Asterisk 1.2.5 ist raus
Netview
IPPF-Promi
1 Apr 2004
Änderungen gegenüber 1.2.4 (changelog):
2006-03-03 Kevin P. Fleming <[email protected]>
	* Asterisk 1.2.5 released
2006-03-03 00:38 +0000 [r11607-11635]  Tilghman Lesher <[email protected]>
	* Makefile: Bug 6638 - Use POSIX command for Solaris
	* build_tools/make_build_h: Bug 6638 - Change from a historic BSD
	  command to a POSIX command for determining username
	* asterisk.c: Bug 6637 - Fixes for Solaris
	* Makefile: If debugging, the frame pointer is helpful
2006-03-02 19:05 +0000 [r11528-11561]  Russell Bryant <[email protected]>
	* res/res_monitor.c: fix inaccurate ack message to ChangeMonitor
	  action (issue #6630)
	* asterisk.sgml: make the terminology used in the synopsis match
	  the option description
	* asterisk.sgml: add the -L option to the synopsis on the man page
2006-03-01 17:41 +0000 [r11479-11503]  Tilghman Lesher <[email protected]>
	* cdr/cdr_manager.c, cdr/cdr_tds.c, res/res_config_odbc.c,
	  include/asterisk/cdr.h, cdr/cdr_pgsql.c, cdr/cdr_odbc.c, cdr.c:
	  Bug 6615 - Fix 64bit conversion errors by using a long int
	* build_tools/make_svn_branch_name: Bug 6618 - Solaris
	  compatibility fix
2006-02-28 19:46 +0000 [r11382-11410]  Russell Bryant <[email protected]>
	* channels/chan_iax2.c: fix the output that indicates whether
	  qualify smoothing is on or not (issue #6608)
	* asterisk.c: adjust the keys directory when astvarlibdir is
	  specified in asterisk.conf (issue #6602)
	* res/res_agi.c: add a missing newline in the agi app description
	  (thanks wunderkin!)
2006-02-27 15:20 +0000 [r11250-11281]  Russell Bryant <[email protected]>
	* cli.c: don't try to print the help text for a CLI command when
	  RESULT_SHOWUSAGE is returned if there is no help text available
	  (issue #6604)
	* channels/chan_sip.c: fix finding realtime peers that are not
	  dynamic by ip address (issue #6093)
	* channel.c: don't hang up the channel if its state is set to UP
	  before we return from ast_call (issue #6569)
2006-02-26 16:26 +0000 [r11165]  Tilghman Lesher <[email protected]>
	* include/asterisk/logger.h, logger.c: Bug 5950 - reenable queue
	  log rotation; also, eliminate redundant code
2006-02-25 19:54 +0000 [r11120]  Matt Frederickson <[email protected]>
	* translate.c: Backport of fix to translation optimizations. Thanks
	  again file!
2006-02-25 05:08 +0000 [r11058-11089]  Kevin P. Fleming <[email protected]>
	* translate.c: factor the number of translation steps required into
	  translation path decisions, so that equal cost paths that require
	  fewer translations are preferred
	* translate.c: reformat code to fit guidelines remember which
	  translation paths are multi-step paths
	* channel.c: ensure that spy frame queueing is able to deal with
	  translation failing for any reason (issue #6546)
2006-02-23 23:06 +0000 [r10952]  Tilghman Lesher <[email protected]>
	* Makefile: set PWD properly
2006-02-23 14:57 +0000 [r10736-10863]  Kevin P. Fleming <[email protected]>
	* dnsmgr.c, include/asterisk/linkedlists.h: backport list handling
	  fix from trunk (solves memory leak problem in cdr variables and
	  device state watchers) remove unused variable to silence
	  compiler warning
	* configs/iax.conf.sample: add comment warning people about trying
	  to use hostnames/IPs in the sample config
2006-02-20 23:01 +0000 [r10577]  Tilghman Lesher <[email protected]>
	* app.c: Would be nice to tell people to look in the right file to
	  increase a constant
2006-02-20 06:17 +0000 [r10511-10535]  Mark Spencer <[email protected]>
	* channels/chan_sip.c: Handle ACKing properly (remove gratuitous
	  -1)
	* channels/chan_iax2.c: Fix numerous places in jitter buffer where
	  freed memory is referenced
2006-02-19 18:29 +0000 [r10462-10487]  Tilghman Lesher <[email protected]>
	* formats/format_sln.c: Okay, fseek doesn't return an offset
	* apps/app_voicemail.c: Fix possible lack of initialization of
	  useadsi
	* formats/format_sln.c: Bug 6539 - Division by two negates error
	  flag
2006-02-18 00:17 +0000 [r10409]  Tilghman Lesher <[email protected]>
	* app.c: Bug 6529 - memory leak in ast_play_and_prepend
2006-02-17 01:55 +0000 [r10301-10368]  Russell Bryant <[email protected]>
	* jitterbuf.c: fix incorrent index calculation for jitterbuffer
	  history (issue #6517)
	* apps/app_voicemail.c: when executing the Directory application
	  from voicemail and a context is not specified, use the "default"
	  context, not the channel's current context (issue #6507)
2006-02-15 01:21 +0000 [r10108-10137]  Kevin P. Fleming <[email protected]>
	* channels/chan_agent.c: ensure that agents logged in via the
	  manager interface are stored in the persistence database (related
	  to issue #6301)
	* funcs/func_enum.c: handle longer ENUM lookup results (issue
	  #6476)
	* res/res_agi.c: ensure that FastAGI launcher can handle system
	  call interruption (issue #6449)
2006-02-14 20:56 +0000 [r10021]  Matt O'Gorman <[email protected]>
	* apps/app_meetme.c: bug fix from 6485 with musiconhold not being
	  turned off by app_meetme
2006-02-14 20:20 +0000 [r10018]  Kevin P. Fleming <[email protected]>
	* apps/app_queue.c: don't double-increment abandon counter for
	  calls that are hung up while dialing members (issue #6289)
2006-02-14 19:11 +0000 [r9990]  Mark Spencer <[email protected]>
	* apps/app_meetme.c: Fix stopstream in menus (bug #6137)
2006-02-14 18:50 +0000 [r9961-9964]  BJ Weschke <[email protected]>
	* asterisk.c: #ifdef the include too.
	* asterisk.c: #ifdef'd the prctl fix to only try and compile on
	  linux systems. Thanks rizzo for pointing this out.
2006-02-14 18:30 +0000 [r9953-9958]  Kevin P. Fleming <[email protected]>
	* channels/chan_sip.c: when answering INVITE, don't send codecs the
	  peer didn't offer (issue #6052)
	* rtp.c: revert yesterday's temporary fix for issue #6052
2006-02-14 04:45 +0000 [r9861-9870]  BJ Weschke <[email protected]>
	* asterisk.c: Fixed my silly backport error from r9861
	* asterisk.c: Merged changes from r9844 from /trunk. Make sure that
	  PR_SET_DUMPABLE is set to make certain that we still dump core if
	  Asterisk has setuid'd to run as non-root.
2006-02-14 00:46 +0000 [r9818]  Kevin P. Fleming <[email protected]>
	* rtp.c: don't try to use peer's dynamic codec numbers, it leads to
	  duplication (issue #6052)
2006-02-13 17:37 +0000 [r9756]  Josh Roberson <[email protected]>
	* apps/app_meetme.c: Don't set the formats before we stop
	  indications. (issue #6380)
2006-02-11 19:23 +0000 [r9581-9609]  Russell Bryant <[email protected]>
	* channels/chan_mgcp.c, channels/chan_sip.c, pbx/pbx_dundi.c,
	  channels/chan_iax2.c: fix memory leak from not destroying the
	  scheduler context on module unload
	* apps/app_page.c: fix due to CDR changes
	* manager.c, pbx/pbx_spool.c, include/asterisk/channel.h,
	  include/asterisk/pbx.h, include/asterisk/manager.h, channel.c,
	  pbx.c: now that CDR is a loadable module, don't depend on it
	  elsewhere (issue #6460)
2006-02-11 15:22 +0000 [r9528]  Kevin P. Fleming <[email protected]>
	* channels/chan_sip.c, cdr.c: clean up my mess from thread-starting
	  change
2006-02-11 06:29 +0000 [r9493]  BJ Weschke <[email protected]>
	* channels/chan_sip.c: kpfleming's fix from r9472 backported to 1.2
2006-02-10 20:38 +0000 [r9404]  Kevin P. Fleming <[email protected]>
	* channels/chan_mgcp.c, dnsmgr.c, channels/chan_sip.c,
	  devicestate.c, channels/chan_modem.c, cdr.c: don't create monitor
	  threads in detached mode, when we need to be able to
	  pthread_join() them later if the module is unloaded (solve
	  crash-on-unload problem for these channel modules)
2006-02-09 21:10 +0000 [r9323-9326]  Tilghman Lesher <[email protected]>
	* apps/app_voicemail.c: Revert behavior change from previous commit
	  (fixes only)
	* apps/app_voicemail.c: Backport 5929 to 1.2
2006-02-09 02:31 +0000 [r9246-9262]  Russell Bryant <[email protected]>
	* apps/Makefile: add another location for postgresql headers (issue
	  #6419)
	* channels/chan_iax2.c: reload peercontext on iax2 reload (issue
	  #6442)
2006-02-08 22:34 +0000 [r9233]  Tilghman Lesher <[email protected]>
	* cdr/Makefile: Leave it to RH/CentOS to put the freetds headers in
	  a completely nonstandard location.
2006-02-08 22:12 +0000 [r9232]  Matt O'Gorman <[email protected]>
	* logger.c, channels/chan_oss.c: Make logger report
	  error,warning,notice if logger.conf not found, also updated
	  chan_oss to give correct error message if its config file is not
	  found.
2006-02-05 17:10 +0000 [r9156]  Tilghman Lesher <[email protected]>
	* apps/app_macro.c: Bug 6176 - Fix race condition
2006-02-02 18:37 +0000 [r9086]  Kevin P. Fleming <[email protected]>
	* Makefile: don't override ASTERISKVERSIONNUM to 000000 for non-svn
	  builds
2006-02-02 16:12 +0000 [r9073]  Matt Frederickson <[email protected]>
	* res/res_odbc.c: Fix for (#6309), potential (highly unlikely)
	  memory leak in res_odbc
Ich habs getestet - und grade wieder ein Downgrade auf 1.2.4 gemacht, weil ich permanent Ausfälle mit 1.2.5 hatte. Bisher hatte ich keine Zeit, der Ursache auf den Grund zu gehen. Die Endgeräte (verschiedener Protokolle) waren zwar nach einer unbestimmten Zeit noch registriert, konnten aber weder eingehend noch abgehend telefonieren.
Manchmal ist der Asterisk auch einfach unmotiviert abgeschmiert.
Bei mir läuft der 1.2.5 seit gut drei Tagen stabil. Ich kann mit allen Telefonen (nur SIP), rein wie raus, problemlos telefonieren.
- mal sehn
schogge
Ich habe gerade ein Upgrade von 1.2.0 auf 1.2.5 gemacht und nun geht meine Voiceboxen nicht mehr! An der Config habe ich nichts verändert.
Ich bekomme im CLI immer die Fehlermeldung:
Mar 15 10:17:59 WARNING[3305]: app_voicemail.c:2411 leave_voicemail: No entry in voicemail config file for '$NEBENSTELLE'
Der Eintrag in der voicemail.conf ist natürlich da......hat ja vorher auch geklappt. .......hat jemand Rat?
Vielen Dank im voraus für Eure Hilfe.
Stevie
Einmal diese Frage zu stellen, sollte eigentlich ausreichen - oder ?
Antworten bitte hier posten.
Sorry! Kommt nicht wieder vor.
Reischitz
