]# ./configure
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking whether make supports nested variables... yes
checking dependency style of gcc... gcc3
checking for grep that handles long lines and -e... (cached) /usr/bin/grep
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether make sets $(MAKE)... (cached) yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking how to print strings... printf
checking for a sed that does not truncate output... /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking mISDN/mbuffer.h usability... yes
checking mISDN/mbuffer.h presence... yes
checking for mISDN/mbuffer.h... yes
checking asterisk/compiler.h usability... yes
checking asterisk/compiler.h presence... yes
checking for asterisk/compiler.h... yes
checking for struct ast_tone_zone_sound... yes
checking for struct ast_party_caller... yes
checking openssl/rsa.h usability... yes
checking openssl/rsa.h presence... yes
checking for openssl/rsa.h... yes
checking for main in -lcrypto... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for OPENCORE_AMRNB... no
checking for main in -lm... yes
checking for main in -lncurses... yes
checking for main in -lpthread... yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking sys/file.h usability... yes
checking sys/file.h presence... yes
checking for sys/file.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking for assert.h... (cached) yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for pid_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking vfork.h usability... no
checking vfork.h presence... no
checking for vfork.h... no
checking for fork... yes
checking for vfork... yes
checking for working fork... yes
checking for working vfork... (cached) yes
checking whether gcc needs -traditional... no
checking whether lstat correctly handles trailing slash... yes
checking whether lstat accepts an empty string... no
checking whether lstat correctly handles trailing slash... (cached) yes
checking for GNU libc compatible malloc... yes
checking for working memcmp... yes
checking return type of signal handlers... void
checking for working strnlen... yes
checking for working strtod... yes
checking for vprintf... yes
checking for _doprnt... no
checking for gettimeofday... yes
checking for memmove... yes
checking for memset... yes
checking for mkdir... yes
checking for socket... yes
checking for strcasecmp... yes
checking for strchr... yes
checking for strerror... yes
checking for strncasecmp... yes
checking for strstr... yes
checking for strtol... yes
checking for strtoul... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating include/Makefile
config.status: creating include/gsmhr/Makefile
config.status: creating libgsmhr/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
configure: Compiled with mISDN support
configure: Not compiled with GSM network side support
configure: Not compiled with GSM mobile side support
configure: Not compiled with GSM half rate codec support
configure: Not compiled with GSM AMR codec support
configure: Compiled with Asterisk channel driver support
configure: Not compiled with CCITT No.5 support
configure: Not compiled with SIP support
configure: Not compiled with VoOTP support
but "make" not:
[root@Elastix4 lcr]# make
make all-recursive
make[1]: Entering directory `/usr/src/lcr'
Making all in include
make[2]: Entering directory `/usr/src/lcr/include'
make[3]: Entering directory `/usr/src/lcr/include'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/usr/src/lcr/include'
make[2]: Leaving directory `/usr/src/lcr/include'
make[2]: Entering directory `/usr/src/lcr'
gcc -DWITH_MISDN -DWITH_CRYPT -Wall -DCONFIG_DATA="\"/usr/local/etc/lcr\"" -DSHARE_DATA="\"/usr/local/share/lcr\"" -DLOG_DIR="\"/usr/local/var/log/lcr\"" -DEXTENSION_DATA="\"/usr/local/var/lib/lcr/extensions\"" -Dast_tone_zone_sound=ast_tone_zone_sound -DAST_1_8_OR_HIGHER -g -O2 -D_GNU_SOURCE -fPIC -c chan_lcr.c -o chan_lcr.po
In file included from chan_lcr.c:172:0:
/usr/include/asterisk/version.h:1:2: error: #error "Do not include 'asterisk/version.h'; use 'asterisk/ast_version.h' instead."
In file included from /usr/include/string.h:633:0,
from chan_lcr.c:115:
chan_lcr.c: In function chan_lcr_log:
chan_lcr.c:254:24: error: dereferencing pointer to incomplete type
strncpy(ast_text, ast->name, sizeof(ast_text)-1);
chan_lcr.c: In function send_message:
chan_lcr.c:396:7: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function apply_opt:
chan_lcr.c:614:5: warning: passing argument 1 of ast_translator_build_path makes pointer from integer without a cast [enabled by default]
call->trans=ast_translator_build_path(AST_FORMAT_SLINEAR, (options.law=='a')?AST_FORMAT_ALAW:AST_FORMAT_ULAW);
In file included from chan_lcr.c:154:0:
/usr/include/asterisk/translate.h:299:23: note: expected struct ast_format * but argument is of type int
struct ast_trans_pvt *ast_translator_build_path(struct ast_format *dest, struct ast_format *source);
chan_lcr.c:614:5: warning: passing argument 2 of ast_translator_build_path makes pointer from integer without a cast [enabled by default]
chan_lcr.c: In function send_setup_to_lcr:
chan_lcr.c:699:2: warning: #warning DISABLED DUE TO DOUBLE LOCKING PROBLEM [-Wcpp]
chan_lcr.c:704:43: error: dereferencing pointer to incomplete type
newparam.setup.capainfo.bearer_capa = ast->transfercapability;
chan_lcr.c: In function lcr_start_pbx:
chan_lcr.c:790:19: error: dereferencing pointer to incomplete type
char *exten = ast->exten;
In file included from chan_lcr.c:181:0:
chan_lcr.c:802:87: error: dereferencing pointer to incomplete type
CDEBUG(call, ast, "Try to start pbx. (exten=%s context=%s complete=%s)\n", exten, ast->context, complete?"yes":"no");
chan_lcr.h:138:110: note: in definition of macro CDEBUG
#define CDEBUG(call, ast, arg...) chan_lcr_log(__LOG_NOTICE, __FILE__, __LINE__, __FUNCTION__, call, ast, ##arg)
chan_lcr.c:810:39: error: dereferencing pointer to incomplete type
if (!ast_canmatch_extension(ast, ast->context, exten, 1, call->oad)) {
chan_lcr.c:811:121: error: dereferencing pointer to incomplete type
CDEBUG(call, ast, "Got 'sending complete', but extension '%s' will not match at context '%s' - releasing.\n", exten, ast->context);
chan_lcr.c:820:37: error: dereferencing pointer to incomplete type
if (!ast_exists_extension(ast, ast->context, exten, 1, call->oad)) {
chan_lcr.c:821:153: error: dereferencing pointer to incomplete type
CDEBUG(call, ast, "Got 'sending complete', but extension '%s' would match at context '%s', if more digits would be dialed - releasing.\n", exten, ast->context);
chan_lcr.c:841:37: error: dereferencing pointer to incomplete type
if (ast_canmatch_extension(ast, ast->context, exten, 1, call->oad)) {
chan_lcr.c:856:35: error: dereferencing pointer to incomplete type
if (ast_exists_extension(ast, ast->context, exten, 1, call->oad)) {
chan_lcr.c:879:11: error: dereferencing pointer to incomplete type
if (!*ast->exten) {
chan_lcr.c:906:5: error: dereferencing pointer to incomplete type
ast->hangupcause = call->cause;
chan_lcr.c: In function lcr_in_setup:
chan_lcr.c:969:18: error: dereferencing pointer to incomplete type
ast_redir = &ast->redirecting;
chan_lcr.c:970:19: error: dereferencing pointer to incomplete type
ast_caller = &ast->caller;
chan_lcr.c:990:5: error: dereferencing pointer to incomplete type
ast->tech_pvt = call;
chan_lcr.c:991:5: error: dereferencing pointer to incomplete type
ast->tech = &lcr_tech;
chan_lcr.c:992:5: error: dereferencing pointer to incomplete type
ast->fds[0] = call->pipe[0];
chan_lcr.c:1002:14: error: dereferencing pointer to incomplete type
strncpy(ast->exten, param->setup.dialinginfo.id, AST_MAX_EXTENSION-1);
chan_lcr.c:1004:14: error: dereferencing pointer to incomplete type
strncpy(ast->context, param->setup.dialinginfo.context, AST_MAX_CONTEXT-1);
chan_lcr.c:1006:14: error: dereferencing pointer to incomplete type
strncpy(ast->context, param->setup.callerinfo.interface, AST_MAX_CONTEXT-1);
chan_lcr.c:1187:5: error: dereferencing pointer to incomplete type
ast->transfercapability = param->setup.capainfo.bearer_capa;
chan_lcr.c:1198:5: error: dereferencing pointer to incomplete type
ast->nativeformats = (options.law=='a')?AST_FORMAT_ALAW:AST_FORMAT_ULAW;
chan_lcr.c:1199:5: error: dereferencing pointer to incomplete type
ast->readformat = ast->rawreadformat = ast->nativeformats;
chan_lcr.c:1199:23: error: dereferencing pointer to incomplete type
chan_lcr.c:1199:44: error: dereferencing pointer to incomplete type
chan_lcr.c:1200:5: error: dereferencing pointer to incomplete type
ast->writeformat = ast->rawwriteformat = ast->nativeformats;
chan_lcr.c:1200:24: error: dereferencing pointer to incomplete type
chan_lcr.c:1200:47: error: dereferencing pointer to incomplete type
chan_lcr.c:1217:5: error: dereferencing pointer to incomplete type
ast->priority = 1;
chan_lcr.c:1218:5: error: dereferencing pointer to incomplete type
ast->hangupcause = 0;
chan_lcr.c: In function lcr_in_proceeding:
chan_lcr.c:1261:8: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function lcr_in_alerting:
chan_lcr.c:1283:8: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function lcr_in_connect:
chan_lcr.c:1306:8: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function lcr_in_disconnect:
chan_lcr.c:1344:6: error: dereferencing pointer to incomplete type
chan_lcr.c:1352:9: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function lcr_in_release:
chan_lcr.c:1383:6: error: dereferencing pointer to incomplete type
chan_lcr.c:1391:9: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function lcr_in_information:
chan_lcr.c:1419:14: error: dereferencing pointer to incomplete type
strncat(ast->exten, param->information.id, AST_MAX_EXTENSION-1);
chan_lcr.c:1441:8: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c:1457:10: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function lcr_in_pattern:
chan_lcr.c:1519:8: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function lcr_in_dtmf:
chan_lcr.c:1550:7: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function release_all_calls:
chan_lcr.c:1735:8: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: In function wake_event:
chan_lcr.c:1884:6: warning: variable rc set but not used [-Wunused-but-set-variable]
int rc;
chan_lcr.c: At top level:
chan_lcr.c:2029:51: error: unknown type name format_t
struct ast_channel *lcr_request(const char *type, format_t format, const struct ast_channel *requestor, void *data, int *cause)
chan_lcr.c: In function lcr_call:
chan_lcr.c:2407:12: error: dereferencing pointer to incomplete type
call = ast->tech_pvt;
chan_lcr.c:2435:9: error: dereferencing pointer to incomplete type
if (ast->transfercapability == INFO_BC_DATAUNRESTRICTED
chan_lcr.c:2436:9: error: dereferencing pointer to incomplete type
|| ast->transfercapability == INFO_BC_DATARESTRICTED
chan_lcr.c:2437:9: error: dereferencing pointer to incomplete type
|| ast->transfercapability == INFO_BC_VIDEO)
chan_lcr.c:2448:9: error: dereferencing pointer to incomplete type
&& ast->transfercapability != INFO_BC_DATAUNRESTRICTED
chan_lcr.c:2449:9: error: dereferencing pointer to incomplete type
&& ast->transfercapability != INFO_BC_DATARESTRICTED
chan_lcr.c:2450:9: error: dereferencing pointer to incomplete type
&& ast->transfercapability != INFO_BC_VIDEO)
chan_lcr.c:2451:6: error: dereferencing pointer to incomplete type
ast->transfercapability = INFO_BC_DATAUNRESTRICTED;
chan_lcr.c: In function send_digit_to_chan:
chan_lcr.c:2509:77: error: dereferencing pointer to incomplete type
CDEBUG(NULL, ast, "Unable to handle DTMF tone '%c' for '%s'\n", digit, ast->name);
chan_lcr.c: In function lcr_digit_begin:
chan_lcr.c:2537:12: error: dereferencing pointer to incomplete type
chan_lcr.c: In function lcr_digit_end:
chan_lcr.c:2584:12: error: dereferencing pointer to incomplete type
chan_lcr.c: In function lcr_answer:
chan_lcr.c:2620:12: error: dereferencing pointer to incomplete type
chan_lcr.c: In function lcr_hangup:
chan_lcr.c:2660:12: error: dereferencing pointer to incomplete type
chan_lcr.c:2679:5: error: dereferencing pointer to incomplete type
ast->tech_pvt = NULL;
chan_lcr.c:2680:5: error: dereferencing pointer to incomplete type
ast->fds[0] = -1;
chan_lcr.c:2689:10: error: dereferencing pointer to incomplete type
if (ast->hangupcause > 0)
chan_lcr.c:2690:26: error: dereferencing pointer to incomplete type
send_release(call, ast->hangupcause, LOCATION_PRIVATE_LOCAL);
chan_lcr.c: In function lcr_write:
chan_lcr.c:2732:18: error: union ast_frame_subclass has no member named codec
if (!f->subclass.codec)
chan_lcr.c:2741:19: error: union ast_frame_subclass has no member named codec
if (!(f->subclass.codec & ast->nativeformats)) {
chan_lcr.c:2741:31: error: dereferencing pointer to incomplete type
chan_lcr.c:2765:40: error: union ast_frame_subclass has no member named codec
ast_set_write_format(ast, f->subclass.codec);
chan_lcr.c:2773:11: error: dereferencing pointer to incomplete type
f = (ast->writetrans) ? ast_translate(
chan_lcr.c:2774:7: error: dereferencing pointer to incomplete type
ast->writetrans, fr, 0) : fr;
chan_lcr.c:2783:12: error: dereferencing pointer to incomplete type
chan_lcr.c: In function lcr_read:
chan_lcr.c:2823:12: error: dereferencing pointer to incomplete type
chan_lcr.c:2870:24: error: union ast_frame_subclass has no member named codec
call->read_fr.subclass.codec = ast->nativeformats;
chan_lcr.c:2870:36: error: dereferencing pointer to incomplete type
chan_lcr.c: In function lcr_indicate:
chan_lcr.c:2926:12: error: dereferencing pointer to incomplete type
chan_lcr.c:2951:37: error: dereferencing pointer to incomplete type
ts = ast_get_indication_tone(ast->zone, "busy");
chan_lcr.c:2959:97: error: dereferencing pointer to incomplete type
CDEBUG(call, ast, "Received indicate AST_CONTROL_CONGESTION from Asterisk. (cause %d)\n", ast->hangupcause);
chan_lcr.c:2967:40: error: dereferencing pointer to incomplete type
newparam.disconnectinfo.cause = ast->hangupcause;
chan_lcr.c:2978:37: error: dereferencing pointer to incomplete type
ts = ast_get_indication_tone(ast->zone, "congestion");
chan_lcr.c:3009:37: error: dereferencing pointer to incomplete type
ts = ast_get_indication_tone(ast->zone, "ring");
chan_lcr.c:3051:30: error: dereferencing pointer to incomplete type
ast_moh_start(ast,data,ast->musicclass);
chan_lcr.c: In function lcr_fixup:
chan_lcr.c:3109:12: error: dereferencing pointer to incomplete type
chan_lcr.c: In function lcr_send_text:
chan_lcr.c:3135:12: error: dereferencing pointer to incomplete type
chan_lcr.c: In function lcr_bridge:
chan_lcr.c:3179:14: error: dereferencing pointer to incomplete type
call1 = ast1->tech_pvt;
chan_lcr.c:3180:14: error: dereferencing pointer to incomplete type
call2 = ast2->tech_pvt;
chan_lcr.c:3292:14: error: dereferencing pointer to incomplete type
chan_lcr.c:3293:14: error: dereferencing pointer to incomplete type
chan_lcr.c:3318:2: warning: initialization makes pointer from integer without a cast [enabled by default]
.capabilities = AST_FORMAT_ALAW,
chan_lcr.c:3318:2: warning: (near initialization for lcr_tech.capabilities) [enabled by default]
chan_lcr.c:3320:15: error: lcr_request undeclared here (not in a function)
.requester = lcr_request,
chan_lcr.c:3331:2: warning: initialization from incompatible pointer type [enabled by default]
.call = lcr_call,
chan_lcr.c:3331:2: warning: (near initialization for lcr_tech.call) [enabled by default]
chan_lcr.c: In function load_module:
chan_lcr.c:3520:24: warning: assignment makes pointer from integer without a cast [enabled by default]
lcr_tech.capabilities = (options.law=='a')?AST_FORMAT_ALAW:AST_FORMAT_ULAW;
make[2]: *** [chan_lcr.po] Error 1
make[2]: Leaving directory `/usr/src/lcr'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/lcr'
make: *** [all] Error 2
