Ständig wechselnde IP-Adressen
pette
28 Nov 2005
Hallo.
Ich habe seit längerem das Problem, dass die Horstbox urplötzlich meldet "IP address changed" und das dann in "regelmäßigen" Abständen wiederholt.
Siehe unten um 22:40 Uhr, 23:04, 23:08:
Jan  1 01:00:05 (none) syslog.info syslogd started: BusyBox v1.2.1
Jan  1 01:00:15 (none) user.notice root: Starting watchdog ...
Jan  1 01:00:15 (none) user.notice root: Starting board reset daemon
Jan  1 01:00:15 (none) user.notice root: Board Reset Daemon started
Jan  1 01:00:15 (none) user.notice root: Configure network ...
Jan  1 01:00:15 (none) user.notice root: Starting firewall...
Jan  1 01:00:16 (none) user.notice root: Setting time to automatic (using ntp)
Jan  1 01:00:16 (none) user.notice root: Creating asterisk directories ...
Jun  1 16:01:37 (none) user.notice root: Starting ntpd...
Jun  1 16:01:38 (none) daemon.notice ntpd[835]: ntpd [email protected] Mon Mar  5 20:02:43 CET 2007 (1)
Jun  1 16:01:39 (none) daemon.debug ntpd[835]: signal_no_reset: signal 13 had flags 4000000
Jun  1 16:01:39 (none) daemon.info ntpd[835]: precision = 4.000 usec
Jun  1 16:01:39 (none) daemon.err ntpd[835]: no IPv6 interfaces found
Jun  1 16:01:39 (none) daemon.info ntpd[835]: kernel time sync status 0040
Jun  1 16:01:41 (none) daemon.notice phone_config: Triggering 0 quickdials
Jun  1 16:01:41 (none) daemon.notice phone_config: Triggering 0 dial plans
Jun  1 16:01:41 (none) daemon.notice phone_config: Triggering 3 accounts
Jun  1 16:01:41 (none) daemon.notice phone_config: Triggering 3 devices
Jun  1 16:01:42 (none) user.notice root: Starting asterisk ...
Jun  1 16:01:42 (none) user.notice root: Setting keys ...
Jun  1 16:01:42 (none) user.notice root: Starting mhttpd ...
Jun  1 16:01:42 (none) local0.notice asterisk[866]: NOTICE[866]: cdr.c:1191 in do_reload: CDR simple logging enabled.
Jun  1 16:01:44 (none) daemon.info mhttpd[874]: MHTTPD - micro http server
Jun  1 16:01:44 (none) daemon.info mhttpd[874]: Copyright (c) 2006 - D-Link (Europe) Ltd., London, UK
Jun  1 16:01:44 (none) daemon.info mhttpd[874]: Copyright (c) 2006 - Maxina GmbH, Neu-Isenburg, DE
Jun  1 16:01:44 (none) daemon.info mhttpd[874]: Version 0.6.4 -- Jordan Hrycaj <[email protected]>
Jun  1 16:01:44 (none) daemon.info mhttpd[874]: SSL/TLS support: OpenSSL 0.9.7e 25 Oct 2004
Jun  1 16:01:44 (none) daemon.info mhttpd[874]: NVRAM client reply socket path is /tmp/nvram-36a
Jun  1 16:01:45 (none) daemon.info mhttpd[874]: Adding control socket services ...
Jun  1 16:01:45 (none) user.notice root: Waiting for the master board to come up ...
Jun  1 16:01:45 (none) authpriv.info dropbear[904]: Not forking
Jun  1 16:01:48 (none) daemon.info rcmdd[918]: RCMD - remote shell command wrapper
Jun  1 16:01:48 (none) daemon.info rcmdd[918]: Copyright (c) 2006 - D-Link (Europe) Ltd., London, UK
Jun  1 16:01:48 (none) daemon.info rcmdd[918]: Version 0.7.12 -- Jordan Hrycaj <[email protected]>
Jun  1 16:01:48 (none) daemon.info rcmdd[918]: Starting command filtering subsytem
Jun  1 16:01:48 (none) daemon.info rcmdd[918]: Default filter sets have been loaded: 15 records
Jun  1 16:01:49 (none) user.notice root: Testing for GCC alignment bug: BUG FOUND
Jun  1 16:01:49 (none) user.notice root: DSP Version: 0.0
Jun  1 16:01:49 (none) user.notice root: DSP Firmware Version: 0.0
Jun  1 16:01:49 (none) user.notice root: DSP is not inizialized
Jun  1 16:01:49 (none) user.notice root: Starting crond ...
Jun  1 16:01:49 (none) user.notice root: Configure Wlan nightservice ...
Jun  1 16:01:49 (none) cron.notice crond[968]: crond 2.3.2 dillon, started, log level 8
Jun  1 16:03:02 (none) daemon.info rcmdd[918]: Adding control socket services ...
Jun  1 16:03:48 (none) user.notice root: IP address changed
Jun  1 16:03:48 (none) user.notice root: IP1: xxx.xxx.147.193
Jun  1 16:03:48 (none) user.notice root: IP2: 0.0.0.0
Jun  1 16:03:48 (none) user.notice root: IP3: 0.0.0.0
Jun  1 16:03:48 (none) user.notice root: Reconfiguring asterisk
Jun  1 16:03:49 (none) local0.notice asterisk[1117]: NOTICE[1117]: cdr.c:1191 in do_reload: CDR simple logging enabled.
Jun  1 16:03:49 (none) daemon.notice phone_config: Triggering 0 quickdials
Jun  1 16:03:49 (none) daemon.notice phone_config: Triggering 0 dial plans
Jun  1 16:03:49 (none) daemon.notice phone_config: Triggering 3 accounts
Jun  1 16:03:49 (none) daemon.notice phone_config: Triggering 3 devices
Jun  1 16:03:49 (none) user.notice root: Restarting ntp
Jun  1 16:03:49 (none) daemon.notice ntpd[835]: ntpd exiting on signal 15
Jun  1 16:03:49 (none) user.notice root: Setting time to automatic (using ntp)
Jun  1 16:03:50 (none) user.notice root: Starting ntpd...
Jun  1 16:03:50 (none) daemon.notice ntpd[1133]: ntpd [email protected] Mon Mar  5 20:02:43 CET 2007 (1)
Jun  1 16:03:50 (none) daemon.debug ntpd[1133]: signal_no_reset: signal 13 had flags 4000000
Jun  1 16:03:50 (none) daemon.info ntpd[1133]: precision = 4.000 usec
Jun  1 16:03:50 (none) daemon.err ntpd[1133]: no IPv6 interfaces found
Jun  1 16:03:50 (none) daemon.info ntpd[1133]: kernel time sync status 0040
Jun  1 16:21:25 (none) syslog.info -- MARK --
Jun  1 16:39:01 (none) cron.notice crond[968]: USER root pid 1138 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Jun  1 16:41:25 (none) syslog.info -- MARK --
Jun  1 17:01:25 (none) syslog.info -- MARK --
Jun  1 17:21:25 (none) syslog.info -- MARK --
Jun  1 17:39:01 (none) cron.notice crond[968]: USER root pid 1143 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Jun  1 17:41:25 (none) syslog.info -- MARK --
Jun  1 17:50:42 (none) authpriv.info dropbear[1152]: Child connection from 192.168.0.3:60033
Jun  1 17:50:45 (none) authpriv.notice dropbear[1152]: password auth succeeded for 'root' from 192.168.0.3:60033
Jun  1 17:50:45 (none) authpriv.warn dropbear[1153]: lastlog_perform_login: Couldn't stat /var/log/lastlog: No such file or directory
Jun  1 17:50:45 (none) authpriv.warn dropbear[1153]: lastlog_openseek: /var/log/lastlog is not a file or directory!
Jun  1 17:50:45 (none) authpriv.warn dropbear[1153]: wtmp_write: problem writing /var/log/wtmp: No such file or directory
Jun  1 17:56:11 (none) local0.warn asterisk[1162]: WARNING[1162]: app_db.c:226 in get_exec: This application has been deprecated, please use the ${DB(family/key)} function instead.
Jun  1 18:01:25 (none) syslog.info -- MARK --
Jun  1 18:21:25 (none) syslog.info -- MARK --
Jun  1 18:39:01 (none) cron.notice crond[968]: USER root pid 1307 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Jun  1 18:41:25 (none) syslog.info -- MARK --
Jun  1 19:01:25 (none) syslog.info -- MARK --
Jun  1 19:21:25 (none) syslog.info -- MARK --
Jun  1 19:39:01 (none) cron.notice crond[968]: USER root pid 1316 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Jun  1 19:41:26 (none) syslog.info -- MARK --
Jun  1 19:42:08 (none) authpriv.info dropbear[1325]: Child connection from 192.168.0.3:35856
Jun  1 19:42:11 (none) authpriv.notice dropbear[1325]: password auth succeeded for 'root' from 192.168.0.3:35856
Jun  1 19:42:12 (none) authpriv.warn dropbear[1326]: lastlog_perform_login: Couldn't stat /var/log/lastlog: No such file or directory
Jun  1 19:42:12 (none) authpriv.warn dropbear[1326]: lastlog_openseek: /var/log/lastlog is not a file or directory!
Jun  1 19:42:12 (none) authpriv.warn dropbear[1326]: wtmp_write: problem writing /var/log/wtmp: No such file or directory
Jun  1 19:53:26 (none) authpriv.warn dropbear[1325]: wtmp_write: problem writing /var/log/wtmp: No such file or directory
Jun  1 19:53:26 (none) authpriv.info dropbear[1325]: exit after auth (root): Exited normally
Jun  1 20:01:26 (none) syslog.info -- MARK --
Jun  1 20:21:26 (none) syslog.info -- MARK --
Jun  1 20:39:01 (none) cron.notice crond[968]: USER root pid 1358 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Jun  1 20:41:26 (none) syslog.info -- MARK --
Jun  1 21:01:26 (none) syslog.info -- MARK --
Jun  1 21:21:26 (none) syslog.info -- MARK --
Jun  1 21:39:01 (none) cron.notice crond[968]: USER root pid 1367 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Jun  1 21:41:26 (none) syslog.info -- MARK --
Jun  1 22:01:26 (none) syslog.info -- MARK --
Jun  1 22:21:26 (none) syslog.info -- MARK --
Jun  1 22:39:01 (none) cron.notice crond[968]: USER root pid 1378 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Jun  1 22:40:18 (none) user.notice root: IP address changed
Jun  1 22:40:19 (none) user.notice root: IP1: xxx.xxx.156.154
Jun  1 22:40:19 (none) user.notice root: IP2: 0.0.0.0
Jun  1 22:40:19 (none) user.notice root: IP3: 0.0.0.0
Jun  1 22:40:19 (none) user.notice root: Reconfiguring asterisk
Jun  1 22:40:19 (none) local0.notice asterisk[1398]: NOTICE[1398]: cdr.c:1191 in do_reload: CDR simple logging enabled.
Jun  1 22:40:19 (none) daemon.notice phone_config: Triggering 0 quickdials
Jun  1 22:40:19 (none) daemon.notice phone_config: Triggering 0 dial plans
Jun  1 22:40:19 (none) daemon.notice phone_config: Triggering 3 accounts
Jun  1 22:40:19 (none) daemon.notice phone_config: Triggering 3 devices
Jun  1 22:40:19 (none) user.notice root: Restarting ntp
Jun  1 22:40:19 (none) daemon.notice ntpd[1133]: ntpd exiting on signal 15
Jun  1 22:40:20 (none) user.notice root: Setting time to automatic (using ntp)
Jun  1 22:40:05 (none) user.notice root: Starting ntpd...
Jun  1 22:40:05 (none) daemon.notice ntpd[1414]: ntpd [email protected] Mon Mar  5 20:02:43 CET 2007 (1)
Jun  1 22:40:05 (none) daemon.debug ntpd[1414]: signal_no_reset: signal 13 had flags 4000000
Jun  1 22:40:05 (none) daemon.info ntpd[1414]: precision = 4.000 usec
Jun  1 22:40:05 (none) daemon.err ntpd[1414]: no IPv6 interfaces found
Jun  1 22:40:05 (none) daemon.info ntpd[1414]: kernel time sync status 0040
Jun  1 22:41:11 (none) syslog.info -- MARK --
Jun  1 23:01:11 (none) syslog.info -- MARK --
Jun  1 23:04:09 (none) user.notice root: IP address changed
Jun  1 23:04:09 (none) user.notice root: IP1: xxx.xxx.147.16
Jun  1 23:04:09 (none) user.notice root: IP2: 0.0.0.0
Jun  1 23:04:09 (none) user.notice root: IP3: 0.0.0.0
Jun  1 23:04:09 (none) user.notice root: Reconfiguring asterisk
Jun  1 23:04:09 (none) local0.notice asterisk[1434]: NOTICE[1434]: cdr.c:1191 in do_reload: CDR simple logging enabled.
Jun  1 23:04:09 (none) daemon.notice phone_config: Triggering 0 quickdials
Jun  1 23:04:09 (none) daemon.notice phone_config: Triggering 0 dial plans
Jun  1 23:04:09 (none) daemon.notice phone_config: Triggering 3 accounts
Jun  1 23:04:09 (none) daemon.notice phone_config: Triggering 3 devices
Jun  1 23:04:09 (none) user.notice root: Restarting ntp
Jun  1 23:04:10 (none) daemon.notice ntpd[1414]: ntpd exiting on signal 15
Jun  1 23:04:10 (none) user.notice root: Setting time to automatic (using ntp)
Jun  1 23:04:09 (none) user.notice root: Starting ntpd...
Jun  1 23:04:09 (none) daemon.notice ntpd[1450]: ntpd [email protected] Mon Mar  5 20:02:43 CET 2007 (1)
Jun  1 23:04:09 (none) daemon.debug ntpd[1450]: signal_no_reset: signal 13 had flags 4000000
Jun  1 23:04:09 (none) daemon.info ntpd[1450]: precision = 4.000 usec
Jun  1 23:04:09 (none) daemon.err ntpd[1450]: no IPv6 interfaces found
Jun  1 23:04:09 (none) daemon.info ntpd[1450]: kernel time sync status 0040
Jun  1 23:08:29 (none) user.notice root: IP address changed
Jun  1 23:08:29 (none) user.notice root: IP1: xxx.xxx.152.5
Jun  1 23:08:29 (none) user.notice root: IP2: 0.0.0.0
Jun  1 23:08:29 (none) user.notice root: IP3: 0.0.0.0
Jun  1 23:08:29 (none) user.notice root: Reconfiguring asterisk
Jun  1 23:08:29 (none) local0.notice asterisk[1466]: NOTICE[1466]: cdr.c:1191 in do_reload: CDR simple logging enabled.
Jun  1 23:08:29 (none) daemon.notice phone_config: Triggering 0 quickdials
Jun  1 23:08:29 (none) daemon.notice phone_config: Triggering 0 dial plans
Jun  1 23:08:29 (none) daemon.notice phone_config: Triggering 3 accounts
Jun  1 23:08:29 (none) daemon.notice phone_config: Triggering 3 devices
Jun  1 23:08:29 (none) user.notice root: Restarting ntp
Jun  1 23:08:30 (none) daemon.notice ntpd[1450]: ntpd exiting on signal 15
Jun  1 23:08:30 (none) user.notice root: Setting time to automatic (using ntp)
Jun  1 23:08:30 (none) user.notice root: Starting ntpd...
Jun  1 23:08:30 (none) daemon.notice ntpd[1482]: ntpd [email protected] Mon Mar  5 20:02:43 CET 2007 (1)
Jun  1 23:08:30 (none) daemon.debug ntpd[1482]: signal_no_reset: signal 13 had flags 4000000
Jun  1 23:08:30 (none) daemon.info ntpd[1482]: precision = 4.000 usec
Jun  1 23:08:30 (none) daemon.err ntpd[1482]: no IPv6 interfaces found
Jun  1 23:08:30 (none) daemon.info ntpd[1482]: kernel time sync status 0040
Jun  1 23:21:10 (none) syslog.info -- MARK --
Oftmals ändert sich die IP sogar mehrmals (5-6 mal) stündlich.
Liegt das Problem beim ISP oder doch an der Horstbox?
Btw, das dsl-reset.sh Skript kann damit nichts zu tun haben, da ich den "manuellen" DSL-Reset auf 4 Uhr gestellt habe und so ist es auch im nvram gespeichert.
[UPDATE]
Während ich diesen Post schrieb, hat sich meine IP abermals mehrmals geändert (s.u.) :-(
Jun  1 23:36:39 (none) user.notice root: IP address changed
Jun  1 23:36:39 (none) user.notice root: IP1: xxx.xxx.146.10
Jun  1 23:36:39 (none) user.notice root: IP2: 0.0.0.0
Jun  1 23:36:39 (none) user.notice root: IP3: 0.0.0.0
Jun  1 23:36:39 (none) user.notice root: Reconfiguring asterisk
Jun  1 23:36:39 (none) local0.notice asterisk[1656]: NOTICE[1656]: cdr.c:1191 in do_reload: CDR simple logging enabled.
Jun  1 23:36:40 (none) daemon.notice phone_config: Triggering 0 quickdials
Jun  1 23:36:40 (none) daemon.notice phone_config: Triggering 0 dial plans
Jun  1 23:36:40 (none) daemon.notice phone_config: Triggering 3 accounts
Jun  1 23:36:40 (none) daemon.notice phone_config: Triggering 3 devices
Jun  1 23:36:40 (none) user.notice root: Restarting ntp
Jun  1 23:36:40 (none) daemon.notice ntpd[1482]: ntpd exiting on signal 15
Jun  1 23:36:40 (none) user.notice root: Setting time to automatic (using ntp)
Jun  1 23:36:39 (none) user.notice root: Starting ntpd...
Jun  1 23:36:39 (none) daemon.notice ntpd[1672]: ntpd [email protected] Mon Mar  5 20:02:43 CET 2007 (1)
Jun  1 23:36:39 (none) daemon.debug ntpd[1672]: signal_no_reset: signal 13 had flags 4000000
Jun  1 23:36:39 (none) daemon.info ntpd[1672]: precision = 4.000 usec
Jun  1 23:36:39 (none) daemon.err ntpd[1672]: no IPv6 interfaces found
Jun  1 23:36:39 (none) daemon.info ntpd[1672]: kernel time sync status 0040
Jun  1 23:38:49 (none) user.notice root: IP address changed
Jun  1 23:38:49 (none) user.notice root: IP1: xxx.xxx.148.6
Jun  1 23:38:49 (none) user.notice root: IP2: 0.0.0.0
Jun  1 23:38:49 (none) user.notice root: IP3: 0.0.0.0
Jun  1 23:38:49 (none) user.notice root: Reconfiguring asterisk
Jun  1 23:38:49 (none) local0.notice asterisk[1688]: NOTICE[1688]: cdr.c:1191 in do_reload: CDR simple logging enabled.
Jun  1 23:38:50 (none) daemon.notice phone_config: Triggering 0 quickdials
Jun  1 23:38:50 (none) daemon.notice phone_config: Triggering 0 dial plans
Jun  1 23:38:50 (none) daemon.notice phone_config: Triggering 3 accounts
Jun  1 23:38:50 (none) daemon.notice phone_config: Triggering 3 devices
Jun  1 23:38:50 (none) user.notice root: Restarting ntp
Jun  1 23:38:50 (none) daemon.notice ntpd[1672]: ntpd exiting on signal 15
Jun  1 23:38:50 (none) user.notice root: Setting time to automatic (using ntp)
Jun  1 23:38:50 (none) user.notice root: Starting ntpd...
Jun  1 23:38:50 (none) daemon.notice ntpd[1704]: ntpd [email protected] Mon Mar  5 20:02:43 CET 2007 (1)
Jun  1 23:38:50 (none) daemon.debug ntpd[1704]: signal_no_reset: signal 13 had flags 4000000
Jun  1 23:38:50 (none) daemon.info ntpd[1704]: precision = 4.000 usec
Jun  1 23:38:50 (none) daemon.err ntpd[1704]: no IPv6 interfaces found
Jun  1 23:38:50 (none) daemon.info ntpd[1704]: kernel time sync status 0040
Jun  1 23:39:01 (none) cron.notice crond[968]: USER root pid 1705 cmd sh /usr/share/board_cfg/wan/dsl-reset.sh
Weiss jemand Rat?
[/UPDATE]
Gruß,
Pette
Hallo Pette,
lass mal Deinen DSL-Anschluß vom Provider überprüfen. Ich hatte das Problem zeitweise an einem ADSL2+-Anschluß auch. Der Support von D-Link hat mir daraufhin geraten, den Anschluß bei der Telekom überprüfen zu lassen. Obwohl ich das Problem mit einem anderen DSL-Router am gleichen Anschluß nicht hatte, habe ich den Rat befolgt :-D Die Telekom hat mir nach einigen Tagen mitgeteilt, daß man etwas am Anschluß gefunden und verändert hätte. Was verändert wurde, wollte mir man nicht verraten. Fest steht, daß das Problem seitdem verschwunden ist ...
Henning
Aha. Gut zu wissen. Dann werde ich die Alice nochmal freundlichst kontaktieren.
Danke erstmal für die Infos. Ich melde mich sobald es hier Neuigkeiten gibt.
Gruß, Pette.
Hallo61Hallo
