Seite 1 von 2 12 LetzteLetzte
Ergebnis 1 bis 20 von 30
Thema: How to modify a 7050 annex B in annex A?
  1. #1
    IPPF-Fan
    Registriert seit
    04.01.2006
    Hello, I would to buy on ebay this modem but since every german model is annex B it cannot work in Italy, where only annex A works.
    The AVM.de said that annex A modem have a different hardware, but I've read that I can patch to annex A an adapter born annex B.
    Is it true? On every 7050? How?
    Thank you
  2. #2
    Moderator Avatar von DM41
    Registriert seit
    26.04.2005
    Ort
    Nettetal
    The modification ist described in this thread:
    http://www.ip-phone-forum.de/showthread.php?t=89428
    In case you don't speak german, there is an englisch description at the end of that thread:
    http://www.ip-phone-forum.de/showthr...162#post481162
    Make sure you have the latest firmware-update on the box before modifying it.
    Hardware: FRITZ!Box Fon WLAN 7390, DECT-Mobilteile: Fritz!Fon MT-F, Sinus 501
    Anbindung: Vodafone DSL 16000 mit ISDN und Festnetz-Flat
    VoIP: für Gespräche in Mobilfunknetze easybell 010 010 VoIP
    Avatar-Foto: DBB/Camera 4
  3. #3
    IPPF-Fan
    Registriert seit
    04.01.2006
    Danke, then I have to do all these operations first by internal browser of the adapter and after the error(after the first upload)by telnet, right?
    But where can i find the telnet-ar7login-reset-debug.rar? And should I flash the firmware you have in you signature? Is it the latest english one? Where can I find it?
    Thanks again.
  4. #4
    Registriert seit
    26.04.2005
    Ort
    Nettetal
    I just saw, that pt-1 did not translate everything literally. He posted an advanced guide for englisch telephone extensions.
    Telnet is only an assurance. If anything goes wrong you can still reach the box by telnet. You can get it here: http://www.ip-phone-forum.de/attachm...2&d=1106239999
    This is haveanicedays modification:
    * put the latest firmware onto your box
    * Get this file to be able to go back to Annex B in case of emergency (for Annex B hardware only!)
    * get this file, don't unpack it and load it onto your FritzBox like a normal firmware update (via the Webinterface/your browser)
    That's it. The rest is only trouble shooting.
  5. #5
    IPPF-Fan
    Registriert seit
    04.01.2006
    Thanks, then I can go ahead to to buy a german version...
    But where is the latest english firmware? In the website of AVM?
    I've heard that there is some new beta eng firmware around...
  6. #6
    IPPF-Tausend-VIP Avatar von haveaniceday
    Registriert seit
    14.10.2004
    Not really. I think the newer english version is just in test by AVM.
    There is a small chance of trouble with an Annex B branded to Annex A.
    The Annex A frequency range is larger than the Annex B range. In case
    of a critical line length you might get the Annex B hardware not to work
    with Annex A.
    But then you can still use the Fritzbox behine a regular DSL modem..
    Regarding branding german => english. That needs special care. Under
    some circumstances you might set it to a "hard to recover" state.
    ( via ADAM2, special bootloader of TI used by AVM )
    Best regards,
    Habeinenschönentag
    The gates in my computer are AND,OR and NOT, not Bill
  7. #7
    IPPF-Fan
    Registriert seit
    04.01.2006
    with Annex A.
    Oh, so it couldn't work properly on my line...
    And what about the english branding, what's the problem? Doesn't it became english flashing the english firmware? What do you mean?
  8. #8
    Registriert seit
    14.10.2004
    Should work for 99.9 % of all cases, but if your provider connection is toooo far away you might
    get lost syncs or a missing syncronisation. ( Until now I just remember one guy at spain )
    There are some ADAM2 bootloader settings.
    A) hardware type
    B) language ( avm or avme )
    C) Annex
    A) and B) can cause trouble during booting. E.g. web interface not reachable. That's a little difficult
    to recover. Also AVM recover tools might fail. ( unexpected error situation )
    Mostly the english version is also older...
    I just mentioned this to ask for special care. So just don't do any quick shots..
    Haveaniceday
  9. #9
    IPPF-Fan
    Registriert seit
    04.01.2006
    A) hardware type
    C) Annex
    Haveaniceday
    Then what should I do? In what careful way?
    If I flash the box with the eng firmware(before annex A patch) will it become with english interface?
    Geändert von zooster (05.01.2006 um 14:53 Uhr)
  10. #10
    IPPF-Fan
    Registriert seit
    04.01.2006
    Can you reply to this plz?
  11. #11
    Registriert seit
    14.10.2004
    Hi zooster,
    I was offline for a while.
    I do not know what to do exactly. I have no experience with the international version.
    So I prefer to wait for hints from somebody else.
    Have a look here for some trouble:
    http://www.ip-phone-forum.de/showthread.php?t=90997 May be somebody else at the Forum can create a proper Howto ?
    Haveaniceday
    PS: I am currently also too busy to analyze/have a look at the international version.
  12. #12
    IPPF-Fan
    Registriert seit
    04.01.2006
    Ok, I've got the 7050 annexB. I've upgraded it to the latest firmware .89.
    After I've tried to upload the annex A .tar, but I've got a page where I haven't understood anything, here is the screenshot after the .tar upload. Is it normal or what?
    Angehängte Grafiken Angehängte Grafiken
  13. #13
    Semi-Moderator Avatar von olistudent
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    Hi.
    It's OK. The letters in red mean "No Error".
    You can check the result on the "DSL-Informationen" page.
    Greets, Oliver
    Router: Fritz!Box Fon WLAN 7570, 7390, 7320, 7270, 3170
    Anbindung: T-Online DSL 16.000 RAM
    Visit ##fritzbox on Freenode for help
    Spenden für Freetz
  14. #14
    IPPF-Fan
    Registriert seit
    04.01.2006
    Thx, now in the dsl page I can see annex A. Now I have only to build an adapter rj11-rj45.
    Thank you very much.
  15. #15
    Registriert seit
    14.10.2004
    Depending how good you can read "german":
    http://www.ip-phone-forum.de/showthread.php?t=85047
    That's the required cabeling.
    Haveaniceday
  16. #16
    IPPF-Fan
    Registriert seit
    04.01.2006
    Then I have to conenct only 4-5 pin(the center ones) in a RJ-45, right?
  17. #17
    IPPF-Fan
    Registriert seit
    04.01.2006
    Solved, thanks
  18. #18
    IPPF-Fan Avatar von ds-sb
    Registriert seit
    19.01.2005
    Ort
    Saarbrücken
    AVM Fritz!Box 7050 Annex A
    Hello,
    now also as Annex A Version international available.
    Regards
    ds-sb
    Anbindung: T-Home 16+ an Universal Enterntain Comfort Plus Option: Country Flat
    Router: AVM FRITZ!Box 7390 FW: 84.04.89 4GB Stick/ 250GB HDD mit FRITZ!Mini Fax2Mail
    Telefonanlage: Auerswald ETS 4216i mit 2 TFS Modulen
    DECT-Mobilteile: MT-F, MT-D, Sinus 501, Beetel 1000
    Repeater: Fon7270 (54MB), FBF7050(~24MB)
    Hotspot: FBF3270 mit Medion UMTS Stick
    3 Anrufbeantworter: Filter für Werbeanrufe ohne Rufnummer
    GSM: T-Mobile Relax-50 mit MulitSIM und X-Tra Classic an FBF 7390 analogem Amt (T-D1 zu VOIP kein Auslandsroaming) Skype Gateway
    VOIP:PoivY 032 (7ct Frankreich Mobil), bluesip.net 089, sipgate 0681
    Mobilfunk: Siemens S35 an Homestation mit SFR Karte (Frankreich)
    IPhone VPN
  19. #19
    IPPF-Fan
    Registriert seit
    04.01.2006
    Annex B 7050 international version? Where????
  20. #20
    IPPF-Einsteiger
    Registriert seit
    09.12.2005
    Zitat Zitat von ds-sb
    ...now also as Annex A Version international available.
    Please, put the link to international version!!!
    Thanks!
Ähnliche Themen
  1. How to modify FRITZ!Box 7050 annex B in annex A?
    Von voipuser.int im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 9
    Letzter Beitrag: 04.08.2011, 00:16
  2. How To Modify Fritzbox 7050 Annex B. INT. Annex A
    Von Ushar im Forum FRITZ!Box tot? Recover, Firmware Up-/ Downgrade
    Antworten: 4
    Letzter Beitrag: 30.01.2010, 19:54
  3. Antworten: 3
    Letzter Beitrag: 12.03.2009, 08:17
  4. How to modify FritzBox Fon WLAN 7140 annex B to annex A
    Antworten: 0
    Letzter Beitrag: 06.12.2006, 23:40
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
