Anklopfen scheint nicht zu funktionieren
huri2khan
23 Nov 2005
im Handbuch ist es wie folgt beschrieben...:
Handbuch schrieb:
The voice path is (7)(6)(4)(2)(1). This feature is enabled by setting <PSTN Ring Thru Line 1> to “yes”. If enabled, all incoming PSTN calls will ring the Line 1 phone regardless the VoIP gateway function is enabled on the SPA or not. Hence the same phone can be used to receive calls from Line 1 VoIP and from the PSTN. If Line 1 is already engaged in another VoIP call at the moment the PSTN line rings, the SPA presents the PSTN call alert signal to the user by playing a call-waiting tone, and the user can then switch between the PSTN call and the VoIP call by hook-flashing (as she normally would with 2 VoIP calls).
SPA implements the ring-thru feature by making an internal VoIP call from the VoIP2 interface to the VoIP1 interface. A by-product of this approach is that the call forwarding and distinctive ringing settings on Line 1 also apply to the PSTN call ringing thru Line 1. Ring thru stops as soon as the VoIP gateway auto-answers the PSTN call, or the VoIP1 interface returns a busy signal to VoIP2.
Nun hab ich es ausprobiert. Per VOIP telefoniert - und mich per Handy auf meinem PSTN angerufen. Aber am Telefon kam kein TON während des Gespräches an, so dass ich nicht "wußte" dass mich einer auf der anderen Leitung anruft.
Hab ich außer dem <PSTN Ring Thru Line 1> to “yes” noch was übersehen, damit das funktioniert?
---EDIT---
Weiteres Blättern im Handbuch brachte mich zu der Stelle
Handbuch schrieb:
b) Line 1 busy at the time the PSTN rings
If Line 1 is busy when the PSTN line rings, the SPA will not attempt to ring through, even if Line 1 later becomes idle while the PSTN is still ringing.
c) Line 1 connected on a VoIP call (via the VoIP1 interface) at the time the PSTN rings
When the PSTN line rings, the SPA plays Call Waiting Tone to alert the Line 1 user and shows callwaiting Caller-ID to the Line 1 phone. The user can switch between the VoIP call and the PSTN call by hook-flashing the phone.
WAS genau ist denn nun der Unterschied zwischen b) und c) mit busy?
Wenn ich über VOIP1 eine Festnetznummer anrufe (und damit bei mir besetzt ist) ist das nur Fall b)? Nach dem wie ich das im Handbuch verstanden habe, ist Fall c) nur dann, wenn ich eine IP angewählt habe - oder?
Mann, dass ist echt nicht einfach...
Ebenso hab ich es noch immer nicht hinbekommen die Examples im Handbuch durchzuspielen. Ich kann mich auf dem PSTN von extern anrufen und es klingelt. Aber der SPA macht kein auto-answer und läßt mich dann die PIN eingeben, damit ich ein VOIP Anruf machen kann, obwohl die Funktion aktiviert ist, die Answer-delay Zeit äußerst kurz ist (10s) und die AUTH auf Pin gesetzt ist (Pin ist definiert, DP ist None)
Ich habe exakt das eingestellt was im Handbuch zu den Beispielen steht, aber es geht nicht :-(
Wie macht ihr das denn? Also von Extern auf PSTN->VOIP ?
---EDIT OUT---
chirri
