[Problem] TLS-Error nach Zwangstrennung OpenVPN
DoctorUltra
4 Aug 2005
seit neustens bekomme ich immer nach der nächtlichen Zwangstrennung einen TLS-ERROR ob wohl ich nichts geändert habe?
Thu Nov 26 21:42:31 2015 OpenVPN 2.3.2 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [IPv6] built on Oct 16 2013
Thu Nov 26 21:42:32 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Thu Nov 26 21:42:32 2015 UDPv4 link local: [undef]
Thu Nov 26 21:42:32 2015 UDPv4 link remote: [AF_INET]46.166.188.212:9201
Thu Nov 26 21:42:32 2015 TLS: Initial packet from [AF_INET]46.166.188.212:9201, sid=3513e117 cea492a7
Thu Nov 26 21:42:32 2015 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Thu Nov 26 21:42:32 2015 CRL CHECK OK: C=US, ST=OH, L=Columbus, O=Private Internet Access, CN=Private Internet Access CA, [email protected]
Thu Nov 26 21:42:32 2015 VERIFY OK: depth=1, C=US, ST=OH, L=Columbus, O=Private Internet Access, CN=Private Internet Access CA, [email protected]
Thu Nov 26 21:42:32 2015 Validating certificate key usage
Thu Nov 26 21:42:32 2015 ++ Certificate has key usage  00a0, expects 00a0
Thu Nov 26 21:42:32 2015 VERIFY KU OK
Thu Nov 26 21:42:32 2015 Validating certificate extended key usage
Thu Nov 26 21:42:32 2015 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Thu Nov 26 21:42:32 2015 VERIFY EKU OK
Thu Nov 26 21:42:32 2015 CRL CHECK OK: C=US, ST=CA, L=LosAngeles, O=Private Internet Access, OU=Private Internet Access, CN=Private Internet Access, name=Private Internet Access, [email protected]
Thu Nov 26 21:42:32 2015 VERIFY OK: depth=0, C=US, ST=CA, L=LosAngeles, O=Private Internet Access, OU=Private Internet Access, CN=Private Internet Access, name=Private Internet Access, [email protected]
Thu Nov 26 21:42:36 2015 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Thu Nov 26 21:42:36 2015 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Nov 26 21:42:36 2015 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Thu Nov 26 21:42:36 2015 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Nov 26 21:42:36 2015 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Thu Nov 26 21:42:36 2015 [Private Internet Access] Peer Connection Initiated with [AF_INET]46.166.188.212:9201
Thu Nov 26 21:42:38 2015 SENT CONTROL [Private Internet Access]: 'PUSH_REQUEST' (status=1)
Thu Nov 26 21:42:38 2015 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 209.222.18.222,dhcp-option DNS 209.222.18.218,ping 10,comp-lzo no,route 10.161.1.1,topology net30,ifconfig 10.161.1.6 10.161.1.5'
Thu Nov 26 21:42:38 2015 OPTIONS IMPORT: timers and/or timeouts modified
Thu Nov 26 21:42:38 2015 OPTIONS IMPORT: LZO parms modified
Thu Nov 26 21:42:38 2015 OPTIONS IMPORT: --ifconfig/up options modified
Thu Nov 26 21:42:38 2015 OPTIONS IMPORT: route options modified
Thu Nov 26 21:42:38 2015 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Nov 26 21:42:38 2015 TUN/TAP device tun0 opened
Thu Nov 26 21:42:38 2015 TUN/TAP TX queue length set to 100
Thu Nov 26 21:42:38 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Nov 26 21:42:38 2015 /sbin/ifconfig tun0 10.161.1.6 pointopoint 10.161.1.5 mtu 1500
Thu Nov 26 21:42:38 2015 /sbin/route add -net 46.166.188.212 netmask 255.255.255.255 gw 192.168.10.1
Thu Nov 26 21:42:39 2015 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.161.1.5
Thu Nov 26 21:42:39 2015 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.161.1.5
Thu Nov 26 21:42:39 2015 /sbin/route add -net 10.161.1.1 netmask 255.255.255.255 gw 10.161.1.5
Thu Nov 26 21:42:39 2015 Initialization Sequence Completed
Fri Nov 27 05:48:45 2015 [Private Internet Access] Inactivity timeout (--ping-restart), restarting
Fri Nov 27 05:48:45 2015 SIGUSR1[soft,ping-restart] received, process restarting
Fri Nov 27 05:48:45 2015 Restart pause, 2 second(s)
Fri Nov 27 05:48:47 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:48:47 2015 UDPv4 link local: [undef]
Fri Nov 27 05:48:47 2015 UDPv4 link remote: [AF_INET]46.166.188.236:9201
Fri Nov 27 05:49:47 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:49:47 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:49:47 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:49:47 2015 Restart pause, 2 second(s)
Fri Nov 27 05:49:49 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:49:49 2015 UDPv4 link local: [undef]
Fri Nov 27 05:49:49 2015 UDPv4 link remote: [AF_INET]46.166.188.236:9201
Fri Nov 27 05:50:49 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:50:49 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:50:49 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:50:49 2015 Restart pause, 2 second(s)
Fri Nov 27 05:50:51 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:50:51 2015 UDPv4 link local: [undef]
Fri Nov 27 05:50:51 2015 UDPv4 link remote: [AF_INET]46.166.188.236:9201
Fri Nov 27 05:51:51 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:51:51 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:51:51 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:51:51 2015 Restart pause, 2 second(s)
Fri Nov 27 05:51:53 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:51:53 2015 UDPv4 link local: [undef]
Fri Nov 27 05:51:53 2015 UDPv4 link remote: [AF_INET]46.166.188.236:9201
Fri Nov 27 05:52:53 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:52:53 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:52:53 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:52:53 2015 Restart pause, 2 second(s)
Fri Nov 27 05:52:55 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:52:55 2015 UDPv4 link local: [undef]
Fri Nov 27 05:52:55 2015 UDPv4 link remote: [AF_INET]46.166.188.236:9201
Fri Nov 27 05:53:55 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:53:55 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:53:55 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:53:55 2015 Restart pause, 2 second(s)
Fri Nov 27 05:53:57 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:53:57 2015 UDPv4 link local: [undef]
Fri Nov 27 05:53:57 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 05:54:57 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:54:57 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:54:57 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:54:57 2015 Restart pause, 2 second(s)
Fri Nov 27 05:54:59 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:54:59 2015 UDPv4 link local: [undef]
Fri Nov 27 05:54:59 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 05:56:00 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:56:00 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:56:00 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:56:00 2015 Restart pause, 2 second(s)
Fri Nov 27 05:56:02 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:56:02 2015 UDPv4 link local: [undef]
Fri Nov 27 05:56:02 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 05:57:02 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:57:02 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:57:02 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:57:02 2015 Restart pause, 2 second(s)
Fri Nov 27 05:57:04 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:57:04 2015 UDPv4 link local: [undef]
Fri Nov 27 05:57:04 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 05:58:04 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:58:04 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:58:04 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:58:04 2015 Restart pause, 2 second(s)
Fri Nov 27 05:58:06 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:58:06 2015 UDPv4 link local: [undef]
Fri Nov 27 05:58:06 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 05:59:06 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 05:59:06 2015 TLS Error: TLS handshake failed
Fri Nov 27 05:59:06 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 05:59:06 2015 Restart pause, 2 second(s)
Fri Nov 27 05:59:08 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 05:59:08 2015 UDPv4 link local: [undef]
Fri Nov 27 05:59:08 2015 UDPv4 link remote: [AF_INET]46.166.188.235:9201
Fri Nov 27 06:00:08 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:00:08 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:00:08 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:00:08 2015 Restart pause, 2 second(s)
Fri Nov 27 06:00:10 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:00:10 2015 UDPv4 link local: [undef]
Fri Nov 27 06:00:10 2015 UDPv4 link remote: [AF_INET]46.166.188.235:9201
Fri Nov 27 06:01:10 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:01:10 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:01:10 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:01:10 2015 Restart pause, 2 second(s)
Fri Nov 27 06:01:12 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:01:12 2015 UDPv4 link local: [undef]
Fri Nov 27 06:01:12 2015 UDPv4 link remote: [AF_INET]46.166.188.235:9201
Fri Nov 27 06:02:13 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:02:13 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:02:13 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:02:13 2015 Restart pause, 2 second(s)
Fri Nov 27 06:02:15 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:02:15 2015 UDPv4 link local: [undef]
Fri Nov 27 06:02:15 2015 UDPv4 link remote: [AF_INET]46.166.188.235:9201
Fri Nov 27 06:03:15 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:03:15 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:03:15 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:03:15 2015 Restart pause, 2 second(s)
Fri Nov 27 06:03:17 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:03:17 2015 UDPv4 link local: [undef]
Fri Nov 27 06:03:17 2015 UDPv4 link remote: [AF_INET]46.166.188.235:9201
Fri Nov 27 06:04:17 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:04:17 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:04:17 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:04:17 2015 Restart pause, 2 second(s)
Fri Nov 27 06:04:19 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:04:19 2015 UDPv4 link local: [undef]
Fri Nov 27 06:04:19 2015 UDPv4 link remote: [AF_INET]46.166.188.241:9201
Fri Nov 27 06:05:19 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:05:19 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:05:19 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:05:19 2015 Restart pause, 2 second(s)
Fri Nov 27 06:05:21 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:05:21 2015 UDPv4 link local: [undef]
Fri Nov 27 06:05:21 2015 UDPv4 link remote: [AF_INET]46.166.188.241:9201
Fri Nov 27 06:06:21 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:06:21 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:06:21 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:06:21 2015 Restart pause, 2 second(s)
Fri Nov 27 06:06:23 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:06:23 2015 UDPv4 link local: [undef]
Fri Nov 27 06:06:23 2015 UDPv4 link remote: [AF_INET]46.166.188.241:9201
Fri Nov 27 06:07:23 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:07:23 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:07:23 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:07:23 2015 Restart pause, 2 second(s)
Fri Nov 27 06:07:25 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:07:25 2015 UDPv4 link local: [undef]
Fri Nov 27 06:07:25 2015 UDPv4 link remote: [AF_INET]46.166.188.241:9201
Fri Nov 27 06:08:25 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:08:25 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:08:25 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:08:25 2015 Restart pause, 2 second(s)
Fri Nov 27 06:08:27 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:08:27 2015 UDPv4 link local: [undef]
Fri Nov 27 06:08:27 2015 UDPv4 link remote: [AF_INET]46.166.188.241:9201
Fri Nov 27 06:09:27 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:09:27 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:09:27 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:09:27 2015 Restart pause, 2 second(s)
Fri Nov 27 06:09:29 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:09:30 2015 UDPv4 link local: [undef]
Fri Nov 27 06:09:30 2015 UDPv4 link remote: [AF_INET]46.166.186.235:9201
Fri Nov 27 06:10:31 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:10:31 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:10:31 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:10:31 2015 Restart pause, 2 second(s)
Fri Nov 27 06:10:33 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:10:33 2015 UDPv4 link local: [undef]
Fri Nov 27 06:10:33 2015 UDPv4 link remote: [AF_INET]46.166.186.235:9201
Fri Nov 27 06:11:33 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:11:33 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:11:33 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:11:33 2015 Restart pause, 2 second(s)
Fri Nov 27 06:11:35 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:11:35 2015 UDPv4 link local: [undef]
Fri Nov 27 06:11:35 2015 UDPv4 link remote: [AF_INET]46.166.186.235:9201
Fri Nov 27 06:12:35 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:12:35 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:12:35 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:12:35 2015 Restart pause, 2 second(s)
Fri Nov 27 06:12:37 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:12:37 2015 UDPv4 link local: [undef]
Fri Nov 27 06:12:37 2015 UDPv4 link remote: [AF_INET]46.166.186.235:9201
Fri Nov 27 06:13:37 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:13:37 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:13:37 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:13:37 2015 Restart pause, 2 second(s)
Fri Nov 27 06:13:39 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:13:39 2015 UDPv4 link local: [undef]
Fri Nov 27 06:13:39 2015 UDPv4 link remote: [AF_INET]46.166.186.235:9201
Fri Nov 27 06:14:39 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:14:39 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:14:39 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:14:39 2015 Restart pause, 2 second(s)
Fri Nov 27 06:14:41 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:14:41 2015 UDPv4 link local: [undef]
Fri Nov 27 06:14:41 2015 UDPv4 link remote: [AF_INET]109.201.154.155:9201
Fri Nov 27 06:15:41 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:15:41 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:15:41 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:15:41 2015 Restart pause, 2 second(s)
Fri Nov 27 06:15:43 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:15:43 2015 UDPv4 link local: [undef]
Fri Nov 27 06:15:43 2015 UDPv4 link remote: [AF_INET]109.201.154.155:9201
Fri Nov 27 06:16:43 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:16:43 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:16:43 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:16:43 2015 Restart pause, 2 second(s)
Fri Nov 27 06:16:45 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:16:45 2015 UDPv4 link local: [undef]
Fri Nov 27 06:16:45 2015 UDPv4 link remote: [AF_INET]109.201.154.155:9201
Fri Nov 27 06:17:45 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:17:45 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:17:45 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:17:45 2015 Restart pause, 2 second(s)
Fri Nov 27 06:17:47 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:17:47 2015 UDPv4 link local: [undef]
Fri Nov 27 06:17:47 2015 UDPv4 link remote: [AF_INET]109.201.154.155:9201
Fri Nov 27 06:18:47 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:18:47 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:18:47 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:18:47 2015 Restart pause, 2 second(s)
Fri Nov 27 06:18:49 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:18:49 2015 UDPv4 link local: [undef]
Fri Nov 27 06:18:49 2015 UDPv4 link remote: [AF_INET]109.201.154.155:9201
Fri Nov 27 06:19:49 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:19:49 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:19:49 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:19:49 2015 Restart pause, 2 second(s)
Fri Nov 27 06:19:51 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:19:51 2015 UDPv4 link local: [undef]
Fri Nov 27 06:19:51 2015 UDPv4 link remote: [AF_INET]85.159.236.209:9201
Fri Nov 27 06:20:51 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:20:51 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:20:51 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:20:51 2015 Restart pause, 2 second(s)
Fri Nov 27 06:20:53 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:20:53 2015 UDPv4 link local: [undef]
Fri Nov 27 06:20:53 2015 UDPv4 link remote: [AF_INET]85.159.236.209:9201
Fri Nov 27 06:21:53 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:21:53 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:21:53 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:21:53 2015 Restart pause, 2 second(s)
Fri Nov 27 06:21:55 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:21:55 2015 UDPv4 link local: [undef]
Fri Nov 27 06:21:55 2015 UDPv4 link remote: [AF_INET]85.159.236.209:9201
Fri Nov 27 06:22:55 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:22:55 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:22:55 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:22:55 2015 Restart pause, 2 second(s)
Fri Nov 27 06:22:57 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:22:57 2015 UDPv4 link local: [undef]
Fri Nov 27 06:22:57 2015 UDPv4 link remote: [AF_INET]85.159.236.209:9201
Fri Nov 27 06:23:57 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:23:57 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:23:57 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:23:57 2015 Restart pause, 2 second(s)
Fri Nov 27 06:23:59 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:23:59 2015 UDPv4 link local: [undef]
Fri Nov 27 06:23:59 2015 UDPv4 link remote: [AF_INET]85.159.236.209:9201
Fri Nov 27 06:24:59 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:24:59 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:24:59 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:24:59 2015 Restart pause, 2 second(s)
Fri Nov 27 06:25:01 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:25:01 2015 UDPv4 link local: [undef]
Fri Nov 27 06:25:01 2015 UDPv4 link remote: [AF_INET]46.166.186.238:9201
Fri Nov 27 06:26:01 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:26:01 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:26:01 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:26:01 2015 Restart pause, 2 second(s)
Fri Nov 27 06:26:03 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:26:03 2015 UDPv4 link local: [undef]
Fri Nov 27 06:26:03 2015 UDPv4 link remote: [AF_INET]46.166.186.238:9201
Fri Nov 27 06:27:03 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:27:03 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:27:03 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:27:03 2015 Restart pause, 2 second(s)
Fri Nov 27 06:27:05 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:27:05 2015 UDPv4 link local: [undef]
Fri Nov 27 06:27:05 2015 UDPv4 link remote: [AF_INET]46.166.186.238:9201
Fri Nov 27 06:28:06 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:28:06 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:28:06 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:28:06 2015 Restart pause, 2 second(s)
Fri Nov 27 06:28:08 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:28:08 2015 UDPv4 link local: [undef]
Fri Nov 27 06:28:08 2015 UDPv4 link remote: [AF_INET]46.166.186.238:9201
Fri Nov 27 06:29:08 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:29:08 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:29:08 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:29:08 2015 Restart pause, 2 second(s)
Fri Nov 27 06:29:10 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:29:10 2015 UDPv4 link local: [undef]
Fri Nov 27 06:29:10 2015 UDPv4 link remote: [AF_INET]46.166.186.238:9201
Fri Nov 27 06:30:10 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:30:10 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:30:10 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:30:10 2015 Restart pause, 2 second(s)
Fri Nov 27 06:30:12 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:30:12 2015 UDPv4 link local: [undef]
Fri Nov 27 06:30:12 2015 UDPv4 link remote: [AF_INET]109.201.154.205:9201
Fri Nov 27 06:31:12 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:31:12 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:31:12 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:31:12 2015 Restart pause, 2 second(s)
Fri Nov 27 06:31:14 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:31:14 2015 UDPv4 link local: [undef]
Fri Nov 27 06:31:14 2015 UDPv4 link remote: [AF_INET]109.201.154.205:9201
Fri Nov 27 06:32:14 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:32:14 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:32:14 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:32:14 2015 Restart pause, 2 second(s)
Fri Nov 27 06:32:16 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:32:16 2015 UDPv4 link local: [undef]
Fri Nov 27 06:32:16 2015 UDPv4 link remote: [AF_INET]109.201.154.205:9201
Fri Nov 27 06:33:16 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:33:16 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:33:16 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:33:16 2015 Restart pause, 2 second(s)
Fri Nov 27 06:33:18 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:33:18 2015 UDPv4 link local: [undef]
Fri Nov 27 06:33:18 2015 UDPv4 link remote: [AF_INET]109.201.154.205:9201
Fri Nov 27 06:34:18 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:34:18 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:34:18 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:34:18 2015 Restart pause, 2 second(s)
Fri Nov 27 06:34:20 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:34:20 2015 UDPv4 link local: [undef]
Fri Nov 27 06:34:20 2015 UDPv4 link remote: [AF_INET]109.201.154.205:9201
Fri Nov 27 06:35:20 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:35:20 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:35:21 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:35:21 2015 Restart pause, 2 second(s)
Fri Nov 27 06:35:23 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:35:23 2015 UDPv4 link local: [undef]
Fri Nov 27 06:35:23 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:36:23 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:36:23 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:36:23 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:36:23 2015 Restart pause, 2 second(s)
Fri Nov 27 06:36:25 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:36:25 2015 UDPv4 link local: [undef]
Fri Nov 27 06:36:25 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:37:26 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:37:26 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:37:26 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:37:26 2015 Restart pause, 2 second(s)
Fri Nov 27 06:37:28 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:37:28 2015 UDPv4 link local: [undef]
Fri Nov 27 06:37:28 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:38:28 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:38:28 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:38:28 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:38:28 2015 Restart pause, 2 second(s)
Fri Nov 27 06:38:30 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:38:30 2015 UDPv4 link local: [undef]
Fri Nov 27 06:38:30 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:39:31 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:39:31 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:39:31 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:39:31 2015 Restart pause, 2 second(s)
Fri Nov 27 06:39:33 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:39:33 2015 UDPv4 link local: [undef]
Fri Nov 27 06:39:33 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:40:33 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:40:33 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:40:33 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:40:33 2015 Restart pause, 2 second(s)
Fri Nov 27 06:40:35 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:40:35 2015 UDPv4 link local: [undef]
Fri Nov 27 06:40:35 2015 UDPv4 link remote: [AF_INET]109.201.154.142:9201
Fri Nov 27 06:41:35 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:41:35 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:41:35 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:41:35 2015 Restart pause, 2 second(s)
Fri Nov 27 06:41:37 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:41:37 2015 UDPv4 link local: [undef]
Fri Nov 27 06:41:37 2015 UDPv4 link remote: [AF_INET]109.201.154.142:9201
Fri Nov 27 06:42:37 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:42:37 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:42:37 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:42:37 2015 Restart pause, 2 second(s)
Fri Nov 27 06:42:39 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:42:39 2015 UDPv4 link local: [undef]
Fri Nov 27 06:42:39 2015 UDPv4 link remote: [AF_INET]109.201.154.142:9201
Fri Nov 27 06:43:39 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:43:39 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:43:39 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:43:39 2015 Restart pause, 2 second(s)
Fri Nov 27 06:43:41 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:43:41 2015 UDPv4 link local: [undef]
Fri Nov 27 06:43:41 2015 UDPv4 link remote: [AF_INET]109.201.154.142:9201
Fri Nov 27 06:44:41 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:44:41 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:44:41 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:44:41 2015 Restart pause, 2 second(s)
Fri Nov 27 06:44:43 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:44:43 2015 UDPv4 link local: [undef]
Fri Nov 27 06:44:43 2015 UDPv4 link remote: [AF_INET]109.201.154.189:9201
Fri Nov 27 06:45:44 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:45:44 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:45:44 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:45:44 2015 Restart pause, 2 second(s)
Fri Nov 27 06:45:46 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:45:46 2015 UDPv4 link local: [undef]
Fri Nov 27 06:45:46 2015 UDPv4 link remote: [AF_INET]109.201.154.189:9201
Fri Nov 27 06:46:46 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:46:46 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:46:46 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:46:46 2015 Restart pause, 2 second(s)
Fri Nov 27 06:46:48 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:46:48 2015 UDPv4 link local: [undef]
Fri Nov 27 06:46:48 2015 UDPv4 link remote: [AF_INET]109.201.154.189:9201
Fri Nov 27 06:47:48 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:47:48 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:47:48 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:47:48 2015 Restart pause, 2 second(s)
Fri Nov 27 06:47:50 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:47:50 2015 UDPv4 link local: [undef]
Fri Nov 27 06:47:50 2015 UDPv4 link remote: [AF_INET]109.201.154.189:9201
Fri Nov 27 06:48:50 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:48:50 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:48:50 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:48:50 2015 Restart pause, 2 second(s)
Fri Nov 27 06:48:52 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:48:52 2015 UDPv4 link local: [undef]
Fri Nov 27 06:48:52 2015 UDPv4 link remote: [AF_INET]109.201.154.189:9201
Fri Nov 27 06:49:53 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:49:53 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:49:53 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:49:53 2015 Restart pause, 2 second(s)
Fri Nov 27 06:49:55 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:49:55 2015 UDPv4 link local: [undef]
Fri Nov 27 06:49:55 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:50:55 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:50:55 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:50:55 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:50:55 2015 Restart pause, 2 second(s)
Fri Nov 27 06:50:57 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:50:57 2015 UDPv4 link local: [undef]
Fri Nov 27 06:50:57 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:51:57 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:51:57 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:51:57 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:51:57 2015 Restart pause, 2 second(s)
Fri Nov 27 06:51:59 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:51:59 2015 UDPv4 link local: [undef]
Fri Nov 27 06:51:59 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:52:59 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:52:59 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:52:59 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:52:59 2015 Restart pause, 2 second(s)
Fri Nov 27 06:53:01 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:53:01 2015 UDPv4 link local: [undef]
Fri Nov 27 06:53:01 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:54:01 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:54:01 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:54:01 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:54:01 2015 Restart pause, 2 second(s)
Fri Nov 27 06:54:03 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:54:03 2015 UDPv4 link local: [undef]
Fri Nov 27 06:54:03 2015 UDPv4 link remote: [AF_INET]109.201.152.238:9201
Fri Nov 27 06:55:03 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:55:03 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:55:03 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:55:03 2015 Restart pause, 2 second(s)
Fri Nov 27 06:55:05 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:55:06 2015 UDPv4 link local: [undef]
Fri Nov 27 06:55:06 2015 UDPv4 link remote: [AF_INET]46.166.188.200:9201
Fri Nov 27 06:56:06 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:56:06 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:56:06 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:56:06 2015 Restart pause, 2 second(s)
Fri Nov 27 06:56:08 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:56:08 2015 UDPv4 link local: [undef]
Fri Nov 27 06:56:08 2015 UDPv4 link remote: [AF_INET]46.166.188.200:9201
Fri Nov 27 06:57:08 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:57:08 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:57:08 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:57:08 2015 Restart pause, 2 second(s)
Fri Nov 27 06:57:10 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:57:10 2015 UDPv4 link local: [undef]
Fri Nov 27 06:57:10 2015 UDPv4 link remote: [AF_INET]46.166.188.200:9201
Fri Nov 27 06:58:10 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:58:10 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:58:10 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:58:10 2015 Restart pause, 2 second(s)
Fri Nov 27 06:58:12 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:58:12 2015 UDPv4 link local: [undef]
Fri Nov 27 06:58:12 2015 UDPv4 link remote: [AF_INET]46.166.188.200:9201
Fri Nov 27 06:59:12 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 06:59:12 2015 TLS Error: TLS handshake failed
Fri Nov 27 06:59:12 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 06:59:12 2015 Restart pause, 2 second(s)
Fri Nov 27 06:59:14 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 06:59:14 2015 UDPv4 link local: [undef]
Fri Nov 27 06:59:14 2015 UDPv4 link remote: [AF_INET]46.166.188.200:9201
Fri Nov 27 07:00:14 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:00:14 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:00:14 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:00:14 2015 Restart pause, 2 second(s)
Fri Nov 27 07:00:16 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:00:16 2015 UDPv4 link local: [undef]
Fri Nov 27 07:00:16 2015 UDPv4 link remote: [AF_INET]46.166.188.219:9201
Fri Nov 27 07:01:16 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:01:16 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:01:16 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:01:16 2015 Restart pause, 2 second(s)
Fri Nov 27 07:01:18 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:01:18 2015 UDPv4 link local: [undef]
Fri Nov 27 07:01:18 2015 UDPv4 link remote: [AF_INET]46.166.188.219:9201
Fri Nov 27 07:02:18 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:02:18 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:02:18 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:02:18 2015 Restart pause, 2 second(s)
Fri Nov 27 07:02:20 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:02:20 2015 UDPv4 link local: [undef]
Fri Nov 27 07:02:20 2015 UDPv4 link remote: [AF_INET]46.166.188.219:9201
Fri Nov 27 07:03:20 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:03:20 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:03:20 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:03:20 2015 Restart pause, 2 second(s)
Fri Nov 27 07:03:22 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:03:22 2015 UDPv4 link local: [undef]
Fri Nov 27 07:03:22 2015 UDPv4 link remote: [AF_INET]46.166.188.219:9201
Fri Nov 27 07:04:22 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:04:22 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:04:22 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:04:22 2015 Restart pause, 2 second(s)
Fri Nov 27 07:04:24 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:04:24 2015 UDPv4 link local: [undef]
Fri Nov 27 07:04:24 2015 UDPv4 link remote: [AF_INET]46.166.188.219:9201
Fri Nov 27 07:05:24 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:05:24 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:05:24 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:05:24 2015 Restart pause, 2 second(s)
Fri Nov 27 07:05:26 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:05:26 2015 UDPv4 link local: [undef]
Fri Nov 27 07:05:26 2015 UDPv4 link remote: [AF_INET]46.166.186.220:9201
Fri Nov 27 07:06:26 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:06:26 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:06:26 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:06:26 2015 Restart pause, 2 second(s)
Fri Nov 27 07:06:28 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:06:28 2015 UDPv4 link local: [undef]
Fri Nov 27 07:06:28 2015 UDPv4 link remote: [AF_INET]46.166.186.220:9201
Fri Nov 27 07:07:28 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:07:28 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:07:28 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:07:28 2015 Restart pause, 2 second(s)
Fri Nov 27 07:07:30 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:07:30 2015 UDPv4 link local: [undef]
Fri Nov 27 07:07:30 2015 UDPv4 link remote: [AF_INET]46.166.186.220:9201
Fri Nov 27 07:08:31 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:08:31 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:08:31 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:08:31 2015 Restart pause, 2 second(s)
Fri Nov 27 07:08:33 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:08:33 2015 UDPv4 link local: [undef]
Fri Nov 27 07:08:33 2015 UDPv4 link remote: [AF_INET]46.166.186.220:9201
Fri Nov 27 07:09:33 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:09:33 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:09:33 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:09:33 2015 Restart pause, 2 second(s)
Fri Nov 27 07:09:35 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:09:35 2015 UDPv4 link local: [undef]
Fri Nov 27 07:09:35 2015 UDPv4 link remote: [AF_INET]46.166.186.220:9201
Fri Nov 27 07:10:35 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:10:35 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:10:35 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:10:35 2015 Restart pause, 2 second(s)
Fri Nov 27 07:10:37 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:10:37 2015 UDPv4 link local: [undef]
Fri Nov 27 07:10:37 2015 UDPv4 link remote: [AF_INET]46.166.190.187:9201
Fri Nov 27 07:11:37 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:11:37 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:11:37 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:11:37 2015 Restart pause, 2 second(s)
Fri Nov 27 07:11:39 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:11:39 2015 UDPv4 link local: [undef]
Fri Nov 27 07:11:39 2015 UDPv4 link remote: [AF_INET]46.166.190.187:9201
Fri Nov 27 07:12:39 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:12:39 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:12:39 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:12:39 2015 Restart pause, 2 second(s)
Fri Nov 27 07:12:41 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:12:41 2015 UDPv4 link local: [undef]
Fri Nov 27 07:12:41 2015 UDPv4 link remote: [AF_INET]46.166.190.187:9201
Fri Nov 27 07:13:41 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:13:41 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:13:41 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:13:41 2015 Restart pause, 2 second(s)
Fri Nov 27 07:13:43 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:13:43 2015 UDPv4 link local: [undef]
Fri Nov 27 07:13:43 2015 UDPv4 link remote: [AF_INET]46.166.190.187:9201
Fri Nov 27 07:14:43 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:14:43 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:14:43 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:14:43 2015 Restart pause, 2 second(s)
Fri Nov 27 07:14:45 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:14:45 2015 UDPv4 link local: [undef]
Fri Nov 27 07:14:45 2015 UDPv4 link remote: [AF_INET]46.166.190.187:9201
Fri Nov 27 07:15:45 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:15:45 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:15:45 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:15:45 2015 Restart pause, 2 second(s)
Fri Nov 27 07:15:47 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:15:47 2015 UDPv4 link local: [undef]
Fri Nov 27 07:15:47 2015 UDPv4 link remote: [AF_INET]46.166.188.193:9201
Fri Nov 27 07:16:47 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:16:47 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:16:47 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:16:47 2015 Restart pause, 2 second(s)
Fri Nov 27 07:16:49 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:16:49 2015 UDPv4 link local: [undef]
Fri Nov 27 07:16:49 2015 UDPv4 link remote: [AF_INET]46.166.188.193:9201
Fri Nov 27 07:17:50 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:17:50 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:17:50 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:17:50 2015 Restart pause, 2 second(s)
Fri Nov 27 07:17:52 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:17:52 2015 UDPv4 link local: [undef]
Fri Nov 27 07:17:52 2015 UDPv4 link remote: [AF_INET]46.166.188.193:9201
Fri Nov 27 07:18:52 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:18:52 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:18:52 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:18:52 2015 Restart pause, 2 second(s)
Fri Nov 27 07:18:54 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:18:54 2015 UDPv4 link local: [undef]
Fri Nov 27 07:18:54 2015 UDPv4 link remote: [AF_INET]46.166.188.193:9201
Fri Nov 27 07:19:54 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:19:54 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:19:54 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:19:54 2015 Restart pause, 2 second(s)
Fri Nov 27 07:19:56 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:19:56 2015 UDPv4 link local: [undef]
Fri Nov 27 07:19:56 2015 UDPv4 link remote: [AF_INET]46.166.188.193:9201
Fri Nov 27 07:20:56 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:20:56 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:20:56 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:20:56 2015 Restart pause, 2 second(s)
Fri Nov 27 07:20:58 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:20:58 2015 UDPv4 link local: [undef]
Fri Nov 27 07:20:58 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 07:21:58 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:21:58 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:21:58 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:21:58 2015 Restart pause, 2 second(s)
Fri Nov 27 07:22:00 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:22:00 2015 UDPv4 link local: [undef]
Fri Nov 27 07:22:00 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 07:23:00 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:23:00 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:23:00 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:23:00 2015 Restart pause, 2 second(s)
Fri Nov 27 07:23:02 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:23:02 2015 UDPv4 link local: [undef]
Fri Nov 27 07:23:02 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 07:24:02 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:24:02 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:24:02 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:24:02 2015 Restart pause, 2 second(s)
Fri Nov 27 07:24:04 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:24:04 2015 UDPv4 link local: [undef]
Fri Nov 27 07:24:04 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 07:25:04 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:25:04 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:25:04 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:25:04 2015 Restart pause, 2 second(s)
Fri Nov 27 07:25:06 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:25:06 2015 UDPv4 link local: [undef]
Fri Nov 27 07:25:06 2015 UDPv4 link remote: [AF_INET]46.166.188.194:9201
Fri Nov 27 07:26:06 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:26:06 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:26:07 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:26:07 2015 Restart pause, 2 second(s)
Fri Nov 27 07:26:09 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:26:09 2015 UDPv4 link local: [undef]
Fri Nov 27 07:26:09 2015 UDPv4 link remote: [AF_INET]46.166.188.225:9201
Fri Nov 27 07:27:09 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:27:09 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:27:09 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:27:09 2015 Restart pause, 2 second(s)
Fri Nov 27 07:27:11 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:27:11 2015 UDPv4 link local: [undef]
Fri Nov 27 07:27:11 2015 UDPv4 link remote: [AF_INET]46.166.188.225:9201
Fri Nov 27 07:28:11 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:28:11 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:28:11 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:28:11 2015 Restart pause, 2 second(s)
Fri Nov 27 07:28:13 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:28:13 2015 UDPv4 link local: [undef]
Fri Nov 27 07:28:13 2015 UDPv4 link remote: [AF_INET]46.166.188.225:9201
Fri Nov 27 07:29:13 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:29:13 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:29:13 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:29:13 2015 Restart pause, 2 second(s)
Fri Nov 27 07:29:15 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:29:15 2015 UDPv4 link local: [undef]
Fri Nov 27 07:29:15 2015 UDPv4 link remote: [AF_INET]46.166.188.225:9201
Fri Nov 27 07:30:15 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:30:15 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:30:15 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:30:15 2015 Restart pause, 2 second(s)
Fri Nov 27 07:30:17 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:30:17 2015 UDPv4 link local: [undef]
Fri Nov 27 07:30:17 2015 UDPv4 link remote: [AF_INET]46.166.188.225:9201
Fri Nov 27 07:31:17 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:31:17 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:31:17 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:31:17 2015 Restart pause, 2 second(s)
Fri Nov 27 07:31:19 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:31:19 2015 UDPv4 link local: [undef]
Fri Nov 27 07:31:19 2015 UDPv4 link remote: [AF_INET]109.201.154.170:9201
Fri Nov 27 07:32:19 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:32:19 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:32:19 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:32:19 2015 Restart pause, 2 second(s)
Fri Nov 27 07:32:21 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:32:21 2015 UDPv4 link local: [undef]
Fri Nov 27 07:32:21 2015 UDPv4 link remote: [AF_INET]109.201.154.170:9201
Fri Nov 27 07:33:21 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:33:21 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:33:21 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:33:21 2015 Restart pause, 2 second(s)
Fri Nov 27 07:33:23 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:33:23 2015 UDPv4 link local: [undef]
Fri Nov 27 07:33:23 2015 UDPv4 link remote: [AF_INET]109.201.154.170:9201
Fri Nov 27 07:34:23 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:34:23 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:34:23 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:34:23 2015 Restart pause, 2 second(s)
Fri Nov 27 07:34:25 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:34:25 2015 UDPv4 link local: [undef]
Fri Nov 27 07:34:25 2015 UDPv4 link remote: [AF_INET]109.201.154.170:9201
Fri Nov 27 07:35:25 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:35:25 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:35:25 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:35:25 2015 Restart pause, 2 second(s)
Fri Nov 27 07:35:27 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:35:27 2015 UDPv4 link local: [undef]
Fri Nov 27 07:35:27 2015 UDPv4 link remote: [AF_INET]109.201.154.170:9201
Fri Nov 27 07:36:28 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:36:28 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:36:28 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:36:28 2015 Restart pause, 2 second(s)
Fri Nov 27 07:36:30 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:36:30 2015 UDPv4 link local: [undef]
Fri Nov 27 07:36:30 2015 UDPv4 link remote: [AF_INET]46.166.188.196:9201
Fri Nov 27 07:37:30 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:37:30 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:37:30 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:37:30 2015 Restart pause, 2 second(s)
Fri Nov 27 07:37:32 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:37:32 2015 UDPv4 link local: [undef]
Fri Nov 27 07:37:32 2015 UDPv4 link remote: [AF_INET]46.166.188.196:9201
Fri Nov 27 07:38:33 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:38:33 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:38:33 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:38:33 2015 Restart pause, 2 second(s)
Fri Nov 27 07:38:35 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:38:35 2015 UDPv4 link local: [undef]
Fri Nov 27 07:38:35 2015 UDPv4 link remote: [AF_INET]46.166.188.196:9201
Fri Nov 27 07:39:36 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:39:36 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:39:36 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:39:36 2015 Restart pause, 2 second(s)
Fri Nov 27 07:39:38 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:39:38 2015 UDPv4 link local: [undef]
Fri Nov 27 07:39:38 2015 UDPv4 link remote: [AF_INET]46.166.188.196:9201
Fri Nov 27 07:40:38 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:40:38 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:40:38 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:40:38 2015 Restart pause, 2 second(s)
Fri Nov 27 07:40:40 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:40:40 2015 UDPv4 link local: [undef]
Fri Nov 27 07:40:40 2015 UDPv4 link remote: [AF_INET]46.166.188.196:9201
Fri Nov 27 07:41:41 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 27 07:41:41 2015 TLS Error: TLS handshake failed
Fri Nov 27 07:41:41 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 27 07:41:41 2015 Restart pause, 2 second(s)
Fri Nov 27 07:41:43 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Fri Nov 27 07:41:43 2015 UDPv4 link local: [undef]
Fri Nov 27 07:41:43 2015 UDPv4 link remote: [AF_INET]46.166.188.212:9201
Fri Nov 27 07:41:43 2015 TLS: Initial packet from [AF_INET]46.166.188.212:9201, sid=32abb824 b76fe4bf
Fri Nov 27 07:41:43 2015 CRL CHECK OK: C=US, ST=OH, L=Columbus, O=Private Internet Access, CN=Private Internet Access CA, [email protected]
Fri Nov 27 07:41:43 2015 VERIFY OK: depth=1, C=US, ST=OH, L=Columbus, O=Private Internet Access, CN=Private Internet Access CA, [email protected]
Fri Nov 27 07:41:43 2015 Validating certificate key usage
Fri Nov 27 07:41:43 2015 ++ Certificate has key usage  00a0, expects 00a0
Fri Nov 27 07:41:43 2015 VERIFY KU OK
Fri Nov 27 07:41:43 2015 Validating certificate extended key usage
Fri Nov 27 07:41:43 2015 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri Nov 27 07:41:43 2015 VERIFY EKU OK
Fri Nov 27 07:41:43 2015 CRL CHECK OK: C=US, ST=CA, L=LosAngeles, O=Private Internet Access, OU=Private Internet Access, CN=Private Internet Access, name=Private Internet Access, [email protected]
Fri Nov 27 07:41:43 2015 VERIFY OK: depth=0, C=US, ST=CA, L=LosAngeles, O=Private Internet Access, OU=Private Internet Access, CN=Private Internet Access, name=Private Internet Access, [email protected]
Fri Nov 27 07:41:46 2015 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Nov 27 07:41:46 2015 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Nov 27 07:41:46 2015 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Nov 27 07:41:46 2015 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Nov 27 07:41:46 2015 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Fri Nov 27 07:41:46 2015 [Private Internet Access] Peer Connection Initiated with [AF_INET]46.166.188.212:9201
Fri Nov 27 07:41:48 2015 SENT CONTROL [Private Internet Access]: 'PUSH_REQUEST' (status=1)
Fri Nov 27 07:41:48 2015 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 209.222.18.222,dhcp-option DNS 209.222.18.218,ping 10,comp-lzo no,route 10.197.1.1,topology net30,ifconfig 10.197.1.6 10.197.1.5'
Fri Nov 27 07:41:48 2015 OPTIONS IMPORT: timers and/or timeouts modified
Fri Nov 27 07:41:48 2015 OPTIONS IMPORT: LZO parms modified
Fri Nov 27 07:41:48 2015 OPTIONS IMPORT: --ifconfig/up options modified
Fri Nov 27 07:41:48 2015 OPTIONS IMPORT: route options modified
Fri Nov 27 07:41:48 2015 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Fri Nov 27 07:41:48 2015 Preserving previous TUN/TAP instance: tun0
Fri Nov 27 07:41:48 2015 NOTE: Pulled options changed on restart, will need to close and reopen TUN/TAP device.
Fri Nov 27 07:41:48 2015 /sbin/route del -net 10.161.1.1 netmask 255.255.255.255
Fri Nov 27 07:41:48 2015 /sbin/route del -net 46.166.188.212 netmask 255.255.255.255
Fri Nov 27 07:41:48 2015 /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Fri Nov 27 07:41:48 2015 /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Fri Nov 27 07:41:48 2015 Closing TUN/TAP interface
Fri Nov 27 07:41:48 2015 /sbin/ifconfig tun0 0.0.0.0
Fri Nov 27 07:41:50 2015 TUN/TAP device tun0 opened
Fri Nov 27 07:41:50 2015 TUN/TAP TX queue length set to 100
Fri Nov 27 07:41:50 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Fri Nov 27 07:41:50 2015 /sbin/ifconfig tun0 10.197.1.6 pointopoint 10.197.1.5 mtu 1500
Fri Nov 27 07:41:50 2015 /sbin/route add -net 46.166.188.212 netmask 255.255.255.255 gw 192.168.10.1
Fri Nov 27 07:41:50 2015 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.197.1.5
Fri Nov 27 07:41:50 2015 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.197.1.5
Fri Nov 27 07:41:50 2015 /sbin/route add -net 10.197.1.1 netmask 255.255.255.255 gw 10.197.1.5
Fri Nov 27 07:41:50 2015 Initialization Sequence Completed
Sat Nov 28 05:47:39 2015 [Private Internet Access] Inactivity timeout (--ping-restart), restarting
Sat Nov 28 05:47:39 2015 SIGUSR1[soft,ping-restart] received, process restarting
Sat Nov 28 05:47:39 2015 Restart pause, 2 second(s)
Sat Nov 28 05:47:41 2015 Socket Buffers: R=[110592->131072] S=[110592->131072]
Sat Nov 28 05:47:41 2015 UDPv4 link local: [undef]
Sat Nov 28 05:47:41 2015 UDPv4 link remote: [AF_INET]85.159.237.3:9201
Sat Nov 28 05:48:41 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Nov 28 05:48:41 2015 TLS Error: TLS handshake failed
Config
client
dev tun
proto udp
#remote nl.privateinternetaccess.com 1194
#remote nl.privateinternetaccess.com 9201
remote nl.privateinternetaccess.com 8080
resolv-retry infinite
nobind
persist-key
persist-tun
ca /tmp/flash/openvpn/ca.crt
tls-client
remote-cert-tls server
auth-user-pass /tmp/flash/openvpn/passfile
comp-lzo
verb 3
log /var/tmp/debug_openvpn.out
reneg-sec 0
crl-verify /tmp/flash/openvpn/crl.pem
Sieht so aus, als hätte sich die Adresse des PIA-Servers geändert nach dem Neuverbinden ... deutet auf DNS-RoundRobin hin, das mag durchaus eine Änderung auf der PIA-Seite sein oder Du hattest bisher immer Glück, daß es weniger Server zur Auswahl gab.
Alles immer unter der Voraussetzung, daß das
DoctorUltra schrieb:
ob wohl ich nichts geändert habe
so auch stimmt. Die Erfahrung zeigt leider, daß es in den allermeisten Fällen doch Änderungen beim Benutzer sind, die dieser nur nicht in Verbindung mit dem Problem bringen würde.
Solange beim Abbau der (toten) OpenVPN-Verbindung nicht ordentlich "aufgeräumt" wird und damit auch die Routen wieder gelöscht werden, zeigt die "Standardroute" (hier zwei Einträge) weiterhin auf den alten OpenVPN-Tunnel:
Thu Nov 26 21:42:38 2015 /sbin/route add -net 46.166.188.212 netmask 255.255.255.255 gw 192.168.10.1
[COLOR="#FF0000"]Thu Nov 26 21:42:39 2015 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.161.1.5
Thu Nov 26 21:42:39 2015 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.161.1.5[/COLOR]
und der nächste Verbindungsaufbau (zur Adresse 46.166.188.236) erfolgt über diesen nicht funktionierenden Tunnel - die beiden letzten Einträge sind ein "Kunstgriff", mit dem das Überschreiben der ursprünglichen Standardroute vermieden wird. Ein Löschen dieser beiden Einträge (eigentlich aller vier hinzugefügten Routen) sollte umgehend dazu führen, daß der neue Verbindungsaufbau erfolgreich ist.
Also mit einem passenden (Down-)Skript oder passenden Optionen (Dein "persist-tun" verhindert genau dieses Aufräumen, Du wirst Dir ja etwas dabei gedacht haben) dafür sorgen, daß diese zusätzlichen Routen beim Beenden der OpenVPN-Instanz (bzw. bei SIGUSR1, was aber auch auf einen Neustart des "worker threads" als "Instanz" hinausläuft) auch wieder entfernt werden.
Wenn unter einem DNS-Namen nur eine einzelne Adresse verzeichnet ist, wird immer diese eine genommen, bei zwei Adressen ist die Chance nur noch 50:50 und wenn der Erfolg und die Auslastung der Server die Verwendung weiterer Ressourcen erforderlich macht und man das nicht unter einem LoadBalancer mit einer Adresse zusammenfaßt, sondern weitere Server zum "DNS-Pool" hinzufügt, sinken die Chancen entsprechend, denselben Server bei einer weiteren DNS-Abfrage erneut zu finden. Da hilft dann eine lokale statische Route, die ihrerseits alle möglichen Einwahladressen abdeckt und damit verhindert, daß der OpenVPN-Traffic selbst wieder in den nicht vorhandenen OpenVPN-Tunnel gesteckt werden soll. Die Verwendung einer statischen Adresse anstelle des DNS-Namens wäre auch denkbar, kann aber auch eine schlechte Idee sein, wenn der Anbieter seinerseits die Auslastung von Servern genau über solche abweichenden DNS-Antworten steuern will (das ist dann lastabhängiges DNS und kein "round robin").
Irgendwie paßt auch Deine angegebene Konfigurationsdatei nicht zum Protokoll (:gruebel: Port 8080 vs. Port 9201) ... PIA verwendet nach eigener Aussage (irgendwo auf den Support-Seiten) die Ports 9201 (wohl "aus historischen Gründen") und 1194 (IANA-Zuweisung), von 8080 ist da nichts zu finden (jedenfalls für mich bei einer schnellen Suche nicht).
Insofern bin ich eher skeptisch, ob Du da tatsächlich alles offengelegt hast, was Du selbst bisher probiert hast (auch das "persist-tun" wird ja irgendwo eine "Quelle" haben, an der Du Dich orientiert hast) ... gerade bei VPNs (gilt eigentlich für jede Inkarnation eines solchen) sollte man schon genau wissen und/oder verstehen, was man da eigentlich macht und sich nicht nur auf fröhliches Probieren (aller möglichen Tipps aus irgendwelchen Internet-Quellen) beschränken, bis es irgendwann funktioniert. Sollte ich Dir damit Unrecht tun, entschuldige ich mich schon mal vorab ... aber wie sollte man sich sonst diese Diskrepanz zwischen Konfiguration und Protokoll erklären, inkl. der (vielleicht von mir nur nicht gefundenen) Quelle für die Verwendung von Port 8080 bei einer OpenVPN-Konfiguration für PIA?
EDIT:
Wenn man sich das noch etwas genauer ansieht, was da bei Dir protokolliert wird, ermittelt Dein OpenVPN in der "Pause" eine recht umfangreiche Liste von möglichen Einwahladressen (22 an der Zahl):
46.166.188.200
46.166.188.212
46.166.188.219
46.166.188.225
46.166.188.235
46.166.188.236
46.166.188.241
46.166.190.187
46.166.186.220
46.166.186.235
46.166.186.238
46.166.188.193
46.166.188.194
85.159.236.209
85.159.237.3
109.201.154.170
109.201.154.189
109.201.154.142
109.201.152.238
109.201.154.205
109.201.154.155
Das sieht eher nicht danach aus, daß dort von der PIA-Seite irgendetwas plötzlich aufgerüstet wurde ... damit steigt - so leid es mir tut - die Wahrscheinlichkeit, daß Du doch an Deiner Konfiguration etwas geändert hast; jedenfalls wäre ich auf eine andere Erklärung gespannt. Immerhin funktioniert dann der Tunnel sogar wieder, nachdem irgendwann auch mal die originale Adresse, für die eine Ausnahme beim Routing existiert, wieder verwendet wird:
Ich habe wirklich nichts geändert und die Ports sollte ich auf Empfehlung von PIA ändern, nach einem Neustart vom Vpn funktioniert immer alles warum gibt es dann Probleme bei einer Zwangstrennung
Ich glaube Pia bietet jetzt einfach mehr Adressen an, was kann ich tun damit er bei der Zwangstrennung kein Probleme mit ip und keys hat?
Habe ich doch geschrieben, lass' einfach das "persist-tun" weg, dann klappt es auch mit dem Nachbarn - wenn Du ohnehin nicht weißt, warum Du das verwendest, brauchst Du es auch nicht.
EDIT: Und unabhängig von einer Empfehlung von PIA kann die Konfigurationsdatei mit Port 8080 nicht zum Protokoll mit 9021 passen ... selbst wenn das VPN nach einem Neustart auch mit Port 8080 funktionieren sollte (finde ich schon etwas merkwürdig), sollte das eine andere Protokolldatei ergeben, bei der dann auch dieser Port auftaucht - der wird offenbar tatsächlich als UDP-Port auch unterstützt, wieso Dir irgendjemand von PIA dessen Verwendung empfiehlt, wenn doch zwischen Deiner FRITZ!Box und dem Internet gar keine weitere Firewall existiert, die anderen Traffic blockieren könnte, wissen sie vermutlich auch nicht.
Die "Erklärung" paßt also nur bedingt ... und daß PIA tatsächlich von einem Tag auf den anderen auf so viele unterschiedliche Einwahladressen aufrüstet (von einer einzelnen vorher), bleibt eher unwahrscheinlich; damit hättest Du bisher ziemliches Glück gehabt.
Schon die Frage, wie Deine FRITZ!Box nach dem Aufbau einer VPN-Verbindung denn DNS-Abfragen nach einer anderen Adresse für "nl.privateinternetaccess.com" machen soll, wenn genau dieser Tunnel nicht funktioniert, ist eigentlich vollkommen ungeklärt ... entweder die Angaben kommen aus dem Cache (eher unwahrscheinlich, denn die A-Einträge für nl.privateinternetaccess.com haben aktuell eine TTL von 60 Sekunden) oder es muß noch einen anderen Weg geben, wie diese Adresse ermittelt werden kann.
Ich will Dir ja gerne die Versicherung glauben, daß Du nichts geändert hast (und dann ja wohl PIA auch nicht, sonst hätten sie Dir ja gleich den richtigen Hinweis geben können) ... bin dann aber auf die Erklärung gespannt, wie das vorher funktioniert hat, wenn Du schon immer das "persist-tun" in Deiner Konfiguration hattest.
Das klappt allerdings genau dann, wenn da (wie schon weiter oben geschrieben) eine statische IP-Adresse in der Konfiguration drinsteht oder von PIA per Push-Reply Routing-Ausnahmen für alle denkbaren Gateway-Adressen gesetzt werden.
Es könnte jedoch tatsächlich eine Änderung bei PIA erfolgt sein, die nunmehr die TTL auf nur noch 60 Sekunden setzt, während es vorher wesentlich länger war und die alte Antwort im DNS-Cache der FRITZ!Box dann beim erneuten Versuch des Verbindungsaufbaus noch verwendbar (weil nicht abgelaufen) war ... aber das sollten Dir eigentlich die Support-Mitarbeiter von PIA viel genauer sagen können, wenn da etwas am DNS geändert wurde.
bisher funktioniert es super, ich schaue morgen mal was bei der richtigen Zwangstrennung passiert. Anscheinend hatte pia vorher nur eine ip u. hat jetzt mehrere.
PatrickSt91
