Asterisk 1.4 beta4 compilier-Probleme
thorsten.gehrig
14 Jun 2004
Hallo
ich versuche gerade die 1.4beta4 unter debian zu compilieren.
Folgende Probleme habe leider:
checking for UW IMAP Toolkit c-client library... no
Folgende Pakete sind allerdings installiert:
libc-client-dev - UW c-client library for mail protocols
libc-client2002edebian - UW c-client library for mail protocols
uw-mailutils - C-client support programs from UW
Somit kriege ich nicht die imap-unterstützung für die Mailbox hin.
Mein nächstes (größeres) Problem:
chan_zap.c: In function 'zt_call':
chan_zap.c:2152: error: too few arguments to function 'pri_sr_set_bearer'
chan_zap.c: In function 'zap_send_keypad_facility_exec':
chan_zap.c:2335: warning: implicit declaration of function 'pri_keypad_facility'
chan_zap.c: In function 'zt_hangup':
chan_zap.c:2618: error: too few arguments to function 'pri_hangup'
chan_zap.c:2638: error: too few arguments to function 'pri_hangup'
chan_zap.c: In function 'zt_handle_event':
chan_zap.c:3740: error: too few arguments to function 'pri_hangup'
chan_zap.c: In function 'pri_dchannel':
chan_zap.c:8494: error: too few arguments to function 'pri_hangup'
chan_zap.c:8653: error: too few arguments to function 'pri_hangup'
chan_zap.c:8785: error: too few arguments to function 'pri_hangup'
chan_zap.c:8820: error: too few arguments to function 'pri_hangup'
chan_zap.c:8829: error: too few arguments to function 'pri_hangup'
chan_zap.c:8837: error: too few arguments to function 'pri_hangup'
chan_zap.c:9072: error: too few arguments to function 'pri_hangup'
chan_zap.c:9138: error: too few arguments to function 'pri_hangup'
chan_zap.c: In function 'start_pri':
chan_zap.c:9346: error: too few arguments to function 'pri_new'
chan_zap.c: In function 'load_module':
chan_zap.c:11231: warning: passing argument 1 of 'pri_set_error' from incompatible pointer type
chan_zap.c:11232: warning: passing argument 1 of 'pri_set_message' from incompatible pointer type
make[1]: *** [chan_zap.o] Fehler 1
make: *** [channels] Fehler 2
Kann mir hier jemand einen Tipp geben?
Zaptel 1.4.0-beta3 hat problemlos durchcompliert (./configure && make && make install)
Thorsten Gehrig
Es gibt doch noch gar keinen offiziellen bristuff für die 1.4 (ich habe jenfalls keinen gefunden!)?
@Netview: wie kommst du denn auf Bristuff?
Ich habe hier versucht den blanko Zaptel und Asterisk zu compilieren.
Ich verwende für den ISDN-Buseine Fritzbox 5012 (also ISDN->SIP Adapter) - brauche also keinen Bristuff mehr..
Thorsten
Wg. chan_zap - diese Modul wird nur erstellt wenn noch Fragmente einer vorherigen bristuff-Installation vorhanden sind!
Du musst dies hier entfernen:
/usr/include/linux/zaptel.h und (ich glaube noch) toriso.h oder ähnlich, dann wird der asterisk nativ ohne bristuff/zaptel-Erweiterung kompilliert!)
Das könnte dann auch dein Fehler sein!!!
Sorry: lese gerade du willst zaptel drinnen haben - dann kannst du mein Geschreibsel vergessen!
Hi
brauche ich denn nicht "immer" zaptel - auch wenn ich gar kein zap_chan verwenden will? irgendwie hatte ich das so im kopf...
Reste vom Bristuff können sicherlich im System verankert sein.... im lösch das mal raus und compilier nochmal neu...
Thorsten
Nachtrag: löschen hat nix gebracht. auch das nicht-auswählen von chan_zap brachte keine besserung...
Nein - zaptel wird zur Unterstützung von analogen Karten benötigt und zaphfc ist die Adaption von Junghanns für isdn. Im Makefile ist eine Abfrage auf
/usr/include/linux/zaptel.h drinnen und dann wird chan_zap usw. hinzugefügt - dehalb zaptel.h und toriso.h eliminieren (und natürlich vorher alles unter/usr/include/asterisk und /usr/lib/asterisk/modules).
Okay - jetzt läufts weiter. Hab schonlange keinen Hausputz mehr machen müssen - zumindest was Asterisk angeht...
Danke für die Tips.
Zu dem UW-Imap-Thema unter Debian irgendwelche Hinweiße?
Und Grundsätzlich Diskussionen zu den neuen Features/Funktionen?
Thorsten Gehrig
PS: Mittlerweile durchcompiliert und läuft! Super!
bei mir läufts auf nem Virt Server - auch klasse
Konfig mit Web-Interface macht Spass auch wenn man noch für spez. Funktionen dann per hand in der extensions.conf basteln muss
Hi
bei mir ist das Web-Interface leer...(page not found) muss man da noch was machen ausser http.conf anzupassen?
gruß
thorsten
BTW:
1.4 lässt sich auch per make menuselect, damit kann man (problematische) Optionen auch deaktiveren.
(oder eben per configure)
me2k
