Asterisk 1.2.6 online
kombjuder
IPPF-Promi
2 Nov 2004
Habe gerade gesehen, dass die Version 1.2.6 online ist, aber nur in den Links, eine Beschreibung war noch nicht da.
Changelog seit 1.2.5:
2006-03-26 Kevin P. Fleming <[email protected]>
	* Asterisk 1.2.6 released
2006-03-25 05:07 +0000 [r14821-14868]  Tilghman Lesher <[email protected]>
	* contrib/init.d/rc.redhat.asterisk: Bug 6601 - More configuration
	  abilities for the RH init script
	* apps/app_voicemail.c: Fix incorrect size of zeroing (left over
	  from when maxmsg was hardcoded at 100)
	* apps/app_voicemail.c: Bug 6783 - When context is specified,
	  voicemail should look for mailboxes in that context
2006-03-24 14:48 +0000 [r14704]  Russell Bryant <[email protected]>
	* image.c: use the correct variable in an error message (issue
	  #6791)
2006-03-24 04:53 +0000 [r14610-14659]  BJ Weschke <[email protected]>
	* apps/app_voicemail.c: Fix a typo in the app description
	* include/asterisk/sched.h: Doxygen comment typo corrections
2006-03-23 21:51 +0000 [r14523]  Joshua Colp <[email protected]>
	* res/res_features.c: Issue #6764 - Return BUSY signal when other
	  party is busy at Attended Transfer (Reported by mnachev)
2006-03-23 21:44 +0000 [r14522]  Matt Frederickson <[email protected]>
	* channels/chan_zap.c: Fix SETUP_ACK handling so that we change
	  channels if so requested
2006-03-23 20:43 +0000 [r14467]  BJ Weschke <[email protected]>
	* apps/app_meetme.c: Bug #5884 - fix a possible race state in
	  app_meetme when a channel has gone away and we are reading
	  continuously for more frames. (mneuhauser)
2006-03-23 20:13 +0000 [r14462]  Russell Bryant <[email protected]>
	* apps/app_readfile.c: don't crash when asked to read from a file
	  that doesn't exist (issue #6786)
2006-03-22 22:18 +0000 [r14191-14276]  Joshua Colp <[email protected]>
	* apps/app_voicemail.c: Fix a minor code issue
	* apps/app_voicemail.c: Issue #6781 - Verbose levels not enforced
	  in app_voicemail (Reported by flobi)
	* include/asterisk/cdr.h, cdr.c: Issue #5918 - Disposition showing
	  FAILED even though call is answered successfully (Reported by
	  tracinet)
	* pbx.c: Issue #6780 - ast_pbx_outgoing_cdr_failed description fix.
	  (Reported and fixed by casper)
2006-03-22 09:10 +0000 [r14140]  Olle Johansson <[email protected]>
	* channels/chan_sip.c: Issue #6766 - fix ;user=phone functionality.
	  (Reported by alein, fix by russell - thanks!)
2006-03-21 18:59 +0000 [r13814-13964]  Russell Bryant <[email protected]>
	* configs/features.conf.sample: add a note explaining how to set
	  the DYNAMIC_FEATURES variable to allow the use of custom features
	  (issue #6747)
	* res/res_features.c: fix crash when using the ParkAndAnnounce
	  application. When using this application, there will be no peer
	  channel to play the parking announcement to. (issue #6756)
	* funcs/func_strings.c: fix REGEX on strings that contain quotes
	  (issue #6678)
	* sounds.txt: fix spelling of whiskey
	* apps/app_meetme.c: don't add conference participant if the user
	  hangs up while recording their name (issue #6661)
	* sample.call: re-add the Account parameter to the sample call file
	  since it's not really deprecated since the CDR function is no
	  longer built in
2006-03-21 06:24 +0000 [r13707-13748]  Tilghman Lesher <[email protected]>
	* apps/app_voicemail.c: Bug 6714 - Workaround to avoid retrieving
	  incomplete voicemail message
	* editline/term.c: Do away with some warnings and fix some
	  indentation
2006-03-20 17:36 +0000 [r13634]  Olle Johansson <[email protected]>
	* channels/chan_iax2.c: Do not overwrite ANI if it's set by IE
	  (sendani=yes in the peer)
2006-03-19 09:59 +0000 [r13550]  Russell Bryant <[email protected]>
	* apps/app_dial.c: revert the change made in revision 12927 in
	  favor of keeping the original behavior of the option. The
	  documentation has now been updated to reflect the actual
	  behavior. (issue #6523)
2006-03-19 09:25 +0000 [r13547]  Olle Johansson <[email protected]>
	* channels/chan_sip.c: Reset global_rtautoclear at sip reload
2006-03-16 20:05 +0000 [r13279]  Tilghman Lesher <[email protected]>
	* ast_expr2.y, ast_expr2.c: Bug 6737 - Fix compile warning on OS X
2006-03-16 17:58 +0000 [r13239]  Olle Johansson <[email protected]>
	* configs/sip.conf.sample: Issue #6690 - clarify progressinband
	  default setting
2006-03-16 17:42 +0000 [r13237]  Russell Bryant <[email protected]>
	* channels/chan_zap.c: always use the callerid signalling method
	  set in the zt_pvt strucutre as opposed to the last one read from
	  the config file (issue #6734, with mods)
2006-03-16 06:56 +0000 [r13197]  Olle Johansson <[email protected]>
	* channels/chan_sip.c: To quote giant developers: "Oops". Thanks,
	  Tony!
2006-03-15 22:16 +0000 [r13161]  Russell Bryant <[email protected]>
	* cdr.c: - remove some calculations that will always result in 0 -
	  if a CDR was never started, don't try to calculate a duration and
	  consider it failed
2006-03-15 13:01 +0000 [r13026]  Olle Johansson <[email protected]>
	* channels/chan_sip.c: Issue #6728: Remove parameters to Event:
	  header on SUBSCRIBE requests
2006-03-14 18:41 +0000 [r12925-12927]  Russell Bryant <[email protected]>
	* apps/app_dial.c: when using the G() option to Dial, fix sending
	  the called channel to 1 priority beyond what was specified (issue
	  #6523)
	* apps/app_queue.c: fix a problem with not loading realtime queue
	  members by always reloading a realtime queue from the database
	  even if it is found in the list (issue #6680)
2006-03-12 19:26 +0000 [r12646]  Russell Bryant <[email protected]>
	* pbx.c: add locking to protect the list of global dialplan
	  variables
2006-03-12 17:57 +0000 [r12577]  Russell Bryant <[email protected]>
	* codecs/gsm/Makefile: fix build on parisc (issue #6704)
2006-03-10 12:13 +0000 [r12477-12495]  Olle Johansson <[email protected]>
	* channels/chan_sip.c: Issue #5937 - Make sure SIP CANCEL's are
	  re-transmitted
	* channels/chan_sip.c: Issue #6576 - SIP_CODEC not used for early
	  media (reported by gpapadop73)
2006-03-08 10:51 +0000 [r12458]  Olle Johansson <[email protected]>
	* channels/chan_sip.c: Issue #6657 - Ignore 183 session progress
	  without SDP
2006-03-07 00:05 +0000 [r12161-12195]  Tilghman Lesher <[email protected]>
	* channels/chan_sip.c: Bug 6020 - Race condition where packet could
	  be lost if first packet on list is acked
	* editline/np/vis.c, editline/readline.c: Bug 6664 - More fixes for
	  Solaris
2006-03-06 14:23 +0000 [r12036-12072]  Olle Johansson <[email protected]>
	* channel.c: Revert earlier change
	* channel.c: Fix for astmm compilation
2006-03-06 02:32 +0000 [r11946]  Russell Bryant <[email protected]>
	* configs/zapata.conf.sample: fix a typo in the description of the
	  ringtimeout option
2006-03-05 12:40 +0000 [r11849]  Olle Johansson <[email protected]>
	* channels/chan_sip.c: Clear page2 flags at reload too
2006-03-04 11:45 +0000 [r11778]  BJ Weschke <[email protected]>
	* apps/app_mixmonitor.c: Substitute variables in the post_process
	  string (if it exists) before those variables could possibly
	  disappear (channel hangup) #6462
Habs mir mal durchgelesen, aber scheint eigentlich nichts wildes dabei zu sein. Ich bleibe dann erstmal bei 1.2.5, die läuft recht stabil. Und wer weiss, wie schnell es weitergeht...
Rolf
Reischitz
