Acces to fritzbox from internet
ilex_ilex
16 Nov 2006
Hi to All,
Sorry I do not write in German but it is not as good as my English :)
I have the following setup:
Access to internet is serviced by draytek vigor 2910 router.
LAN ip address is 192.168.100.1
Fritzbox 7050 is running in client mode with IP address 192.168.100.250.
It does only VOIP functionality - nothing else
I can easily access FB from any PC within LAN. I have login prompt, I punch in password & I am in.
The idea is to have an access to FB from internet. While I have a static WAN IP address I can reach my network. On the draytek I have configured port forwarding (port 80, protocols UDP & TCP) to 192.168.100.250.
Now If I try to access FB from internet I sometimes get login prompt but usually nothing, only the name of the website is displayed "FRITZ!Box" and that is all. :(
Question:
Do I have to forward more ports on the draytek ?
Looking forward for some help :)
By the way, VOIP is running 100% well
MG
Guude, and Wellcome to this Forum
I am not quite sure if the "Fernwartung" Function is implemented in the 7050.
This "Fernwartung" is invoked by an HTTPS call on port 443
So aside off the security belongings of this port-forwarding, what do you want to do ?
try to forward port 443 ( secure HTTP )
tatatataaa
1. It did not work also with 443
2. The reason I want to access to FB is to check phones log.
Any other hints ? :)
Push mail is not an option if I would like to check it live from my mobile phone through www.
[.....]if I would like to check it live from my mobile phone through www.
That is right so far.
By the way, there are other means aside the WWW to solve this. "paralell call" might be one of them and your mobile phone tells it immediately:)
well, that is realy not an option I am looking for :D
In current firmware-versions is it not possible to access the webinteface if the device has no IP from the FritzBox-range. You'll get a blank page. It should be possible via VPN.
Gruß Telefonmännchen
I know, it does work over VPN. Well, case unsolved, maybe in the future but I think AVM will not develope any newer firmware (7050 is an old device).
Greetings
Quick and dirty solution, configure your browser to disable the transmission of the HTTP Referer header.
Can You give me a hint how to do it please ?
I think, this is not possible with an embedded browser of an mobile device.
I have no solution for a mobile browser, but one for a desktop browser. In the firefox browser you have to enter "about:config" (without the "") as a URL. Then you have to find/edit the key "network.http.sendRefererHeader" doubleclick the key and change the value from "2" to "0". Thats all.
It may be possible to do that with an alternative mobile browser like Opera on your mobile device.
WOW !!!!
It helped at least from mozilla firefox :)
Unfortunately from mobile phone web browser not that much luck but always better then nothing. Thanks to all for the support.
Greetings.
Duggy
