CLI> pri debug span 3
Enabled debugging on span 3
-- Executing Dial("SIP/mathias-00f6", "Zap/g2/2700622|60|tr") in new stack
3 -- Making new call for cr 131
-- Requested transfer capability: 0x00 - SPEECH
3 > Protocol Discriminator: Q.931 (8) len=33
3 > Call Ref: len= 1 (reference 3/0x3) (Originator)
3 > Message type: SETUP (5)
3 > [3 043 033 803 903 a33 ]
3 > Bearer Capability (len= 5) [ Ext: 1 Q.931 Std: 0 Info transfer capability: Speech (0)
3 > Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
3 > Ext: 1 User information layer 1: A-Law (35)
3 > [3 183 013 893 ]
3 > Channel ID (len= 3) [ Ext: 1 IntID: Implicit, Other Spare: 0, Exclusive Dchan: 0
3 > ChanSel: B1 channel
3 ]
3 > [3 6c3 093 413 813 4d3 413 543 483 493 413 533 ]
3 > Calling Number (len=11) [ Ext: 0 TON: Subscriber Number (4) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
3 > Presentation: Presentation permitted, user number passed network screening (1) 'MATHIAS' ]
3 > [3 703 083 c13 323 373 303 303 363 323 323 ]
3 > Called Number (len=10) [ Ext: 1 TON: Subscriber Number (4) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1) '2700622' ]
-- Called g2/2700622
-- Zap/7-1 answered SIP/mathias-00f6
3 < Protocol Discriminator: Q.931 (8) len=13
3 < Call Ref: len= 1 (reference 131/0x83) (Terminator)
3 < Message type: STATUS (125)
3 < [3 083 043 823 e43 983 6c3 ]
3 < Cause (len= 6) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Public network serving the local user (2)
3 < Ext: 1 Cause: (null) (100), class = Protocol Error (6) ]
3 < Cause data 1: 98 (152)
3 < Cause data 2: 6c (108)
3 < [3 143 013 013 ]
3 < Call State (len= 3) [ Ext: 0 Coding: CCITT (ITU) standard (0) Call state: Call Initiated (1)
3 -- Processing IE 8 (cs0, Cause)
3 -- Processing IE 20 (cs0, Call State)
Mar 22 11:36:33 WARNING[4970]: chan_zap.c:8206 zt_pri_error: 3 updating callstate, peercallstate 2 to 1
3 < Protocol Discriminator: Q.931 (8) len=7
3 < Message type: SETUP ACKNOWLEDGE (13)
3 < [3 183 013 893 ]
3 < Channel ID (len= 3) [ Ext: 1 IntID: Implicit, Other Spare: 0, Exclusive Dchan: 0
3 < ChanSel: B1 channel
3 ]
3 -- Processing IE 24 (cs0, Channel Identification)
3 < Protocol Discriminator: Q.931 (8) len=4
3 < Message type: CALL PROCEEDING (2)
3 < Protocol Discriminator: Q.931 (8) len=8
3 < Message type: ALERTING (1)
3 < [3 1e3 023 823 883 ]
3 < Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Public network serving the local user (2)
3 < Ext: 1 Progress Description: Inband information or appropriate pattern now available. (8) ]
3 -- Processing IE 30 (cs0, Progress Indicator)
3 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Call Delivered, peerstate Call Received
-- Hungup 'Zap/7-1'
== Spawn extension (internal, 72700622, 1) exited non-zero on 'SIP/mathias-00f6'
-- Executing Hangup("SIP/mathias-00f6", "") in new stack
== Spawn extension (internal, h, 1) exited non-zero on 'SIP/mathias-00f6'
3 < Protocol Discriminator: Q.931 (8) len=11
3 < Message type: CONNECT (7)
3 < [3 293 053 063 033 163 0b3 243 ]
3 < Time Date (len= 7) [ 3 063 -033 -223 113 :363 ]
3 -- Processing IE 41 (cs0, Date/Time)
3 > Protocol Discriminator: Q.931 (8) len=4
3 > Message type: CONNECT ACKNOWLEDGE (15)
3 < Protocol Discriminator: Q.931 (8) len=28
3 < Message type: FACILITY (98)
3 < [3 1c3 163 913 a13 133 023 023 ec3 303 023 013 223 303 0a3 a13 053 303 033 023 013 013 823 013 003 ]
3 < Facility (len=24, codeset=0) [ 3 0x91, 0xa1, 0x13, 0x02, 0x02, 0xec, '0', 0x02, 0x01, 0x22, '0', 0x0a, 0xa1, 0x05, '0', 0x03, 0x02, 0x01, 0x01, 0x82, 0x01, 0x003 ]
3 -- Processing IE 28 (cs0, Facility)
3 Handle Q.932 ROSE Invoke component
3 < Protocol Discriminator: Q.931 (8) len=36
3 < Message type: DISCONNECT (69)
3 < [3 083 023 853 903 ]
3 < Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the remote user (5)
3 < Ext: 1 Cause: Unknown (16), class = Normal Event (1) ]
3 < [3 1c3 163 913 a13 133 023 023 ec3 313 023 013 223 303 0a3 a13 053 303 033 023 013 013 823 013 013 ]
3 < Facility (len=24, codeset=0) [ 3 0x91, 0xa1, 0x13, 0x02, 0x02, 0xec, '1', 0x02, 0x01, 0x22, '0', 0x0a, 0xa1, 0x05, '0', 0x03, 0x02, 0x01, 0x01, 0x82, 0x01, 0x013 ]
3 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Disconnect Indication, peerstate Disconnect Request
3 > Protocol Discriminator: Q.931 (8) len=8
3 > Message type: RELEASE (77)
3 > [3 083 023 813 903 ]
3 > Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
3 > Ext: 1 Cause: Unknown (16), class = Normal Event (1) ]
3 < Message type: RELEASE COMPLETE (90)
3 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Null, peerstate Null
3 NEW_HANGUP DEBUG: Destroying the call, ourstate Null, peerstate Null
