Hello
My local SIP provider (which I can't change, since they have a monopoly on the local numbers) has some weird obligations :
- Type of Service (DSCP) must be set to 12 for both SIP and RTP (af12 / 0x30) for the packets to be routed to its private network
- the username contains mix of uppercase and lowercase letters.
Using my fritzbox 7050, I can only change the DSCP values for all voip accounts at once - which means that if I set DSCP to 30, I can connect to my local SIP provider, but not to my other accounts! If I don't set it to 30, I can only connect to my other SIP accounts.
Well, I can "almost" connect to my local SIP provider, because the username is a mix of uppercase and lowercase letters, which my fritzbox insists on converting to all lowercase
I can not fix that in the voip.cfg file since I don't know how the username is encrypted (should not be !)
I tested a GrandStream HT-286 - it registers fine on my local SIP provider network, with the UsErNaMe and the TOS requirements.
But then I can not use it with my fritzbox since the port 5060 of the fritzbox can not be forwarded to the ATA : the HT-286 can perfectly register and receive incoming calls notification, but calls will not even ring.
Could anyone suggest anything to make either the fritzbox alone or the fritzbox + my HT 286 connect to this SIP provider ?
I think siproxd could work, if there was a port of it for the fritzbox
I am using firmware 14.4.26 or a 7050 annex A
Thanks
Guylhem
Thanks
Guylhem
