- Mitglied seit
- 1 Apr 2004
- Beiträge
- 3,366
- Punkte für Reaktionen
- 0
- Punkte
- 36
download: ftp://ftp.digium.com/pub/asterisk/asterisk-1.2.2.tar.gz
changelog:
changelog:
006-01-18 Russell Bryant <[email protected]>
* Asterisk 1.2.2 Released
2006-01-18 00:47 +0000 [r8162] Matt O'Gorman <[email protected]>
* loader.c: Changed order of autoload so that pbx_ comes before
channels, and in doing so cause bug 6002 to not be an issue
2006-01-17 20:10 +0000 [r8140] Matt O'Gorman <[email protected]>
* apps/app_festival.c: Stop any generators running on a channel
when festival is called as described in 5996
2006-01-17 18:29 +0000 [r8134] Matt Frederickson <[email protected]>
* res/res_features.c: Backport of fix for #6094
2006-01-17 16:55 +0000 [r8124] Matt O'Gorman <[email protected]>
* logger.c: Fixed code ordering of logger_init and queue_log_init
bug 6263
2006-01-17 13:11 +0000 [r8122] Kevin P. Fleming <[email protected]>
* asterisk.c: update CLI copyright notice
2006-01-16 23:51 +0000 [r8112] Kevin P. Fleming <[email protected]>
* asterisk.c: do rlimit check _after_ reading config file, in case
'dumpcore' is specified there
2006-01-14 19:06 +0000 [r8074] Tilghman Lesher <[email protected]>
* funcs/func_strings.c: Bug 6238 - Fix segfault when delimiter not
specified
2006-01-13 06:07 +0000 [r8047] Russell Bryant <[email protected]>
* channels/chan_agent.c: fix spelling errors (issue #6227)
2006-01-12 06:14 +0000 [r7999] Tilghman Lesher <[email protected]>
* apps/app_voicemail.c, configs/voicemail.conf.sample: Bug 6211 -
Add option deletevoicemail as equivalent to option delete for
Realtime
2006-01-11 19:08 +0000 [r7986] Russell Bryant <[email protected]>
* channels/chan_agent.c: move variable to correct scope (issue
#6197)
2006-01-11 07:18 +0000 [r7976] Russell Bryant <[email protected]>
* apps/app_voicemail.c: fix temp greetings with ODBC storage (issue
#6078)
2006-01-11 05:46 +0000 [r7972] Russell Bryant <[email protected]>
* channels/chan_sip.c: fix mem leak on module unload (issue #6190)
2006-01-11 05:26 +0000 [r7970] Russell Bryant <[email protected]>
* app.c: don't override an error condition that occurred when
acting on the primary channel when stopping the autoservice on
the peer channel. (from issue #6087)
2006-01-11 04:53 +0000 [r7965] Russell Bryant <[email protected]>
* translate.c: lock list of translators *before* recalculating the
translation matrix
2006-01-11 04:38 +0000 [r7963] Matt O'Gorman <[email protected]>
* channel.c: Minor typo refrenced in 6191
2006-01-11 04:19 +0000 [r7960] Russell Bryant <[email protected]>
* pbx.c: fix locking error - lock instead of unlock
2006-01-11 03:12 +0000 [r7957] Russell Bryant <[email protected]>
* apps/app_dial.c: fix a little typo
2006-01-11 01:30 +0000 [r7955] Tilghman Lesher <[email protected]>
* apps/app_voicemail.c: Bug 6192 - behave correctly when mailbox is
specified as argument
2006-01-10 08:48 +0000 [r7939] Olle Johansson <[email protected]>
* doc/README.cdr: - Adding reference to README.tds - Reformatting
table
2006-01-09 22:48 +0000 [r7917] Kevin P. Fleming <[email protected]>
* channels/chan_iax2.c: re-initialize _all_ sequence numbers when
transfer completes
2006-01-09 22:07 +0000 [r7915] Russell Bryant <[email protected]>
* file.c: add missing unlock (issue #6112)
2006-01-09 20:08 +0000 [r7908] Tilghman Lesher <[email protected]>
* pbx/pbx_spool.c: Bug 6157 - Memory leak
2006-01-09 18:37 +0000 [r7904] Tilghman Lesher <[email protected]>
* doc/README.variables: Update variable documentation to match the
code
2006-01-09 18:11 +0000 [r7898-7900] Kevin P. Fleming <[email protected]>
* asterisk.c: commit user/group-related changes from trunk
* db.c: backport fix from revision 7856 of trunk
* apps/app_voicemail.c: fix breakage introduced in revision 7871
2006-01-09 05:11 +0000 [r7871] Russell Bryant <[email protected]>
* apps/app_voicemail.c: fix seg fault when using greek syntax in
VoicemMailMain (issue #6142)
2006-01-09 04:52 +0000 [r7870] Russell Bryant <[email protected]>
* manager.c: backport fix for unnecessary unlock (issue #6171)
2006-01-07 07:27 +0000 [r7848] Tilghman Lesher <[email protected]>
* pbx/pbx_spool.c: Bug 6156 - catch all threading errors, not just
simple failure
2006-01-06 00:34 +0000 [r7831] Tilghman Lesher <[email protected]>
* pbx/pbx_config.c: Dumb error messages - "Context 'context'
already included in 'in' context"
2006-01-06 00:21 +0000 [r7829] Kevin P. Fleming <[email protected]>
* channels/chan_agent.c: update agent persistence when an agent
gets logged off by autologoff
2006-01-05 23:53 +0000 [r7827] Tilghman Lesher <[email protected]>
* include/asterisk/strings.h: Bug 6076 - Fix documentation of
ast_trim_blank return value
2006-01-05 23:49 +0000 [r7825] Kevin P. Fleming <[email protected]>
* channel.c: eliminate rounding errors that caused call time limits
to be inaccurate (issue #5913) round 'time left' reported during
call limit warnings up to sound more accurate
2006-01-05 23:07 +0000 [r7823] Tilghman Lesher <[email protected]>
* res/res_features.c: Bug 6081 - fix for memory leak, formatting
fixes
2006-01-05 20:52 +0000 [r7819] Kevin P. Fleming <[email protected]>
* formats/format_pcm.c, formats/format_pcm_alaw.c: ensure that
variable is initialized
2006-01-05 09:13 +0000 [r7812] Olle Johansson <[email protected]>
* res/res_features.c: Fix copyright of changed file
2006-01-05 00:58 +0000 [r7809] Kevin P. Fleming <[email protected]>
* channels/chan_agent.c: send device state updates for auto-logoff
of agents as well
2006-01-05 00:18 +0000 [r7807] Kevin P. Fleming <[email protected]>
* formats/format_pcm.c, formats/format_pcm_alaw.c: doh... fseek()
has no useful return value
2006-01-04 23:51 +0000 [r7805] Kevin P. Fleming <[email protected]>
* formats/format_pcm.c, formats/format_pcm_alaw.c: use proper
fwrite() parameters and return value
2006-01-04 23:45 +0000 [r7803] Kevin P. Fleming <[email protected]>
* formats/format_pcm.c, formats/format_pcm_alaw.c: return properly
after extending file
2006-01-04 23:27 +0000 [r7800] Kevin P. Fleming <[email protected]>
ulaw/alaw sound files are filled with silence when extended (not
zeroes)
2006-01-04 23:02 +0000 [r7799] Kevin P. Fleming <[email protected]>
* channel.c: make monitoring more tolerant of peers that deliver
frames in bursts
2006-01-04 21:46 +0000 [r7795] Olle Johansson <[email protected]>
* res/res_features.c: Issue #5980: Removing extra CR+LF in manager
events - needs port to trunk
2006-01-04 21:43 +0000 [r7792] Olle Johansson <[email protected]>
* channels/chan_sip.c: Fixing typo in XML for video updates.
2006-01-04 07:06 +0000 [r7773] Russell Bryant <[email protected]>
* funcs/func_moh.c: use a more correct way of determining the size
of the destination buffer
2006-01-04 05:27 +0000 [r7771] BJ Weschke <[email protected]>
* apps/app_privacy.c: Fix the 'if' clause to be true under the
right conditions. Bug #6126
2006-01-03 20:22 +0000 [r7746] Kevin P. Fleming <[email protected]>
* ast_expr.y (removed): remove unused 'old' expression parser
2006-01-03 18:15 +0000 [r7743] Tilghman Lesher <[email protected]>
* apps/app_stack.c: Bug 6121 - typo in application description
2006-01-03 17:24 +0000 [r7740] Kevin P. Fleming <[email protected]>
* include/asterisk/chanspy.h, apps/app_chanspy.c,
apps/app_mixmonitor.c, channel.c: revert incorrect fix for bug
#6048 from revision 7709 put in correct (simpler) fix add doxygen
docs for channel spy 'state' values
2006-01-03 17:00 +0000 [r7738] Kevin P. Fleming <[email protected]>
* channels/chan_sip.c: backport rport scanning fix from trunk (bug
#6071)
2006-01-03 16:34 +0000 [r7736] Kevin P. Fleming <[email protected]>
* ast_expr2f.c, ast_expr2.fl: don't leak memory for (most)
expression evaluations
2006-01-02 07:31 +0000 [r7709] Tilghman Lesher <[email protected]>
* apps/app_mixmonitor.c: Bug 6084 - MixMonitor after a 'cli stop
monitor' deadlocks
2006-01-02 02:04 +0000 [r7706] BJ Weschke <[email protected]>
* channels/chan_sip.c, channels/chan_iax2.c: Fix compiler warnings.
2005-12-30 14:54 +0000 [r7677] Tilghman Lesher <[email protected]>
* channel.c: Bug 6091 - Fix race condition around uniqueid
2005-12-28 17:35 +0000 [r7665] Russell Bryant <[email protected]>
* channels/chan_sip.c: fix memory leak in build_rpid (issue #6070)
2005-12-27 21:07 +0000 [r7663] Russell Bryant <[email protected]>
* apps/app_chanspy.c: backport fix for permissions of created
recordings (issue #6067)
2005-12-27 00:07 +0000 [r7641] Kevin P. Fleming <[email protected]>
* channels/chan_zap.c: backport fix to ensure that DSP is never
enabled on pseudo channels
2005-12-26 20:32 +0000 [r7637] Tilghman Lesher <[email protected]>
* cdr/cdr_tds.c: Remove copy of code in libc, preferring code in
utils.c (public domain code)
2005-12-26 18:19 +0000 [r7634] Russell Bryant <[email protected]>
* channels/chan_sip.c, channels/chan_agent.c, apps/app_sms.c,
asterisk.c, config.c, pbx/pbx_dundi.c, apps/app_externalivr.c,
apps/app_queue.c, channels/chan_iax2.c, cli.c,
apps/app_chanspy.c, res/res_monitor.c: cast time_t to an int in
printf/scanf (issue #5635)
2005-12-23 06:38 +0000 [r7608] Tilghman Lesher <[email protected]>
* apps/app_hasnewvoicemail.c: Bug 6051 - VMCOUNT should work as
documented and count all, not quit after finding 1
2005-12-23 03:01 +0000 [r7606] Kevin P. Fleming <[email protected]>
* asterisk.c: add license reference to copyright notice displayed
when CLI session begins add 'show warranty' and 'show license'
CLI commands (still need a complete list of non-GPL components
included in Asterisk)
2005-12-23 00:00 +0000 [r7605] BJ Weschke <[email protected]>
* apps/app_waitforsilence.c: Another app documentation tweak.
2005-12-22 22:04 +0000 [r7601] Tilghman Lesher <[email protected]>
* apps/app_voicemail.c: Bug 6050 SQL requires the use of single
ticks to delimit values, not quotes
2005-12-22 20:36 +0000 [r7599] Russell Bryant <[email protected]>
* channels/chan_sip.c, configs/sip.conf.sample: revert changes to
videosupport to allow per-peer setting, since it isn't quite
complete and there is not an obvious fix at this point
2005-12-22 16:17 +0000 [r7595] Russell Bryant <[email protected]>
* channels/chan_sip.c: remove stray unlock (issue #5955)
2005-12-21 22:23 +0000 [r7586] Josh Roberson <[email protected]>
* channels/chan_sip.c: Actually put in the per-peer settings for
sip video, as they didn't make it in at astricon somehow, and
I've been too busy up until now to redo it.
2005-12-21 20:01 +0000 [r7582] Tilghman Lesher <[email protected]>
* channels/chan_alsa.c: Allow a chan_alsa that failed to open sound
devices to be unloaded.
2005-12-21 19:53 +0000 [r7580] BJ Weschke <[email protected]>
* channels/chan_agent.c: Bug #6040 - Documentation correction
2005-12-21 19:23 +0000 [r7577] Tilghman Lesher <[email protected]>
* pbx/pbx_ael.c: Bug 5777 - Remove parentheses on Goto in AEL, so
that it parses correctly
2005-12-20 20:21 +0000 [r7557] Russell Bryant <[email protected]>
* res/res_agi.c: check array bounds when parsing arguments to AGI
(issue #5868)
2005-12-20 18:05 +0000 [r7552] Russell Bryant <[email protected]>
* channels/chan_iax2.c: backport fix for reloading peer context
(issue #6007)
2005-12-20 17:34 +0000 [r7550] Russell Bryant <[email protected]>
* apps/app_directed_pickup.c: backport fix for segfault on directed
pickup when no CDR is available (issue #5998)
2005-12-20 12:58 +0000 [r7546] Kevin P. Fleming <[email protected]>
* apps/app_meetme.c: backport fix for larger-than-20ms-frames from
trunk (bug #5697)
2005-12-19 23:47 +0000 [r7529] Russell Bryant <[email protected]>
* channels/chan_sip.c: I messed up and accidently committed this to
the trunk first ... - add note on required values of sip_methods
struct - remove duplicate function prototype - remove duplicate
ast_mutex_lock (issue #6025)
2005-12-19 19:06 +0000 [r7523] Tilghman Lesher <[email protected]>
* file.c: Bug 5988 - record append option not working
2005-12-19 05:38 +0000 [r7521] Tilghman Lesher <[email protected]>
* cdr.c: Bug 6026 - segfault for the sequence NoCDR(),
SetAMAFlags()
2005-12-17 18:55 +0000 [r7519] Tilghman Lesher <[email protected]>
* doc/README.ael: Document that curley braces must be on the same
line as the keyword.
2005-12-17 17:19 +0000 [r7517] Tilghman Lesher <[email protected]>
* apps/app_chanspy.c: Bug 6009 - off by one error
2005-12-17 03:59 +0000 [r7515] Kevin P. Fleming <[email protected]>
* channels/chan_sip.c: Max-Forwards headers must only be present on
requests, not responses
2005-12-17 03:44 +0000 [r7513] Kevin P. Fleming <[email protected]>
* channels/chan_sip.c: forcibly expire previous subscriptions from
a peer when they resubscribe (keeps them from building up and
waiting for expiration, and stops us sending unwanted NOTIFY
messages to devices)
2005-12-17 02:20 +0000 [r7510] Kevin P. Fleming <[email protected]>
* build_tools/make_svn_branch_name: fix some buglet when building
team branch version strings
2005-12-17 01:02 +0000 [r7508] Tilghman Lesher <[email protected]>
* include/asterisk/linkedlists.h: We want to check the previous
value, not the current value (which was just changed).
2005-12-16 00:49 +0000 [r7497] Tilghman Lesher <[email protected]>
* apps/app_cut.c: First field is truncated
2005-12-15 10:52 +0000 [r7490] Christian Richter <[email protected]>
* doc/README.misdn, channels/misdn/mISDNuser.patch (added),
channels/misdn/isdn_lib_intern.h, channels/misdn/mISDN.patch
(added), channels/misdn/isdn_lib.h, channels/chan_misdn.c,
channels/misdn/Makefile, channels/misdn/chan_misdn_config.h,
channels/misdn/ie.c, channels/chan_misdn_config.c,
channels/misdn/isdn_msg_parser.c, channels/Makefile,
channels/misdn/isdn_lib.c: * Added mISDN/mISDNuser Echo cancel
Patch * Fixed Makefiles so that chan_misdn can be compiled again
* added some hints, that mISDN cannot be compiled against gcc-4,
SMP, Spinlock Debug * fixed some Minor issues in chan_misdn,
regarding Type Of Number and Presentation
2005-12-15 02:51 +0000 [r7482] BJ Weschke <[email protected]>
* channel.c: Bug #6003 - Don't free the channel structure until
after having sent the manager event.
2005-12-13 18:54 +0000 [r7470] Kevin P. Fleming <[email protected]>
* doc/README.variables: clarify substring documentation
2005-12-13 16:06 +0000 [r7468] Kevin P. Fleming <[email protected]>
* utils.c: correct broken math in tvfix() for timestamp values over
one million
2005-12-13 05:53 +0000 [r7453] Kevin P. Fleming <[email protected]>
* apps/app_dial.c: restore ability of caller to hangup calls that
are still ringing (issue #5839)
2005-12-13 05:14 +0000 [r7451] Kevin P. Fleming <[email protected]>
* channels/chan_sip.c, pbx.c: ensure that hangups while incoming
calls are in early state are handled properly (issue #5919)
2005-12-13 04:43 +0000 [r7449] Kevin P. Fleming <[email protected]>
* channels/chan_agent.c: only report AGENT_IDLE for callback mode
agents when they are actually idle (issue #5902)
2005-12-13 04:25 +0000 [r7448] Kevin P. Fleming <[email protected]>
* app.c: use the stream's current point when pausing/unpausing,
instead of elapsed time (which doesn't work when the stream has
been skipped forward or backward) (issue #5897)
2005-12-12 17:30 +0000 [r7435] Kevin P. Fleming <[email protected]>
* apps/app_externalivr.c: set all the child file descriptors to
non-blocking so that we don't hang if the child fails to send a
newline-terminated command or error message
2005-12-12 17:19 +0000 [r7433] Tilghman Lesher <[email protected]>
* include/asterisk/linkedlists.h: Typo
2005-12-11 06:08 +0000 [r7430] Russell Bryant <[email protected]>
* utils/astman.c: silence a couple of compiler warnings about
pointer signedness
2005-12-11 01:26 +0000 [r7429] Tilghman Lesher <[email protected]>
* include/asterisk/linkedlists.h: Bug 5965 - major bug in
AST_LIST_REMOVE
2005-12-11 01:15 +0000 [r7427] Tilghman Lesher <[email protected]>
* apps/app_voicemail.c: Bug 5967
2005-12-10 18:10 +0000 [r7425] BJ Weschke <[email protected]>
* channels/chan_zap.c: Bug #5877 Make sure the digit string from
E&M wink DNIS collection is properly null terminated as it grows.
2005-12-08 23:45 +0000 [r7406] Tilghman Lesher <[email protected]>
* apps/app_voicemail.c: Bug 5960
2005-12-08 23:32 +0000 [r7404] Tilghman Lesher <[email protected]>
* configs/res_odbc.conf.sample: Documenting two keywords that were
previously missing
2005-12-08 01:05 +0000 [r7386] Kevin P. Fleming <[email protected]>
* pbx.c: initialize the buffer before using it...
2005-12-07 20:46 +0000 [r7382] Kevin P. Fleming <[email protected]>
* pbx.c: ensure that hints are allowed to use global variable
references
2005-12-06 Kevin P. Fleming <[email protected]>
* Asterisk 1.2.1 Released
2005-12-06 00:19 +0000 [r7349] Kevin P. Fleming <[email protected]>
* contrib/firmware/iax/iaxy.bin: replace with unmodified file
2005-12-06 00:08 +0000 [r7346-7347] Kevin P. Fleming <[email protected]>
* contrib/firmware/iax/iaxy.bin: _really_ don't mess with line
endings
* contrib/firmware/iax/iaxy.bin: don't try to expand keywords in
this file
2005-12-06 00:02 +0000 [r7345] Kevin P. Fleming <[email protected]>
* contrib/firmware/iax/iaxy.bin: set this file to binary mode, so
it won't be mangled on export/checkout
2005-12-05 06:47 +0000 [r7340] Russell Bryant <[email protected]>
* Makefile: remove ASTERISKVERSIONNUM from the version string given
to doxygen
2005-12-05 00:09 +0000 [r7337] Russell Bryant <[email protected]>
* apps/app_queue.c: don't delete dynamic queue members when
reloading the static members from a realtime database (issue
#5922)
2005-12-05 00:01 +0000 [r7335] Russell Bryant <[email protected]>
* channels/chan_sip.c: fix the order of arguments to an error
message (issue #5927)
2005-12-04 18:03 +0000 [r7329] Kevin P. Fleming <[email protected]>
* build_tools/make_svn_branch_name: use a more efficient way to get
the revision number, that will also report if the working copy
contains uncommitted modifications
2005-12-03 19:55 +0000 [r7310] Tilghman Lesher <[email protected]>
* apps/app_voicemail.c: Bug 5925: check for "Unknown", as that's
what app_voicemail puts into the field for Unknown callerid Also,
remove useless res checks (initialized to 0; never set)
2005-12-03 01:24 +0000 [r7299] Olle Johansson <[email protected]>
* configs/sip.conf.sample: Documenting the default registerattempts
setting as 0, continue hammering the server for ever and ever ;-)
2005-12-02 21:12 +0000 [r7285] Tilghman Lesher <[email protected]>
* contrib/init.d/rc.debian.asterisk,
contrib/init.d/rc.mandrake.asterisk,
contrib/init.d/rc.redhat.asterisk,
contrib/init.d/rc.gentoo.asterisk,
contrib/init.d/rc.mandrake.zaptel,
contrib/init.d/rc.slackware.asterisk: Turn on executable bits for
startup scripts, and fix bash var interpolation for Mandrake
2005-12-02 00:52 +0000 [r7275] Olle Johansson <[email protected]>
* channels/chan_sip.c: Bug #5907. Improve SIP INFO DTMF debugging
output. (1.2 & Trunk)
2005-12-02 00:51 +0000 [r7274] Kevin P. Fleming <[email protected]>
* apps/app_page.c, pbx.c: inherit channel variables into channels
created by Page() application (issue #5888)
2005-12-02 00:42 +0000 [r7273] Kevin P. Fleming <[email protected]>
* apps/app_voicemail.c, configs/voicemail.conf.sample, UPGRADE.txt:
allow previous context-searching behavior to be used if desired
(issue #5899)
2005-12-02 00:39 +0000 [r7272] Kevin P. Fleming <[email protected]>
* apps/app_voicemail.c: properly handle password changes when
mailbox is last line of config file and not followed by a newline
(issue #5870) reformat password changing code to conform to
coding guidelines (issue #5870)
2005-12-02 00:28 +0000 [r7270-7271] Kevin P. Fleming <[email protected]>
* channels/chan_agent.c: protect agent_bridgedchannel() from
segfaulting when there is no bridged channel (issue #5879)
* channels/chan_local.c: allow variables to exist on both 'halves'
of the Local channel (issue #5810)
2005-12-01 23:49 +0000 [r7269] Kevin P. Fleming <[email protected]>
* apps/app_festival.c: don't block waiting for the Festival server
forever when it goes away (issue #5882)
2005-12-01 23:34 +0000 [r7268] Kevin P. Fleming <[email protected]>
* channel.c: ensure channel's scheduling context is freed (issue
#5788)
2005-12-01 23:18 +0000 [r7266] Kevin P. Fleming <[email protected]>
* Makefile, patches (removed): Makefile 'update' target now
supports updating from Subversion repositories (issue #5875)
remove support for 'patches' subdirectory, it's no longer useful
2005-12-01 23:18 +0000 [r7265] Olle Johansson <[email protected]>
* doc/README.misdn: Changing bug report address to the Asterisk
issue tracker
2005-12-01 22:21 +0000 [r7263] Olle Johansson <[email protected]>
* doc/README.jitterbuffer, doc/README.realtime: Removing references
to 1.1dev, replacing with 1.2, in documentation files.
2005-12-01 21:38 +0000 [r7261] Olle Johansson <[email protected]>
* doc/README.misdn: Fixing some spelling errors, as well as
changing "cvs" to "subversion" in misdn documentation.
2005-12-01 19:25 +0000 [r7257] Kevin P. Fleming <[email protected]>
* build_tools/make_svn_branch_name: ensure that 'svn info' output
is in the expected language for the script to parse (issue #5880)
2005-12-01 02:33 +0000 [r7251] Russell Bryant <[email protected]>
* apps/app_externalivr.c: use ast_app_separate_args to split
arguments (issue #5686)
2005-12-01 01:19 +0000 [r7249] Russell Bryant <[email protected]>
* apps/app_queue.c: fix queue weight feature - compare member
interfaces instead of pointers to the members, since each queue
has its own list of members. (issue #5863)
2005-12-01 00:44 +0000 [r7247] Russell Bryant <[email protected]>
* build_tools/make_svn_branch_name: use '=' instead of '==' for
string comparisons. /bin/bash is ok with this, but /bin/sh is
not. (issue #5885)
2005-11-30 21:31 +0000 [r7244] Russell Bryant <[email protected]>
* redhat/asterisk (removed), Makefile: remove outdated redhat init
script and provide the updated one in 'make rpm' (issue #5786)
2005-11-30 21:24 +0000 [r7242] Russell Bryant <[email protected]>
contrib/init.d/rc.redhat.asterisk: Comment out LD_ASSUME_KERNEL
by default. Print error messages if the asterisk executable or
the asterisk configuration directory are not found. (issue #5785,
#5708)
2005-11-30 17:39 +0000 [r7234] Russell Bryant <[email protected]>
* apps/app_dial.c: fix DIALEDTIME when call has not been answered
(issue #5862)
2005-11-30 14:27 +0000 [r7233] Russell Bryant <[email protected]>
* rtp.c: do not allow an rtp message with zero type (issue #5749)
2005-11-30 07:22 +0000 [r7231] Russell Bryant <[email protected]>
* pbx.c: fix hint case sensitivity (issue #5856)
2005-11-30 05:26 +0000 [r7228] Russell Bryant <[email protected]>
* configs/sip.conf.sample: add description of the "fromdomain"
option (issue #5874)
2005-11-30 03:52 +0000 [r7227] Josh Roberson <[email protected]>
* apps/app_voicemail.c, UPGRADE.txt, ChangeLog: backport fix from
trunk
2005-11-30 03:37 +0000 [r7226] Kevin P. Fleming <[email protected]>
* doc/cdr.txt, doc/CODING-GUIDELINES, include/asterisk.h,
doc/README.mp3: remove remaining CVS references
2005-11-30 03:20 +0000 [r7224] Kevin P. Fleming <[email protected]>
* channel.c: port memory leak fix from rev 7223 in trunk
2005-11-28 04:01 +0000 [r7208] Kevin P. Fleming <[email protected]>
* Makefile, build_tools/make_svn_branch_name (added): port version
string computation from trunk
2005-11-27 16:04 +0000 [r7199] Kevin P. Fleming <[email protected]>
* / (added): branch renames remove unneeded branches
2005-11-29 Josh Roberson <[email protected]>
* apps/app_voicemail.c: Only look in 'default' context when no context defined to VoiceMailMain(). (issue #5887)
2005-11-25 Russell Bryant <[email protected]>
* apps/app_dial.c: Properly duplicate the string for ANI (issue #5850)
2005-11-23 Russell Bryant <[email protected]>
* configs/voicemail.conf.sample: Add note to indicate that #include should not be used for this file. (issue #5828)
* indications.c: Fix spelling of "cadence", allowing the old misspelling for backwards compatability. (issue #5826)
* configs/indications.conf.sample: Fix spelling of "cadence", allowing the old misspelling for backwards compatability. (issue #5826)
* include/asterisk/indications.h: Fix spelling of "cadence", allowing the old misspelling for backwards compatability. (issue #5826)
* res/res_indications.c: Fix spelling of "cadence", allowing the old misspelling for backwards compatability. (issue #5826)
* apps/app_voicemail.c: Remove left over "yay!" debugging message. (issue #5829)
2005-11-21 Kevin P. Fleming <[email protected]>
* apps/app_cut.c: remove unnecessary include that causes spurious rebuilding
* channels/chan_sip.c (build_peer): ensure that case changes made to peer names are not ignored during reload operations
(build_peer): when a peer is changed from dynamic to static mode, reset the default port number if no other has been specified
* channels/chan_iax2.c (build_peer and build_user): ensure that case changes made to peer/user names are not ignored during reload operations
2005-11-21 Russell Bryant <[email protected]>
* Makefile: Revert previous change for Darwin.
* apps/app_osplookup.c: Properly populate the number of results. (issue #5789)
* Makefile: Don't hard-code that poll functionality needs to be provided on Darwin.
* apps/Makefile: Fix incorrect portion of the patch to fix 'make install' on Solaris.
* channels/chan_iax2.c (iax2_getpeername): Return non-zero to indicate that a peer was found when using realtime (issue #5815)
2005-11-20 Russell Bryant <[email protected]>
* Makefile apps/Makefile: Fix 'make install' for Solaris. (issue #5775)
* apps/app_record.c: Don't leak a frame if writing it to the file fails. (issue #5787)
* Makefile: Create the monitor spool directory when the other spool directories are created.
* channels/chan_sip.c channels/chan_iax2.c: Change warning messages about the number of scheduled events happening all at once to debug messages. (issue #5794)
* pbx/pbx_spool.c: Fix crash when a value is not specified with a variable on a Set: line in a call file. (issue #5806)
* apps/app_meetme.c: Fix the 'X' option to the MeetMe application. (issue #5773)
* apps/app_voicemail.c: Correct the use of a mailbox entered by the calling party instead of indicated as an argument to the Voicemail application. (issue #5774)
* apps/app_controlplayback.c: Fix logic in checking for success when jumping to priority n+101.
* apps/app_md5.c: Fix logic in checking for success when jumping to priority n+101.
* apps/app_hasnewvoicemail.c: Fix a typo in the application description. Also, fix the logic in checking for success when jumping to priority n+101. (issue #5795)
* UPGRADE.txt: Add a note on a second way that the IAX2 channel naming convention has changed. (issue #5792)
* channels/chan_iax2.c: Fix alignment of the output for the "iax2 show peer <peer>" CLI command (issue #5792)
* channels/Makefile: Re-add chan_oss to the default build. (issue #5799)
* res/res_musiconhold.c: Fix incorrect argument for the buffer size to an ast_copy_string call (issue #5803)
* funcs/func_enum.c: Shorten the module description (issue #5791)
2005-11-17 Russell Bryant <[email protected]>
* Makefile: Fix the output of Makefile generated variables to doxygen
* channels/chan_sip.c: Add missing carriage return and line feed to the SDP line indicating that we don't support VAD (issue #5780)
2005-11-16 Kevin P. Fleming <[email protected]>
* Asterisk 1.2.0 released.
2005-11-16 Jeremy McNamara <[email protected]>
* apps/app_voicemail.c (load_config): do not terminate asterisk if no voicemail config file
* channels/chan_skinny: Don't register channel type until ready, code formatting updates
2005-11-16 Josh Roberson <[email protected]>
* Makefile: Update to fix non-responsive remote console on Darwin (OSX)(issue #5757)
* channels/Makefile: don't build chan_modem and sub-modules by default
* configs/modules.conf.sample: explicitly 'noload' chan_modem.so and submodules, in case old versions exist
* res/Makefile: issue mpg123 not-installed warning at 'make install' time, not 'make'
* apps/app_forkcdr.c (forkcdr_exec): issue warning (and don't segfault) if ForkCDR is called on a channel that doesn't have a CDR (issue #5763)
* channel.c (ast_queue_hangup): ensure that the channel lock is held before changing its fields... (issue #5770)
* res/res_musiconhold.c: don't spit out incorrect log messages (and leak memory) during reload (issue #5766)
* channels/chan_sip.c (process_sdp): don't pass video codec number into ast_getformatname(), it is not valid input for that function (issue #5764)
* pbx/pbx_ael.c (match_assignment): properly parse equal signs surrounded by whitespace (issue #5761)
* doc/README.realtime: document the limitations of using FreeTDS with Realtime (issue #5767)
2005-11-15 Kevin P. Fleming <[email protected]>
* Makefile: use -g3 for compiler to include macro information for debugger
* astmm.c (__ast_vasprintf): don't re-use the ap list without copying it; that's not safe on some platforms (issue #5035)
* doc/README.backtrace: add note about properly building Asterisk to be able to produce backtraces; wrap text and remove DOS line endings
* channels/chan_sip.c (add_codec_to_sdp): add 'annexb=no' to G.729A SDP (issue #5539)
* channels/chan_alsa.c (alsa_hangup): handle autohangup properly (issue #5672)
* channels/chan_misdn.c (and other files): various fixes (issue #5739)
* channels/chan_sip.c (handle_request_info): properly forward 'flash' events received via SIP INFO (issue #5751, different patch)
* apps/app_disa.c (disa_exec): don't duplicate constant strings when not needed
* apps/app_playback.c (playback_exec): use correct logic tests for options (issue #5752)
* apps/app_disa.c (disa_exec): use standard arg parsing routines (issue #5736)
2005-11-15 Russell Bryant <[email protected]>
* manager.c: Don't crash on a SetVar action if the channel name is not set, or variable's value is not set (issue #5760)
* doc/README.variables: Add application exit status variables
2005-11-14 Josh Roberson <[email protected]>
* manager.c: Fix crash on variable passing from AMI originate (issue #5737)
2005-11-14 Russell Bryant <[email protected]>
* many files: Merge doxygen documentation updates. (issue #5605)
* apps/app_dial.c: Fix typo in RetryDial description.
2005-11-12 Russell Bryant <[email protected]>
* channels/chan_oss.c: Fix a typo in an error message.
2005-11-11 Kevin P. Fleming <[email protected]>
* Asterisk 1.2.0-rc2 released.
* channels/chan_sip.c (thread_safe_rand): ensure that threads don't get the same random number (issue #5712)
* apps/app_voicemail.c (forward_message): correct bugs in message forwarding (issue #5718)
(copy_message): use correct path for locking (issue #5704)
* apps/app_dial.c (wait_for_answer): correct flag copying for automon feature (issue #5720)
* channels/chan_iax2.c: correct comment
* apps/app_voicemail.c (close_mailbox): correct previous commit (issue #5663)
(vm_change_password): fix password change writing (issue #5721)
* channels/chan_sip.c (transmit_invite): remove useless debug message; don't try to add OSP tokens to OPTIONS pings
* apps/app_voicemail.c (close_mailbox): properly remove deleted messages at mailbox close time (issue #5663)
2005-11-11 Mark Spencer <[email protected]>
* channels/chan_zap.c (zt_bridge): only enable/disable DTMF detection on SUB_REAL channels
2005-11-10 Kevin P. Fleming <[email protected]>
* channels/chan_iax2.c: ensure that system headers that provide basic types are included first (issue #5713)
2005-11-11 Russell Bryant <[email protected]>
* many files in apps/: Clean up application descriptions. Clarify some wording and make sure they wrap at 80 characters.
2005-11-10 Mark Spencer <[email protected]>
* rtp.c (ast_rtp_raw_write): use unsigned int for return value from calc_txstamp() (issue #5595)
(calc_txstamp): never return a value that was less than zero before being turned into 'unsigned int' (issue #5595)
* include/asterisk/chanspy.h: move spy-related stuff into separate header so chan_h323 can build (issue #5590)
* include/asterisk/linkedlists.h (AST_LIST_HEAD_SET_NOLOCK): properly initialize tail pointer when list head is directly set (issue #5669)
* app.c (ast_app_parse_options): ok, so we aren't all perfect... let's make the while loop actually work properly here (issue #5684)
* apps/app_disa.c (disa_exec): correct password file parsing (issue #5676)
* apps/app_meetme.c (conf_run): don't restrict admin users from joining a locked conference (issue #5680)
* channels/chan_misdn.c: include stdio.h (issue #5671)
* channels/chan_misdn_config.c: fix prototype warning (issue #5671)
* pbx.c: remove apps that were deprecated before 1.0 was released (issue #5673)
* apps/app_striplsd.c, apps/app_substring.c: remove apps that were deprecated before 1.0 was released (issue #5673)
* include/asterisk/lock.h (PTHREAD_MUTEX_RECURSIVE_NP): work around header problems on Cygwin (issue #5668)
* pbx/pbx_ael.c: handle switch default cases inside macros properly (issue #5354)
* configs/voicemail.conf.sample (format): add strong warning about changing format list when mailboxes contain messages (issue #5689)
* many files: ensure that system headers are included before Asterisk headers (issue #5693)
* channels/chan_iax2.c (complete_iax2_show_peer): don't return from function without releasing lock (issue #5685)
* channels/iax2-provision.c (iax_provision_reload): don't leak memory (issue #5700)
* pbx/pbx_ael.c (handle_macro): don't leak memory (issue #5701)
(handle_context): ditto
* res/res_features.c (load_config): properly initialize referenced variable (issue #5703)
* apps/app_queue.c (rqm_exec): correct segfault problem (issue #5705)
(aqm_exec): ditto
* app.c (ast_app_parse_options): don't increment 's' until after checking for NULL (related to issue #5630)
* apps/app_rpt.c: solve a memory leak (config structure was not freed) (issue #5706)
2005-11-10 Russell Bryant <[email protected]>
* app.c (ast_app_separate_args): Don't consider the open parenthesis as part of the arguments to an option. (issue #5630)
* many files: Change all references to ast_separate_app_args to ast_app_separate_args
* many files in apps/: Clean up some application descriptions. Make sure all descriptions in changed files are wrapped at 80 characters.
2005-11-09 Russell Bryant <[email protected]>
* pbx.c: Clean up descriptions of built-in dialplan applications. Changes include clearer wording and not referring to return values.
2005-11-09 Kevin P. Fleming <[email protected]>
* channels/chan_iax2.c (update_registry): don't complain about unspecifed registration expiration intervals, just use the minimum
2005-11-08 Kevin P. Fleming <[email protected]>
* Asterisk 1.2.0-rc1 released.
* include/asterisk/file.h: add test to ensure that stdio.h is included before this file (issue #5658)
* res/res_odbc.c (odbc_prepare_and_execute): add new API call for use to properly handle prepared statements across server disconnects (issue #5563)
* pbx.c (pbx_substitute_variables_helper_full): use already-substituted buffer for parsing variable name (issue #5664)
* channels/chan_zap.c (zt_request): return AST_CAUSE_CONGESTION when a group-channel is requested and the group exists but all channels are busy (issue #3360, related fix)
* channels/chan_iax2.c (create_addr): treat UNREACHABLE as AST_CAUSE_UNREGISTERED so that it will generate CHANUNAVAIL from app_dial (issue #3360)
* res/res_features.c (ast_bridge_call_thread_launch): set SCHED_RR separately from thread creation, so it won't fail when running as non-root (issue #5601, different fix)
* pbx.c (pbx_builtin_pushvar_helper): add new API function for setting variables that can exist multiple times (issue #2720)
* apps/Makefile (APPS): add app_stack (issue #2720)
* apps/app_stack.c: new applications (issue #2720)
* apps/app_meetme.c: fix two audio delay problems related to using non-Zap channels in conferences (issues #3599 and #4252)
* configs/meetme.conf.sample: add documentation of new 'audiobuffers' setting to control buffering on incoming audio from non-Zap channels
* channels/chan_local.c (local_call): move channel variables from incoming to outgoing instead of inheriting them (issue #5604)
* many files: add explicit include of stdio.h (issue #5650)
2005-11-07 Kevin P. Fleming <[email protected]>
* UPGRADE.txt (Parking): add note about new parking behavior (issue #5532)
* many files: more Cygwin compatibility, and proper getloadavg() prototype/macro (issue #5569)
* include/asterisk/lock.h (__ast_pthread_mutex_lock): correct build with DETECT_DEADLOCKS defined (issue #5570)
2005-11-07 Russell Bryant <[email protected]>
* apps/app_queue.c: upgrade to new arg/option API and implement priority jumping control (issue #5580)
* many files: Add missing include of stdio.h, and remove some duplicate and unused header includes
* include/asterisk/app.h: Increment the arg_index in the options structure to fix applicaiton options that have arguments to them
* cryptostub.c: include necessary headers
* include/asterisk/crypto.h: don't include unnecessary headers
* manager.c (action_setvar): add support for setting global variables (issue #5571)
* Makefile: correct cross-compilation issue introduced in Cygwin patches (issue #5572)
* apps/app_voicemail.c: upgrade to new arg/option API and implement priority jumping control (issue #5649)
* asterisk.c (main): setpriority() failure is not a reason to stop the process (issue #5581)
* say.c (ast_say_date_with_format_da): say hours properly (issue #5576)
* manager.c (astman_get_variables): restore old multiple-variable behavior for "Variable" header (issue #5585)
* many files: don't check for NULL before calling ast_strlen_zero, it can do it itself (issue #5648)
* pbx.c (handle_show_hints): use proper state-to-string function for hint state (issue #5583)
* rtp.c: use unsigned format for debug packet output (issue #5595)
* asterisk.c (main): force a dnsmgr background refresh after all other modules are initialized (issue #5599)
* dnsmgr.c: add ability to start a background refresh on demand (issue #5599)
* apps/app_dial.c (HANDLE_CAUSE): set CDR disposition to match cause code (issue #5602)
* asterisk.c: support 'runuser' and 'rungroup' options in asterisk.conf (issue #5621)
* res/Makefile, apps/Makefile, channels/Makefile, Makefile: support WITHOUT_ZAPTEL define to forcibly avoid building Zaptel support (issue #5634)
* Makefile: various fixes (issue #5633)
* apps/app_osplookup.c: upgrade to new arg/option API and implement priority jumping control
* channels/chan_misdn.c: various fixes (issue #5639)
* channels/misdn/isdn_lib.c: various fixes (issue #5639)
* apps/app_playback.c: upgrade to new arg/option API and implement priority jumping control
* apps/app_privacy.c: upgrade to new arg/option API and implement priority jumping control
* apps/app_sendtext.c: upgrade to new arg/option API and implement priority jumping control
* apps/app_transfer.c: upgrade to new arg/option API and implement priority jumping control
* apps/app_txtcidname.c: upgrade to new arg/option API and implement priority jumping control
* Makefile: restore function of 'dont-optimize'
* config.c (config_text_file_load): don't generate log message when stat() fails
* many files: clean up application documentation to not refer to return values, since they cannot be used in the dialplan (work done by Neil Lewis)
2005-11-06 Russell Bryant <[email protected]>
* many files: alphabetize options in applicaiton descriptions
* channels/chan_iax2.c: Use an enum to define iax peer/user flags as well as the pvt structure state. Use the ast_flags macros for checking or setting the state.
* sounds.txt: Add missing words from the description of the vm-opts prompt
* apps/app_externalivr.c: Add a space that fixes building on older versions of gcc
* many files: Add doxygen updates to categorize modules into groups. Convert a lot of comments over to doxygen style. Add some text giving a basic overview of channels.
* many files: Update applications to add an exit status variable, make priority jumping optional, and use new args parsing macros
* pbx.c cdr.c res/res_features.c apps/app_dial.c include/asterisk/cdr.h: Convert some built-in applications to use new args parsing macros. Change ast_cdr_reset to take a pointer to an ast_flags structure instead of an integer for flags.
* channels/chan_agent.c: Don't loop forever on an invalid options string
* apps/app_disa.c apps/app_forkcdr.c: Fix to use correct arguments to ast_cdr_reset
2005-11-05 Kevin P. Fleming <[email protected]>
* Makefile: don't rebuild asterisk/build.h unless the asterisk binary is going to be relinked for some other reason (stops spurious recompile/link every time 'make' is issued); clean up variable substitutions to use consistent syntax
* asterisk.c: don't include asterisk/build.h (it's unnecessary)
* cli.c: don't include asterisk/build.h, use extern references to buildinfo.c
* buildinfo.c: new file to hold version info strings
2005-11-04 Kevin P. Fleming <[email protected]>
* apps/app_mixmonitor.c (mixmonitor_exec): correct app name in an error message
2005-11-04 Russell Bryant <[email protected]>
* channels/chan_iax2.c: Create a function that stores a peer's status in a given buffer. Use this function in "iax2 show peers" and "iax2 show peer <peername>". Also, add the peer's status as an option to the IAXPEER dialplan function.
* include/asterisk/compiler.h: don't try to use always_inline on old compilers
2005-11-03 Russell Bryant <[email protected]>
* res/res_agi.c: initialize buffer for result so that the contents are always valid in the response to GET FULL VARIABLE
2005-11-03 Kevin P. Fleming <[email protected]>
* doc/README.variables: document DYNAMIC_FEATURES
* res/res_features.c (ast_bridge_call): remove unused variables
* apps/app_dial.c (dial_exec_full): simplify options and flag usage
* include/asterisk/app.h: re-work application arg/option parsing APIs for consistent naming, add doxygen docs for option API
* many files: update to new APIs
2005-11-02 Kevin P. Fleming <[email protected]>
* apps/app_dial.c (dial_exec_full): convert to use API calls for argument/option parsing
* include/asterisk/channel.h: add doxygen docs for silence generator APIs
* channel.c (ast_channel_bridge): simplify native-bridge return logic, remove 'unsuccessful' message since it causes too many questions :-)
2005-11-01 Kevin P. Fleming <[email protected]>
* stdtime/localtime.c: fix build failure on uClibc systems (issue #5558)
* devicestate.c: same
* many files: make chan_misdn actually build (issue #5566)
* many files: more Cygwin build system support (issue #4678)
* apps/app_parkandannounce.c (parkandannounce_exec): supply parent channel to ast_request_and_dial so channel variables can be inherited (issue #5564)
* include/asterisk/channel.h: add parent_channel field
* channel.c (__ast_request_and_dial): use parent_channel field to inherit variables into new channel
* apps/app_cut.c (cut_internal): use ast_app_separate_args() instead of open code (issue #5560)
* apps/app_mixmonitor.c (launch_monitor_thread): ast_strlen_zero can handle NULL input (issue #5561)
(mixmonitor_exec): same
* res/res_features.c (ast_feature_request_and_dial): ensure that channel variables are inherited from the channel placing the call (issue #5499)
* utils.c (getloadavg): change to using _BSD_SOURCE as the indicator for whether this function is present or not (issue #5549)
* include/asterisk/utils.h (ast_slinear_saturated_add): force to be inlined whenever possible
(ast_slinear_saturated_multiply): same
(ast_slinear_saturated_divide): same
(inaddrcmp): same
* include/asterisk/strings.h (ast_strlen_zero): force to be inlined whenever possible
* include/asterisk/compiler.h (force_inline): add macro to force inlining of functions
* app.c (ast_play_and_record): use ast_silence_generator during recording if requested
* asterisk.c: add global option to enable silence-during-record (issue #5135)
* channel.c (silence_generator_alloc): new
(silence_generator_release): new
(silence_generator_generate): new
(ast_channel_start_silence_generator): new API call to start generating silence on a channel
(ast_channel_stop_silence_generator): parallel call to stop silence generation
* apps/app_record.c (record_exec): use ast_silence_generator during recording if requested
* Asterisk 1.2.0-beta2 released.
