Asterisk 1.0.8/1.0.9 tarball erschienen!
Netview
IPPF-Promi
1 Apr 2004
Wie die Überschrift schon sagt - und läuft bereits ;-)
changelog (neu gegenüber 1.0.7):
Asterisk 1.0.8
 -- chan_zap
    -- Asterisk will now also look in the regular context for the fax extension while
       executing a macro.  Previously, for this to work, the fax extension would have
       to be included in the macro definition.
    -- On some systems, ALERTING will be sent after PROCEEDING, so code has been
       added to account for this case.
    -- If no extension is specified on an overlap call, the 's' extension will be used.
 -- chan_sip
    -- We no longer send a "to" tag on "100 Trying" messages, as it is inappropriate
       to do so.
    -- We now respond correctly to an invite for T.38 with a "488 Not acceptable here"
    -- We now discard saved tags on 401/407 responses in case the provider we're talking
       to tries to pull a dirty trick on us and change it.
    -- rtptimeout options will now be correctly set on a peer basis rather than only global
 -- chan_mgcp
    -- Fixed setting of accountcode
    -- Fixed where *67 to block callerid only worked for first call
 -- chan_agent
    -- We now will not pass audio until the agent has acked the call if the configuration
       is set up for the agent to do so.
 -- chan_alsa
    -- Fixed problems with the unloading of this module
 -- res_agi
    -- A fix has been added to prevent calls from being hung up when more than one
       call is executing an AGI script calling the GET DATA command.
    -- AGI scripts will now continue to run even if a file was not found with the
       GET DATA command.
    -- When calling SAY NUMBER with a number like 09, we will now say "nine" instead
       of "zero"
 -- app_dial
    -- There was a problem where text frames would not be forwarded before the channel
       has been answered.
 -- app_disa
    -- Fixed the timeout used when no password is set
 -- app_queue
    -- Distinctive ring has been fixed to work for queue members
  -- rtp
    -- Fixed a logic error when setting the "rtpchecksums" option
 -- say.c
    -- A problem has been fixed with saying the date in Spanish.
 -- Makefile
    -- A line was missing for the autosupport script that caused "make rpm" to fail
 -- format_wav_gsm
    -- Fixed a problem with wav formatting that prevented files from being played
       in some media players
 -- pbx_spool
    -- Fixed if the last line of text in a file for the call spool did not contain
       a new line, it would not be processed
 -- logger
    -- Fixed the logger so that color escape sequences wouldn't be sent to the logs
 -- format_sln
    -- A lot of changes were made to correctly handle signed linear format on
       big endian machines
 -- asterisk.conf
     -- fix 'highpriority' option for asterisk.conf
Netview schrieb:
Ein weiterer wichtiger Grund um auf 1.0.8 zu wechseln:
http://www.ippf.tk/forum/viewtopic.php?t=19897
Das dachte ich auch. Jetzt habe ich aber ein Problem:
loader.c:258 ast_load_resource: /usr/lib/asterisk/modules/chan_capi.so: undefined symbol: ast_smoother_feed
Was heisst das und wie bekomme ich das weg?
Aufgebaut mit bristuff-0.2.0-RC8h auf Suse 9.2, chan-capi 0.3.5
Hast du die chan_capi neu kompiliert oder nur die module aus der 1.0.7 reinkopiert bzw. waren diese noch vorhanden (und vor dem "make install" ein "make clean" gemacht? ;-) )
Ich war auch etwas bequem und habe die chan-capi aus der 1.0.7 einfach nach 1.0.8 kopieren wollen - Resultat ähnlich wie bei dir!
Nö, warum? Ging doch bisher auch immer ohne.
Danke das wars.
und tarball 1.0.9 ist raus!
changelog:
Asterisk 1.0.9
-- fix bug in callerid matching in the dialplan that was introduced in 1.0.8
Hmm, ein "make update" und auch "cvs update" holen bei mir keine neue pbx_config.c , die ja betroffen war/ist !? Wie hast Du von 1.08 auf 1.09 ge-updated?
Thnx,
Tin
Vielen Dank :)
theyakimchuk
