Everyone is busy
mathboy
3 Jul 2010
hallo, ich habe das Snom 300 und einen Asterisk server auf der Fritzbox.
Leider klappt es nicht, dass ich dort anrufe.
Ich bekomme als Meldung 'Everyone is busy/congested at this time (1:0/0/1)'
Könnt ihr mir da helfen ? (Das ganze soll über das Internet gehen, also nicht nur lokal im LAN)
asterisk CLI output
[Nov  1 14:45:17] WARNING[2441]: chan_sip.c:2945 __sip_autodestruct: Autodestruct on dialog '75e551d36d096c6a240e6b257c4be98d@%myInetIP%' with owner in place (Method: ACK)
  == ISDN1#02: Incoming call '%caller-nr%' -> '%msn2%'
    -- Executing [%msn2%@capi_in1:1] NoOp("CAPI/ISDN1#02/%msn2%-6", "Anruf von %caller-nr%") in new stack
    -- Executing [%msn2%@capi_in1:2] Set("CAPI/ISDN1#02/%msn2%-6", "MSGFILENAME=") in new stack
    -- Executing [%msn2%@capi_in1:3] Dial("CAPI/ISDN1#02/%msn2%-6", "SIP/%userSIPid%,20,r") in new stack
  == Using SIP RTP CoS mark 5
    -- Called %userSIPid%
    -- Got SIP response 482 "Loop Detected" back from %myInetIP%
    -- Now forwarding CAPI/ISDN1#02/%msn2%-6 to 'Local/%userSIPid%@sip%userSIPid%' (thanks to SIP/%userSIPid%-00642dc0)
  == Everyone is busy/congested at this time (1:0/0/1)
    -- Executing [%msn2%@capi_in1:4] Goto("CAPI/ISDN1#02/%msn2%-6", "record,s,1") in new stack
    -- Goto (record,s,1)
    -- Executing [s@record:1] Macro("CAPI/ISDN1#02/%msn2%-6", "entfernegitter") in new stack
    -- Executing [s@macro-entfernegitter:1] Set("CAPI/ISDN1#02/%msn2%-6", "EXTEN2=s") in new stack
    -- Executing [s@record:2] Wait("CAPI/ISDN1#02/%msn2%-6", "1") in new stack
    -- Executing [s@record:3] Playback("CAPI/ISDN1#02/%msn2%-6", "VM_MESSAGE") in new stack
  == ISDN1#02: Answering for %msn2%
  == ISDN1#02: Setting up DTMF detector (PLCI=0xe01, flag=1)
    -- <CAPI/ISDN1#02/%msn2%-6> Playing 'VM_MESSAGE.gsm' (language 'de')
    -- Executing [s@record:4] Set("CAPI/ISDN1#02/%msn2%-6", "TIMESTAMP=Mon Nov  1 14:51:00 2010") in new stack
    -- Executing [s@record:5] Set("CAPI/ISDN1#02/%msn2%-6", "MSGFILENAME=%caller-nr%") in new stack
    -- Executing [s@record:6] Set("CAPI/ISDN1#02/%msn2%-6", "MAILER_SUBJECT=Anrufer:%caller-nr% Zeit:Mon Nov  1 14:51:00 2010") in new stack
    -- Executing [s@record:7] Record("CAPI/ISDN1#02/%msn2%-6", "/var/spool/asterisk/%caller-nr%.WAV,5,60") in new stack
    -- <CAPI/ISDN1#02/%msn2%-6> Playing 'beep.gsm' (language 'de')
    -- Executing [h@record:1] GotoIf("CAPI/ISDN1#02/%msn2%-6", "%caller-nr%?20:48") in new stack
    -- Goto (record,h,49)
    -- Executing [h@record:49] NoOp("CAPI/ISDN1#02/%msn2%-6", "") in new stack
    -- Executing [h@record:50] Hangup("CAPI/ISDN1#02/%msn2%-6", "") in new stack
  == Spawn extension (record, h, 50) exited non-zero on 'CAPI/ISDN1#02/%msn2%-6'
  == ISDN1#02: CAPI Hangingup for PLCI=0xe01 in state 2
       > ISDN1#02: CAPI INFO 0x3490: Normal call clearing
[Nov  1 14:51:28] WARNING[2441]: chan_sip.c:2945 __sip_autodestruct: Autodestruct on dialog '162246661358c6f41f9ecb9f69b970ef@%myInetIP%' with owner in place (Method: ACK)
sip.conf
[general]
context=default                 ; Default context for incoming calls
; port 5060 already used by fritzbox, so use 5061
; and reconfigure local sip phones (remote sip goes through asterisk!)
; XLITE in same subnet example config (fritzbox 192.168.222.100)
; - System Settings / SIP Proxy / Default
;   - Enabled: Yes
;   - Display Name=Username=Auth. User=: 7701
;   - Password: 7701
;   - Domain/Realm: 192.168.222.100
;   - SIP Proxy: 192.168.222.100:5061
;   - Outbound Proxy: (empty)
;   - Use Outbound Proxy: Never
;   - Send Internal IP: Always
;   - Register: Default
; - Advanced System Settings / Audio / Silence Settings
;   - Transmit Silence: Yes
bindport=5061                   ; UDP Port to bind to (SIP standard port is 5060)
bindaddr=0.0.0.0                ; IP address to bind to (0.0.0.0 binds to all)
tcpenable=yes
tcpbindaddr=0.0.0.0:5061
;tlsenable=yes                  ; tls is not enabled by default
;tlsbindaddr=0.0.0.0:5062       ; default tls port is 5061 which conflicts with
                                ; default fritzbox asterisk sip port 5061
srvlookup=yes                   ; Enable DNS SRV lookups on outbound calls
language=de
notifyringing=yes
progressinband=no
;using external sip provider
;and coping with dynamic ip address (the entry localnet=127...
;is required if the avm sip client is registered at localhost:5061)
;(idea taken from [email protected])
externhost=%myIP.dyndns%
externrefresh=10
;localnet=127.0.0.0/255.0.0.0
;nat=yes
;canreinvite=no
localnet=192.168.178.0/255.255.255.0
;realm=asterisk
;register => bluesip/username:[email protected]/sip1
;...(http://www.ip-phone-forum.de/showpost.php?p=500468&postcount=12)
register => %userSIPid%:%userSIPid_PW%@%myIP.dyndns%:5061
[%userSIPid%]
context=sip%userSIPid%
callerid="SIP %userSIPid%" <%userSIPid%>
host=dynamic
nat=yes
qualify=no
type=friend
user=%userSIPid%
secret=*
canreinvite=no
disallow=all
allow=gsm
allow=ilbc
allow=ulaw
allow=alaw
extension.conf
[globals]
; gehende Nummer in [festnetz_out]
CAPI_CALLERID=%msn2%
LOG_PATH=/var/spool/asterisk/logs
;SIP5776 globale Setting
; Kurzes Klingeln, wenn SIP5776 nicht erreichbar
;RING_FOR_NOTICE=
MAILER_TO=%toadress%
MAILER_FROM=%fromadress%
MAILER_SMTP=%smtp%
; smtp user und password nur bei Bedarf eintragen (sonst leer lassen!)
MAILER_USER=%mail-user%
MAILER_PASSWORD=%mail-pw%
[general]
static=yes
writeprotect=no
; Macros
[macro-entfernegitter]
; wenn Nummer mit # e?hlt werden
        t)
exten => s,1,Set(EXTEN2=${IF( $[ ${MACRO_EXTEN:-1} = # ] ? ${MACRO_EXTEN:0:$[${LEN(${MACRO_EXTEN})}-1]} : ${MACRO_EXTEN} )})
;exten => s,n,NoOp(${EVAL(${EXTEN2})} -- ${MACRO_CONTEXT})
;Begruessungsnachricht des Anrufbeantworters aufnehmen
[record_message]
exten => _91!,1,Macro(entfernegitter)
exten => _91!,n,answer
exten => _91!,n,wait(1)
;exten => _91!,n,playback(beep)
exten => _91!,n,record(VM_MESSAGE.gsm,4,60)
exten => _91!,n,playback(VM_MESSAGE)
exten => _91!,n,hangup
;bei usb-Installation werden die Nachrichten vor dem mailen
;auf den usb-Speicher geschrieben (/var/spool/asterisk);
;(Schreiben auf RAM durch Ersetzen von /var/spool/asterisk durch /var/spool)
[recordtest]
; Prompt caller to authenticate and validate passcode
exten => _90!,1,Goto(record,s,1)
; nicht per include in lokal aufzunehmen; wird ueber recordtest aufgerufen.
[record]
exten => s,1,Macro(entfernegitter)
;exten => s,n,answer(2000)
exten => s,n,wait(1)
; Ansagetext vorspielen
exten => s,n,playback(VM_MESSAGE)
exten => s,n,set(TIMESTAMP=${STRFTIME(||%Y-%m-%d_%H-%M-%S)})
exten => s,n,set(MSGFILENAME=${CALLERID(num)})
exten => s,n,set(MAILER_SUBJECT=Anrufer:${CALLERID(num)} Zeit:${TIMESTAMP})
exten => s,n,record(/var/spool/asterisk/${MSGFILENAME}.WAV,5,60)
;exten => s,n,playback(/var/spool/asterisk/${MSGFILENAME})
exten => s,n,hangup
; Nachricht nach Hangup per e-mail versenden und l?schen
exten => h,1,gotoif(${MSGFILENAME}?20:48)
exten => h,20,system(mv /var/spool/asterisk/${MSGFILENAME}.WAV /var/spool/asterisk/${MSGFILENAME}.wav)
exten => h,n,gotoif(${MAILER_USER}?40)
exten => h,n,system(mailer -s "${MAILER_SUBJECT}" -m "${MAILER_SMTP}" -f "${MAILER_FROM}" -t "${MAILER_TO}" -d /var/spool/asterisk/
exten => h,n,goto(45)
exten => h,40,system(mailer -a "${MAILER_USER}" -w "${MAILER_PASSWORD}" -s "${MAILER_SUBJECT}" -m "${MAILER_SMTP}" -f "${MAILER_FRO
; Nachricht bei erfolgreichem Versand loeschen
exten => h,45,gotoif($[${SYSTEMSTATUS} = SUCCESS]?46:48)
exten => h,46,system(rm /var/spool/asterisk/${MSGFILENAME}.wav)
exten => h,47,goto(49)
exten => h,48,NoOp(Hanging up - no message to send)
exten => h,49,NoOp()
exten => h,50,hangup
;addon - mein Handy wird 2 mal kurz angerufen damit ich ¸ber neue Nachrichten informiert werde
;exten => h,n,system(echo -e "Channel: CAPI/ISDN1/${RING_FOR_NOTICE}" >> /var/spool/callfile.txt)
;exten => h,n,system(echo -e "Callerid: %msn2%" >> /var/spool/callfile.txt)
;exten => h,n,system(echo -e "Context: sips" >> /var/spool/callfile.txt)
;exten => h,n,system(echo -e "Extension: 111111" >> /var/spool/callfile.txt)
;exten => h,n,system(echo -e "MaxRetries: 1" >> /var/spool/callfile.txt)
;exten => h,n,system(echo -e "RetryTime: 5" >> /var/spool/callfile.txt)
;exten => h,n,system(echo -e "WaitTime: 9" >> /var/spool/callfile.txt)
;exten => h,n,system(echo -e "Priority: 1" >> /var/spool/callfile.txt)
;exten => h,n,system(mv /var/spool/callfile.txt /var/spool/asterisk/outgoing/callfile.txt)
;exten => h,108,NoOp(nichts hinterlassen)
;exten => h,n,hangup
[echotest]
exten => _80!,1,Macro(entfernegitter)
exten => _80!,n,answer
exten => _80!,n,wait(2)
exten => _80!,n,SayNumber(80)
exten => _80!,n,wait(4)
exten => _80!,n,playback(demo-echotest)
exten => _80!,n,echo
exten => _80!,n,playback(demo-echodone)
exten => _80!,n,hangup
;[authtest]
;exten => _89!,1,Macro(entfernegitter)
;exten => _89!,n,answer
;exten => _89!,n,wait(2)
;exten => _89!,n,authenticate(/etc/asterisk/passwd)
;exten => _89!,n,system(zebedee2.bin -f /etc/zebedee/zbdr23.conf)
;exten => _89!,n,playback(beep)
;exten => _89!,n,hangup
; f¸r rausgehende Rufe                                               -
; Es hat sich als gute Praxis erwiesen, die Inhalte der Datei        -
; extensions.conf modular aufzubauen. Diese Praxis wollen            -
; wir auch hier anwenden                                             -
[lokal]                                                              -
include => echotest                                                  -
include => recordtest                                                -
include => record_message                                            -
; Erreichbarkeit der Nebenstellen                                    -
; untereinander herstellen                                           -
[festnetz_out]                                                       -
; Raustelefon?hlt!)                                                  -
; erzwinge default calller id aus capi.conf: /d                      -
; (/d geht nicht; SetCallerID verwenden)                             -
exten => _0900X.,1,GOTO(9)                                           -
exten => _0180X.,1,GOTO(9)                                           -
exten => _0137X.,1,GOTO(9)                                           -
exten => _0[1-9]X.,1,Set(SIP_ID=${CALLERID(num)})                    -
exten => _0[1-9]X.,2,Set(CALLERID(num)=%msn2%)                     -
exten => _0[1-9]X.,3,Set(NUM_DIGITS=${LEN(${EXTEN})})                -
exten => _0[1-9]X.,4,GOTOIF($[${NUM_DIGITS}>11]?5:7)                 -
exten => _0[1-9]X.,5,system(echo "${STRFTIME(||%Y-%m-%d_%H-%M-%S)} - ${CALLERID(num)}: Call from Account SIP-${SIP_ID} to ${EXTEN}
exten => _0[1-9]X.,6,GOTO(9)
exten => _0[1-9]X.,7,system(echo "${STRFTIME(||%Y-%m-%d_%H-%M-%S)} - ${CALLERID(num)}: Call from Account SIP-${SIP_ID} to ${EXTEN}
exten => _0[1-9]X.,8,Dial(CAPI/ISDN1/${EXTEN},55,Tt)
exten => _0[1-9]X.,9,HangUP()
; f¸r reinkommende Rufe                                              -
; hier kommt der default-Context, in dem alle Geraete in der         -
; Grundkonfiguration erstmal laufen.                                 -
; Alle Geraete koennen sich gegenseitig anrufen                      -
[default]                                                            -
;include => lokal                                                    -
[%userSIPid%]                                                           -
include => lokal                                                     -
include => festnetz_out                                              -
; ISDN S0 extern                                                     -
[capi_in1]                                                           -
exten => _%msn2%,1,noop(Anruf von ${CALLERID(num)})                -
exten => _%msn2%,2,set(MSGFILENAME=)                               -
exten => _%msn2%,3,Dial(SIP/%userSIPid%,20,r)                            -
exten => _%msn2%,4,Goto(record,s,1)                                -
capi.conf
[general]
nationalprefix=0
internationalprefix=00
rxgain=1.0       ;linear receive gain (1.0 = no change)
txgain=1.0       ;linear transmit gain (1.0 = no change)
language=de      ;set default language (en/de...)
;ulaw=yes        ;set this, if you live in u-law world instead of a-law
;jb.....         ;with Asterisk 1.4 you can configure jitterbuffer,
                 ;see Asterisk documentation for all jb* setting available.
;mohinterpret=default ;Asterisk 1.4: default music on hold class when placed on hold.
; interface sections ...
[ISDN1]          ; fritzbox 7050/7170 external S0 (or external analog line: experimental)
ntmode=no      ;if isdn card operates in nt mode, set this to yes
isdnmode=msn     ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
incomingmsn=%msn2%    ;allow incoming calls to this list of MSNs/DIDs, * = any,
defaultcid=%msn1%  ;set a default caller id to that interface for dial-out,
                 ;this caller id will be used when dial option 'd' is set.
controller=1     ;capi controller number to use (=4: fritzbox 7050/7150 at analog line)
group=1          ;dialout group
softdtmf=off      ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=off     ;in addition to softdtmf, you can use relaxed dtmf detection
accountcode=     ;PBX accountcode to use in CDRs
context=capi_in1  ;context for incoming calls
;holdtype=hold   ;when the PBX puts the call on hold, ISDN HOLD will be used. If
                 ;set to 'local' (default value), no hold is done and the PBX may
                 ;play MOH.
bridge=no      ;native bridging (CAPI line interconnect) if available
devices=2        ;number of concurrent calls on this controller
                 ;(2 makes sense for single BRI, 30 for PRI)
[ISDN3]          ; fritzbox 7050 internal S0
ntmode=yes      ;if isdn card operates in nt mode, set this to yes
isdnmode=did     ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
                 ;when using NT-mode, 'DID' should be set in any case
incomingmsn=*    ;allow incoming calls to this list of MSNs/DIDs, * = any
;defaultcid=123  ;set a default caller id to that interface for dial-out,
controller=3     ;capi controller number to use
group=3          ;dialout group
context=capi_in3  ;context for incoming calls
                 ;play MOH.
;immediate=yes   ;DID: immediate start of pbx with extension 's' if no digits were
                 ;     received on incoming call (no destination number yet)
                 ;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
                 ;     info like REDIRECTINGNUMBER may be lost, but this is necessary for
                 ;     drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
; unused example (reference)
;[ISDN9]          ;this example interface gets name 'ISDN9' and may be any
                 ;name not starting with 'g' or 'contr'.
                 ;Use one interface section for each isdn port!
;ntmode=yes      ;if isdn card operates in nt mode, set this to yes
;isdnmode=did     ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
;incomingmsn=8001,8002 ;allow incoming calls to this list of MSNs/DIDs, * = any
;controller=0    ;ISDN4BSD default
;controller=7    ;ISDN4BSD USB default
;controller=1     ;capi controller number of this interface/port
;group=1          ;dialout group
;prefix=0        ;set a prefix to calling number on incoming calls
;softdtmf=on      ;enable/disable software dtmf detection, recommended for AVM cards
;relaxdtmf=on     ;in addition to softdtmf, you can use relaxed dtmf detection
;faxdetect=off    ;enable faxdetection and redirection to EXTEN 'fax' for incoming and/or
                 ;outgoing calls. (default='off', possible values: 'incoming','outgoing','both')
;accountcode=     ;PBX accountcode to use in CDRs
;amaflags=default;AMA flags for CDR ('default', 'omit', 'billing', or 'documentation')
;context=capi_in  ;context for incoming calls
                 ;play MOH.
;echosquelch=1   ;_VERY_PRIMITIVE_ echo suppression
;echocancel=yes  ;EICON DIVA SERVER (CAPI) echo cancelation (yes=g165)
                 ;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
;echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64     ;echo cancel tail setting (default=0 for maximum)
;echocancelnlp=1 ;activate non-linear-processing; this improves echo cancel ratio, but might
                 ;incorporate variable gain in the signal path.
;bridge=yes      ;native bridging (CAPI line interconnect) if available
;callgroup=1     ;PBX call group
;pickupgroup=1   ;PBX pickup group (which call groups are we allowed to pickup)
;language=de     ;set language for this device (overwrites default language)
;disallow=all    ;RTP codec selection (valid with Eicon DIVA Server only)
;allow=all       ;RTP codec selection (valid with Eicon DIVA Server only)
;devices=2        ;number of concurrent calls (b-channels) on this controller
                 ;(2 makes sense for single BRI, 30/23 for PRI/T1)
;qsig=on         ;enable use of Q.SIG extensions.
sip show peers:
Name/username              Host            Dyn Nat ACL Port     Status
%userSIPid%/%userSIPid%                %myInetIP%    D   N      5061     Unmonitored
snom configuration:
language!: English
redirect_number!:
redirect_busy_number!:
redirect_time_number!:
redirect_time!:
redirect_time_on_code!:
redirect_time_off_code!:
redirect_always_on_code!:
redirect_always_off_code!:
redirect_busy_on_code!:
redirect_busy_off_code!:
dnd_on_code!:
dnd_off_code!:
phone_type!: snom300
codec_tos!: 160
mac&: 000413345144
setting_server!: http://provisioning.snom.com/snom300/snom300.php?mac={mac}
subscribe_config!:
pnp_config!: on
ip_adr!: 192.168.178.35
netmask!: 255.255.255.0
update_server!:
dns_domain!: fritz.box
dns_server1!: 192.168.178.1
dns_server2!:
dhcp!: on
gateway!: 192.168.178.1
phone_name!:
utc_offset!: -21600
ntp_server!: 192.53.103.104
lcserver1!:
http_proxy!:
http_port!: 80
http_user!:
http_pass!:
http_scheme!: Basic
https_port!: 443
webserver_type!: http_https
webserver_cert!:
dst!: 3600 10.02.06 22:00:00 03.02.06 22:00:00
timezone!: CHL-6
contrast!: 24
sip_retry_t1!: 500
timer_support!: on
session_timer!: 3600
network_id_port!:
max_forwards!: 70
user_phone!: off
active_line!: 1
outgoing_identity!: 1
challenge_response!: off
refer_brackets!: off
sip_proxy!:
register_http_contact!: off
cmc_feature!: off
filter_registrar!: on
xml_notify!: on
challenge_reboot!: off
challenge_checksync!: off
action_received_subscr_notify_url!:
action_dnd_on_url!:
action_dnd_off_url!:
action_redirection_on_url!:
action_redirection_off_url!:
action_incoming_url!:
action_outgoing_url!:
action_setup_url!:
action_offhook_url!:
action_onhook_url!:
action_missed_url!:
action_connected_url!:
action_disconnected_url!:
aoc_amount_display!: off
aoc_pulse_currency!: $
aoc_cost_pulse!: 1
rtp_port_start!: 49152
rtp_port_end!: 65534
preselection_nr!:
auto_dial!: off
dtmf_payload_type!: 101
dnd_mode!: off
privacy_in!: off
privacy_out!: off
admin_mode_login!:
admin_mode_password!:
admin_mode_password_confirm!:
admin_mode!: true
tone_scheme!: USA
vol_headset!: 15
vol_speaker!: 12
vol_ringer!: 10
vol_handset!: 15
vol_speaker_mic!: 5
vol_handset_mic!: 5
vol_headset_mic!: 5
log_level!: 5
auto_connect_type!: auto_connect_type_handsfree
auto_connect_indication!: on
logon_wizard!: on
guess_number!: off
guess_start_length!: 4
friends_ring_sound!: Ringer1
family_ring_sound!: Ringer1
colleagues_ring_sound!: Ringer1
work_ring_sound!: Ringer1
vip_ring_sound!: Ringer1
alert_internal_ring_text!: alert-internal
alert_external_ring_text!: alert-external
alert_group_ring_text!: alert-group
alert_internal_ring_sound!: Ringer1
alert_external_ring_sound!: Ringer1
alert_group_ring_sound!: Ringer1
break_key!: false
publish_presence!: off
edit_alpha_mode!: false
display_method!: display_name
call_waiting!: on
cw_dialtone!: on
disable_speaker!: off
no_dnd!: off
mute!: off
dirty_host_ttl!:
headset_device!: headset_rj
update_policy!: settings_only
conf_hangup!: on
enum_suffix!: e164.arpa
mwi_notification!: silent
vlan_id!:
vlan_qos!:
block_url_dialing!: off
release_sound!: off
deny_all_feature!: off
transfer_on_hangup!: off
ethernet_replug!: nothing
mwi_dialtone!: stutter
support_idna!: off
custom_melody_url!:
ringer_headset_device!: speaker
dtmf_speaker_phone!: on
presence_timeout!: 15
require_prack!: on
offer_gruu!: on
offer_mpo!: off
firmware_status!:
firmware_interval!:
firmware!: http://provisioning.snom.com/download/fw/snom300-8.4.18-SIP-f.bin
update_filename!:
update_host_f&:
sip_port&: 2048
web_language!: English
call_completion!: off
callpickup_dialoginfo!: off
use_backlight!: on
reset_settings!:
date_us_format!: off
time_24_format!: off
call_join_xfer!: off
alert_info_playback!: on
ringing_time!: 120
silence_compression!: off
syslog_server!:
screen_saver_timeout!: 60
with_flash!: off
snmp_trusted_addresses!:
snmp_port!: 161
multicast_listen!: off
multicast_address!:
multicast_port!:
short_form!: off
audio_device_indicator!: on
license_data&: Mac:000413345144;Version:Standard;Hardware:snom300 (H: R2A);Date:17/08/09;Copyright(C) snom technology AG
license_url!:
holding_reminder!: on
keytones!: off
ethernet_detect!: on
support_rtcp!: on
partial_lookup!: off
signaling_tos!: 160
eth_net!: auto
eth_pc!: auto
answer_after_policy!: idle
ldap_server!:
ldap_port!:
ldap_base!:
ldap_username!:
ldap_password!:
ldap_max_hits!: 50
keyboard_lock!: off
keyboard_lock_pw!:
keyboard_lock_timeout!:
tcp_listen!: off
peer_to_peer_cc!: on
auto_logoff_time!:
text_softkey!: off
ringer_animation!: on
speaker_dialer!: on
overlap_dialing!: off
redundant_fkeys!: on
web_logout_timer!:
cancel_on_hold!: off
ntp_refresh_timer!: 3600
reboot_after_nr!: 0
watch_arp_cache!: 0
calling_title!: lang_calling
connected_title!: lang_connected
ringing_title!: lang_ringing
enter_number_title!: lang_enter_number
held_by_title!: lang_held_by
disconnected_title!: lang_terminated_finished
flood_tracing!: on
sip_tracing!: on
message_led_other!: on
keyboard_lock_emergency!: 911 112 110 999 19222
cancel_missed!: on
cancel_desktop!: off
scroll_outgoing!: on
show_local_line!: off
show_xml_pickup!: off
pickup_indication!: off
firmware_version!: snom300-SIP 8.4.18
redirect_ringing!: on
auto_redial!: off
auto_redial_value!: 10
disable_blind_transfer!: off
disable_deflection!: off
action_log_on_url!:
action_log_off_url!:
show_call_status!: off
action_reg_failed!:
max_boot_delay!: 0
http_client_user!:
http_client_pass!:
mailbox_active!: off
idle_offhook!: off
reject_calls_with_603!: off
ldap_lookup_ringing!: on
ldap_sort_results!: off
enable_keyboard_lock!: on
presence_lookup_number!: off
vlan_port_tagging!: off
vlan_net_id!:
vlan_net_priority!:
vlan_pc_id!:
vlan_pc_priority!:
emergency_proxy!:
pbx_buttons!: off
retry_after_failed_register!: 300
send_prack!: on
documentation_link!: http://wiki.snom.com/wiki/index.php/Settings/
watchdog!: on
rtp_keepalive!: on
ldap_search_filter!:
ldap_number_filter!:
ldap_name_attributes!:
ldap_number_attributes!:
ldap_display_name!:
country_code!:
area_code!:
action_unhold!:
action_hold!:
action_transfer!:
ip_adr_vlan!:
netmask_vlan!:
gateway_vlan!:
action_blind_transfer!:
action_attended_transfer!:
csta_control!: on
handsfree_mode!: quiet
enable_e164_substitution!: on
speaker_receive_call!: on
global_missed_counter!: on
use_hidden_tags!: off
show_history_info!: on
show_name_dialog!: off
ignore_security_warning!: off
naptr_sip_uri!: off
encode_display_name!: off
uboot_lock!:
auto_reboot_on_setting_change!: off
show_diversion!: on
offhook_dial_prompt!: on
fkey_delay_timeout!: 5
update_called_party_id!: on
uboot_version!: 1.1.3-s
subscription_delay!: 0
terminate_subscribers_on_reboot!: on
show_ivr_digits!: on
settings_refresh_timer!: 0
redirect_allways!: off
redirect_on_busy!: off
redirect_on_timeout!: off
idle_ok_key_action!: keyevent F_REDIAL
idle_cancel_key_action!: keyevent F_CANCEL
idle_up_key_action!: keyevent F_CALL_LIST
idle_down_key_action!: keyevent F_SETTINGS
idle_left_key_action!: keyevent F_PREV_ID
idle_right_key_action!: keyevent F_NEXT_ID
ocip_server!:
ocip_port!:
ocip_username!:
ocip_password!:
ocip_max_hits!: 50
dfks!: off
ring_count!: 5
backlight_idle!: 8
ip_frag_enable!: off
advertisement!: on
advertisement_url!: http://snom.com/{web_lng_iso_code}/AddOn
enable_rport_rfc3581!: on
dim_timer!: 20
intercom_connect_type!: intercom_connect_type_handsfree
inactive_timeout!: 15
away_timeout!: 60
empty_tls_client_cert!: off
prioritise_pbx_number_lookup!: on
vq_report_collector!:
action_firewall_test!:
refuse_call_pickup_of_connected_calls!: off
blink_very_fast!: off
ms_before_returning_to_idle_xml!: 10000
tbook_sort!: 0
ldap_predict_text!: off
prefer_saved_over_received_photo!: on
lastexit!: 0
laststate!: 0
lastmethod!: 0
lastkey!: 0
lastsignal!: 0
ice_diagnostics!: 0
http_proxy_user!:
http_proxy_pass!:
xcap_tbook_sync_interval!: 7200
xcap_server_name!:
xcap_server_port!: 8080
xcap_directory_auid!: services/resource-lists
xcap_dir_doc_name!: contacts-resource-list.xml
xcap_via_tls!: true
cancel_conference!: off
leftnav_hidden_user!:
leftnav_hidden_admin!:
save_latest_callrecords_to_flash!: on
suppress_ringing_during_hold!: on
offer_outbound!: off
led_on!: ON BUSY IN_A_CALL IN_A_MEETING HOLDING DND UNAVAILABLE ACTIVE INACTIVE AWAY
led_blink_slow!:
led_blink_medium!:
led_blink_fast!: RINGING
led_red!: BUSY IN_A_CALL IN_A_MEETING HOLDING DND
led_green!: AVAILABLE
led_orange!: AWAY INACTIVE
led_red_green!:
led_red_orange!:
led_green_orange!:
dialnumber_us_format!: on
transfer_on_hangup_with_starcode!: off
ignore_dhcp_findings!:
apply_settings_timeout!:
use_NTLMv2!: on
user_agent_string!:
jb!: off
jb_min!: 40
jb_max!: 240
jb_shrink!: 500
suppress_sip_messages!:
tr69_acs_url!:
tr69_acs_user!:
tr69_acs_passwd!:
tr69_use_acs!: off
tr69_events!:
tr69_params!:
tr69_cnr_user!:
tr69_cnr_pass!:
tr69_bootstrap!: on
tr69_download_status!:
ignore_missed_calls_on_busy!: off
user_admin_mode!:
action_received_attended_transfer!:
show_clock!: on
mka!: off
transfer_on_hangup_non_pots!: off
sdp_version_check!: on
perform_initial_query_in_ldap_state!: on
upd_sip_uri_with_contact_from_notifies!: on
key_f1_remapped!: f1
key_f2_remapped!: f2
key_f3_remapped!: f3
key_f4_remapped!: f4
key_f5_remapped!: f5
key_cancel_remapped!: cancel
key_enter_remapped!: enter
key_left_remapped!: left
key_right_remapped!: right
key_up_remapped!: up
key_down_remapped!: down
key_record_remapped!: record
key_retrieve_remapped!: retrieve
key_mute_remapped!: mute
key_speaker_remapped!: speaker
key_headset_remapped!: headset
key_redial_remapped!: redial
key_dnd_remapped!: dnd
key_directory_remapped!: directory
key_help_remapped!: help
key_menu_remapped!: menu
key_snom_remapped!: snom
key_transfer_remapped!: transfer
key_settings_remapped!: settings
key_conference_remapped!: conference
key_hold_remapped!: hold
key_vol_up_remapped!: volume up
key_vol_down_remapped!: volume down
key_0_remapped!: 0
key_1_remapped!: 1
key_2_remapped!: 2
key_3_remapped!: 3
key_4_remapped!: 4
key_5_remapped!: 5
key_6_remapped!: 6
key_7_remapped!: 7
key_8_remapped!: 8
key_9_remapped!: 9
key_star_remapped!: *
key_hash_remapped!: #
logoff_all_no_confirm!: off
auto_connect_indication_tone!:
tls_server_authentication!: off
sip_request_timeout!: 64
sip_failover_response!:
sip_failover_response_reg!:
rtcp_xr!:
stutter_timeout!: 1000
dns_fallback_time!: 65535
lid_core_dump!: off
lcs_core_dump!: off
number_simultaneous_calls!: off
ieee8021x_eap_md5_username!:
ieee8021x_eap_md5_password!:
tftp_secret!:
sip_reconnect_on_rejected_refer!:
dns_cache_clear_timeout!:
dtmf_volume!: 4
dtmf_micro_delay!: 0
restrict_uri_queries!: true
lldp_med_discover_vlan!: off
disable_redirection_menu!: off
send_starcodes_with_audio!: off
allow_rtp_on_mute!: off
user_active1!: on
user_active2!: on
user_active3!: on
user_active4!: on
user_realname1!: %HomePhone%
user_realname2!: %SipPhone%
user_realname3!:
user_realname4!:
user_name1!: %userSIPid%
user_name2!: %sipgateID%
user_name3!:
user_name4!:
user_host1!: %myIP.dyndns%
user_host2!: sipgate.de
user_host3!:
user_host4!:
user_pname1!: %userSIPid%
user_pname2!: %sipgateID%
user_pname3!:
user_pname4!:
user_pass1!:
user_pass2!:
user_pass3!:
user_pass4!:
user_hash1!:
user_hash2!:
user_hash3!:
user_hash4!:
user_q1!: 1.0
user_q2!: 1.0
user_q3!: 1.0
user_q4!: 1.0
user_expiry1!: 3600
user_expiry2!: 3600
user_expiry3!: 3600
user_expiry4!: 3600
user_mailbox1!:
user_mailbox2!: 50000
user_mailbox3!:
user_mailbox4!:
user_srtp1!: on
user_srtp2!: on
user_srtp3!: on
user_srtp4!: on
user_symmetrical_rtp1!: off
user_symmetrical_rtp2!: off
user_symmetrical_rtp3!: off
user_symmetrical_rtp4!: off
user_ice1!: on
user_ice2!: off
user_ice3!: off
user_ice4!: off
user_moh1!:
user_moh2!:
user_moh3!:
user_moh4!:
user_stream1!:
user_stream2!:
user_stream3!:
user_stream4!:
user_idle_text1!: HausCall
user_idle_text2!: SipCall
user_idle_text3!:
user_idle_text4!:
user_alert_info1!:
user_alert_info2!:
user_alert_info3!:
user_alert_info4!:
user_pic1!:
user_pic2!:
user_pic3!:
user_pic4!:
user_auto_connect1!: off
user_auto_connect2!: off
user_auto_connect3!: off
user_auto_connect4!: off
user_xml_screen_url1!:
user_xml_screen_url2!:
user_xml_screen_url3!:
user_xml_screen_url4!:
user_descr_contact1!: on
user_descr_contact2!: on
user_descr_contact3!: on
user_descr_contact4!: on
cc_token1!:
cc_token2!:
cc_token3!:
cc_token4!:
user_uid1!: 910a091c-76fc-4abd-86db-1b68d813824c
user_uid2!:
user_uid3!:
user_uid4!:
user_sipusername_as_line1!: off
user_sipusername_as_line2!: off
user_sipusername_as_line3!: off
user_sipusername_as_line4!: off
user_proxy_require1!:
user_proxy_require2!:
user_proxy_require3!:
user_proxy_require4!:
user_shared_line1!: off
user_shared_line2!: off
user_shared_line3!: off
user_shared_line4!: off
user_send_local_name1!: off
user_send_local_name2!: off
user_send_local_name3!: off
user_send_local_name4!: off
user_dp_str1!:
user_dp_str2!:
user_dp_str3!:
user_dp_str4!:
user_dp_exp1!:
user_dp_exp2!:
user_dp_exp3!:
user_dp_exp4!:
user_ringer1!: Ringer6
user_ringer2!: Ringer1
user_ringer3!: Ringer1
user_ringer4!: Ringer1
user_custom1!:
user_custom2!:
user_custom3!:
user_custom4!:
user_outbound1!: %myIP.dyndns%:5061
user_outbound2!: sipgate.de
user_outbound3!:
user_outbound4!:
codec1_name1!: 0
codec1_name2!: 0
codec1_name3!: 0
codec1_name4!: 0
codec2_name1!: 8
codec2_name2!: 8
codec2_name3!: 8
codec2_name4!: 8
codec3_name1!: 9
codec3_name2!: 9
codec3_name3!: 9
codec3_name4!: 9
codec4_name1!: 2
codec4_name2!: 2
codec4_name3!: 2
codec4_name4!: 2
codec5_name1!: 3
codec5_name2!: 3
codec5_name3!: 3
codec5_name4!: 3
codec6_name1!: 18
codec6_name2!: 18
codec6_name3!: 18
codec6_name4!: 18
codec7_name1!: 4
codec7_name2!: 4
codec7_name3!: 4
codec7_name4!: 4
codec_size1!: 20
codec_size2!: 20
codec_size3!: 20
codec_size4!: 20
stun_server1!: stun.sipgate.net:10000
stun_server2!: stun.sipgate.net:10000
stun_server3!:
stun_server4!:
stun_binding_interval1!: 240
stun_binding_interval2!: 240
stun_binding_interval3!:
stun_binding_interval4!:
keepalive_interval1!: 20
keepalive_interval2!: 20
keepalive_interval3!:
keepalive_interval4!:
record_missed_calls1!: on
record_missed_calls2!: on
record_missed_calls3!: on
record_missed_calls4!: on
ring_after_delay1!:
ring_after_delay2!:
ring_after_delay3!:
ring_after_delay4!:
fkey0!: line
fkey1!: line
fkey2!: keyevent F_REDIAL
fkey3!: keyevent F_ADR_BOOK
fkey4!: keyevent F_TRANSFER
fkey5!: keyevent F_MUTE
fkey_context0!: 1
fkey_context1!: 2
fkey_context2!: active
fkey_context3!: active
fkey_context4!: active
fkey_context5!: active
speed0!:
speed1!:
speed2!:
speed3!:
speed4!:
speed5!:
speed6!:
speed7!:
speed8!:
speed9!:
speed10!:
speed11!:
speed12!:
speed13!:
speed14!:
speed15!:
speed16!:
speed17!:
speed18!:
speed19!:
speed20!:
speed21!:
speed22!:
speed23!:
speed24!:
speed25!:
speed26!:
speed27!:
speed28!:
speed29!:
speed30!:
speed31!:
speed32!:
auth_tmp_pass1!:
auth_tmp_pass2!:
auth_tmp_pass3!:
auth_tmp_pass4!:
auth_tmp_realm1!:
auth_tmp_realm2!:
auth_tmp_realm3!:
auth_tmp_realm4!:
user_dtmf_info1!: off
user_dtmf_info2!: off
user_dtmf_info3!: off
user_dtmf_info4!: off
user_dp1!:
user_dp2!:
user_dp3!:
user_dp4!:
user_event_list_subscription1!: off
user_event_list_subscription2!: off
user_event_list_subscription3!: off
user_event_list_subscription4!: off
user_event_list_uri1!:
user_event_list_uri2!:
user_event_list_uri3!:
user_event_list_uri4!:
user_presence_subscription1!: off
user_presence_subscription2!: off
user_presence_subscription3!: off
user_presence_subscription4!: off
user_presence_buddy_list_uri1!:
user_presence_buddy_list_uri2!:
user_presence_buddy_list_uri3!:
user_presence_buddy_list_uri4!:
user_full_sdp_answer1!: on
user_full_sdp_answer2!: on
user_full_sdp_answer3!: on
user_full_sdp_answer4!: on
user_server_type1!:
user_server_type2!:
user_server_type3!:
user_server_type4!:
presence_state1!: Available
presence_state2!: Available
presence_state3!: Available
presence_state4!: Available
user_remove_all_bindings1!: off
user_remove_all_bindings2!: off
user_remove_all_bindings3!: off
user_remove_all_bindings4!: off
user_failover_identity1!: none
user_failover_identity2!: none
user_failover_identity3!: none
user_failover_identity4!: none
record_dialed_calls1!: on
record_dialed_calls2!: on
record_dialed_calls3!: on
record_dialed_calls4!: on
record_received_calls1!: on
record_received_calls2!: on
record_received_calls3!: on
record_received_calls4!: on
user_presence_host1!:
user_presence_host2!:
user_presence_host3!:
user_presence_host4!:
user_subscription_expiry1!: 3600
user_subscription_expiry2!: 3600
user_subscription_expiry3!: 3600
user_subscription_expiry4!: 3600
user_presence_uri1!:
user_presence_uri2!:
user_presence_uri3!:
user_presence_uri4!:
user_enable_hookflash1!: off
user_enable_hookflash2!: off
user_enable_hookflash3!: off
user_enable_hookflash4!: off
internal_ringer_text0!:
internal_ringer_text1!:
internal_ringer_text2!:
internal_ringer_text3!:
internal_ringer_text4!:
internal_ringer_text5!:
internal_ringer_text6!:
internal_ringer_text7!:
internal_ringer_text8!:
internal_ringer_text9!:
internal_ringer_text10!:
internal_ringer_file0!: Ringer1
internal_ringer_file1!: Ringer1
internal_ringer_file2!: Ringer1
internal_ringer_file3!: Ringer1
internal_ringer_file4!: Ringer1
internal_ringer_file5!: Ringer1
internal_ringer_file6!: Ringer1
internal_ringer_file7!: Ringer1
internal_ringer_file8!: Ringer1
internal_ringer_file9!: Ringer1
internal_ringer_file10!: Ringer1
user_savp1!: off
user_savp2!: off
user_savp3!: off
user_savp4!: off
user_auth_tag1!: on
user_auth_tag2!: on
user_auth_tag3!: on
user_auth_tag4!: on
user_report_machine_state1!: on
user_report_machine_state2!: on
user_report_machine_state3!: on
user_report_machine_state4!: on
user_report_phone_state1!: on
user_report_phone_state2!: on
user_report_phone_state3!: on
user_report_phone_state4!: on
user_dynamic_payload1!: on
user_dynamic_payload2!: on
user_dynamic_payload3!: on
user_dynamic_payload4!: on
user_publish_presence_bootup1!: on
user_publish_presence_bootup2!: on
user_publish_presence_bootup3!: on
user_publish_presence_bootup4!: on
tcp_keepidle1!: 5
tcp_keepidle2!: 5
tcp_keepidle3!: 5
tcp_keepidle4!: 5
tcp_keepcnt1!: 5
tcp_keepcnt2!: 5
tcp_keepcnt3!: 5
tcp_keepcnt4!: 5
tcp_keepintvl1!: 5
tcp_keepintvl2!: 5
tcp_keepintvl3!: 5
tcp_keepintvl4!: 5
tcp_failover1!: off
tcp_failover2!: off
tcp_failover3!: off
tcp_failover4!: off
user_additional_supported_header1!:
user_additional_supported_header2!:
user_additional_supported_header3!:
user_additional_supported_header4!:
mc_address1!:
mc_address2!:
mc_address3!:
mc_address4!:
mc_address5!:
mc_address6!:
mc_address7!:
mc_address8!:
mc_address9!:
mc_address10!:
user_g726_packing_order1!: on
user_g726_packing_order2!: on
user_g726_packing_order3!: on
user_g726_packing_order4!: on
user_pic_tie_to_tbook1!: off
user_pic_tie_to_tbook2!: off
user_pic_tie_to_tbook3!: off
user_pic_tie_to_tbook4!: off
user_media_setup_offer1!: active
user_media_setup_offer2!: active
user_media_setup_offer3!: active
user_media_setup_offer4!: active
user_media_transport_offer1!: udp
user_media_transport_offer2!: udp
user_media_transport_offer3!: udp
user_media_transport_offer4!: udp
fkey_label0!:
fkey_label1!:
fkey_label2!:
fkey_label3!:
fkey_label4!:
fkey_label5!:
user_presence_only1!: off
user_presence_only2!: off
user_presence_only3!: off
user_presence_only4!: off
user_presence_identity1!: none
user_presence_identity2!: none
user_presence_identity3!: none
user_presence_identity4!: none
user_default_contact_uri1!: none
user_default_contact_uri2!: none
user_default_contact_uri3!: none
user_default_contact_uri4!: none
using_server_managed_dnd1!: off
using_server_managed_dnd2!: off
using_server_managed_dnd3!: off
using_server_managed_dnd4!: off
using_server_managed_fwd_all1!: off
using_server_managed_fwd_all2!: off
using_server_managed_fwd_all3!: off
using_server_managed_fwd_all4!: off
using_server_managed_fwd_busy1!: off
using_server_managed_fwd_busy2!: off
using_server_managed_fwd_busy3!: off
using_server_managed_fwd_busy4!: off
using_server_managed_fwd_time1!: off
using_server_managed_fwd_time2!: off
using_server_managed_fwd_time3!: off
using_server_managed_fwd_time4!: off
server_managed_dnd_state1!: off
server_managed_dnd_state2!: off
server_managed_dnd_state3!: off
server_managed_dnd_state4!: off
server_managed_fwd_all_state1!: off
server_managed_fwd_all_state2!: off
server_managed_fwd_all_state3!: off
server_managed_fwd_all_state4!: off
server_managed_fwd_all_nr1!:
server_managed_fwd_all_nr2!:
server_managed_fwd_all_nr3!:
server_managed_fwd_all_nr4!:
server_managed_fwd_busy_state1!: off
server_managed_fwd_busy_state2!: off
server_managed_fwd_busy_state3!: off
server_managed_fwd_busy_state4!: off
server_managed_fwd_busy_nr1!:
server_managed_fwd_busy_nr2!:
server_managed_fwd_busy_nr3!:
server_managed_fwd_busy_nr4!:
server_managed_fwd_time_state1!: off
server_managed_fwd_time_state2!: off
server_managed_fwd_time_state3!: off
server_managed_fwd_time_state4!: off
server_managed_fwd_time_nr1!:
server_managed_fwd_time_nr2!:
server_managed_fwd_time_nr3!:
server_managed_fwd_time_nr4!:
server_managed_fwd_time_secs1!: off
server_managed_fwd_time_secs2!: off
server_managed_fwd_time_secs3!: off
server_managed_fwd_time_secs4!: off
record_missed_calls_cwi_off1!: on
record_missed_calls_cwi_off2!: on
record_missed_calls_cwi_off3!: on
record_missed_calls_cwi_off4!: on
callrecord_missed_local0!: %sipgateID%@sipgate.de
callrecord_missed_local1!: %userSIPid%@%myIP.dyndns%
callrecord_missed_local2!:
callrecord_missed_local3!:
callrecord_missed_local4!:
callrecord_missed_remote0!:
callrecord_missed_remote1!:
callrecord_missed_remote2!:
callrecord_missed_remote3!:
callrecord_missed_remote4!:
callrecord_missed_time0!:  9:44AM
callrecord_missed_time1!:  1:03PM
callrecord_missed_time2!:
callrecord_missed_time3!:
callrecord_missed_time4!:
callrecord_missed_date0!: 1.11.2010
callrecord_missed_date1!: 16.10.2010
callrecord_missed_date2!:
callrecord_missed_date3!:
callrecord_missed_date4!:
callrecord_missed_duration0!:  0:00
callrecord_missed_duration1!:  0:00
callrecord_missed_duration2!:
callrecord_missed_duration3!:
callrecord_missed_duration4!:
callrecord_missed_costs0!:
callrecord_missed_costs1!:
callrecord_missed_costs2!:
callrecord_missed_costs3!:
callrecord_missed_costs4!:
callrecord_received_local0!: %userSIPid%@%myIP.dyndns%
callrecord_received_local1!: %userSIPid%@%myIP.dyndns%
callrecord_received_local2!: %sipgateID%@sipgate.de
callrecord_received_local3!:
callrecord_received_local4!:
callrecord_received_remote0!:
callrecord_received_remote1!:
callrecord_received_remote2!:
callrecord_received_remote3!:
callrecord_received_remote4!:
callrecord_received_time0!:  10:18AM
callrecord_received_time1!:  9:43AM
callrecord_received_time2!:  12:25PM
callrecord_received_time3!:
callrecord_received_time4!:
callrecord_received_date0!: 17.10.2010
callrecord_received_date1!: 17.10.2010
callrecord_received_date2!: 16.10.2010
callrecord_received_date3!:
callrecord_received_date4!:
callrecord_received_duration0!:  0:00
callrecord_received_duration1!:  0:00
callrecord_received_duration2!:  0:07
callrecord_received_duration3!:
callrecord_received_duration4!:
callrecord_received_costs0!:
callrecord_received_costs1!:
callrecord_received_costs2!:
callrecord_received_costs3!:
callrecord_received_costs4!:
callrecord_dialed_local0!: %userSIPid%@%myIP.dyndns%
callrecord_dialed_local1!: %userSIPid%@%myIP.dyndns%
callrecord_dialed_local2!: %userSIPid%@%myIP.dyndns%
callrecord_dialed_local3!: %sipgateID%@sipgate.de
callrecord_dialed_local4!: %userSIPid%@%myIP.dyndns%
callrecord_dialed_remote0!:
callrecord_dialed_remote1!:
callrecord_dialed_remote2!: 1
callrecord_dialed_remote3!:
callrecord_dialed_remote4!:
callrecord_dialed_time0!:  9:38AM
callrecord_dialed_time1!:  10:16AM
callrecord_dialed_time2!:  10:15AM
callrecord_dialed_time3!:  9:41AM
callrecord_dialed_time4!:  1:58PM
callrecord_dialed_date0!: 1.11.2010
callrecord_dialed_date1!: 17.10.2010
callrecord_dialed_date2!: 17.10.2010
callrecord_dialed_date3!: 17.10.2010
callrecord_dialed_date4!: 16.10.2010
callrecord_dialed_duration0!:  0:02
callrecord_dialed_duration1!:  0:33
callrecord_dialed_duration2!:  0:00
callrecord_dialed_duration3!:  0:00
callrecord_dialed_duration4!:  0:00
callrecord_dialed_costs0!:
callrecord_dialed_costs1!:
callrecord_dialed_costs2!:
callrecord_dialed_costs3!:
callrecord_dialed_costs4!:
redirect_identity_allways1!:
redirect_identity_allways2!:
redirect_identity_allways3!:
redirect_identity_allways4!:
mc_output_device1!: speaker
mc_output_device2!: speaker
mc_output_device3!: speaker
mc_output_device4!: speaker
mc_output_device5!: speaker
mc_output_device6!: speaker
mc_output_device7!: speaker
mc_output_device8!: speaker
mc_output_device9!: speaker
mc_output_device10!: speaker
user_hold_inactive1!: off
user_hold_inactive2!: off
user_hold_inactive3!: off
user_hold_inactive4!: off
retry_after_failed_subscribe1!: 600
retry_after_failed_subscribe2!: 600
retry_after_failed_subscribe3!: 600
retry_after_failed_subscribe4!: 600
chars_in_lower_case0!:
chars_in_lower_case1!:
chars_in_lower_case2!:
chars_in_lower_case3!:
chars_in_lower_case4!:
chars_in_lower_case5!:
chars_in_lower_case6!:
chars_in_lower_case7!:
chars_in_lower_case8!:
chars_in_lower_case9!:
chars_in_upper_case0!:
chars_in_upper_case1!:
chars_in_upper_case2!:
chars_in_upper_case3!:
chars_in_upper_case4!:
chars_in_upper_case5!:
chars_in_upper_case6!:
chars_in_upper_case7!:
chars_in_upper_case8!:
chars_in_upper_case9!:
snom level 5 log
[2] 1/11/2010 10:38:54: start_dst(1286661600) end_dst(1299967200) offset_dst(3600) offset_utc(-21600)
[2] 1/11/2010 10:38:54: start DST: 10/09/2010 22:00:00 (1286661600)
[2] 1/11/2010 10:38:54: end DST: 03/12/2011 22:00:00 (1299967200)
[1] 1/11/2010 10:38:54: UDP: could not set reuseaddr option: Bad address (14)
[5] 1/11/2010 10:38:54: sip::process_auth:Match challenge for user=%userSIPid%, realm=asterisk
[1] 1/11/2010 10:38:55: UDP: could not set reuseaddr option: Bad address (14)
[5] 1/11/2010 10:38:55: sip::process_auth:Match challenge for user=%mySIPGateID%, realm=sipgate.de
[2] 1/11/2010 10:38:55: Registered at registrar as %userSIPid%@%myIP.dyndns% (Expires: 3600 secs)
[5] 1/11/2010 10:38:55: SIP: Cannot send registration report as no collector is specified
[2] 1/11/2010 10:38:55: Registered at registrar as %mySIPGateID%@sipgate.de (Expires: 600 secs)
[5] 1/11/2010 10:38:55: Fetching FW URL: provisioning.snom.com:80//snom300/snom300-firmware.htm done, result 200
[5] 1/11/2010 10:39:16: Settings applied!
[5] 1/11/2010 10:39:22: send lldp advertisment
Na ich hoffe ihr könnt damit was anfangen.
Vielen dank auf jedenfall schomal ;)
Schau mal:
1. Got SIP response 482 "Loop Detected" back from %myInetIP%
2. register => %userSIPid%:%pw%@%myIP.dyndns%:5061
3. %userSIPid%/%userSIPid% %myInetIP% D N 5061 Unmonitored
vielleicht sollte ich noch sagen, dass das Snom phone im lokalen Netz angeschlossen war. Allerdings will ich wie gesagt, dass es übers Inet funktioniert.
Hast Du eine Idee, welche Einstellung falsch ist ?
Ist die Kombination Snom und Asterisk nicht möglich ?
Also ich hab jetzt mal ein Softphone am Server (im Lan) getestet.
Sip show peers zeigt immernoch unmonitered.
Am Anfang konnte ich anrufen und dort auch angerufen werden. (Übers Telefonnetz)
Ich habe dann mehrer male angerufen und wieder aufgelegt.
Und irgendwann klappt es dann einfach nicht mehr.
Einmal hab ich folgendes bekommen, nachdem ich aufgelegt habe.
       > ISDN1#01: CAPI INFO 0x3490: Normal call clearing
    -- Unregistered SIP '%userSIPid%'
    -- Registered SIP '%userSIPid%' at 192.168.178.22 port 55405 expires 300
Danach ging es dann nicht mehr
Habt ihr ne Idee was das '[1] 1/11/2010 10:38:54: UDP: could not set reuseaddr option: Bad address (14)' sein könnte ?
Protonator
