[Info] FB 7490 Labor-FW en-de-es-it-fr-pl 113.06.10-28194 vom 27.06.2014
  • Ersteller Ersteller SF1975
S
SF1975
Guest
More improvements in the various lab versions
--- Improvements in the version FRITZ!OS 6.10-28194 ---
DSL
  • See how long no signal was received on the DSL-information page
  • VDSL Interop improvements
  • Improved stability for G.Vector
  • Improved DSL Diagnosis
Home network
  • Display of MIMO-standard in the detail informations of Powerline-devices
  • Use of fixed IP addresses via DHCP server improved
  • Change Child-protection profile in the detail settings of every network-device
Telephony
  • Configuration and editing of telephone numbers corrected
Internet
  • VPN-connection to Android-devices no longer disconnected after one hour
  • Online counter now able to display higher bandwidths
  • When activating MyFRITZ! a random port for https will be selected
  • Fixes a possibility to circumvent child-protection via guest-access
  • Added Diffie Hellmann Group 5, 14 and 15 for VPN
  • TR-069-Connection request port is now being closed, once TR-069 has been deactivated
  • Improved accessibility in IP-Client mode
Media server
  • Support for Google "all Inclusive" music added
  • Support for Google Play Music Playlists
NAS
  • Improved speed when displaying folder content and preview images
  • HTML-player for photos, audio and video added
  • Added a filter function to the search
  • Search using metadata (date, size, last change)
  • Upload multiple files via Drag&Drop
  • Rename multiple files at the same time
  • Separate icon for shared files and folders
  • Optimized display of NAS-pages on mobile devices
Security
  • Enhanced security area in WLAN settings
  • Assistance in choosing safe passwords
  • Push mails are now by default sent using SSL encryption
  • Import- and export the SSL-certificate used by your FRITZ!Box
Smart Home
  • Use FRITZ!DECT Repeaters as temperature sensors
  • Display the current temperature in FRITZ!Box GUI and MyFRITZ!App
  • Configure push mail to inform you whenever FRITZ!DECT 200 is switched on or off
  • Send a push mail when the connection to FRITZ!DECT 200 is lost
  • Select individual power consumption value to enable standby
System
  • Notification for important FRITZ!OS-Updates
  • Crashes when using the new Push Services fixed
  • Enables setting a password for the saved settings before the update
  • New FRITZ!OS-Updates can be installed automatically (default setting)*
  • Several improvements for the update process
  • Improved scheduled switching for tablets and smartphones
Telephony
  • Forced speed dial for phonebook entries fixed
  • Prefix "**8" is displayed when using Vanity Codes
  • Plausibility test for the entry of fixed line numbers fixed
  • Sporadic reboots when using IP-telephones fixed
  • Improved voice quality in case of parallel data transfer (WLAN<->LAN)
Telephony/DECT
  • For mail reception, encrypted transmission via port 995 is always tried first
  • Improved functionality for Gigaset handsets
  • Ability to set and delete custom ringtones for online phonebooks
  • Display of current temperature on FRITZ!DECT handsets
  • Support for more audio codecs for FRITZ!DECT handsets (FLAC & OggVorbis)
  • Improved playback of internet radio on FRITZ!DECT handsets
  • Improved sound quality for internet radio/podcast/media player
  • Improved update of RSS-feeds
  • FRITZ!Fon C4 - Improved automatic brightness adjustment*
  • Support for the new call list with voice messages*
  • Permanent signaling of E-Mails on the handset fixed
USB
  • Improved stability when disconnecting USB-devices
  • Improved detection of 3G-sticks
  • Improved detection of some USB storage devices
WLAN
  • WLAN auto channel can be updated over the user interface
  • Initial setup extended for WLAN information and setup
  • List of access points in the WLAN environment sorted by signal strength
  • WPS for the WLAN guest access / private hotspot can be started via FRITZ!Box user interface
  • Detailed information about connected WLAN devices (Rx/Tx data rate, RSSI-value, WLAN-standard etc.)
  • Option for allowing WLAN auto channel only on channels without DFS (no impact of RADAR)
  • Faster activation of changed WLAN settings
  • Improved display of the WLAN-guest access on the main page of the user interface
  • Ready for HotSpot 2.0/Passpoint (can only be activated by provider)
  • Improved printer-view
  • Direct link to the WLAN guest access on the main page
  • MAC address filter moved to WLAN/Security
  • Connection by QR code enabled for main AP
* FRITZ!Fon handsets must be updated to at least 3.29
Notice:
When updating from a version older than 06.10-28194 the SSL certificate of FRITZ!Box will change. If you are using an App or a program that uses the certificate, there might an error message.
FRITZ!Box can periodically search for a new FRITZ!OS version and automatically update (usually at night), you can change the default setting at System/Update.
Important: during the update of FRITZ!OS services such as telephony and IPTV will be disconnected temporarily.
Download: >>>klick<<<
PS: Falls es schon einen Thread gibt, bitte zum löschen melden ;)
buggernot123
