a@h läuft nicht mehr hoch
achim22
20 Okt 2005
hallo,
habe mal versuch 2 hfc karten einzubinden, laut anweisung:
http://dondisperato.blogspot.com/
leider startet asterisk jetzt nicht mehr.
---log----------------------------------------------------------------------
Dec 5 16:16:22 WARNING[1515]: Unable to open '/dev/zap/channel': No such device
Dec 5 16:16:22 ERROR[1515]: Unable to open channel 1: No such device
here = 0, tmp->channel = 1, channel = 1
Dec 5 16:16:22 ERROR[1515]: Unable to register channel '1-2'
Dec 5 16:16:22 WARNING[1515]: chan_zap.so: load_module failed, returning -1
Dec 5 16:16:22 VERBOSE[1515]: == Unregistered channel type 'Tor'
Dec 5 16:16:22 VERBOSE[1515]: == Unregistered channel type 'Zap'
Dec 5 16:16:22 WARNING[1515]: Loading module chan_zap.so failed!
hier mal die meine zapata.conf
; Zapata telephony interface
; Configuration file
[trunkgroups]
[channels]
language=de
switchtype = euroisdn
; p2mp TE mode (for connecting ISDN lines in point-to-multipoint mode)
; signalling = bri_cpe_ptmp
; p2p TE mode (for connecting ISDN lines in point-to-point mode)
; p2mp NT mode (for connecting ISDN phones in point-to-multipoint mode)
; signalling = bri_net_ptmp
; p2p NT mode (for connecting an ISDN pbx in point-to-point mode)
pridialplan = dynamic
prilocaldialplan = local
nationalprefix = 0
internationalprefix = 00
overlapdial=yes
usecallerid=yes
hidecallerid=no
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
callreturn=yes
echocancel=yes
echocancelwhenbridged=no
echotraining=no
rxgain=0.0
txgain=0.0
immediate=no
; ptmp NT mode
context = from-internal
group = 0
channel => 1-2
; p2mp TE
; Amts-Leitungen Point-to-multi-point
context = from-pstn
group = 1
channel => 4-5
und die zaptel.conf
# hfc-s pci a span definition
# most of the values should be bogus because we are not really zaptel
loadzone=nl
defaultzone=nl
span=1,1,3,ccs,ami
bchan=1-2
dchan=3
span=2,1,3,ccs,ami
bchan=4-5
dchan=6
weiß nicht mehr weiter :(
gruß
achim
Dasselbe Problem mit A@H 2.2 und Bristuff 030PRE1d
bei mir leider dasselbe. Mein Asterisk läuft nur noch wenn ich die Zeile "channel => 1-2" auskommentiere. Die Fehlermeldung ist ansonsten identisch.
Hast Du eine Lösung gefunden?
Version ?
verratet ihr auch die Version?
A@H 2.2 (*-1.2.1) mit bristuff-030PRE1d
Hallo flydsl,
meine *-Version s.o.
Folgende Fehlermeldung erscheinen beim Start von Asterisk:
Dec 28 21:20:24 VERBOSE[4504] logger.c: == Parsing '/etc/asterisk/agents.conf':
Dec 28 21:20:24 VERBOSE[4504] logger.c: == Parsing '/etc/asterisk/agents.conf': Found
Dec 28 21:20:24 VERBOSE[4504] logger.c: [skipping chan_oss.so]
Dec 28 21:20:24 VERBOSE[4504] logger.c: [chan_zap.so]
Dec 28 21:20:24 VERBOSE[4504] logger.c: [chan_zap.so] => (Zapata Telephony w/PRI)
Dec 28 21:20:24 VERBOSE[4504] logger.c: == Parsing '/etc/asterisk/zapata.conf':
Dec 28 21:20:24 VERBOSE[4504] logger.c: == Parsing '/etc/asterisk/zapata.conf': Found
Dec 28 21:20:24 WARNING[4504] chan_zap.c: Unable to open '/dev/zap/channel': No such file or directory
Dec 28 21:20:24 ERROR[4504] chan_zap.c: Unable to open channel 1: No such file or directory here = 0, tmp->channel = 1, channel = 1
Dec 28 21:20:24 ERROR[4504] chan_zap.c: Unable to register channel '1-2'
Dec 28 21:20:24 WARNING[4504] loader.c: chan_zap.so: load_module failed, returning -1
Dec 28 21:20:24 WARNING[4504] loader.c: Loading module chan_zap.so failed!
Inzwischen läuft Asterisk und auch die ISDN-Karte wird fehlerfrei eingebunden. Vermutliche Lösung:
Ich habe den System-Service "Zaptel" wieder ausgeschaltet (Ja: Anleitungen lesen; befolgen und auch nichts hinzufügen) und im Kernel ein "make clean" ausgeführt.
Jetzt bekomme ich bei Reboot nur noch die Meldung "zt_receive" nicht bekannt - Kernel tainted. Aber sonst funktioniert die ISDN-Karte und Asterisk.
Die HFC Karten sind wohl noch nicht im NT modus. Überprüft das mal mit zttools.
Wie ich AAH 2.2 mit bristuff und Florz patch versehen habe steht hier:
http://www.mebc.de/bristuffed_aah.htm
Die Kiste läuft inzwischen ohne Abstürze.
VG
Laterunner
mp24
