Asterisk E100P
derlo
12 Aug 2005
hab einen Asterisk mit einer E100P von Digium gegen einen Anschluß der Telekom laufen. Eigentlich funktioniert soweit alles gut, jedoch hab ich in den Log-Files sporadisch diese Einträge:
less /var/log/asterisk/messages |grep FCS:
Feb 22 19:45:08 NOTICE[15092] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 22 21:02:01 NOTICE[15092] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 23 09:09:03 NOTICE[15092] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 23 12:20:13 NOTICE[15092] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 23 17:47:06 NOTICE[15092] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 23 18:30:31 NOTICE[15092] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 23 21:28:25 NOTICE[15092] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 24 17:50:52 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 25 18:29:27 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 26 17:10:15 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 27 19:25:37 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 28 01:25:02 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 28 04:28:38 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 28 04:30:40 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 28 04:51:58 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Würde nun gern wissen ob der Anschluss der Telekom möglicherweiße Fehler hat, oder die Konfiguration der Asterisk-Anlage.
Und noch was. Weiß jemand vielleicht ob das iAXY von Digium callgroups und pickupgroups unterstützt. Hab in den Dokus dazu nichts gefunden.
Konfiguration:
E100P, 2*BN4S0, 1*TDM400P
Asterisk 1.2.4
Zaptel 1.2.3
Libpri 1.2.2
Martin
Hallo Martin,
du solltest versuchen hinzubekommen, dass die E100P einen eigenen Interrupt hat.
Mit "cat /proc/interrupts" siehst du auf welchen Treiber welcher Interrupt fällt. Mit "lspci -v" siehst du die Interrupts jedes einzelnen PCI Geräts.
Du kannst um Interrupts zu sparen, Soundkarte, serielle und paralle Schnittstelle und USB vom Bios aus deaktivieren.
Ausserdem kannst du versuchen den PCI Steckplatz zu tauschen. Das Kabel kannst du auch mal prüfen ;-)
cat /proc/zaptel/1 zeigt dir übrigens die missed IRQs für diesen Zaptelport an.
Hallo, danke für die schnelle Antwort. Hab mal generell nach HDLC-Fehlern gesucht. Dies kam dabei raus:
cat /var/log/asterisk/messages |grep HDLC
Feb 22 19:45:10 NOTICE[15092] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 23 21:28:25 NOTICE[15092] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 24 17:50:50 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 26 16:14:03 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 26 17:10:15 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 27 20:31:42 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 28 05:18:45 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 28 17:58:34 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 28 19:47:17 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
Feb 28 19:47:17 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 28 19:47:20 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Feb 28 19:47:23 NOTICE[30265] chan_zap.c: PRI got event: HDLC Bad FCS (8) on Primary D-channel of span 1
Mar  1 07:59:52 NOTICE[30265] chan_zap.c: PRI got event: HDLC Abort (6) on Primary D-channel of span 1
cat /proc/interrupts:
  CPU0
  0:  683276780          XT-PIC  timer
  1:       2545             XT-PIC  i8042
  2:          0               XT-PIC  cascade
  3:   90098266           XT-PIC  SysKonnect SK-98xx, HFC-multi
  4:   85738821           XT-PIC  HFC-multi
  5:  683104860           XT-PIC  wctdm, eth1
  7:  683103560           XT-PIC  t1xxp
  9:          0               XT-PIC  acpi
 11:     472473            XT-PIC  libata
 14:         45              XT-PIC  ide0
NMI:          0
LOC:          0
ERR:          0
MIS:          0
lspci -v
0000:00:00.0 Host bridge: Intel Corp. 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
        Subsystem: Asustek Computer, Inc. P4P800 Mainboard
        Flags: bus master, fast devsel, latency 0
        Memory at f8000000 (32-bit, prefetchable)
        Capabilities: [e4] #09 [2106]
        Capabilities: [a0] AGP version 3.0
0000:00:01.0 PCI bridge: Intel Corp. 82865G/PE/P PCI to AGP Controller (rev 02) (prog-if 00 [Normal decode])
        Flags: bus master, 66Mhz, fast devsel, latency 64
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
        Memory behind bridge: fc900000-fe9fffff
        Prefetchable memory behind bridge: e7f00000-f7efffff
0000:00:1e.0 PCI bridge: Intel Corp. 82801 PCI Bridge (rev c2) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
        I/O behind bridge: 0000d000-0000dfff
        Memory behind bridge: fea00000-feafffff
0000:00:1f.0 ISA bridge: Intel Corp. 82801EB/ER (ICH5/ICH5R) LPC Bridge (rev 02)
        Flags: bus master, medium devsel, latency 0
0000:00:1f.1 IDE interface: Intel Corp. 82801EB/ER (ICH5/ICH5R) Ultra ATA 100 Storage Controller (rev 02) (prog-if 8a [Master SecP PriP])
        Flags: bus master, medium devsel, latency 0, IRQ 11
        I/O ports at <unassigned>
        I/O ports at fc00 [size=16]
        Memory at 40000000 (32-bit, non-prefetchable) [size=1K]
0000:00:1f.2 IDE interface: Intel Corp. 82801EB (ICH5) Serial ATA 150 Storage Controller (rev 02) (prog-if 8f [Master SecP SecO PriP PriO])
        Subsystem: Asustek Computer, Inc.: Unknown device 80a6
        Flags: bus master, 66Mhz, medium devsel, latency 0, IRQ 11
        I/O ports at efe0
        I/O ports at efac [size=4]
        I/O ports at efa0 [size=8]
        I/O ports at efa8 [size=4]
        I/O ports at ef90 [size=16]
0000:00:1f.3 SMBus: Intel Corp. 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
        Flags: medium devsel, IRQ 10
        I/O ports at 0400 [size=32]
0000:01:00.0 VGA compatible controller: nVidia Corporation NV18 [GeForce4 MX 440 AGP 8x] (rev c1) (prog-if 00 [VGA])
        Subsystem: nVidia Corporation: Unknown device 0191
        Flags: bus master, 66Mhz, medium devsel, latency 64, IRQ 10
        Memory at fd000000 (32-bit, non-prefetchable) [size=fe9e0000]
        Memory at e8000000 (32-bit, prefetchable) [size=128M]
        Expansion ROM at 00020000 [disabled]
        Capabilities: [60] Power Management version 2
        Capabilities: [44] AGP version 3.0
0000:02:05.0 Ethernet controller: Marvell Technology Group Ltd. Yukon Gigabit Ethernet 10/100/1000Base-T Adapter (rev 13)
        Subsystem: Asustek Computer, Inc.: Unknown device 811a
        Flags: bus master, 66Mhz, medium devsel, latency 64, IRQ 3
        Memory at feaf8000 (32-bit, non-prefetchable) [size=feaa0000]
        I/O ports at d800 [size=256]
        Capabilities: [48] Power Management version 2
        Capabilities: [50] Vital Product Data
0000:02:09.0 Network controller: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface
        Subsystem: Unknown device b1d9:0001
        Flags: bus master, medium devsel, latency 64, IRQ 5
        I/O ports at d400
        Memory at feaff000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [40] Power Management version 2
0000:02:0a.0 ISDN controller: Cologne Chip Designs GmbH: Unknown device 08b4 (rev 01)
        Subsystem: Cologne Chip Designs GmbH: Unknown device b560
        Flags: medium devsel, IRQ 3
        I/O ports at dfe0
        Memory at feafe000 (32-bit, non-prefetchable) [disabled] [size=4K]
0000:02:0b.0 Network controller: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface
        Subsystem: Unknown device 6159:0001
        Flags: bus master, medium devsel, latency 64, IRQ 7
        I/O ports at d000
        Memory at feafd000 (32-bit, non-prefetchable) [size=4K]
0000:02:0c.0 ISDN controller: Cologne Chip Designs GmbH: Unknown device 08b4 (rev 01)
        Flags: medium devsel, IRQ 4
        I/O ports at dfa8
        Memory at feafc000 (32-bit, non-prefetchable) [disabled] [size=4K]
0000:02:0d.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
        Subsystem: Realtek Semiconductor Co., Ltd. RT8139
        I/O ports at de00
        Memory at feaf7c00 (32-bit, non-prefetchable) [size=256]
        Capabilities: [50] Power Management version 2
cat /proc/zaptel/1
Span 1: WCT1/0 "Digium Wildcard E100P E1/PRA Card 0" HDB3/CCS/CRC4 ClockSource
        IRQ misses: 3
           1 WCT1/0/1 Clear (In use)
           2 WCT1/0/2 Clear (In use)
           3 WCT1/0/3 Clear (In use)
           4 WCT1/0/4 Clear (In use)
           5 WCT1/0/5 Clear (In use)
           6 WCT1/0/6 Clear (In use)
           7 WCT1/0/7 Clear (In use)
           8 WCT1/0/8 Clear (In use)
           9 WCT1/0/9 Clear (In use)
          10 WCT1/0/10 Clear (In use)
          11 WCT1/0/11 Clear (In use)
          12 WCT1/0/12 Clear (In use)
          13 WCT1/0/13 Clear (In use)
          14 WCT1/0/14 Clear (In use)
          15 WCT1/0/15 Clear (In use)
          16 WCT1/0/16 HDLCFCS (In use)
          17 WCT1/0/17 Clear (In use)
          18 WCT1/0/18 Clear (In use)
          19 WCT1/0/19 Clear (In use)
          20 WCT1/0/20 Clear (In use)
          21 WCT1/0/21 Clear (In use)
          22 WCT1/0/22 Clear (In use)
          23 WCT1/0/23 Clear (In use)
          24 WCT1/0/24 Clear (In use)
          25 WCT1/0/25 Clear (In use)
          26 WCT1/0/26 Clear (In use)
          27 WCT1/0/27 Clear (In use)
          28 WCT1/0/28 Clear (In use)
          29 WCT1/0/29 Clear (In use)
          30 WCT1/0/30 Clear (In use)
          31 WCT1/0/31 Clear (In use)
Soweit sieht alles gut aus. Die E100P hat einen eigenen Interrupt. Dass sich die andere Karten die Interrupts teilen stört nicht weiter. Muss noch das Kabel austauschen. Vielleicht hilft es ja.
Martin
Die Meldungen kommen ja relativ selten, am Tag vielleicht 5 mal oder so.. Ich denke das sollte nicht unbedingt kritisch sein, auch wenns nicht schön ist.
Die Fehler kommen vermutlich von den verpassten Interrupts. Sehe ich das Richtig, daß da ausserdem noch zwei HFC und eine andere ISDN-Karte drinstecken? Ist eher erstaunlich, daß das so gut geht. ;)
Kannst du bei dem Rechner ACPI verwenden? Es könnte helfen, weniger Interrupts zu sharen, auch wenn die Wildcard nicht direkt betroffen ist.
Ich glaub nicht, dass die Fehler von den verpaßten Interrupts kommt. Heut morgen nochmal nachgeschaut. Immer noch 3 verpaßte Interrupts aber 7 neue Fehlermeldungen.
Und ja, in dem Rechner ist eine E100P, zwei BN4SO ISDN-Karten von Beronet und eine TDM400P. Und bis auf diese Fehlermeldung funktioniert es einwandfrei. ACPI ist übrigens aktiviert.
Martin
Bist du sicher, daß ACPI aktiviert ist? In deiner /proc/interrupts steht XT-PIC, bei aktiven ACPI sollte da was mit IO-APIC stehen.
Sicher bin ich mir nicht.
Aber ein cat config-2.6.8-24.19-default |grep ACPI gibt dies aus:
CONFIG_ACPI=y
CONFIG_ACPI_BOOT=y
CONFIG_ACPI_INTERPRETER=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_SLEEP_PROC_FS=y
CONFIG_ACPI_AC=m
CONFIG_ACPI_BATTERY=m
CONFIG_ACPI_BUTTON=m
CONFIG_ACPI_FAN=m
CONFIG_ACPI_PROCESSOR=m
CONFIG_ACPI_THERMAL=m
CONFIG_ACPI_ASUS=m
CONFIG_ACPI_SONY=m
CONFIG_ACPI_TOSHIBA=m
CONFIG_ACPI_DEBUG=y
CONFIG_ACPI_BUS=y
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_PCI=y
CONFIG_ACPI_SYSTEM=y
CONFIG_ACPI_INITRD=y
und ein grep auf /proc/interrupts:
9: 0 XT-PIC acpi
aber wie gesagt, sicher bin ich mir nicht.
MarcinK
