Linksys 2102: 404 Not found
mototun
3 Aug 2007
Hallo liebe community,
seit ca. 2 Monate versuche ich vergeblich SPA2102 oder PAP2T mit T-Online VOIP zu verkoppeln
laut Antwort der Telekom SIP-Server wird meine Rufnummer bei dem REGISTER-Vorgang nicht erkannt:
Nov 3 01:03:48 192.168.1.199
Nov 3 01:03:55 192.168.1.199 SYSCFG: WARMBOOT 31 8a
Nov 3 01:03:55 192.168.1.199 fu: 0:5157, 0089 008a 0001
Nov 3 01:03:55 192.168.1.199 system: request reboot
Nov 3 01:03:55 192.168.1.199 fu: 0:5174, [URL="tel:0038 0445 0001"]0038 0445 0001[/URL]
Nov 3 01:03:55 192.168.1.199 fu: 0:51cc, 03e4 05b0 0001
Nov 3 01:04:00 192.168.1.199 System: started: [email protected], reboot reason:W4
Nov 3 01:04:00 192.168.1.199 subnet: mask: 255.255.255.0
Nov 3 01:04:00 192.168.1.199 gateway: ip: 192.168.1.1
Nov 3 01:04:00 192.168.1.199 dns: servers(2):
Nov 3 01:04:00 192.168.1.199 192.168.1.1:
Nov 3 01:04:00 192.168.1.199 194.25.2.129:
Nov 3 01:04:01 192.168.1.199 ++++: sip skt[1]= INVALID
Nov 3 01:04:01 192.168.1.199 Reg Addr Change(0) 0:0->d90010aa:5060
Nov 3 01:04:01 192.168.1.199 ->217.0.16.170:5060(516)
Nov 3 01:04:01 192.168.1.199 REGISTER: sip:217.0.16.170 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.199:5060;branch=z9hG4bK-ecbab30b;rport
From: [URL="tel:06449717526"]06449717526[/URL] <sip:[email protected]>;tag=244d8e7b6556fff co0
To: [URL="tel:06449717526"]06449717526[/URL] <sip:[email protected]>
Call-ID: [email protected]
CSeq: 10941 REGISTER
Max-Forwards: 70
Contact: [URL="tel:06449717526"]06449717526[/URL] <sip:[email protected]:5060>;expires=600
User-Agent: Linksys/SPA2102-3.3.6
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura
Nov 3 01:04:01 192.168.1.199 <<217.0.16.170:5060(337)
Nov 3 01:04:01 192.168.1.199 SIP/2.0: 404 Not Found
Via: SIP/2.0/UDP 192.168.1.199:5060;rport=5060;received=87.146.92.2 53;branch=z9hG4bK-ecbab30b
To: [URL="tel:06449717526"]06449717526[/URL] <sip:[email protected]>;tag=8d8f0c8e
Content-Length: 0
Nov 3 01:04:01 192.168.1.199 ExtIpChanged: [URL="tel:87.146.92.253"]87.146.92.253[/URL]
Nov 3 01:04:01 192.168.1.199 RegFail. Retry in 60
welche Einstellungen muss ich ändern damit die REGISTER abgeschlossen wird?
Vielen Dank im voraus
Slava
Problem gelöst: https://forum.telekom.de/foren/read...pct-5020-an-speedport-w724v,439,11163741.html
das Problem ist, daß bestimmte Router oder TK Anlagen eine gewisse Art der Registrierung nicht beherrschen. Auf der VOIP Plattform gibt es unterschiedliche Server die einmal diese spezielle Form der Registrierung erwarten. Dies kann man umgehen indem man einen anderen Outbound Proxy verwendet (IP Adresse 217.0.18.16 wie weiter oben geschrieben). Normalerweise bekommt man über die DNS Abfrage automatisch sonst einen zugewiesen.
Wenn Du diesen speziellen Proxy verwendest, solltest du aber Deine Telefon Nummer (sprich Benutzername) und Displaynamen im internationalen Format schreiben, sonst kannst Du die Sprachbox nicht benutzen. (also +49891234567 für 0891234567).
Nov 6 21:40:05 192.168.1.199
Nov 6 21:40:05 192.168.1.199 <<217.0.18.16:5060(646)
Nov 6 21:40:05 192.168.1.199 SIP/2.0: 200 OKM
Nov 6 21:40:05 192.168.1.199 RegOK. NextReg in 465 (1)
Kann mir jemand bestätigen, ob es eine Änderung am Outboud Proxy mit der IP Adresse 217.0.18.16 gab? Bei mir schlägt mit einem Cisco SPA 112 seit gestern Abend jeglicher Authentifizierungvorgang fehl.
IDfour
