The auto dial of international prefix(0039) not working
zooster
4 Jan 2006
I've tried to set italian international prefix to make calls without dial manually 0039, but it ain't work. Everytime I try to store 0039 it stores only 039 and in system log I see:
Internettelefonie mit xxxxxxxxxx über sip1.sipdiscount.com fehlgeschlagen. Fehlergrund: Forbidden (403)
Instead if I try to call dialing manually 0039 it's all right.
Why?
Enable the international city/country prefix rules in your Fritz!Box and use proper city and country code in your settings for the sipdiscount account you defined. It will work :)
The combination should be country code = 0039, country code prefix = 00, keep country code prefix = NO.
Don't try to mess with the settings on "Wahlregeln"/"Dialling Rules". If you enter any fixed provider prefix there, this may screw up the numbers actually dialled.
Cheers,
--gandalf.
May you please tell me where I should go? What german voice of menu...
thx
Thx, but there are a lot of options, including language english... It means I can change the language in english on my 7050 annexB german?? And what's that enum?
Keine Mitglieder online.
#Kuddel#
