SN 4638 Asterisk / Lizenz(en)
snaker
27 Sep 2005
ich habe mir einen SN 4638 zugelegt und möchte diesen nun an meinem Asterisk anbinden.
Bis zur unten stehenden config habe ich es geschafft, aber ich kann keine Gespräche durchführen.
Eventuell kann mir jemand helfen und sagen was fehlt...
Fehlen eventuell Lizenzen?
Danke schon ein mal
Stefan
# SN4638/5BIS #
# R5.3 2009-03-18 H323 SIP BRI #
# 2009-05-31T14:11:26 #
# SN/00A0BA048B72 #
# Generated configuration file #
cli version 3.20
no terminal telnet
administrator admin password XXXXXXXXXXXX== encrypted
clock local offset +02:00
dns-client server 192.168.123.8
dns-client server 192.168.123.2
webserver port 80 language en
sntp-client
sntp-client server primary 192.168.123.2 port 123 version 3
system hostname vgw.xxx.local
system
ic voice 0
low-bitrate-codec g729
system
clock-source 1 bri 0 0
clock-source 2 bri 0 1
clock-source 3 bri 0 2
clock-source 4 bri 0 3
clock-source 5 bri 0 4
profile ppp default
profile tone-set default
profile voip default
codec 1 g711alaw64k rx-length 20 tx-length 20
codec 2 g711ulaw64k rx-length 20 tx-length 20
codec 3 g729 rx-length 20 tx-length 20
rtp traffic-class local-default
fax transmission 1 relay t38-udp
profile pstn default
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
rtp-port-range 16384 16481
interface eth0
ipaddress 192.168.123.25 255.255.255.0
tcp adjust-mss rx mtu
tcp adjust-mss tx mtu
context cs switch
routing-table called-e164 RT_CDPN_OUT
mapping-table calling-pi to called-e164 MP_REM_CLIR
map restricted to +4926XXXXXXXXXX
interface isdn IF_S0_00
route call dest-table RT_CDPN_OUT
interface isdn IF_S0_01
interface isdn IF_S0_02
interface isdn IF_S0_03
interface sip 192.168.123.23
bind context sip-gateway SIP
remote 192.168.123.23 5060
context cs switch
no shutdown
authentication-service VOIP_AS_0
username Patton password XXXXXXXXXXXX== encrypted
location-service xxx.local
domain 1 eth0 5060
identity Patton
authentication outbound
authenticate 1 authentication-service VOIP_AS_0 username Patton
authentication inbound
registration outbound
registrar 192.168.123.23 5060
proxy 1 192.168.123.23 5060
lifetime 3600
register auto
retry-timeout on-system-error 10
retry-timeout on-client-error 10
retry-timeout on-server-error 10
registration inbound
contact 192.168.123.23 5060 switch 192.168.123.23 priority 1000
interface 192.168.123.23
bind interface eth0 context router port 5060
bind location-service xxx.local
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
bind interface eth0 router
vlan 123
map cos 0 to local-default
map cos 3 to local-voice
map cos 5 to local-voice
encapsulation ip
no shutdown
vlan 110
encapsulation ip
no shutdown
port ethernet 0 0
no shutdown
port ethernet 0 1
medium auto
encapsulation ip
shutdown
port bri 0 0
clock auto
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side net
bchan-number-order ascending
encapsulation cc-isdn
bind interface IF_S0_00 switch
port bri 0 0
shutdown
port bri 0 1
clock auto
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side net
bind interface IF_S0_01 switch
port bri 0 1
shutdown
port bri 0 2
clock auto
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side net
bind interface IF_S0_02 switch
port bri 0 2
shutdown
port bri 0 3
clock auto
power-feed
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
bind interface IF_S0_03 switch
port bri 0 3
shutdown
port bri 0 4
clock auto
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side net
port bri 0 4
shutdown
Edit Guard-X: Bitte nächstes Mal Code-Tags verwenden!
Hallo!
Ich verwende noch immer die SW 4.2 un dort sieht eine Konfiguration mit asterisk so aus:
context cs switch
digit-collection timeout 2
national-prefix 0
international-prefix 00
routing-table called-e164 RT_von_ISDN_zu_SIP
route (.%)T dest-interface SIP_INFOTECH ZU_ASTERISK
routing-table called-e164 RT_von_SIP_zu_ISDN
route default dest-service HUNT-BRI
route 0043T dest-service HUNT-BRI MT_AUSGEHEND_0043
mapping-table called-e164 to called-e164 ZU_ASTERSIK
map 7(..) to 7\1
map (..) to \1
map default to 111
mapping-table called-e164 to called-e164 MT_AUSGEHEND_0043
map 0043(.%) to 0\1
interface isdn ISDN_00
route call dest-table RT_von_ISDN_zu_SIP
isdn-date-time
inband-info accept force call-setup call-proceeding
interface isdn ISDN_01
isdn-date-time
interface isdn ISDN_02
isdn-date-time
interface isdn ISDN_03
isdn-date-time
interface sip SIP_ASTERISK
bind gateway GW_SIP
service default
route call dest-table RT_von_SIP_zu_ISDN
remote 192.168.45.10
early-disconnect
service hunt-group HUNT-BRI
cyclic
timeout 1
drop-cause normal-unspecified
drop-cause no-circuit-channel-available
drop-cause network-out-of-order
drop-cause temporary-failure
drop-cause switching-equipment-congestion
drop-cause access-info-discarded
drop-cause circuit-channel-not-available
drop-cause resources-unavailable
route call 1 dest-interface ISDN_00
route call 2 dest-interface ISDN_01
route call 3 dest-interface ISDN_02
route call 4 dest-interface ISDN_03
context cs switch
no shutdown
gateway sip GW_SIP
bind interface LAN router
service default
gateway sip GW_SIP
no shutdown
Edit Guard-X: Bitte nächstes Mal Code Tags verwenden!
Hallo und Danke,
Die Config ist also im großen und ganzem in Ordnung.
Der Fehler lag also an meiner Asterisk Config, wo ich der Extension ein Passwort eingebaut hatte...
Stefan
Das müsste also schon gehen. Muss dann auf dem Patton unter interface sip bzw. dem service default eingetragen werden:
service default
user <extension> authenticate password <..> register
Für mehr Infos siehe SmartWare Software Configuration Guide.
bimbomix75
