Problem mit Asterisk auf Eicom Diva, Sprache nicht verständlich.
reeinsle
2 Jan 2009
Hallo Forum,
ich möchte mal erste Erfahrungen mit Asterisk sammeln. Dazu haben ich eine Eicom Diva in mein Server mit eingebaut.
lspci:
07:01.0 Network controller: Dialogic Corporation BRI (rev 01)
        Subsystem: Dialogic Corporation Diva BRI-2 PCI v2
        Flags: bus master, medium devsel, latency 64, IRQ 17
        Memory at febfec00 (32-bit, non-prefetchable) [size=256]
        I/O ports at e400 [size=256]
        Memory at fe000000 (32-bit, non-prefetchable) [size=8M]
        Memory at febd0000 (32-bit, non-prefetchable) [size=64K]
        Capabilities: [40] Power Management version 1
        Capabilities: [48] CompactPCI hot-swap <?>
        Capabilities: [4c] Vital Product Data <?>
        Kernel driver in use: divas
        Kernel modules: divas
Dann habe ich mir von Melware die passenden Treiber installiert
dmesg:
[ 8732.134005] Dialogic DIVA - DIDD table (http://www.melware.net)
[ 8732.134005] divadidd: Rel:3.1.4-109.75-1  Rev:1.13  Build:108-131(local)
[ 8732.143796] Dialogic DIVA Server driver (http://www.melware.net)
[ 8732.143796] divas: Rel:3.1.4-109.75-1  Rev:1.46  Build: 108-131(local)
[ 8732.143796] divas: support for: BRI/PCI PRI/PCI adapters
[ 8732.143796] divas: Dialogic Diva BRI-2 PCI v2 bus: 00000007 fn: 00000008 insertion.
[ 8732.143796] ACPI: PCI Interrupt 0000:07:01.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 8732.207959] divas: Dialogic Diva BRI-2 PCI v2 IRQ:17 SerNo:21289
[ 8732.207989] divas: started with major 248
[ 8799.324811] Dialogic DIVA - MAINT module (http://www.melware.net)
[ 8799.324811] diva_mnt: Rel:3.1.4-109.75-1  Rev:1.32  Build: local
[ 8799.324811] console [0] enabled
[ 8799.324811] diva_mnt: trace buffer = ffffc20011fb1004 - 128 kBytes, internal (Major: 247), notifier registered, reboot notifier registered
capiinfo:
Number of Controllers : 1
Controller 1:
Manufacturer: Eicon Networks
CAPI Version: 2.0
Manufacturer Version: 3.0
Serial Number: 21289
BChannels: 2
Global Options: 0x000003f9
   internal controller supported
   DTMF supported
   Supplementary Services supported
   channel allocation supported (leased lines)
B1 protocols support: 0x000003df
   64 kbit/s with HDLC framing
   64 kbit/s bit-transparent operation
   V.110 asynconous operation with start/stop byte framing
   V.110 synconous operation with HDLC framing
   T.30 modem for fax group 3
   56 kbit/s bit-transparent operation
   Modem with all negotiations
   Modem asyncronous operation with start/stop byte framing
   Modem syncronous operation with HDLC framing
B2 protocols support: 0x00001fdf
   ISO 7776 (X.75 SLP)
   Transparent
   SDLC
   LAPD with Q.921 for D channel X.25 (SAPI 16)
   T.30 for fax group 3
   Transparent (ignoring framing errors of B1 protocol)
   Modem error correction and compression (V.42bis or MNP5)
   ISO 7776 (X.75 SLP) with V.42bis compression
   V.120 asyncronous mode
   V.120 asyncronous mode with V.42bis compression
   V.120 bit-transparent mode
   LAPD with Q.921 including free SAPI selection
B3 protocols support: 0x000000bf
   Transparent
   T.90NL, T.70NL, T.90
   ISO 8208 (X.25 DTE-DTE)
   X.25 DCE
   T.30 for fax group 3 with extensions
   Modem
  0100
  0200
  f9030000
  df030000
  df1f0000
  bf000000
  0281ffff 96020000 00000000 589e4d5d 0181ffff 847d2480
  ff410038 00000000 00000000 00000000 00000000
FAC REQ - Illegal application number (0x1101)
hab mir dann auch von melware die chan_capi geholt, und installiert.
Von der Hardware schauts so aus, das die ISDN-Karte hinter einer Telefonanlage mit Anlagen-Anschluß hängt, aber hier ja dann im PTMP-Modul läuft. Meiner Meinung nach passt die Konfig auch, weil ich den Anruf sehe, und werde, da kein SIP-Phone angeschlossen, direkt auf das Voice-Mail geleitet.
extension.conf:
[isdn-in]
exten => 41,1,Dial(SIP/58,20)
exten => 41,n,VoiceMail(58,u)
Jetzt ist das, was ich vom Voicemail hört total verstümmelt, auch das was aufgezeichnet wird, ist nicht verständlich. Ich habe in etwa 6 Sekungen draufgesprochen, aber im .wav kommen nur ca. 1 Sekunde an.
Jetzt habe ich im Moment leider keine Idee mehr, an welcher stelle ich noch suchen kann.
Die capi.conf ist die orginale aus dem chan_capi 1.1.5 Packet.
Hätte mir evtl jemand nen Tipp an welcher Stelle ich noch suchen kann?
Vielen Dank
Robert
Was für einen Codec benutzt du?
Sieh mal zu das alles auf alaw steht was mit dem ISDN Teil zu tun hat, dann braucht * nicht zu transcodieren.
Hy Numsi,
ja, das wars. Jetzt kann ich ohne Probleme mit meiner Voice-Box telefonieren. Ich wunder mich zwar, wieso jetzt die Digits beim deutschen Voiceprompts von Amooma noch in englisch kommen, aber das sollt ich noch finden.
Danke dafür
Robert
Callendaar
