[FRAGE] Testsoftware um zu sehen ob Router sip-aware ist
der_Gersthofer
Admin-Team
17 Apr 2004
Gibt es so etwas auch für den privaten Bereich?
http://press.arrivenet.com/tec/article.php/664640.html
http://www.qacafe.com/sip-testing.pdf
Denn das richtet sich wohl eher an Firmen, oder?
Thank you for your interest in CDRouter. You may download the demo
using the following link:
ftp://qacafe.com/pub/users/qacafe/cdrouterdemo-2.7.exe
The demo file contains binary packages for Red Hat Linux, Debian Linux,
and SuSE Linux. Once downloaded to your Linux machine, make the *.exe
file executable:
chmod 755 cdrouterdemo-2.7.exe
Next, run the *.exe which will display our license agreement.
./cdrouterdemo-2.7.exe
If you agree to the license agreement, a *.tgz file will be installed
in the current working directory. Untar the file on your Linux system
and follow the directions in the DEMO-README.txt file.
tar zxvf cdrouterdemo-2.7.tgz
QA Cafe products require a license key to run. You must download a demo
key,
which will be available for the next 30 days, from the link below. This
key
needs to be placed in the /etc directory on the system running the
software.
http://www.qacafe.com/demo?t=26TS9w
More Help:
For help getting started running the tests, see the UserGuide.pdf
file
included with this distribution.
The User Guide is also available on-line at:
http://qacafe.com/cdrouter/UserGuide.pdf
You can also check the on-line knowledge base for common questions
http://qacafe.com/help
Or email
[email protected]
Thank you,
QA Cafe Support Team
FritzFunk
