7240 alien 7270v2 annex A problem
Hi Tokka.
Can you please attach your .config? I will then try to flash this image on a 7240.
Regards
Oliver
Hi Oliver, here are the .config file of trunk 5770 (working) and of trunk 6687 (not working).
Now i will try trunk 6692 :)
Cheers
Tokka
Edit: trunk 6692 don't works too :(
http://freetz.org/changeset/6698
Next round... ping
I think the 7270 v2 international firmware is too old for using it as Alien source. So I added 7270v3 international firmware and used it. On my 7240 this image is working. Please give it a try. Perhaps you should start with a minimal variant and not with your 100 selected packages. ;-)
Regards
Oliver
Hello Oli :)
i have test last trunk and it's now working :) with my 7240 :D
If i may suggest something can you also add replacement of "kopfbalken.gif" and "DectFBoxIcon.png" same like you have done for "kopfbalken_mitte.gif".
Best Regards
Rudi
Hi Oliver, tested too, now it works fine:D
Sorry for my 100 packages :p
Just a little question (and a little OT, sorry): there is a reason for the swap limit at 128mb?
Btw, thanks a lots, :groesste:
Kind regards
Tokka
Hi guys,
Recently i have notes that speed of file copy from Usb Hdd@7240 via smb has decrease to avg 2MB/s
When i was using trunk 5712 it was avg 3MB/s .
Do you have similar issues with yours FBox ?
Best
Rudi
Ah, I got it. Do you really need more than 128 MB? I think the device will be unusable slow when using so much swap space?
Regards
Oliver
It's just for an experiment :P
Factory22
