ar7.cfg defekt
erikdvorsky
9 Jul 2005
BusyBox v1.00-pre3 (2005.11.04-09:38+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
HWRevision='77'
ANNEX='B'
OEM='avm'
Language='en'
Country='99'
TZ='CET-1CEST,M3.5.0,M10.5.0'
CONFIG_AB_COUNT='3'
CONFIG_ANNEX='A'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BLUETOOTH='n'
CONFIG_BLUETOOTH_CTP='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='y'
CONFIG_CAPI_MIPS='n'
CONFIG_CAPI_UBIK='y'
CONFIG_CAPI_XILINX='n'
CONFIG_CDROM='y'
CONFIG_CDROM_FALLBACK='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ENVIRONMENT_PATH='/proc/sys/dev/adam2'
CONFIG_ETH_COUNT='2'
CONFIG_FIRMWARE_URL='http://www.avm.de/fritzbox-firmware-update.php?hardware=77&oem=avm&language=en&country='
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_HOSTNAME='fritz.fonwlan.box'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_wlan_50494'
CONFIG_NFS='n'
CONFIG_OEM_DEFAULT='avm'
CONFIG_PRODUKT='Fritz_Box_7050'
CONFIG_PRODUKT_NAME='FRITZ!Box Fon WLAN 7050 Annex A'
CONFIG_RAMSIZE='32'
CONFIG_ROMSIZE='4'
CONFIG_SERVICEPORTAL_URL='http://www.avm.de/fritzbox-service-portal.php?hardware=77&oem=avm&language=en&country='
CONFIG_STOREUSRCFG='y'
CONFIG_SUBVERSION=''
CONFIG_UBIK2='y'
CONFIG_USB='y'
CONFIG_USB_HOST_AVM='n'
CONFIG_USB_HOST_TI='n'
CONFIG_USB_PRINT_SERV='n'
CONFIG_USB_STORAGE='n'
CONFIG_USB_WLAN_AUTH='n'
CONFIG_VERSION='03.91'
CONFIG_VERSION_MAJOR='14'
CONFIG_VLYNQ0='1'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
ermittle die aktuelle TTY
tty is "/dev/tts/0"
Serielles Terminal
# reboot
# system is going down ..
[sys_reboot]: cmd=0x89abcdef
The system is going down NOW !!
Sending SIGTERM to all proceskcapi: appl 3 down
ses.
kcapi: appl 1 down
kcapi: recv_handler: applid 1 ? (MANUFACTURER_CONF          ID=001 #0x0000 LEN=0025
  Controller/PLCI/NCCI            = 0x2
  ManuID                          = 0x214d5641
  Class                           = 0x0
  Function                        = 0x8001
  ManuData                        = default
kcapi: appl 2 down
Sending SIGKILL
Please stand by while rebooting the system.
[sys_reboot]: cmd=0x1234567
Restarting system.
ADAM2 Revision TI:0.18.01 AVM: Version:97
(C) Copyright 1996-2003 Texas Instruments Inc. All Rights Reserved.
(C) Copyright 2003 Telogy Networks, Inc.
(C) Copyright 2003-2004 AVM
AVM_Ar7 >
Press any key to abort OS load, or wait 5 seconds for OS to boot...
-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|Launching kernel decompressor.
Kernel decompressor was successful ... launching kernel.
LINUX started...
Config serial console: ttyS0,38400
prom_init: local_env_buffer 930 used (max 2048)
CPU revision is: 00018448
Primary instruction cache 16kb, linesize 16 bytes (4 ways)
Primary data cache 16kb, linesize 16 bytes (4 ways)
Number of TLB entries 16.
Linux version 2.4.17_mvl21-malta-mips_fp_le (jpluschke@EmbeddedVM) (gcc version 3.3.2) #893-4 Fri Nov 18 18:09:45 CET 2005
Reset Status: SW reset 1
DEBUG: Bring MDIO out of reset.
Determined physical RAM map:
 memory: 14000000 @ 00000000 (reserved)
 memory: 00020000 @ 14000000 (ROM data)
 memory: 01fe0000 @ 14020000 (usable)
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line:
calculating r4koff... 000b71b0(750000)
CPU frequency 150.00 MHz
Calibrating delay loop... 149.91 BogoMIPS
Freeing Adam2 reserved memory [0x14001000,0x0001f000]
Memory: 30752k/32768k available (1241k kernel code, 2016k reserved, 75k data, 44k init)
Dentry-cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode-cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Checking for 'wait' instruction...  available.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Disabling the Out Of Memory Killer
devfs: v1.7 (20011216) Richard Gooch ([email protected])
devfs: boot_options: 0x1
Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher
pty: 32 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with no serial options enabled
ttyS00 at 0xa8610e00 (irq = 15) is a 16550A
block: 64 slots per queue, batch=16
Universal TUN/TAP device driver 1.4 (C)1999-2001 Maxim Krasnyansky
resize flash to 0x400000 Bytes
avalanche flash device: 0x400000 at 0x10000000.
 Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Physically mapped flash:0: Swapping erase regions for broken CFI table.
number of CFI chips: 1
Looking for mtd device :mtd0:
Found a mtd0 image (0xc0000), with size (0x300000).
Creating 1 MTD partitions on "Physically mapped flash:0":
0x000c0000-0x003c0000 : "mtd0"
Looking for mtd device :mtd1:
locking for hidden SquashFs image (0x90010000 - 0x900c0000)
hidden SquashFs image found at 0xb009d000
add to memory config: hidden squashfs 0x9009d000-0x900c0000
Found a mtd1 image (0x10000), with size (0xb0000).
0x00010000-0x000c0000 : "mtd1"
Looking for mtd device :mtd2:
Found a mtd2 image (0x0), with size (0x10000).
0x00000000-0x00010000 : "mtd2"
Looking for mtd device :mtd3:
Found a mtd3 image (0x3c0000), with size (0x20000).
0x003c0000-0x003e0000 : "mtd3"
Looking for mtd device :mtd4:
Found a mtd4 image (0x3e0000), with size (0x20000).
0x003e0000-0x00400000 : "mtd4"
Found a mtd5 image (0x9d000), with size (0x23000).
0x0009d000-0x000c0000 : "mtd5"
mtd: partition "mtd5" doesn't start on an erase block boundary -- force read-only
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
      mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
Initializing the WAN Bridge.
Please set the MAC Address for the WAN Bridge.
Set the Environment variable 'wan_br_mac'.
MAC Address should be in the following format: xx.xx.xx.xx.xx.xx
802.1Q VLAN Support v1.6  Ben Greear <[email protected]>
vlan Initialization complete.
VFS: Mounted root (squashfs filesystem) readonly.
root device=/dev/mtdblock/0
Mounted devfs on /dev
Freeing unused kernel memory: 44k freed
[sys_reboot]: cmd=0x0
init started:  BusyBox v1.00-pre3 (2005.11.04-09:38+0000) multi-call binary
Algorithmics/MIPS FPU Emulator v1.5
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avm.o
Warning: loading avm will taint the kernel: non-GPL license -
(C) Copyright 20AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: Nov 18 2005 18:11:22)
03, Texas Instruments, Inc
(C) Copyright 2004, 2005, AVM
  See [URL="http://www.tux.org/lkml/#export-tainted"]http://www.tux.org/lkml/#export-tainted[/URL] for information about tainted modules
c002f000 __insmod_avm_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avm.o_M43833CA2_V-1    [avm]
c002f060 __insmod_avm_S.text_L28992    [avm]
c00361c0 __insmod_avm_S.rodata_L3952    [avm]
c0037420 __insmod_avm_S.data_L416    [avm]
AR7WDT: System Init UEberwachung 120 Sekunden
**** adam2 environment ****
HWRevision    77
ProductID    Fritz_Box_7050_AnnexA
SerialNumber    0000000000000000
annex    B
autoload    yes
bootloaderVersion    0.18.01
bootserport    tty0
bluetooth    00:04:0E:FF:FF:07
cpufrequency    150000000
firstfreeaddress    0x94730258
firmware_version    avm
firmware_info    14.03.91
flashsize    0x00400000
maca    00:15:0C:83:1E:CE
macb    00:15:0C:83:1E:CF
macwlan    00:15:0C:83:1E:D0
macdsl    00:15:0C:83:1E:D1
memsize    0x02000000
modetty0    38400,n,8,1,hw
modetty1    38400,n,8,1,hw
mtd0    0x900C0000,0x903C0000
mtd1    0x90010000,0x900C0000
mtd2    0x90000000,0x90010000
mtd3    0x903C0000,0x903E0000
mtd4    0x903E0000,0x90400000
my_ipaddress    192.168.178.2
prompt    AVM_Ar7
ptest
reserved    00:04:0E:FF:FF:00
req_fullrate_freq    125000000
sysfrequency    125000000
urlader-version    97
usb_board_mac    00:15:0C:83:1E:D2
usb_rndis_mac    00:15:0C:83:1E:D3
usb_device_id    0x4201
usb_revision_id    0x0200
usb_device_name    USB DSL Device
usb_manufacturer_name    AVM
wlan_key    30343436313035383631313939
HWRevision='77'
ANNEX='B'
OEM='avm'
Language='en'
Country='99'
CONFIG_AB_COUNT='3'
CONFIG_ANNEX='A'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='y'
CONFIG_CDROM='y'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_I2C='n'
CONFIG_NFS='n'
CONFIG_RAMSIZE='32'
CONFIG_ROMSIZE='4'
CONFIG_UBIK2='y'
CONFIG_USB='y'
CONFIG_VLYNQ0='1'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
set 'Activate Wizzard'
ln -s /etc/default.99/fx_moh.default /var/fx_moh
checkempty: : No such file or directory
checkempty: warning, /var/flash/ar7.cfg not found - nop
checkempty: warning, /var/flash/voip.cfg not found - nop
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_cpmac.o
Warning: loading avalanche_cpmac will taint the kernel: non-GPL license -
(C) Copyright 2003, Texas Instruments, Inc
(C) Copyright 2004, AVM
cpmac .bss-address: 0xc004f92c (&cpmac_cpu_freq - 0x4)
 eth0 irq= 0 io=a8610000
 eth1 irq= 0 io=a8612800
Installed 2 cpmac instances.
c003c060 __insmod_avalanche_cpmac_S.text_L63488    [avalanche_cpmac]
c004b880 __insmod_avalanche_cpmac_S.rodata_L13200    [avalanche_cpmac]
c004ec10 __insmod_avalanche_cpmac_S.data_L1104    [avalanche_cpmac]
c003c000 __insmod_avalanche_cpmac_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_cpmac.o_M43833CA3_V-1    [avalanche_cpmac]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_vlynq.o
Warning: loadivlynq_dev_init: 1/2 VLYNQs, mask 0x0001
ng avalanche_vlyGPIO pin reset, bit 6
nq will taint thSetup registers for VLYNQ0
e kernel: non-GPSet local_mem.RxSize to 0x2000000
L license - (C) VLYNQ_TXMAP_REG = 4000000
Copyright 2003, VLYNQ_R_RXMAP_OFFSET_REG(map=1) = c0000000
Texas InstrumentVLYNQ_R_RXMAP_SIZE_REG(map=1) = 40000
s, Inc
(C) CopyVLYNQ_R_RXMAP_OFFSET_REG(map=2) = f0000000
right 2004, AVM
VLYNQ_R_RXMAP_SIZE_REG(map=2) = 22000
  See [URL="http://wwVLYNQ_R_TXMAP_REG"]http://wwVLYNQ_R_TXMAP_REG[/URL] = 0
w.tux.org/lkml/#VLYNQ_RXMAP_OFFSET_REG(map=1) = 14000000
export-tainted fVLYNQ_RXMAP_SIZE_REG(map=1) = 2000000
or information aVLYNQ_REV_REG = 1010b
bout tainted modVLYNQ0: init succeeded!
ules
vlynq init done
VLYNQ0: Misc device vlynq0 registered, minor #63. (0)
VLYNQ0: Running on IRQ 29.
VLYNQ1: Misc device vlynq1 registered, minor #62. (0)
VLYNQ1: Init failed!
c0053000 __insmod_avalanche_vlynq_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_vlynq.o_M43833CA3_V-1    [avalanche_vlynq]
c0053060 __insmod_avalanche_vlynq_S.text_L7856    [avalanche_vlynq]
c0054f30 __insmod_avalanche_vlynq_S.rodata_L2064    [avalanche_vlynq]
c0055a30 __insmod_avalanche_vlynq_S.data_L1168    [avalanche_vlynq]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_usb.o
Warning: loading avalanche_usb will taint the kernel: non-GPL license - ProprietAVM netusb, revision 02.01.06
ary
  See http:
//www.tux.org/lkInitializing USB CDC/CDROM driver (starting in CDC mode)...
ml/#export-taint
ed for informatinetusb: device_id=0x4201 , revision_id=0x0200
Loaded.
c0058000 __insmod_avalanche_usb_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_usb.o_M43833CA3_V-1    [avalanche_usb]
c0058060 __insmod_avalanche_usb_S.text_L29488    [avalanche_usb]
c005f3b0 __insmod_avalanche_usb_S.rodata_L2656    [avalanche_usb]
c005fe10 __insmod_avalanche_usb_S.data_L2912    [avalanche_usb]
usb: CDROM Fallback=n ISO=/lib/modules/cdrom.iso
attempting to load DSL Firmware '/lib/modules/ubik/ubik2-dsl.bin'
**** ANNEX: 'B'
setting DSL Firmware to Annex B
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/atm/tiatm.o
Warning: loading tiatm will taint the kernel: non-GPL license -
  See hregistered device TI Avalanche SAR
ttp://www.tux.ortiatm driver (patch_annex=0xc00772a0)
g/lkml/#export-tSangam detected
ainted for information about tainted modules
PM_STATUS2(before switch on) = 0x03
12 Volt:up korrekt 1.5 Volt: up korrekt Fuse Mode is disabled
PM_STATUS2(after switch on) = 0x03
power up success !
#### DSP Core voltage set to 1,5 V ####
DSP binary filesize = 272804 bytes
avm event register
Texas Instruments ATM driver: version:[4.06.04.08]
c0063000 __insmod_tiatm_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/atm/tiatm.o_M43833CA3_V-1    [tiatm]
c0063060 __insmod_tiatm_S.text_L67968    [tiatm]
c0073a00 __insmod_tiatm_S.rodata_L7200    [tiatm]
c0075890 __insmod_tiatm_S.data_L6672    [tiatm]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/ubik2.o
Warning: loading ubik2 will taint the kernel: non-GPL license -
ubik2 driver (ubik2 - 0x10=0xc00877e0)
  See [URL="http://atm_dsp_register_ubik2:"]http://atm_dsp_register_ubik2:[/URL] ubik2_ToMIPS_notify=0xc007ca7c
[URL="http://www.tux.org/lkmlatm_dsp_register_ubik2:"]www.tux.org/lkmlatm_dsp_register_ubik2:[/URL] dsp mem pointer 0xa100e494
/#export-tainted[status_dsp_activate]
 for informationubik2_init_interface: Default Queue DataSize: 256
[status_dsp_reactivate]
c007c000 __insmod_ubik2_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/ubik2.o_M43833CA3_V-1    [ubik2]
c007c060 __insmod_ubik2_S.text_L36176    [ubik2]
c0084dd0 __insmod_ubik2_S.rodata_L9696    [ubik2]
c0087600 __insmod_ubik2_S.data_L464    [ubik2]
download /lib/modules/ubik/boot-ubik2-sport.lod to /dev/ubik_boot_0 ...
[status_boot_0_done]
ubik2.boot_state = ubik2_boot_phase_0_done
boot result phasubik2_commit: no buffer to free
e 0: ubik2_boot_phase_0_done
no boot file for boot phase 1 (continue)
no boot file for boot phase 2 (continue)
download /lib/modules/ubik/ubik2-firmware.lod to /dev/ubik_boot_last ...
[status_boot_3_done]
ubik2.boot_state = ubik2_boot_phase_last
e 3: ubik2_boot_phase_runone
UBIK booted (Time:1961 ms Sent=105 kByte 431 Kbit/s)!
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capifs.o
capifs: Rev 1.1.4.1
c009f000 __insmod_capifs_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capifs.o_M43833CA2_V-1    [capifs]
c009f060 __insmod_capifs_S.text_L3632    [capifs]
c009feb0 __insmod_capifs_S.rodata_L224    [capifs]
c00a00b0 __insmod_capifs_S.data_L272    [capifs]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capiutil.o
c00a2000 __insmod_capiutil_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capiutil.o_M43833CA2_V-1    [capiutil]
c00a2060 __insmod_capiutil_S.text_L3888    [capiutil]
c00a2fb0 __insmod_capiutil_S.rodata_L1920    [capiutil]
c00a38f0 __insmod_capiutil_S.data_L1216    [capiutil]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/kernelcapi.o
CAPI-driver Rev 1.1.4.1: loaded
c00a7000 __insmod_kernelcapi_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/kernelcapi.o_M43833CA2_V-1    [kernelcapi]
c00a7060 __insmod_kernelcapi_S.text_L15968    [kernelcapi]
c00aaee0 __insmod_kernelcapi_S.rodata_L2288    [kernelcapi]
c00ab950 __insmod_kernelcapi_S.data_L304    [kernelcapi]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capi.o
capi20: started up with major 68
kcapi: capi20 attached
capi20: Rev 1.1.4.2: started up with major 68 (middleware+capifs)
c00b5960 __insmod_capi_S.rodata_L1104    [capi]
c00b1060 __insmod_capi_S.text_L18656    [capi]
c00b1000 __insmod_capi_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capi.o_M43833CA2_V-1    [capi]
c00b5db0 __insmod_capi_S.data_L224    [capi]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/isdn_fon2/isdn_fbox.o
Warning: loading isdn_fbox will taint the kernel: non-GPL license - Proprietary
isdn_fbox: AVM F!Box driver, revision  1.7  #852
isdn_fbox: (isdn_fbox built on Nov 18 2005 at 18:11:44)
isdn_fbox: Loading...
isdn_fbox: Driver 'isdn_fbox' attached to stack
kcapi: driver isdn_fbox attached
isdn_fbox: Auto-attaching with io 0x0, irq 0...
[ubik2_ll_control_tasklet] start
isdn_fbox: Stack version 3.11-07
kcapi: Controller 1: fritz-ar7 attached
kcapi: Controller 2: fritz-ar7 attached
kcapi: Controller 3: fritz-ar7 attached
kcapi: Controller 4: fritz-ar7 attached
kcapi: Controller 5: fritz-ar7 attached
kcapi: card 1 "fritz-ar7" ready.
kcapi: card 2 "fritz-ar7" ready.
kcapi: notify up contr 1
capi: controller 1 up
kcapi: card 3 "fritz-ar7" ready.
kcapi: notify up contr 2
capi: controller 2 up
kcapi: card 4 "fritz-ar7" ready.
kcapi: notify up contr 3
capi: controller 3 up
kcapi: card 5 "fritz-ar7" ready.
kcapi: notify up contr 4
capi: controller 4 up
isdn_fbox: Loaded.
kcapi: notify up contr 5
capi: controller 5 up
c00b8000 __insmod_isdn_fbox_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/isdn_fon2/isdn_fbox.o_M43833CA2_V-1    [isdn_fbox]
c00b8060 __insmod_isdn_fbox_S.text_L349984    [isdn_fbox]
c010d7a0 __insmod_isdn_fbox_S.rodata_L16400    [isdn_fbox]
c01117b0 __insmod_isdn_fbox_S.data_L8112    [isdn_fbox]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/dsld/kdsldmod.o
Warning: loading kdsldmod will taint the kernel: no license
kdsldmod: init start
kdsld: cache_create(datapipe)
kdsld: cache_create(datapipe_mod)
kdsld: cache_create(ipaccessset)
kdsld: cache_create(ipaccessrule)
kdsld: cache_create(ipfragid)
kdsld: cache_create(ipmasqentry)
kdsld: cache_create(ipmasqfwinfo)
kdsld: cache_create(ipmasqigdpm)
kdsld: cache_create(ipmasqappldata)
kdsld: cache_create(dnsmasqentry)
kdsld: cache_create(dnsstaticentry)
kdsld: cache_create(pingerentry)
kdsld: cache_create(pingerwaiter)
kdsld: cache_create(iprouteset)
kdsld: DATAPIPE: with header optimization
kdsld_thread: start
kdsld: PPP led: off (value=0)
kdsldmod: init done
c0186000 __insmod_kdsldmod_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/dsld/kdsldmod.o_M43833CA2_V-1    [kdsldmod]
c0186060 __insmod_kdsldmod_S.text_L351504    [kdsldmod]
c01dbd90 __insmod_kdsldmod_S.rodata_L28320    [kdsldmod]
c01e2c50 __insmod_kdsldmod_S.data_L56688    [kdsldmod]
2002-09-08 14:00:23 cltmgr: csock: using poll
Sep  8 14:00:23 cltmgr[318]: csock: using poll
2002-09-08 14:00:23 cltmgr: process priority is 19
Sep  8 14:00:23 cltmgr[318]: process priority is 19
Sep  8 14:00:23 cltmgr[324]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep  8 14:00:23 cltmgr[324]: load_config(ar7): open problem - factory default loaded
Sep  8 14:00:23 cltmgr[324]: EVENT(60): ?60?
2002-09-08 14:00:23 wlancfgctl: FactoryDefault=/etc/default/avm/wlan.cfg (wlan)
Sep  8 14:00:23 wlancfgctl[325]: FactoryDefault=/etc/default/avm/wlan.cfg (wlan)
2002-09-08 14:00:23 wlancfgctl: load_config(wlan): open problem - factory default loaded
Sep  8 14:00:23 wlancfgctl[325]: load_config(wlan): open problem - factory default loaded
2002-09-08 14:00:23 wlancfgctl: EVENT(60): ?60?
Sep  8 14:00:23 wlancfgctl[325]: EVENT(60): ?60?
Sep  8 14:00:23 cltmgr[324]: load_ar7_config failed with -1
MAC WLAN:     00:15:0C:83:1E:D0
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/wlan/tiap.o
Warning: loading tiap will taint the kernel: non-GPL license -
(C) Copyright 2003, 2004, Texas Instruments, Inc
(C) Copyright 2005, AVM
2002-09-08 14:00:26 unknown: FactoryDefault=/etc/default/avm/wlan.cfg (wlan)
Sep  8 14:00:26 unknown[344]: FactoryDefault=/etc/default/avm/wlan.cfg (wlan)
2002-09-08 14:00:26 unknown: load_config(wlan): open problem - factory default loaded
Sep  8 14:00:26 unknown[344]: load_config(wlan): open problem - factory default loaded
2002-09-08 14:00:26 unknown: EVENT(60): ?60?
Sep  8 14:00:26 unknown[344]: EVENT(60): ?60?
WSTART (Nov 18 2005 10:30:32)Wstart - ERROR: load_wlan_config failed
WSTART: done(-6)
2002-09-08 14:00:27 cltmgr: not running
Sep  8 14:00:27 cltmgr[346]: not running
2002-09-08 14:00:28 cltmgr: csock: using poll
Sep  8 14:00:28 cltmgr[348]: csock: using poll
2002-09-08 14:00:28 cltmgr: process priority is 19
Sep  8 14:00:28 cltmgr[348]: process priority is 19
WLAN is enabled
tiwlan0 device is activated
Sep  8 14:00:29 cltmgr[352]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep  8 14:00:29 cltmgr[352]: load_config(ar7): open problem - factory default loaded
Sep  8 14:00:29 cltmgr[352]: EVENT(60): ?60?
Sep  8 14:00:29 cltmgr[352]: load_ar7_config failed with -1
Sep  8 14:00:29 websrv[358]: csock: using poll
Sep  8 14:00:29 igdd[363]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep  8 14:00:29 igdd[363]: load_config(ar7): open problem - factory default loaded
Sep  8 14:00:29 igdd[363]: EVENT(60): ?60?
Sep  8 14:00:29 igdd[363]: csock_exit called
Sep  8 14:00:29 igdd[363]: exit: 0 entries freed
Sep  8 14:00:29 igdd[363]: exit: 0 used and 0 free entries
Sep  8 14:00:29 websrv[358]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep  8 14:00:29 websrv[358]: load_config(ar7): open problem - factory default loaded
Sep  8 14:00:29 websrv[358]: EVENT(60): ?60?
Sep  8 14:00:29 websrv[358]: load_websrv_config failed
Sep  8 14:00:29 websrv[358]: exit: 0 entries freed
2002-09-08 14:00:30 multid: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep  8 14:00:30 multid[366]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
2002-09-08 14:00:30 multid: load_config(ar7): open problem - factory default loaded
Sep  8 14:00:30 multid[366]: load_config(ar7): open problem - factory default loaded
2002-09-08 14:00:30 multid: EVENT(60): ?60?
Sep  8 14:00:30 multid[366]: EVENT(60): ?60?
DEBUG 2002-09-08 14:00:30 multid: csock_exit called
Sep  8 14:00:30 multid[366]: csock_exit called
DEBUG 2002-09-08 14:00:30 multid: exit: 0 entries freed
Sep  8 14:00:30 multid[366]: exit: 0 entries freed
DEBUG 2002-09-08 14:00:30 multid: exit: 0 used and 0 free entries
Sep  8 14:00:30 multid[366]: exit: 0 used and 0 free entries
2002-09-08 14:00:31 dsld: csock: using poll
Sep  8 14:00:31 dsld[370]: csock: using poll
2002-09-08 14:00:31 dsld: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep  8 14:00:31 dsld[370]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
2002-09-08 14:00:31 dsld: load_config(ar7): open problem - factory default loaded
Sep  8 14:00:31 dsld[370]: load_config(ar7): open problem - factory default loaded
2002-09-08 14:00:31 dsld: EVENT(60): ?60?
Sep  8 14:00:31 dsld[370]: EVENT(60): ?60?
kcapi: appl 1 up
kcapi: appl 2 up
kcapi: appl 3 up
voipd: csock: using poll
Sep  8 14:00:32 voipd[394]: FactoryDefault=/etc/default/avm/voip.cfg (voip)
Sep  8 14:00:32 voipd[394]: load_config(voip): open problem - factory default loaded
Sep  8 14:00:32 voipd[394]: EVENT(60): ?60?
Sep  8 14:00:32 voipd[394]: INFO led: off (value=0)
Sep  8 14:00:32 voipd[394]: INTERNET led value = 0
Sep  8 14:00:32 voipd[394]: exit: 0 entries freed
2002-09-08 14:00:32 ar7cfgctl: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep  8 14:00:32 ar7cfgctl[393]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
2002-09-08 14:00:32 ar7cfgctl: load_config(ar7): open problem - factory default loaded
Sep  8 14:00:32 ar7cfgctl[393]: load_config(ar7): open problem - factory default loaded
2002-09-08 14:00:32 ar7cfgctl: EVENT(60): ?60?
Sep  8 14:00:32 ar7cfgctl[393]: EVENT(60): ?60?
run_clock demon started
Please help ar7.cfg
Hello erikdvorsky,
What's yuor problem? Try to say this in the title, "ar7.cfg" isn't ok!
Novize schrieb:
Hello erikdvorsky,
Lan A LanB Kaput hilfe
ar7.cfg defekt
We are able to read! ;-)
You have to tell us some more details?
1. What Box do you have? 7050? Annex A?
2. Have you modified something over telnet?
3. What firmware is on the Box?
Greets, Oliver
Greets, Oliver
Telnet change Annex B
Please help ar7.cfg
We would understand you better if you wrote in your native language, what ever that might be caus English aint work'in
ar7.cfg
Ich habe schlecht ar7.cfg das reparieren wenn auch das sperren recovery Box_Fon_WLAN_7050.AnnexA.en.03.91.recover-image so das immer schreibt
WSTART: done(-6)
Nach meinem Wissen:
Nach einem Recover sollte eine ar7.cfg nicht existieren. ( Oder auch nach einem Werksreset )
=> Wird erstellt bei der ersten echten Änderung.
Die Meldung ist kein Fehler sondern zeigt an, dass die defaultwerte genutzt
werden.
Haveaniceday
King Manaka
