I'd like to add the following to the freetz kernel modules configuration
routine. Dependencies for sr_mod and ext2 have been fixed.
And these aren't compiled in yet
Index: kernel/Config.in
--- kernel/Config.in (revision 2110)
+++ kernel/Config.in (working copy)
@@ -45,7 +45,6 @@
config FREETZ_MODULE_cdrom
bool "cdrom.ko"
default n
config FREETZ_MODULE_capiconn
bool "capiconn.ko"
@@ -101,6 +100,7 @@
config FREETZ_MODULE_sr_mod
bool "sr_mod.ko"
select FREETZ_MODULE_scsi_mod
+ select FREETZ_MODULE_cdrom
default n
config FREETZ_MODULE_slhc
@@ -186,6 +186,7 @@
config FREETZ_MODULE_ext2
bool "ext2.ko"
+ select FREETZ_MODULE_mbcache
default n
config FREETZ_MODULE_fat
@@ -229,6 +230,10 @@
select FREETZ_MODULE_lockd
default n
+config FREETZ_MODULE_udf
+ bool "udf.ko"
+ default n
config FREETZ_MODULE_nls_cp437
bool "nls_cp437.ko"
default n
@@ -245,6 +250,10 @@
bool "nls_iso8859-1.ko"
default n
+config FREETZ_MODULE_nls_utf8
+ bool "nls_utf8.ko"
+ default n
config FREETZ_MODULE_ntfs
bool "ntfs.ko"
default n
Index: make/linux/Config.ur8-8mb_26.7270
--- make/linux/Config.ur8-8mb_26.7270 (revision 2110)
+++ make/linux/Config.ur8-8mb_26.7270 (working copy)
@@ -1320,7 +1320,7 @@
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
# CONFIG_ZISOFS is not set
-# CONFIG_UDF_FS is not set
+CONFIG_UDF_FS=m
# DOS/FAT/NT Filesystems
@@ -1472,7 +1472,7 @@
CONFIG_NLS_ISO8859_15=m
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
-# CONFIG_NLS_UTF8 is not set
+CONFIG_NLS_UTF8=m
# Profiling support
