libtiff build problem: libtiffxx.so not found
arikfunke
28 Apr 2011
Hi
Using the current trunk for 7270 v3 I am having trouble building libtiff. Build log of "make tiff-precompiled" is attached below.
Primary problem seems to be a missing libtiffxx.so... file. This occurs whether libtiffxx is selected or not.
Any idea what I am doing wrong?
Many thanks
Arik
Build Log
cmd() { PATH="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3
make[1]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3'
Making all in port
make[2]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/port'
make[2]: Für das Ziel »all« ist nichts zu tun.
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/port'
Making all in libtiff
make[2]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff'
make all-am
make[3]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff'
make[3]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff'
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff'
Making all in tools
make[2]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/tools'
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/tools'
Making all in build
make[2]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/build'
make[3]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/build'
make[3]: Für das Ziel »all-am« ist nichts zu tun.
make[3]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/build'
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/build'
make[2]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3'
make[2]: Für das Ziel »all-am« ist nichts zu tun.
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3'
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3'
cmd() { PATH="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff \
DESTDIR="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc" \
install
make[1]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff'
/bin/mkdir -p '/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include'
/usr/bin/install -c -m 644 tiff.h tiffio.h tiffvers.h tiffio.hxx '/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include'
/usr/bin/install -c -m 644 tiffconf.h '/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include'
/bin/mkdir -p '/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib'
/bin/bash ../libtool --mode=install /usr/bin/install -c libtiff.la libtiffxx.la '/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib'
libtool: install: /usr/bin/install -c .libs/libtiff.so.5.2.0 /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.so.5.2.0
libtool: install: (cd /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib && { ln -s -f libtiff.so.5.2.0 libtiff.so.5 || { rm -f libtiff.so.5 && ln -s libtiff.so.5.2.0 libtiff.so.5; }; })
libtool: install: (cd /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib && { ln -s -f libtiff.so.5.2.0 libtiff.so || { rm -f libtiff.so && ln -s libtiff.so.5.2.0 libtiff.so; }; })
libtool: install: /usr/bin/install -c .libs/libtiff.lai /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.la
libtool: install: warning: relinking `libtiffxx.la'
libtool: install: (cd /home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff; /bin/bash /home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtool --tag CXX --mode=relink /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -no-undefined -version-info 7:0:2 -L/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib -o libtiffxx.la -rpath /usr/lib tif_stream.lo ../libtiff/libtiff.la ../port/libport.la -ljpeg -lz -lm -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc)
*** Warning: linker path does not have real file for library -lgcc.
*** I have the capability to make that library automatically link in when
*** you link to this library. But I can only do this if you have a
*** shared version of the library, which you do not appear to have
*** because I did check the linker path looking for a file starting
*** with libgcc and none of the candidates passed a file format test
*** using a file magic. Last file checked: /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/lib/gcc/mipsel-linux-uclibc/4.6.4/libgcc.map
*** The inter-library dependencies that have been dropped here will be
*** automatically added whenever a program is linked with this library
*** or is declared to -dlopen it.
*** Since this library must not contain undefined symbols,
*** because either the platform does not support them or
*** it was explicitly requested with -no-undefined,
*** libtool will only create a static version of it.
libtool: relink: (cd .libs/libtiffxx.lax/libport.a && mipsel-linux-ar x "/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff/../port/.libs/libport.a")
libtool: relink: mipsel-linux-ar cru .libs/libtiffxx.a tif_stream.o .libs/libtiffxx.lax/libport.a/dummy.o
libtool: relink: mipsel-linux-ranlib .libs/libtiffxx.a
libtool: relink: rm -fr .libs/libtiffxx.lax
libtool: relink: ( cd ".libs" && rm -f "libtiffxx.la" && ln -s "../libtiffxx.la" "libtiffxx.la" )
libtool: install: /usr/bin/install -c .libs/libtiffxx.lai /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.la
libtool: install: /usr/bin/install -c .libs/libtiff.a /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.a
libtool: install: chmod 644 /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.a
libtool: install: mipsel-linux-ranlib /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.a
libtool: install: /usr/bin/install -c .libs/libtiffxx.a /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.a
libtool: install: chmod 644 /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.a
libtool: install: mipsel-linux-ranlib /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.a
libtool: install: warning: remember to run `libtool --finish /usr/lib'
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff'
cmd() { PATH="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3 \
install-pkgconfigDATA
/bin/mkdir -p '/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/pkgconfig'
/usr/bin/install -c -m 644 libtiff-4.pc '/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/pkgconfig'
sed -i -r -e "s,^(libdir=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc\3\4,g" -e "s,^(includedir=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc\3\4,g" -e "s,^(prefix=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc\3\4,g" -e "s,^(exec_prefix=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc\3\4,g" -e "/^dependency_libs/s,[ \t], ,g;s,([ '])((/usr)?/lib/[^ /]+[.]la)([ ']),\1/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc\2\4,g;s, +, ,g" \
/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/pkgconfig/libtiff*.pc \
/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.la /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.la
install
libtool: install: (cd /home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtiff; /bin/bash /home/freetz/freetz-trunk/source/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/tiff-4.0.3/libtool --tag CXX --mode=relink /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -no-undefined -version-info 7:0:2 -L/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib -o libtiffxx.la -rpath /usr/lib tif_stream.lo ../libtiff/libtiff.la ../port/libport.la -ljpeg -lz -lm -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc -inst-prefix-dir /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc)
chmod 755 /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.so.5.2.0; mkdir -p packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/; cp -a /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiff.so* packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/; /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/libtiff.so.5.2.0;
chmod 755 /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.so.5.2.0; mkdir -p packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/; cp -a /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.so* packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/; /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/libtiffxx.so.5.2.0;
chmod: Zugriff auf »/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.so.5.2.0“ nicht möglich: Datei oder Verzeichnis nicht gefunden
cp: der Aufruf von stat für »/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libtiffxx.so*“ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.6.4_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip: 'packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/libtiffxx.so.5.2.0': No such file
make: *** [packages/target-mipsel_gcc-4.6.4_uClibc-0.9.32.1/root/usr/lib/freetz/libtiffxx.so.5.2.0] Fehler 1
This is not the full log, it's just a part showed again and again after the build has failed for the 1st time. Could you please do the following
make tiff-dirclean
make tiff-precompiled 2>&1 | tee tiff-precompiled.log
and then attach/post tiff-precompiled.log here. It would also help a lot if you would attach your .config
make tiff-dirclean
I have been trying to replicate my problem. First I could not get it to go away, not I cannot reproduce it. It might have been related to me running different clean options (or to a libc update).
Using the same config file on a fresh checkout of trunk (completely new directory) everything works perfectly. I am stumped. Next time I will post the correct build log to begin with to avoid the repeatability issues.
Many thanks.
Protonator
