7940 Sip Upgrade
Thegnar
11 Jul 2007
Ich habe mir schon einige Threads dazu durchgelesen, aber keiner scheint meine Probleme zu haben ;)
Mein 7940er möchte die Dateien:
CTLSEP0011BB9A110E.tlv und
SEP0011BB9A110E.cnf.xml haben.
Auszug aus dem TFTP Logfile:
[07/11/07 14:54:47] 'CTLSEP0011BB9A110E.tlv' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:54:47] 'SEP0011BB9A110E.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:54:47] 'SIP0011BB9A110E.cnf' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:54:47] Transfer of 'SIP0011BB9A110E.cnf' has successfully completed
[07/11/07 14:54:47] 'SIPDefault.cnf' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:54:47] Transfer of 'SIPDefault.cnf' has successfully completed
[07/11/07 14:55:14] 'CTLSEP0011BB9A110E.tlv' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:55:14] 'SEP0011BB9A110E.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:55:14] 'XMLDefault.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:55:14] Transfer of 'XMLDefault.cnf.xml' has successfully completed
[07/11/07 14:55:45] 'CTLSEP0011BB9A110E.tlv' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:55:45] 'SEP0011BB9A110E.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:55:45] 'XMLDefault.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/11/07 14:55:45] Transfer of 'XMLDefault.cnf.xml' has successfully completed
Die XMLDefault.cnf.xml musste ich selber anlegen, die hat er auch immer verlangt.
Könnt Ihr mir weiterhelfen?
LG
Werner
wie sehen denn die dateien vom inhalt aus?
Von welcher Version möchtest du upgraden?
Also wenn ich aufs Webinterface des 7940G gehe, steht da:
Version: 7.2(4.0)
Meine SIP0011BB9A110E.cnf sieht so aus:
line1_name: "SIP-ID"
line1_authname: "SIP-ID"
line1_password: "SIP-Password"
phone_label: "YourID"	; Has no effect on SIP messaging
line1_displayname: "Your Name"
phone_prompt:   "SIP Phone"      ; Limited to 15 characters (Default - SIP Phone)
phone_password: "cisco" ; Limited to 31 characters (Default - cisco)
user_info: ip
Die SIPDefault.cnf:
# SIP Default Generic Configuration File
# Image Version
image_version: P0S3-08-2-00
# Proxy Server
proxy1_address: "sipgate.de"		; Can be dotted IP or FQDN
proxy2_address: ""		; Can be dotted IP or FQDN
proxy3_address: ""		; Can be dotted IP or FQDN
proxy4_address: ""		; Can be dotted IP or FQDN
proxy5_address: ""		; Can be dotted IP or FQDN
proxy6_address: ""		; Can be dotted IP or FQDN
# Proxy Server Port (default - 5060)
proxy1_port: 5060
proxy2_port: 5060
proxy3_port: 5060
proxy4_port: 5060
proxy5_port: 5060
proxy6_port: 5060
# Proxy Registration (0-disable (default), 1-enable)
proxy_register: 1
# Phone Registration Expiration [1-3932100 sec] (Default - 3600)
timer_register_expires: 3600
# Codec for media stream (g711ulaw (default), g711alaw, g729a)
preferred_codec: g711ulaw
# TOS bits in media stream [0-5] (Default - 5)
tos_media: 5
# Inband DTMF Settings (0-disable, 1-enable (default))
dtmf_inband: 1
# Out of band DTMF Settings (none-disable, avt-avt enable (default), avt_always - always avt )
dtmf_outofband: avt
# DTMF dB Level Settings (1-6dB down, 2-3db down, 3-nominal (default), 4-3db up, 5-6dB up)
dtmf_db_level: 3
# SIP Timers
timer_t1: 500 			; Default 500 msec
timer_t2: 4000 			; Default 4 sec
sip_retx: 10			; Default 10
sip_invite_retx: 6 		; Default 6
timer_invite_expires: 180 	; Default 180 sec
####### New Parameters added in Release 2.0 #######
# Dialplan template (.xml format file relative to the TFTP root directory)
dial_template: dialplan
# TFTP Phone Specific Configuration File Directory
tftp_cfg_dir: ""		; Example:  ./sip_phone/
# Time Server (There are multiple values and configurations refer to Admin Guide for Specifics)
sntp_server: "217.10.79.4"	; SNTP Server IP Address
sntp_mode: directedbroadcast	; unicast, multicast, anycast, or directedbroadcast (default)
time_zone: CET			; Time Zone Phone is in
dst_offset: 1			; Offset from Phone's time when DST is in effect
dst_start_month: April		; Month in which DST starts
dst_start_day: ""		; Day of month in which DST starts
dst_start_day_of_week: Sun	; Day of week in which DST starts
dst_start_week_of_month: 1	; Week of month in which DST starts
dst_start_time: 02		; Time of day in which DST starts
dst_stop_month: Oct		; Month in which DST stops
dst_stop_day: ""		; Day of month in which DST stops
dst_stop_day_of_week: Sunday	; Day of week in which DST stops
dst_stop_week_of_month: 8	; Week of month in which DST stops 8=last week of month
dst_stop_time: 2		; Time of day in which DST stops
dst_auto_adjust: 1		; Enable(1-Default)/Disable(0) DST automatic adjustment
time_format_24hr: 1		; Enable(1 - 24Hr Default)/Disable(0 - 12Hr)
# Do Not Disturb Control (0-off, 1-on, 2-off with no user control, 3-on with no user control)
dnd_control: 0			; Default 0 (Do Not Disturb feature is off)
# Caller ID Blocking (0-disbaled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
callerid_blocking: 0		; Default 0 (Disable sending all calls as anonymous)
# Anonymous Call Blocking (0-disabled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
anonymous_call_block: 0		; Default 0 (Disable blocking of anonymous calls)
# DTMF AVT Payload (Dynamic payload range for AVT tones - 96-127)
dtmf_avt_payload: 101		; Default 101
# Sync value of the phone used for remote reset
sync: 1				; Default 1
####### New Parameters added in Release 2.1 #######
# Backup Proxy Support
proxy_backup: "217.10.79.9"		; Dotted IP of Backup Proxy
proxy_backup_port: 5060		; Backup Proxy port (default is 5060)
# Emergency Proxy Support
proxy_emergency: "" 		; Dotted IP of Emergency Proxy
proxy_emergency_port: 5060	; Emergency Proxy port (default is 5060)
# Configurable VAD option
enable_vad: 0			; VAD setting 0-disable (Default), 1-enable
####### New Parameters added in Release 2.2 ######
# NAT/Firewall Traversal
nat_enable: 1                   ; 0-Disabled (default), 1-Enabled
nat_address: ""	; WAN IP address of NAT box (dotted IP or DNS A record only)
voip_control_port: 5060      	; UDP port used for SIP messages (default - 5060)
start_media_port: 16384 	; Start RTP range for media (default - 16384)
end_media_port: 32766   	; End RTP range for media (default - 32766)
nat_received_processing: 1	; 0-Disabled (default), 1-Enabled
# Outbound Proxy Support
outbound_proxy: "" 	; restricted to dotted IP or DNS A record only
outbound_proxy_port: 5060       ; default is 5060
####### New Parameter added in Release 3.0 #######
# Allow for the bridge on a 3way call to join remaining parties upon hangup
cnf_join_enable : 1		; 0-Disabled, 1-Enabled (default)
####### New Parameters added in Release 3.1 #######
# Allow Transfer to be completed while target phone is still ringing
semi_attended_transfer: 1	; 0-Disabled, 1-Enabled (default)
# Telnet Level (enable or disable the ability to telnet into the phone)
telnet_level: 2			; 0-Disabled (default), 1-Enabled, 2-Privileged
####### New Parameters added in Release 4.0 #######
# XML URLs
services_url: ""		; URL for external Phone Services
directory_url: ""		; URL for external Directory location
logo_url: ""			; URL for branding logo to be used on phone display
# HTTP Proxy Support
http_proxy_addr: ""		; Address of HTTP Proxy server
http_proxy_port: 80		; Port of HTTP Proxy Server (80-default)
# Dynamic DNS/TFTP Support
dyn_dns_addr_1: ""              ; restricted to dotted IP
dyn_dns_addr_2: ""              ; restricted to dotted IP
dyn_tftp_addr: "192.168.0.4"               ; restricted to dotted IP
# Remote Party ID
remote_party_id: 0		; 0-Disabled (default), 1-Enabled
####### New Parameters added in Release 4.4 #######
# Call Hold Ringback (0-off, 1-on, 2-off with no user control, 3-on with no user control)
call_hold_ringback: 0		; Default 0 (Call Hold Ringback feature is off)
####### New Parameters added in Release 6.0 #######
# Dialtone Stutter for MWI
stutter_msg_waiting: 0		; 0-Disabled (default), 1-Enabled
# RTP Call Statistics (SIP BYE/200 OK message exchange)
call_stats: 0			; 0-Disabled (default), 1-Enabled
Die OS79XX.txt:
P0S3-08-2-00
Die XMLDefault.cnf.xml:
<Default>
<callManagerGroup>
    <members>
       <member priority="0">
          <callManager>
             <ports>
                <ethernetPhonePort>2000</ethernetPhonePort>
                <mgcpPorts>
                   <listen>2427</listen>
                   <keepAlive>2428</keepAlive>
                </mgcpPorts>
             </ports>
             <processNodeName></processNodeName>
          </callManager>
       </member>
    </members>
</callManagerGroup>
<loadInformation8 model="IP Phone 7940">P0S3-08-2-00</loadInformation8>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<idleURL></idleURL>
<informationURL></informationURL>
<messagesURL></messagesURL>
<servicesURL></servicesURL>
</Default>
Eigentlich alle Files Standard außer das letzte.
Muss ich eventuell erst auf eine andere Version ziehen?
LG
Werner
edith sagt:
Versionen hab ich nun unter Status ausgelesen:
Anw-Lade-ID:
P00307020400
Boot-Lade-ID:
PC0303010100
Version:
7.2(4.0)
Also gut.
Die CTLSEP0011BB9A110E.tlv benötigst du nicht - ignorieren.
die XMLDefault.cnf.xml sollte wie folgt aussehen:
<Default>
<callManagerGroup>
<members>
<callManager>
<ports>
</ports>
<processNodeName>192.168.1.4</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
<loadInformation6 model="IP Phone 7910"></loadInformation6>
<loadInformation124 model="Addon 7914"></loadInformation124>
<loadInformation9 model="IP Phone 7935"></loadInformation9>
<loadInformation8 model="IP Phone 7940">P003-08-2-00</loadInformation8>
<loadInformation7 model="IP Phone 7960"></loadInformation7>
<loadInformation20000 model="IP Phone 7905"></loadInformation20000>
<loadInformation30008 model="IP Phone 7902"></loadInformation30008>
<loadInformation30007 model="IP Phone 7912"></loadInformation30007>
</Default>
Vielen Dank für Deine Antwort.
Ich habe die Datei angepasst und bei <processNodeName> die Ip von der frischen Asterisk (sample.config) eingetragen.
Das Telefon bootet und meldet sich via skinny an Asterisk an.
Als Firmware läuft noch immer die alte, also es hat kein Update statt gefunden.
/edith sagt:
Hier noch ein Auszug aus dem tftp.log:
[07/12/07 15:05:15] 'CTLSEP0011BB9A110E.tlv' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:15] 'SEP0011BB9A110E.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:15] 'SIP0011BB9A110E.cnf' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:15] Transfer of 'SIP0011BB9A110E.cnf' has successfully completed
[07/12/07 15:05:15] 'SIPDefault.cnf' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:15] Transfer of 'SIPDefault.cnf' has successfully completed
[07/12/07 15:05:36] 'CTLSEP0011BB9A110E.tlv' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:36] 'SEP0011BB9A110E.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:36] 'XMLDefault.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:36] Transfer of 'XMLDefault.cnf.xml' has successfully completed
[07/12/07 15:05:37] 'SEP0011BB9A110E.cnf.xml' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:37] 'RINGLIST.XML' of type 'octet' is requested from 10.1.60.2
[07/12/07 15:05:37] 'DISTINCTIVERINGLIST.XML' of type 'octet' is requested from 10.1.60.2
Die Binarys scheinen nicht einmal angefordert zu werden.
hast du mal die SEP0011BB9A110E.cnf.xml angelegt und mit daten gefüllt?
Nein, ich weiß nicht was da rein soll.
Ah Super, danke Chaos, die Sip Software ist nun drauf, allerdings meldet sich das Phone nicht am Asterisk an.
Ich werd mal Threads durchforsten und wenn ichs nicht finde im Asterisk Forum posten.
Vielen Dank!
du musst authname name usw gleich haben (sorry, weiss jetzt grade nicht wie es in sip richtig heisst).
Wenn Du mit asterisk arbeitest, warum dann nicht mit sccp?
Jop, das wars, danke, hab es in einem Thread gefunden.
Phone meldet sich nun an, kann zwar och nix damit machen, aber ist schonmal ein Anfang, den ich ohne Dich nicht geschafft hätte :)
buggernot123
