E60 Update V3 verfügbar
  • Ersteller Ersteller Hobbyfahrer
H
Hobbyfahrer
Guest
Moin,
per Nokia Updater ist endlich die Version 3.0633.09.04 verfübar!
bei mir gibt es nun ein seltsames Erscheinen mit der neuen FW:
Wenn ich den unter Installationen befindlichen Internet_Tel. Punkt auswähle verbindet er mir einfach nur meine SIP-Dienste - Einstellungsmöglichkeiten habe ich keine mehr...
Ist das bei Euch auch so??
Hoppla, ich hatte diesen Thread nicht gesehen und einen eigenen aufgemacht.
Hier nochmal:
VoIP 2.0
* Extended NAT/Firewall traversal mechanisms added (STUN, persistent TCP/IP)
* Integrated Easy VoIP Client with fast hotspot connection
* More detailed info about VoIP 2.0 can be found from “www.forum.nokia.com" web site
Device management
* Multiple application support in same session added to Application installation over DM
* Large Application support added to Application installation over DM
* DM Server Certificate renewal support added
* DM support added for new VoIP features (NAT/STUN)
Synchronisation
* Added support to Oracle 1.2 remote DS Server
Bluetooth
* Interoperability, volume control and audio related improvements when using HF and Carkit devices.
* Bluetooth multiple connection improvements
Accessories
* BH-900 audio connection improvements
* Improved functionality of HS-12W
VOIP
* Interoperability improvements with infra vendors and service providers
* Usage of multiple SIP settings improved
* Robustness improvements
* VoIP call barring default to ‘No’
WLAN
* WLAN ad-hoc functionality improved
* WPA2 functionality with U-APSD enabled WLAN AP’s improved
* Support for Cisco 4400 series LWAP’s
* WMM functionality improvements
* Better support for WiFi hotspots
* Support for multiple SIP connections improved
* Overall WLAN robustness improved
Messaging
* POP/IMAP email polling improved
* IMAP Idle Interoperability improved to certain email servers
* Shortcut handling improved (Ctrl+C, Ctrl+V, Ctrl+X)
* New email indication improved
* Mass delete of emails improved
* Email key interworking improved
* Email size limit improved
* SMS sending have been accelerated
Calendar / PIM
* Recurring calendar event handling improved
Device management
* Remote DM Performance increased
* Large packet handling: MAX Object Size of remote DM changed from 10k to 65k
* Updating Applications over DM improved
* VoIP Settings handling improved
Client provisioning
* Support added to WLAN WPA/WPA2 PSK settings
* WLAN WEP key handling improved
Office tools
* No changes to Mobile office
* Quick Office Editors can be downloaded from Catalogs
Synchronisation
* Increased robustness of recurring event synchronization
* Remote DS Performance increased
* Large packet handling: MAX Object Size of remote DS changed from 10k to 65k
Backup & restore
* Overall robustness increased
Performance
Telephony
* IHF activation tone is no longer sent to network
* Homezone indications changes faster to UI during idle and GPRS connections
WEB browser
* Stability improvements to Web browser
* Improvement to manual selection of character encoding in browser
* SDP stream file support to downloads
WAP browser
Networking
* Improvement to VPN access point VPN Policy view
* GPRS to WLAN roaming have been improved
* Applications Auto installation from memory card improved
Quelle: http://forum.my-s60.com/topic.php?id=903&page=1&#4744
wie es scheint vereinheitlicht nokia die voip client versionen der E serie. das e70 hat auch vor ein paar tagen die v3 firmware bekommen.
kann jemand bestätigen dass voip over umts nicht mehr möglich ist?
http://discussions.europe.nokia.com/discussions/board/message?board.id=swupdate&message.id=7802&view=by_date_ascending&page=4
auch wenn wir alle auf stun gewartet habe, diese implementierung von nokia ist nur interessant wenn man eine provisioning möglichkeit bekommt.
wer opfert sich für die programmierung eines nokia sip konfigurators auf :wink:
könnte mal einer allgemeinverständlich erklären, was "Provisioning" im Zusammenhang mit Nokias E-Serie bedeutet und wie man sich das technisch vorzustellen hat?
Wer kann so etwas und welche Voraussetzungen müssen bestehen?
Joel hat den Begriff in einem anderen Fred auch schon in den Raum geworfen, ohne dass ich damit etwas anfangen kann.
Danke schonmal im voraus, dt
ich kann an dem Update bisher keine Vorteile erkennen. T-Online VOIP über FritzBox (mit dort aktivierter Internettelefonie) geht immer noch nicht.
Es werden ein paar Applikationen auf dem Handy angemeckert, die unter der neuen Version nicht laufen. Ärgerlich: Man muss die Karte entnehmen und die SIS Files händisch am PC nach den inkompatiblen Applikationen durchsuchen, sonst versucht er diese bei jedem einschalten zu installieren.
Gruß, Carsten
Ich habe anderes Problemm:
Bei mir im Nokia Software Updater wird immer noch Version 2.x angezeigt.
Ist bei jemandem auch so?
jo, ist bei mir auch so...bei mir ist eine Vodafone-Version drauf ohne weiteres Branding drauf.
lg Kontrabass
Habe das Update auf meinem E60 und alles funktioniert ohne Probleme. Nachteil: Mann muss nur halt alle Einstellungen wieder von Hand konfigurieren da eine Datenrücksicherung nicht wirklich gut funktioniert. Auch VoIP über UMTS funktioniert! Habe auch das Gefül das mein E60 nun etwas schneller arbeitet. Aber das kann auch Einbildung sein. :-)
Gruß Elektronick
Welches E60 hab Ihr denn? Gibt es einen HW-Versionsunterschied? Ich bekomme nur die alte Firmware angeboten .... :-( Ich möchte es endlich an der EUMEX 800V an's Laufen bekommen ....
das wären sehr gute neuigkeiten. hat sich etwas in der hinsicht geändert? komisch dass der typ im nokia forum genau gegenteiliges behauptet :noidea:
Hallo
Ich habe es doch richtig verstanden, dass STUN jetzt integriert ist und somit eigentlich alle Provider ohne jegliche Probleme laufen müssten....
Ich bekomme aber 1und1 nicht zum laufen. Wo muss ich denn den STUN Server einstellen?
Vielen Dank für eure Hilfe!
Habe die Einstellungen vom N80 für 1und1 hier im Forum übernommen, klappt einwandfrei. Kein PBXES mehr habe nicht mehr mit dieser Firmware gerechnet. Den Stun habe ich glaube ich nirgens einstellen müssen.
freuu....
Gruss Paolo
v3 gibt es (u.a.) für das E60 Version 0524383 (deutsch, ohne Branding)
..., aber nicht uber Software Updater, oder.....? Bei mir wird v2.x als neue angezeigt.
@schurgan: doch - steht so auch schon im Eingangsposting
die Version des SU war erst noch 1.2.20 - der hat sich dann erst einmal selbst auf 1.3.X geupdatet und damit ging es reibungslos.
Das wiedereingespielte Backup war vollständig. Die SIP Profile musste ich allerdings komplett neu einrichten, da sie da waren, aber nicht mehr funktionierten.
Ich habe ein RM-49 E60-1 mit Code 0524329 .... Weiss jemand was damit ist? Auf der NOKIA Update Seite wird mir gesagt, dass die 2. Firmware die aktuelle ist ....
@NRWler04
ich habe auch ein 0524329, bis gestern abend wurde auch im software update v2 angezeigt. es kann ein paar tage/wochen dauern bis alle product codes im softwareupdate erscheinen.
@daelch
gebrandetes gerät habe ich keines, laut diese liste ist es eine ALPS version. es dürfte stimmen denn ich wohne in österreich und kaufte das handy hier.
die geräte, die auf der liste nicht erscheinen dürften brandinggeräte sein.
0519047 EURO1 SILVER
0520472 CTR US DEFAULT SILVER
0524327 CTR EURO2 TURKEY SILVER
0524328 CTR EURO1 FRANCE SILVER
0524329 CTR EURO1 ALPS SILVER
0524383 CTR EURO2 SILVER
0524418 CTR EURO2 SOUTH AFRICA SILVER
0524435 CTR EURO2 BLACK
0524436 CTR EURO2 GREY
0524507 CTR SCANDINAVIA SILVER
0524508 CTR BALTIAN Silver
0524509 CTR RUSSIAN SILVER
0524510 CTR RUSSIAN UKRAINE SILVER
0524652 CTR RUSSIAN CIS SILVER
0524653 CTR EURO3 SILVER
0524654 CTR BALKANS SILVER
0524655 CTR BALKANS GREECE/CYPROS SILVER
0524674 CTR ARABIC LEBANON SILVER
0524675 CTR ARABIC GULF SILVER
0524676 CTR HEBREW ISRAEL SILVER
0524929 CTR EURO1 GREY
0524930 CTR EURO1 BLACK
0535642 Nokia E60 Finland Country Variant
0535685 CTR BELARUS/MOLDOVA SILVER
Nik320
