Ergebnis 1 bis 13 von 13
Thema: Fli4L mit proxy-Paket und opt-squid
  1. #1
    IPPF-Tausend-VIP Avatar von ploieel
    Registriert seit
    13.03.2005
    Ort
    Vogtland
    vielleicht kann ja mir hier jemand mitlesender bei der Konfiguration ein wenig "in die Seite treten".
    Ich poste mal einfach meine config-Dateien hier rein, eventuell gibt es den einen oder anderen Hinweis dazu.
    proxy.txt
    # Optional package: PRIVOXY (Privacy Enhancing Proxy)
     OPT_PRIVOXY='yes'                  # privoxy: yes or no
    PRIVOXY_LISTEN_N='1'              # number off interfaces to listen on
    PRIVOXY_LISTEN_1='192.168.115.122:8118'
    				  # use an ip adress or a symblic name like
    				  # IP_NET_1_IPADDR followed by a port number
    PRIVOXY_ALLOW_N='2'
    PRIVOXY_ALLOW_1='IP_NET_1'        # open firewall for the hosts and networks
    PRIVOXY_ALLOW_2='192.168.115.0/24'  # listed in the allow list
    PRIVOXY_FORWARD=''                # optional forward-host:forward-port
    PRIVOXY_TOGGLE='yes'              # may user switch privoxy off?
    PRIVOXY_EDIT_CONFIG='yes'         # may users edit the config online?
    PRIVOXY_LOGDIR=''                 # do you want a log file?
    PRIVOXY_LOGLEVEL='1 4096 8192'    # what to log? (see manual)
    PRIVOXY_USETOR='yes'               # forward all request to the tor anon proxy
    OPT_TOR='yes'                      # install tor sock4/5 anon proxy
    TOR_LISTEN_N='1'                  # number off interfaces to listen on
    TOR_LISTEN_1='192.168.115.5:9050'
    TOR_ALLOW_N='2'
    TOR_ALLOW_1='IP_NET_1'            # open firewall for the hosts and networks
    TOR_ALLOW_2='192.168.115.0/24'      # listed in the allow list
    squid.txt
    # Optional package: PROXY (squid)
    OPT_SQUID='yes'
    SQUID_TRANSPARENT_CACHING='no'                  # squid redirects port 80 to
                                                    # cache clients who do not
                                                    # enter proxy in configuration
    SQUID_HTTP_PORT='3128'                          # Squid listens on this port
                                                    # default: 3128
    SQUID_MEM_CACHE_SIZE='8'                        # in MB
                                                    # default: 8
    SQUID_DISK_CACHE_SIZE='128'                     # in MB
                                                    # first Squid cache directory
    SQUID_MAX_OBJECT_SIZE='65536'                   # maximum size of objects in
                                                    # cache in kB
    SQUID_WORK_DIR='/data/squid'                    # dir where cache and logs are
                                                    # stored. Must have rw access
                                                    # and should not be deleted on
                                                    # reboot
    # log file settings:
    SQUID_CYCLE_LOG_N='10'                          # number of logfile rotations
                                                    # (0=disable the rotation)
    SQUID_CYCLE_LOG_TIME='172800'                   # if empty default of 48 hours
                                                    # will be used. You have to set
                                                    # it in seconds(48h=172800sec.)
                                                    # could be 1h (3600) if you
                                                    # have not enough space
                                                    # after X sec. log files will
                                                    # be deleted to free up space
    SQUID_ACCESS_LOG='yes'                          # create access.log or not
    SQUID_HTTPD_LIKE_LOG='yes'                      # emulate httpd like log entries
                                                    # to make them more readable
                                                    # e.g. if you don't want to have
                                                    # a unix like timestamp in your
                                                    # log's
                                                    # prevents some loganalyzers
    # squid network settings:
    SQUID_AUTO_CONFIG='yes'                         # configure allowed networks
                                                    # with networks in base.txt
    SQUID_ACCESS_NET_N='1'                          # number of IP ethernet networks
    SQUID_ACCESS_NET_1='192.168.115.0/24'                 # network wich is allowed to
                                                    # access squid
    SQUID_ACCESS_NET_2='172.16.0.0/12'              # network wich is allowed to
                                                    # access squid
    SQUID_ACCESS_NET_3='192.168.0.0/16'             # network wich is allowed to
                                                    # access squid
    # squid advanced settings:
    SQUID_CACHE_DIR_N='0'                           # define more than cache dirs
                                                    # if you want to spread cache
                                                    # over multiple disks
    SQUID_CACHE_1_DIR='/disk2/squid-cache'          # where the cache is located
    SQUID_CACHE_1_SIZE='1000'                       # in MB
    SQUID_NEXT_PROXY='no'                           # Parent Proxy
    SQUID_NEXT_PROXY_URL='www-proxy.t-online.de'    # URL or IP of Parent Proxy
    SQUID_NEXT_PROXY_PORT='80'                      # Port Parent Proxy
    Zur Erklärung:
    - mein Router hat die IP 192.168.115.5
    - alle Clients sind im gleichen Netzwerksegment
    - ich möchte beide Proxies kaskadieren, also soll der Weg vom Browser zum privoxy und weiter zum squid gehen. Und natürlich soll Tor auch noch benutzt werden...
    Für die Profis hier unter uns sicherlich ein kleines Problem, für mich schon fast eine unüberwindliche Barriere.
    Danke für die Hilfe.
    Box: Fritz!Box 7270v2
    Telefone: 3 DECT-Telefone ; am externen S0-Bus ein ISDN-Telefon
    Anbindung: VDSL mit 51384 down/10084 up
  2. #2
    Registriert seit
    13.03.2005
    Ort
    Vogtland
    Nunja, habe schon was gefunden:
    auf der Web-Oberfläche im access-log gibt squid ein paar Fehlermeldungen aus, wo am Ende der Zeile immer steht: TCP_MISS doppelpunktDIRECT (doppelpunkt als : , sonst kommt ein smylie)
    Wo liegt der Fehler?
  3. #3
    IPPF-Fünfhundert-Club
    Registriert seit
    01.08.2005
    Ort
    Hessen
    Mein letzter Fli liegt lange zurück, aber wenn ich das richtig verstehe sollen die browser privoxy als proxy nutzen (um werbung zu filtern) und privoxy soll wiederum squid als Proxy benutzen (zum cachen). Demnach musst zu bei der privoxy-config den squid angeben:
    --> PRIVOXY_FORWARD='localhost:3128'
    Beim squid wiederum kannst du TOR als Proxy angeben:
    SQUID_NEXT_PROXY
    Ansonsten empfehle ich die weltklasse fli4l-Dokumentation. Insbesodnere diese Zeile hier erscheint mir auch komisch:
    Warum gibts du hier nicht "IP_NET_1_IPADDR:8118" an? Und wenn du mit Router, der die 192.168.115.5 hat, deinen Fli4L meinst, dann kann obige Zeile ja gar nicht stimmen. Da gibt man die Interfaces an, auf denen der Proxy lauscht.
    Bei privoxy gibst du an:
    Bei Tor
    obwohl die auf der gleichen Maschine laufen, demnach müsstest du außer der NIC für DSL noch mindestens 2 weitere NICs im Fli4L haben, die im gleichen Subnetz hängen, was keinen Sinn macht. Ich denke, du hast schon privoxy falsch konfiguriert. Ich würde da jeweils "IP_NET_x_IPADDR:Port" nehmen.
    Also ich würde FLi4L Doku lesen. Mir scheint, das ist nicht wirklich geschehen. Mit der Doku und meinem Posting wirst du es schaffen.
    Wohnung 1
    Anbindung: T-DSL 6.000 (mit 3.000 kbit/s), congster local flat, T-ISDN
    Signal-/Rauschtoleranz: 22/25 dB, Leitungsdämpfung: 33/16 dB (Werte laut Fritz!Box)
    Router: Fritz! Box FON WLAN 7050 AVM, Firmware-Version 14.04.33ds26-15
    Telefonanlage: T-Eumex 620 LAN am S0 der Fritz!Box
    VoIP-Provider: GMX
    Fritz!Box-Softwares: JFritz
    Wohnung 2
    Anbindung: 1&1 3DSL mit 16.000 kbit/s (ATM Datenrate 17690/1183 kBit/s), T-ISDN
    Signal-/Rauschtoleranz: 6/8 dB, Leitungsdämpfung: 8/6 dB (Werte laut Fritz!Box)
    VoIP-Provider: 1&1
  4. #4
    Registriert seit
    13.03.2005
    Ort
    Vogtland
    Hallo kleinc,
    ja genauso will ich es machen.
    Zitat Ende.
    Ich habe nochmals Doku hin- und hergelesen, und auch Dein Posting versucht einzuarbeiten, trotzdem: wenn ich im Browser einen port 8118 oder 9050 eingebe, kommt beim Firefox eine Fehlermeldung: der Proxy hat die Verbindung zurückgewiesen. Es Funktioniert nur beim port 3128. Also der squid geht. Aber ich komme nicht weiter durch.
    Ich poste nochmals die überarbeiteten Files und bitte Dich, nochmals kurz darüberwegzusehen:
    squid:
    OPT_SQUID='yes'
                                                    # default: 3128
                                                    # default: 8
                                                    # cache in kB
                                                    # reboot
                                                    # log's
    SQUID_AUTO_CONFIG='no'                         # configure allowed networks
                                                    # access squid
                                                    # access squid
                                                    # access squid
    SQUID_NEXT_PROXY='yes'                           # Parent Proxy
    SQUID_NEXT_PROXY_URL='192.168.115.5'    # URL or IP of Parent Proxy
    SQUID_NEXT_PROXY_PORT='9050'                      # Port Parent Proxy
    privoxy
    PRIVOXY_LISTEN_1='IP_NET_1_IPADDR:8118'
    PRIVOXY_ALLOW_N='2'
    PRIVOXY_FORWARD='localhost:3128'                # optional forward-host:forward-port
    TOR_LISTEN_1='IP_NET_1_IPADDR:9050'
    TOR_ALLOW_N='2'
    Muss ich in der base.txt noch irgendwelche ports forwarden? Oder vielleicht Firewall-Regeln ändern?
    Danke für Deine Hinweise.
  5. #5
    Registriert seit
    01.08.2005
    Ort
    Hessen
    Nein, du kommst ja von intern, da darfst du auf alle Ports des Fli4L zugreifen (außer du hast da was gedreht).
    Die Configs sehen ganz gut aus jetzt. Wenn du auf tor und privoxy keinen Zugriff hast, dann ist vielleicht "IP_NET_1" nicht dein LAN? Sondern "IP_NET_0" (in Ausnahmefällen denkbar). Also das kannst du in der base nachsehen, ganz sicher erscheint mir bei dir
    PRIVOXY_LISTEN_1='192.168.115.5:8118'
    aber du solltest schon wissen, ob "IP_NET_1_IPADDR" oder "IP_NET_0_IPADDR" die 192.168.115.5 ist!
    An zwei Stellen hast du immer noch nicht richtig nachgelesen:
    PRIVOXY_ALLOW_N='2'
    TOR_ALLOW_N='2'
    Du hast ja sicher nur 2 Netzwerkkarten in deinem FLi4L: Eine für DSL, eine fürs LAN. Demnach ist dort nur dein LAN anzugeben, entweder in der Form
    PRIVOXY_ALLOW_N='1'
    oder in der Form
    PRIVOXY_ALLOW_N='1'
    PRIVOXY_ALLOW_1='192.168.115.0/24'
    Beides zusammen macht bei dir keinen Sinn (sollte aber auch nicht schädlich sein).
    Warum du jetzt auf die anderen Proxys nicht erreichst, weiß ich nicht. Du könntest ja auch einfach squid-privoxy-tor versuchen.
    Ansonsten: Doku Doku Doku, und dann gibts immer noch dei Archive der FLi4L Newsgroups! Sehr empfehlenswert.
    Wohnung 1
    VoIP-Provider: GMX
    Wohnung 2
    VoIP-Provider: 1&1
  6. #6
    Moderator Avatar von Netview
    Registriert seit
    01.04.2004
    Ort
    Westerwald
    Ob sich die Aktivitäten in diese Richtung lohnen?
    Laut fli4l-newsgroup wird's wohl bald ein opt squid-addons geben:
    http://groups.google.de/group/spline...3e14e5ff4316ad
    Router: A330GC + pfsense 1.2.3/freebsd 7.2 |squid-3.2.0.15|squidgard 1.5.0_3|Firewall|QoS|dynIP
    Asterisk 10 ( rev. 352556 ) on alix 2C2 / Voyage-Linux 0.4 + patton sn4634 [Smartware R5.T/17-01-11 | 3 BRI -> NT-Mode] chan_capi rev. 919 + speex 1.2rc1|xmail 1.27|
    spamd 4.8.0|fetchmail 7.0.0|samba 3.0.35
    Bkp-Router: Bintec X4000 FW 7.2 Rev. 1
    Adapter: SPA-1001 FW 3.1.9b
    Phones: S450IP P2000W FW WJ.00.13 + 7921G Wifi/7940G/7971G FW akt. (chan_sccp_b trunk|rev. 2299), HTC HD2, Nokia XM5800, TC300, SL 75 WLAN)
    Test: GXP2000, GXP2020, Sipura 3000, Netgear TA612V, ST 186 (IAX2), Allnet 7902, StarCom F1000G
    Provider: KD via KEVAG-Telekom Professional 26000/1000
  7. #7
    Registriert seit
    01.08.2005
    Ort
    Hessen
    Na ja, es muss ja auch so gehen, dafür braucht man nur wirklich kein extra opt.
    Mich würde hier schnell der Ehrgeiz packen.
  8. #8
    Registriert seit
    13.03.2005
    Ort
    Vogtland
    Hallo kleinc,
    Du machst mir Mut, es weiter zu versuchen, das privoxy zum laufen zu bekommen.
    Es will einfach nicht. Ich habe jetzt den squid und den tor nicht weitergeleitet, und will erstmal privoxy solo zum laufen bekommen. Im Browser habe ich eingetragen: proxy 192.168.115.5, port 8118, und Firefox meldet:
    Fehler: Proxy-Server verweigert die Verbindung
    Firefox wurde konfiguriert, einen Proxy-Server zu nutzen, der die Verbindung zurückweist.
    * Überprüfen Sie bitte, ob die Proxy-Einstellungen korrekt sind
    * Kontaktieren Sie bitte Ihren Netzwerk-Administrator, um sicherzustellen, dass der Proxy-Server funktioniert
    Ich poste hier nochmals meine config, um sicher zu sein, hier nichts falsches mehr eingetragen zu haben:
    PRIVOXY_ALLOW_N='1'
    PRIVOXY_USETOR='no'               # forward all request to the tor anon proxy
    OPT_TOR='no'                      # install tor sock4/5 anon proxy
    TOR_ALLOW_N='1'
    und in der base.txt steht (Auszug):
    # Ether networks used with IP protocol:
    IP_NET_N='1'                   # number of IP ethernet networks, usually 1
    IP_NET_1='192.168.115.5/24'      # IP address of your n'th ethernet card and
                                   # netmask in CIDR (no. of set bits)
    IP_NET_1_DEV='eth0'            # required: device name like ethX
    Es MUSS doch so gehen, aber es geht einfach nicht.
    Geändert von ploieel (04.03.2006 um 19:52 Uhr)
  9. #9
    Registriert seit
    01.08.2005
    Ort
    Hessen
    Guck doch mal in die privoxy Logdateien.
  10. #10
    Registriert seit
    13.03.2005
    Ort
    Vogtland
    Wo liegen die, bzw. wo kann ich das einrichten, dass welche geschrieben werden? In welchen Pfad gehören die Logfiles?
    Mein Firefox meldet nach wie vor:
    FEHLER
    Der angeforderte URL konnte nicht geholt werden
    Während des Versuches, den URL
    http://p.p/
    zu laden, trat der folgende Fehler auf:
    * Es war unmöglich, eine IP-Adresse für p.p zu bestimmen.
    Der DNS-Server gab:
    Name Error: The domain name does not exist.
    zurück.
    Der Cache war nicht in der Lage, den in der URL enthaltenen Hostnamen aufzulösen. Überprüfen Sie, ob die Adresse korrekt ist.
    Ihr Cache Administrator ist squid@lan.fli4l.
    Generated Sat, 04 Mar 2006 21:28:57 GMT by fli4l.lan.fli4l (squid/2.5.STABLE12)
    Es ist doch so, das der squid funktioniert, nur leitet er die Anfragen nicht korrekt an den privoxy weiter. Und ich weiß auch nicht mehr weiter.
  11. #11
    Registriert seit
    01.08.2005
    Ort
    Hessen
    Lesen tust du weder Doku noch die Kommentare in den Konfig-Dateien...
    Das kann man doch nicht übersehen, setzt man sich ernsthaft mit dem Problem auseinander. Dann kann ich dir leider auch nicht weiter helfen.
    Die Fehlermeldungen beim Aufruf einer fiktiven Domain (p.p) sind ja wohl auch selbsterklärend.
    Viel Glück noch.
    Wohnung 1
    VoIP-Provider: GMX
    Wohnung 2
    VoIP-Provider: 1&1
  12. #12
    Registriert seit
    13.03.2005
    Ort
    Vogtland
    Jetzt sieht es so aus:
    PRIVOXY_LOGDIR='/opt/etc/privoxy/'
    PRIVOXY_LOGLEVEL='512'
    in dem angegebenen Verzeichnis entsteht trotzdem kein logfile, mit WinSCP kann ich keines finden. Es gibt dort ein Verzeichnis templates und 4 files (default.action, standard.action, user.action, default.filter).
    Noch eine Idee?
  13. #13
    Registriert seit
    01.08.2005
    Ort
    Hessen
    Weil man in /opt/etc nicht schreiben kann... Du brauchst natürlich eine Datenpartion, um Logfiles anzulegen und abzuspeichern.
    Wohnung 1
    VoIP-Provider: GMX
    Wohnung 2
    VoIP-Provider: 1&1
Ähnliche Themen
  1. Squid Proxy auf der FBF 7050 ?
    Von quicksilver im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 84
    Letzter Beitrag: 01.02.2012, 11:17
  2. squid als transparenten Proxy kompilieren
    Von jnappert im Forum Freetz
    Antworten: 7
    Letzter Beitrag: 13.09.2009, 21:06
  3. offtopic: squid/2.6.STABLE18 fli4l.3.x.x
    Von Netview im Forum Asterisk ON fli4l
    Antworten: 21
    Letzter Beitrag: 10.01.2008, 20:12
  4. FLI4l 2.0.8. ISDN Paket
    Von hondaracer im Forum Linux Software-Router
    Antworten: 0
    Letzter Beitrag: 01.04.2007, 19:59
  5. offtopic: squid/2.5.STABLE14-20060622 for fli4l.3.x.x
    Antworten: 28
    Letzter Beitrag: 02.07.2006, 00:37
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
