Cisco SIP Firmware Release 7.5 vom 11. Juli
flo2005
14 Jul 2005
da ich hier noch gar nichts darüber gelesen habe, wollte ich mal posten, dass es eine neue Version der SIP-Firmware für das 7940/7960 gibt.
Einen Auszug aus den Release Notes darf ich ja hoffentlich posten...
Identifier Summary
CSCdy38909 Exit softkey highlighted and frozen
CSCed23057 SIP phone having problem setting up lines rollover
CSCed61099 SIP: Add DIVERSION or CC-DIVERSION to 302 Moved messages for
CFWDALL
CSCef03069 URL dialing on Cisco IP Phone 7940G does not work correctly
CSCef12937 inconsistent handling of SIP MERGED REQUESTs by Cisco IP Phones
CSCef24554 Cisco SIP IP Phone 7940G: CANCEL after ACK generates 481 response instead
of 200
CSCef24665 Cisco SIP IP Phone 7940Gdoes not retransmit 180 RINGING on receipt of initial
INVITE
CSCef25428 Cisco SIP IP Phone 7940G/7960G: DNS behavior needs to comply with RFC3263
section 4.2
CSCef30287 Cisco SIP IP Phone 7940G/7960G: Wrong ACK URI in ACK for CANCEL after
handling 302 moved
CSCef30442 Cisco SIP IP Phone 7940G/7960G: If caller_id blocking is on the transferring
phone, attended transfer fails
CSCef35589 Cisco SIP IP Phone 7940G/7960G: i Statistics stop when volume setting on phone
is changed
CSCef36049 Cisco SIP IP Phone 7940G/7960G: Phone sends ACK for 487 to registered proxy
when outbound proxy
CSCef36145 Cisco SIP IP Phone 7940G/7960G: protocol configuration not erased fully with erase
protocol-flash command
CSCef36846 Cisco SIP IP Phone 7940G/7960G: Conference JOIN softkey removal from LCD
when pressed
CSCef54206 ICMP hard error vulnerability
CSCef65512 Cisco IP Phone 7940G/7960G: SIP firmware lacks output for MORE softkey in
XML debugs
CSCef75039 Cisco SIP IP Phone 7940G/7960G: 500 Internal Server error when FQDN in
headers are not in DNS
CSCef86019 Vendor string inconsistent
CSCef86031 Cisco IP Phone does not accept option 66 with trailing dot in hostname
CSCef96994 Blind Transfer (BlndXfr) on SIP phone fails if performed too quickly
CSCef97229 Redundant DNS query on registered proxy when outbound proxy configured
CSCef97246 Memory leak galore requests messages cannot be sent
CSCeg00874 Cisco IP Phone 7960G configured for Outbound_Proxy performs DNS lookup to
SIP Proxy
CSCeg17839 Cisco SIP IP Phone SIP: Search button in External Directory Lookup is not
working
CSCeg39329 No audio issues in SRST mode when DNS unreachable
CSCeg50138 Pressing the Speaker or Headset button drops call when incoming call is waiting
CSCeg53739 Issues with DNS A query with Cisco SIP IP Phone 7940G
CSCeg57821 Call waiting tone plays though it was disabled
CSCeg61881 Cisco SIP IP Phone 7940G phone freezes after one minute when external
application run
CSCeg73740 Call not registered if hung up before connect
CSCeh06789 Nonce count is wrong
CSCeh06884 Transfer of a transfer has incorrect Conference softkey displayed
CSCsa61335 SNTP: Phone does not send out broadcast message when sntp_server =“ ”
CSCsa66530 Cisco IP Phone 7940G edit feature does not work
CSCsa66534 Cisco IP Phone 7940G softkeys have duplicate options
CSCsa68469 Cisco IP Phone 7960G with SIP load MWI does not work for e.164 numbers
CSCsa68504 Audio is heard in the speaker while using handset
CSCsa68720 HTTP status line is stuck
CSCsa68745 CANCEL/200 Race condition causes retry/UI issues on the recipient phone
CSCsa69639 Cisco SIP IP Phone 7940G/7960G: Phone is not functional after Codenomicon SIP
Test Suite run
CSCsa69654 Cisco SIP IP Phone 7960G: 183 (SDP) followed by 180 (noSDP)—ringing not
applied
CSCsa70268 Cisco SIP IP Phone 7940G/7960G: Malformed ACK response results in hung call
state
CSCsa71413 Cisco SIP IP Phone 7940G/7960G: Invalid answer in 200 OK results in no ACK
before BYE sent
CSCsa72019 Remote media address may not be updated properly when address is FQDN
CSCsa72503 Duplicate 183s are ignored
CSCsa73377 Cisco SIP IP Phone 7940G/7960G: SIP phone stuck in Busy state due to PROTOS
Test Suite
CSCsa75606 ARP cache timeout if set to 0 in the Cisco IP Phone 7960G floods the network with
ARP queries
CSCsa76323 SIP phone not clearing CCB after retries for 487 message
CSCsa81386 CSeq with a different method name is not rejected
CSCsa81406 Phone accepts CSeq value greater than 231 or 2147483648
CSCsa81956 Phone does not send 501 for incoming SUBSCRIBE, PRACK, PUBLISH, COMET
CSCsa82030 Phone not discarding Response messages with multiple Via headers
CSCsa83100 Phone not sending 400 for an incoming INVITE with missing callid
CSCsa84386 XML directory entry displays broken in the Cisco SIP IP Phone 7960G screen
CSCsa84410 Phone does not send ACK for 487 in CANCEL scenario
CSCsa84546 Phone does not send 481 to reject CANCEL with wrong Call-ID
CSCsa84733 Phone generates DSPAlarms when talking to a Conexant UA
CSCsa84743 Cisco SIP IP Phone 7940G/7960G: Backspace underbar cursor one spot too far left
during edit
CSCsa85977 Phone not sending 405 for incoming REGISTER
CSCsa87013 Cisco SIP IP Phone 7940G/7960G: Phone does not send NOTIFY with 100 trying
body immediately
CSCsa87079 Cisco SIP IP Phone 7940G/7960G: Malformed INVITE with Replaces if REFER
has display name in header
CSCsa87406 Cisco IP Phone 7960G fails to call to backup proxy intermittently
CSCsa87820 Phone fails CSeq sequence number scenarios
CSCsb05659 Cisco SIP IP Phone 7940G/7960G: Transfer Failed Status line message even though
transfer succeeds
CSCsb07307 Bad Record-Route header not handled properly and may crash phone
CSCsb07936 DNS command dns -c/p needs to include SRV
CSCsb09417 Bad Req-URI may cause phone to crash
CSCsb09615 Transfer failure: the URI in Refer-To is unreachable
CSCsb09625 Transfer interop issue: transferrer may not like NOTIFY(100 Trying)
CSCsb15840 Hold and conference failing with Mediatrix
CSCuk55038 Echo fades in and out when talking Cisco IP Phone to Cisco IP Phone
Nur mal so zur Info... :wink:
Hast recht. Das wurde hier nur indirekt erwähnt, aber nicht in einem eigenen Thread.
Die Release Notes dürften wohl öffentlich sein. Der Link ist ja auch frei zugänglich.
Das ganze setzen wir auch mal auf wichtig, wie bei Skype auch.
Wen es interessiert (RFCs bitte selber nachschlagen) - das sind die eigentlichen neuen Features, das im Ursprungspost ist die Liste der behobenen Bugs:
Release 7.5 provides the following features:
• RFC 3261 compliance (no TCP)
• RFC 3264 compliance
• RFC 3311 Compliance (display updates only, no media)
• Remote-Party-ID for display updates—A Remote-Party-ID header received in an INVITE or 200 OK will now update the display of the phone to accurately reflect the connected party
• New Configuration parameters sip_max_forwards and rfc_2543_hold
• REGISTER contact header sip.instance parameter support
Gruss
Markus
tdxchris92
