Ergebnis 1 bis 2 von 2
Thema: Siemens optiPoint 400 problem?
  1. #1
    IPPF-Einsteiger
    Registriert seit
    03.03.2005
    I just get a Siemens optiPoint 400 SIP phone. Three problems occours.
    1-i connect it properly to my LAN and give electricity but no dial tone is coming. is everything alright?
    2- i can make settings either with keypad or with web gui ( <ip number>:8085 ) But not registered my SIP server. (This server is on my LAN) i gave it an ip address, and enter gateway and mask. Is anything i overlook?
    3- Sometimes it is rebooting itself and about it's repating about in 1-2 minutes untill i plug off RJ-45 cable and plug it again.
    Please write your answers in english, i don't know german.
    Thank you.
  2. #2
    IPPF-Aufsteiger Avatar von mysip
    Registriert seit
    09.10.2004
    Hi.
    1) dial tone will be applied only if you have registered successfully to your proxy / server. If this is not the case, you will see the IP adress alternating with "no server" message in the display.
    2) For the server (which one are you using?) you have to enter the SIP registrar / proxy addresses first. This should be in the Web admin under the "SIP environment" menue item.
    3) As far as I remember, the reboot occurs only if some basics are not set. I suggest to make sure you have a valid IP address first (try a PING), then set SIP settings. Which application version are you running (you find this under "General information" on the Web Admin. Should be SIP V2.3 or V2.4.
    regards
    mysip
Ähnliche Themen
  1. Siemens OptiPoint 600
    Von mode im Forum Optipoint
    Antworten: 24
    Letzter Beitrag: 09.05.2011, 20:13
  2. Siemens OptiPoint 600
    Von dg303 im Forum Optipoint
    Antworten: 4
    Letzter Beitrag: 23.09.2006, 14:01
  3. Siemens optiPoint 400 SIP
    Von bogazici im Forum Optipoint
    Antworten: 19
    Letzter Beitrag: 08.06.2005, 11:47
  4. Siemens Optipoint 400 SIP
    Von Roland im Forum Optipoint
    Antworten: 2
    Letzter Beitrag: 30.11.2004, 23:36
  5. SIEMENS Optipoint 400 SIP
    Von dfrye im Forum Andere VoIP-Hardware
    Antworten: 12
    Letzter Beitrag: 09.10.2004, 11:50
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
