Ich habe nun schon Tage damit verbracht hier im Forum zu suchen und über die HFC-Karte rauszutelefonieren. Eingehende Anrufe funktioniert einwandfrei. Beim raustelefonieren kommt nur kurz Die gewählte Nummer ist nicht vergeben... und dann Target busy.
Hier meine zaptel.conf:
Hier meine zapata.conf:
zapata_additional.conf:
extensions_additional.conf
Es wäre super wenn jemand helfen könnte.
Gruss
hrvill
loadzone = nl
defaultzone = nl
span=1,1,3,ccs,ami
bchan=1-2
dchan=3
; Zapata telephony interface
; Configuration file
;[trunkgroups]
[channels]
language=de
switchtype = euroisdn
context=from-pstn
signalling=bri_cpe_ptmp
channel => 1-2
pridialplan=local
prilocaldialpla=local
rxwink=300 ; Atlas seems to use long (250ms) winks
; Whether or not to do distinctive ring detection on FXO lines
;usedistinctiveringdetection=yes
usecallerid=yes
hidecallerid=no
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
callreturn=yes
echocancel=yes
echocancelwhenbridged=yes
echotraining=800
rxgain=0.0
txgain=0.0
nationalprefix=0
internationalprefix=00
group=0
callgroup=1
pickupgroup=1
immediate=yes
;faxdetect=both
faxdetect=incoming
;faxdetect=outgoing
;faxdetect=no
;Include genzaptelconf configs
#include zapata-auto.conf
;Include AMP configs
#include zapata_additional.conf
;;;;;;[407128]
record_out=Always
record_in=Always
mailbox=407128@device
echotraining=800
echocancel=yes
context=from-pstn
callprogress=no
callerid=device <407128>
busydetect=no
busycount=7
channel=>1-2
[globals]
#include globals_custom.conf
VM_PREFIX = *
RINGTIMER = 15
REGTIME = 7:55-17:05
REGDAYS = mon-fri
RECORDEXTEN = ""
PARKNOTIFY = SIP/200
OUT_1 = ZAP/g0
OUTPREFIX_1 = 0
OUTMAXCHANS_1 = 2
OUTCID_1 = 407128
OPERATOR =
NULL = ""
IN_OVERRIDE = none
INCOMING = EXT-100
FAX_RX_EMAIL = [email protected]
FAX_RX = system
FAX =
DIRECTORY_OPTS =
DIRECTORY = last
DIAL_OUT = 9
DIAL_OPTIONS = tr
DIALOUTIDS = 1/
CALLFILENAME = ""
AFTER_INCOMING = EXT-100
[ext-local]
include => ext-local-custom
exten => 100,1,Macro(exten-vm,100,100)
exten => ${VM_PREFIX}100,1,Macro(vm,100)
exten => 100,hint,SIP/100
exten => 101,1,Macro(exten-vm,101,101)
exten => ${VM_PREFIX}101,1,Macro(vm,101)
exten => 101,hint,SIP/101
exten => 102,1,Macro(exten-vm,102,102)
exten => ${VM_PREFIX}102,1,Macro(vm,102)
exten => 102,hint,SIP/102
exten => 407128,1,Macro(exten-vm,novm,407128)
exten => 407128,hint,ZAP/g0/
[outbound-allroutes]
include => outbound-allroutes-custom
include => outrt-001-9_outside
[outrt-001-9_outside]
include => outrt-001-9_outside-custom
exten => _9.,1,Macro(dialout-trunk,1,${EXTEN:1},)
exten => _9.,2,Macro(outisbusy) ; No available circuits
Gruss
hrvill
