Stinky Linux V1.06
BOFHELL
19 Okt 2006
Die Änderungen beziehen sich fast ausschließlich auf Tuxbox/DBox/Dreambox Geschichten, "nur" für dsmod ist kein update notwenig!
Download Links werden in kürze Nachgereicht!
Stinky Linux
Stinky Linux is a VMWare Appliance created for the following Project:
Tuxbox ( DBox/Dreambox )
Dreambox ( OE )
Fritzbox/DSMod
Just Download the VMWare Player at: http://www.vmware.com/download/player/ ( you need to register, but anyhow it's free! )
Install VMWare Player ( if asked select "Bridged Network" ! )
Start VMWare Player and select Stinky Linux
At first boot it ask to keep some Information or not, select "keep"!
here we go :o)
User : slightly
Pass : stinky
User : root
Pass : stinky
IP : DHCP ( Start -> System -> Systemverwaltung -> Netzwerk for fixed IP )
SMB : Arbeitsgruppe
Host : StinkyLinux
URL : https://www.dbox2world.selfip.com/board/index.php/
Forum : https://www.dbox2world.selfip.com/board/index.php/
IRC : irc.Matrix-Network.org : 6667 #SlightlyStinky #StinkyLinux #DBox2World
Base : Debian GNU/Linux etch
Kernel : 2.6.18-4 Vanilla Kernel
History:
Version 1.06
Readd missing kftpgrabber
add fakeroot mklibs for Tuxbox-Project
add diffstat rsync openembedded-essential for Dreambox-OE-Project
add nxserver for remote Desktop connections see www.Nomachine.com
add Icons for xchat and gaim
add Democonfig for VMWare with 2CPUs and 1024 MB of RAM (see 2CPU-1024mb - Other Linux 2.6.x kernel)
Version 1.05
- use 7zip to reduce Downloadsize to ~346MB see http://www.7-zip.org/ or use the latest Winrar Version
Version 1.04
- Add hdparm
- Add liberation TrueType
- modify rtc/max-user-freq
- some speedups
Version 1.03
- Add jam - need by some AVM/ds-mod Stuff
- Add gawk - need by Tripple dragon
- Add tex - need by Tripple dragon
- Add tftfpd - need for DBox2 Flash
- Add dhcp - need for DBox2 Flash
- Add minicom - need for DBox2
- Add cutecom - Terminal Programm
- Remove a lot of Stuff und Shrink Image to 437 MB
Version 1.02
- Mousewheel support
- Add Chat Channel #StinkyLinux and Sort Channels
- Add some aliases to User Stinky
- Add dolphin as Filemamager
- Add mkfs.cramfs und mkfs.jffs2 support for User for Tuxbox
- Remove KDE Stuff to free some more Space and Shrink Image to ~460 MB
Version 1.01 ( internal release ) - Alpha Status
- add SSH Server
- add Samba Server and share slightly-Home to the Network
- some cosmetics
- remove vanilla kernel-source ( 2.6.18-4.tar.bz2 )
- remove ready compiled kernel folder
- add script to download vanilla kernel source ( usr/src )
- Shrink Image to ~560 MB ( bevor 666 MB - Devilrelease *g* )
Version 1.0 ( internal release )
- Inital Release
Erfolgreich getestet mit
DBox2:
Tuxbox-CVS Classic ( make flash-squashfsimages & make flash-cramfsimages )
Tuxbox-CVS Newmake ( make flash-all-all-all )
Dreambox:
Tuxbox-CVS (500/5620/7000) ( make dreamboximage_root rebuild-flash flash-compress )
Tuxbox-OE (600/7020/7025) ( make -f Makefile-opendreambox image )
AVM:
dsmod Kernel 2.6: ds26-15.2
StinkyLinux 1.06 - Freetz-Mirrors sind aktuell
Die drei Freetz-Mirrors haben das Image nun auch online:
Außerdem hat Benutzer Yetie ebenfalls einen (inoffiziellen) Mirror angeboten: http://dsmod.supportschnorrer.de/StinkyLinux-v1.06.7z
Achtung! Gerade bei großen Dateien wie dieser und insbesondere beim Download von einem inoffiziellen Mirror ist es angebracht, MD5- oder SHA1-Prüfsummen zur Verifikation des Downloads einzusetzen. Sie lauten:
MD5: d23b7465dd11560e91dd8fe147fc0213
SHA1: c46b90f4f28de4afc0b75c933da02eb0edace9ff
danke für die mirrors!
@BOFHELL: Also für dbox2 und Dreambox bastelst Du auch?
Bau doch mal Support für die DGStation CubeCafe ein (auch ABCOM IPBox) :)
Ist vergleichbar mit der 7000er Dream...
Gruss Manuel
@xsapling: Wenn die richtigen Pakete installiert sind - die Anforderungen haben sich ein bißchen geändert seit 15.2, vgl. Wiki - ist es wurscht, welches Linux Du installiert hast, d.h. es sollte mit Stinky genauso gehen. Was da drin vorinstalliert ist, weiß ich allerdings nicht, weil ich es nicht benutze.
Because this stinky linux is in german, i tried to install in vmware a debian linux dist, and added most needed packages to make it compile the dsmod, it works untill i add the Mc-Commander package, where it stops the Make when it reaches an LD command saying it is incompatible. what devel packages are needed to make the mc commander?
Please check out the wiki.
i added all of these, plus bzip2 which was not mentioned but needed, but now when i select the Midnight Commander it stops with this error:
when i unselect the package, make finishes successfully, and firmware image works on my fritz with no problems.
nur kann ich leider nicht herausfinden, welche Pakete und in welcher Version freetz benötigt. Habe ich leider nirgends gefunden.
click mal auf den wiki link... da stehen die pakete
@ramik: LD is the object-files linker - it combines the parts to the final
program after compilation of the different object-files and includes parts
of different needed libraries. Maybe some paths are wrong and the wrong linker is used. Maybe the libraries are used for linking ? I am not as good in programming but maybe this helps!? Could you append the full log of freetz-creation and the file Config.in from freetz-trunk? I think this would help
a lot. Maybe you could set a higher debug-level to see more and clear error-messages(please search the forum!).
best regards
Manuel
@frakky2k: ja da stehen die Pakte, aber für den alten mod. Wie Alex schon in diesem Thread schrieb, gibt es Unterschiede zwichem dem alten dsmod und dem freetz hinsichtlich der Anfoderungen.
Es täte dir übrigens gut, einen Gesprächsverlauf als erstes in Gänze zu lesen und nicht schon wild drauf laus schreiben!
da steht auch definitiv drin was für pre16 benötigt wird !!!!
best regards
Manuel
i checked the midnight commander website, the make needs the glib 1.2.6 library, which is not available in a basic debian installation, have to add it manually.
für alle die PRobleme haben, laut wiki fehlen dei folgenden Pakete: tofrodos jikes ecj-bootstrap fastjar realpath libstring-crc32-perl
su
apt-get update
apt-get install tofrodos jikes ecj-bootstrap fastjar realpath libstring-crc32-perl
exit
und dann nochmal testen, aus mangel an eienr 7270 kann ich leider selebr nicht testen
Die Pakete hab ich alle installiert und das 7270 Image läuft aber trotzdem nicht.
micha
so ein log vom booten der Box wäre ganz cool
@supamicha
Diese Pakete haben keinen Einfluß auf dein Problem. Aber so lange ich noch keine 7270 in den Fingern habe, kann ich da nix machen.
MfG Oliver
wenn mir jemand sagen kann wie so ein bootlog gezogen werden kann, könnte ich eins bereitstellen.
Gruss
figo12
