[Problem] Asterisk + Hylafax + IAXMODEM
mabikus
12 Sep 2013
habe das Problem das die Faxe teilweise:
-unsauber / halb ankommen
-garnicht ankommen
So hier mal meine Config
/etc/iaxmodem/ttyIAX0
device          /dev/ttyIAX0
owner           uucp:uucp
mode            660
port            4570
refresh         50
server          127.0.0.1
peername        iaxmodem
secret          password
codec           alaw
/etc/asterisk/iax.conf
[general]
bindport=4569
bindaddr=0.0.0.0
language=de
jitterbuffer=no
minregexpire=40
maxregexpire=3600
autokill=yes
iaxthreadcount=50
iaxmaxthreadcount=200
transfer=no
delayreject=yes
maxcallnumbers=256
maxcallnumbers_nonvalidated=512
calltokenoptional=127.0.0.1
tos=ef
disallow=all
allow=ulaw
allow=alaw
iaxcompat=yes
[iaxmodem]
type = friend
secret = password
port = 4570
host = dynamic
context = default
allow = alaw
requirecalltoken=no
Faxstat:
root@bbk-pbx-5:/etc/hylafax# faxstat
HylaFAX scheduler on bbk-pbx-5.bbk.local: Running
Modem ttyIAX0 (+49 2241 2409978): Running and idle
CLI:
  == Using SIP RTP CoS mark 5
    -- Executing [49XXXXXXX@sipgate-ankommend:1] Dial("SIP/sip-in-00000220", "IAX2/iaxmodem") in new stack
    -- Called IAX2/iaxmodem
    -- Call accepted by 127.0.0.1 (format alaw)
    -- Format for call is (alaw)
    -- IAX2/iaxmodem-2394 is ringing
    -- IAX2/iaxmodem-2394 answered SIP/sip-in-00000220
       > 0xb3c58030 -- Probation passed - setting RTP source address to 217.10.77.43:28536
    -- Hungup 'IAX2/iaxmodem-2394'
  == Spawn extension (sipgate-ankommend, 49XXXXXXX, 1) exited non-zero on 'SIP/sip-in-00000220'
hylafax
Jan  7 15:53:10 bbk-pbx-5 FaxGetty[5950]: ANSWER: FAX CONNECTION  DEVICE '/dev/ttyIAX0'
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: checkHostIdentity("localhost")
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: <--- 220 bbk-pbx-5.bbk.local server (HylaFAX (tm) Version 6.0.5) ready.
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: command: USER root
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: USER root
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: <--- 230 User root logged in.
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: command: TZONE LOCAL
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: TZONE LOCAL
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: <--- 200 Using time values in CET.
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: command: MDMFMT
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: <--- 200 Modem %m (%n): %s
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: command: EPRT |1|127.0.0.1|46281|
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: Parsing hostPort(): "EPRT"
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: Parsing "|1|127.0.0.1|46281|"
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]:  `-> s.length() = 19
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]:  `-> s[0] = '|'
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]:  `-> s[2] = '|'
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]:  `-> s[18] = '|'
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: Looks like extended syntax: "|1|127.0.0.1|46281|" [7C: |]
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: `-> Got a: 127.0.0.1[13]
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: `-> Got a: 46281[19]
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: Parsed: Family 1 Address 127.0.0.1 Port 46281
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: EPRT |1|127.0.0.1|51636|
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: <--- 200 EPRT command successful.
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: command: LIST status
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: LIST status
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: <--- 150 Opening new data connection for "status".
Jan  7 15:53:24 bbk-pbx-5 HylaFAX[7906]: <--- 226 Transfer complete.
Jan  7 15:53:57 bbk-pbx-5 FaxGetty[5950]: MODEM WWW.SOFT-SWITCH.ORG spandsp/
Jan  7 16:46:38 bbk-pbx-5 FaxGetty[5950]: RECV FAX (000000083): recvq/fax000000069.tif from Powered by MiniFax, route to <unspecified>, 0 pages in 0:00:33
Jan  7 16:46:38 bbk-pbx-5 FaxGetty[5950]: RECV FAX (000000083): session with Powered by MiniFax terminated abnormally: COMREC received DCN (sender abort)
Jan  7 16:46:38 bbk-pbx-5 FaxGetty[5950]: RECV FAX: bin/faxrcvd "recvq/fax000000069.tif" "ttyIAX0" "000000083" "COMREC received DCN (sender abort)"
Jan  7 16:46:47 bbk-pbx-5 FaxGetty[5950]: MODEM WWW.SOFT-SWITCH.ORG spandsp/
Jan  7 17:10:02 bbk-pbx-5 FaxGetty[5950]: ANSWER: FAX CONNECTION  DEVICE '/dev/ttyIAX0'
recvq/fax000000062.tif (ftp://bbk-pbx-5:4559/recvq/fax000000062.tif):
          Sender:
           Pages: 1
         Quality: Fine
            Size: 1728 by 224
        Received: 2014:01:07 15:01:16
 Time To Receive: 0:02:11
     Signal Rate: 14400 bit/s
     Data Format: 2-D MMR
   Error Correct: Yes
         CallID1:
         CallID2:
     Received On: ttyIAX0
          CommID: 000000076 (ftp://bbk-pbx-5:4559/log/c000000076)
Session log:
Jan 07 15:00:08.77: [ 5950]: SESSION BEGIN 000000076 4922412409978 Jan 07 15:00:08.77: [ 5950]: HylaFAX (tm) Version 6.0.5 Jan 07 15:00:08.77: [ 5950]: <-- [4:ATA\r] Jan 07 15:00:12.48: [ 5950]: --> [7:CONNECT] Jan 07 15:00:12.48: [ 5950]: ANSWER: FAX CONNECTION  DEVICE '/dev/ttyIAX0'
Jan 07 15:00:12.48: [ 5950]: RECV FAX: begin Jan 07 15:00:12.48: [ 5950]: <-- data [32] Jan 07 15:00:12.48: [ 5950]: <-- data [2] Jan 07 15:00:13.44: [ 5950]: --> [7:CONNECT] Jan 07 15:00:13.44: [ 5950]: <-- data [23] Jan 07 15:00:13.44: [ 5950]: <-- data [2] Jan 07 15:00:14.28: [ 5950]: --> [7:CONNECT] Jan 07 15:00:14.28: [ 5950]: <-- data [13] Jan 07 15:00:14.28: [ 5950]: <-- data [2] Jan 07 15:00:14.82: [ 5950]: --> [2:OK] Jan 07 15:00:14.82: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:00:21.82: [ 5950]: --> [0:] Jan 07 15:00:21.82: [ 5950]: MODEM <Empty line> Jan 07 15:00:21.82: [ 5950]: <-- data [1] Jan 07 15:00:21.82: [ 5950]: --> [2:OK] Jan 07 15:00:21.82: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:00:21.84: [ 5950]: --> [2:OK] Jan 07 15:00:21.84: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:00:21.86: [ 5950]: --> [7:CONNECT] Jan 07 15:00:21.86: [ 5950]: <-- data [32] Jan 07 15:00:21.86: [ 5950]: <-- data [2] Jan 07 15:00:23.63: [ 5950]: --> [7:CONNECT] Jan 07 15:00:23.63: [ 5950]: <-- data [23] Jan 07 15:00:23.63: [ 5950]: <-- data [2] Jan 07 15:00:24.37: [ 5950]: --> [7:CONNECT] Jan 07 15:00:24.37: [ 5950]: <-- data [13] Jan 07 15:00:24.37: [ 5950]: <-- data [2] Jan 07 15:00:24.94: [ 5950]: --> [2:OK] Jan 07 15:00:24.94: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:00:31.94: [ 5950]: --> [0:] Jan 07 15:00:31.94: [ 5950]: MODEM <Empty line> Jan 07 15:00:31.94: [ 5950]: <-- data [1] Jan 07 15:00:31.96: [ 5950]: --> [2:OK] Jan 07 15:00:31.96: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:00:31.98: [ 5950]: --> [2:OK] Jan 07 15:00:31.98: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:00:32.00: [ 5950]: --> [7:CONNECT] Jan 07 15:00:32.00: [ 5950]: <-- data [32] Jan 07 15:00:32.00: [ 5950]: <-- data [2] Jan 07 15:00:33.76: [ 5950]: --> [7:CONNECT] Jan 07 15:00:33.76: [ 5950]: <-- data [23] Jan 07 15:00:33.76: [ 5950]: <-- data [2] Jan 07 15:00:34.49: [ 5950]: --> [7:CONNECT] Jan 07 15:00:34.49: [ 5950]: <-- data [13] Jan 07 15:00:34.49: [ 5950]: <-- data [2] Jan 07 15:00:35.06: [ 5950]: --> [2:OK] Jan 07 15:00:35.06: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:00:42.06: [ 5950]: --> [0:] Jan 07 15:00:42.06: [ 5950]: MODEM <Empty line> Jan 07 15:00:42.06: [ 5950]: <-- data [1] Jan 07 15:00:42.08: [ 5950]: --> [2:OK] Jan 07 15:00:42.08: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:00:42.10: [ 5950]: --> [2:OK] Jan 07 15:00:42.10: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:00:42.12: [ 5950]: --> [7:CONNECT] Jan 07 15:00:42.12: [ 5950]: <-- data [32] Jan 07 15:00:42.12: [ 5950]: <-- data [2] Jan 07 15:00:43.87: [ 5950]: --> [7:CONNECT] Jan 07 15:00:43.87: [ 5950]: <-- data [23] Jan 07 15:00:43.87: [ 5950]: <-- data [2] Jan 07 15:00:44.60: [ 5950]: --> [7:CONNECT] Jan 07 15:00:44.60: [ 5950]: <-- data [13] Jan 07 15:00:44.60: [ 5950]: <-- data [2] Jan 07 15:00:45.17: [ 5950]: --> [2:OK] Jan 07 15:00:45.17: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:00:46.07: [ 5950]: --> [7:CONNECT] Jan 07 15:00:47.66: [ 5950]: --> [2:OK] Jan 07 15:00:47.66: [ 5950]: RECV recv TSI (sender id) Jan 07 15:00:47.66: [ 5950]: REMOTE TSI ""
Jan 07 15:00:47.66: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:00:47.93: [ 5950]: --> [7:CONNECT] Jan 07 15:00:47.97: [ 5950]: --> [2:OK] Jan 07 15:00:47.97: [ 5950]: RECV recv DCS (command signal) Jan 07 15:00:47.97: [ 5950]: REMOTE wants 14400 bit/s Jan 07 15:00:47.97: [ 5950]: REMOTE wants A4 page width (215 mm) Jan 07 15:00:47.97: [ 5950]: REMOTE wants unlimited page length Jan 07 15:00:47.97: [ 5950]: REMOTE wants 7.7 line/mm Jan 07 15:00:47.97: [ 5950]: REMOTE wants 2-D MMR Jan 07 15:00:47.97: [ 5950]: REMOTE wants T.30 Annex A, 256-byte ECM Jan 07 15:00:47.97: [ 5950]: RECV training at v.17 14400 bit/s Jan 07 15:00:47.97: [ 5950]: <-- [11:AT+FRM=145\r] Jan 07 15:00:49.66: [ 5950]: --> [7:CONNECT] Jan 07 15:00:51.27: [ 5950]: RECV: TCF 2936 bytes, 1% non-zero, 2896 zero-run Jan 07 15:00:51.27: [ 5950]: --> [10:NO CARRIER] Jan 07 15:00:51.27: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:00:51.36: [ 5950]: --> [2:OK] Jan 07 15:00:51.36: [ 5950]: TRAINING succeeded Jan 07 15:00:51.36: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:00:51.37: [ 5950]: --> [7:CONNECT] Jan 07 15:00:51.37: [ 5950]: <-- data [3] Jan 07 15:00:51.37: [ 5950]: <-- data [2] Jan 07 15:00:52.43: [ 5950]: --> [2:OK] Jan 07 15:00:52.43: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:00:58.28: [ 5950]: --> [8:+FCERROR] Jan 07 15:00:58.28: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:00:58.33: [ 5950]: --> [8:+FCERROR] Jan 07 15:00:58.33: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:00:58.49: [ 5950]: --> [7:CONNECT] Jan 07 15:00:59.79: [ 5950]: --> [2:OK] Jan 07 15:00:59.79: [ 5950]: RECV recv TSI (sender id) Jan 07 15:00:59.79: [ 5950]: RECV recv TSI (sender id) Jan 07 15:00:59.79: [ 5950]: REMOTE TSI ""
Jan 07 15:00:59.79: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:01:00.00: [ 5950]: --> [7:CONNECT] Jan 07 15:01:00.10: [ 5950]: --> [2:OK] Jan 07 15:01:00.10: [ 5950]: RECV recv DCS (command signal) Jan 07 15:01:00.10: [ 5950]: REMOTE wants 14400 bit/s Jan 07 15:01:00.10: [ 5950]: REMOTE wants A4 page width (215 mm) Jan 07 15:01:00.10: [ 5950]: REMOTE wants unlimited page length Jan 07 15:01:00.10: [ 5950]: REMOTE wants 7.7 line/mm Jan 07 15:01:00.10: [ 5950]: REMOTE wants 2-D MMR Jan 07 15:01:00.10: [ 5950]: REMOTE wants T.30 Annex A, 256-byte ECM Jan 07 15:01:00.10: [ 5950]: RECV training at v.17 14400 bit/s Jan 07 15:01:00.10: [ 5950]: <-- [11:AT+FRM=145\r] Jan 07 15:01:01.80: [ 5950]: --> [7:CONNECT] Jan 07 15:01:03.44: [ 5950]: RECV: TCF 2936 bytes, 1% non-zero, 2896 zero-run Jan 07 15:01:03.44: [ 5950]: --> [10:NO CARRIER] Jan 07 15:01:03.44: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:01:03.48: [ 5950]: --> [2:OK] Jan 07 15:01:03.48: [ 5950]: TRAINING succeeded Jan 07 15:01:03.48: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:01:03.50: [ 5950]: --> [7:CONNECT] Jan 07 15:01:03.50: [ 5950]: <-- data [3] Jan 07 15:01:03.50: [ 5950]: <-- data [2] Jan 07 15:01:04.54: [ 5950]: --> [2:OK] Jan 07 15:01:04.54: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:01:10.34: [ 5950]: --> [8:+FCERROR] Jan 07 15:01:10.34: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:01:10.49: [ 5950]: --> [8:+FCERROR] Jan 07 15:01:10.49: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:01:10.65: [ 5950]: --> [7:CONNECT] Jan 07 15:01:11.84: [ 5950]: --> [2:OK] Jan 07 15:01:11.84: [ 5950]: RECV recv TSI (sender id) Jan 07 15:01:11.84: [ 5950]: RECV recv TSI (sender id) Jan 07 15:01:11.84: [ 5950]: REMOTE TSI ""
Jan 07 15:01:11.84: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:01:12.13: [ 5950]: --> [7:CONNECT] Jan 07 15:01:12.19: [ 5950]: --> [2:OK] Jan 07 15:01:12.19: [ 5950]: RECV recv DCS (command signal) Jan 07 15:01:12.19: [ 5950]: REMOTE wants 14400 bit/s Jan 07 15:01:12.19: [ 5950]: REMOTE wants A4 page width (215 mm) Jan 07 15:01:12.19: [ 5950]: REMOTE wants unlimited page length Jan 07 15:01:12.19: [ 5950]: REMOTE wants 7.7 line/mm Jan 07 15:01:12.19: [ 5950]: REMOTE wants 2-D MMR Jan 07 15:01:12.19: [ 5950]: REMOTE wants T.30 Annex A, 256-byte ECM Jan 07 15:01:12.19: [ 5950]: RECV training at v.17 14400 bit/s Jan 07 15:01:12.19: [ 5950]: <-- [11:AT+FRM=145\r] Jan 07 15:01:13.87: [ 5950]: --> [7:CONNECT] Jan 07 15:01:15.51: [ 5950]: RECV: TCF 2936 bytes, 1% non-zero, 2896 zero-run Jan 07 15:01:15.51: [ 5950]: --> [10:NO CARRIER] Jan 07 15:01:15.51: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:01:15.54: [ 5950]: --> [2:OK] Jan 07 15:01:15.54: [ 5950]: TRAINING succeeded Jan 07 15:01:15.54: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:01:15.56: [ 5950]: --> [7:CONNECT] Jan 07 15:01:15.56: [ 5950]: <-- data [3] Jan 07 15:01:15.56: [ 5950]: <-- data [2] Jan 07 15:01:16.60: [ 5950]: --> [2:OK] Jan 07 15:01:16.60: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:01:17.97: [ 5950]: --> [7:CONNECT] Jan 07 15:01:18.66: [ 5950]: RECV received frame number 0 Jan 07 15:01:18.80: [ 5950]: RECV received frame number 1 Jan 07 15:01:18.93: [ 5950]: RECV received frame number 2 Jan 07 15:01:19.06: [ 5950]: RECV received frame number 3 Jan 07 15:01:19.22: [ 5950]: RECV received frame number 4 Jan 07 15:01:19.39: [ 5950]: RECV received frame number 5 Jan 07 15:01:19.49: [ 5950]: RECV received frame number 6 Jan 07 15:01:19.62: [ 5950]: RECV received frame number 7 Jan 07 15:01:19.76: [ 5950]: RECV received frame number 8 Jan 07 15:01:19.89: [ 5950]: RECV received frame number 9 Jan 07 15:01:20.02: [ 5950]: RECV received frame number 10 Jan 07 15:01:20.39: [ 5950]: RECV received frame number 11 Jan 07 15:01:20.45: [ 5950]: RECV received frame number 12 Jan 07 15:01:20.60: [ 5950]: RECV received frame number 13 Jan 07 15:01:20.72: [ 5950]: RECV received frame number 14 Jan 07 15:01:20.85: [ 5950]: RECV received frame number 15 Jan 07 15:01:20.98: [ 5950]: RECV received frame number 16 Jan 07 15:01:21.14: [ 5950]: RECV received frame number 17 Jan 07 15:01:21.27: [ 5950]: RECV received frame number 18 Jan 07 15:01:21.41: [ 5950]: RECV received frame number 19 Jan 07 15:01:21.56: [ 5950]: RECV received frame number 20 Jan 07 15:01:21.81: [ 5950]: RECV received frame number 21 Jan 07 15:01:21.94: [ 5950]: RECV received frame number 22 Jan 07 15:01:22.10: [ 5950]: RECV received frame number 23 Jan 07 15:01:22.23: [ 5950]: RECV received frame number 24 Jan 07 15:01:22.32: [ 5950]: RECV received frame number 25 Jan 07 15:01:22.52: [ 5950]: RECV received frame number 26 Jan 07 15:01:22.64: [ 5950]: RECV received frame number 27 Jan 07 15:01:22.77: [ 5950]: RECV received frame number 28 Jan 07 15:01:22.90: [ 5950]: RECV received frame number 29 Jan 07 15:01:23.20: [ 5950]: RECV received frame number 30 Jan 07 15:01:23.37: [ 5950]: RECV received frame number 31 Jan 07 15:01:23.48: [ 5950]: RECV received frame number 32 Jan 07 15:01:23.60: [ 5950]: RECV received frame number 33 Jan 07 15:01:23.73: [ 5950]: RECV received frame number 34 Jan 07 15:01:23.88: [ 5950]: RECV received frame number 35 Jan 07 15:01:24.02: [ 5950]: RECV received frame number 36 Jan 07 15:01:24.15: [ 5950]: RECV received frame number 37 Jan 07 15:01:24.38: [ 5950]: RECV received frame number 38 Jan 07 15:01:24.44: [ 5950]: RECV received frame number 39 Jan 07 15:01:24.57: [ 5950]: RECV received frame number 40 Jan 07 15:01:24.84: [ 5950]: RECV received frame number 41 Jan 07 15:01:24.98: [ 5950]: RECV received frame number 42 Jan 07 15:01:25.11: [ 5950]: RECV received frame number 43 Jan 07 15:01:25.24: [ 5950]: RECV received frame number 44 Jan 07 15:01:25.44: [ 5950]: RECV received frame number 45 Jan 07 15:01:25.53: [ 5950]: RECV received frame number 46 Jan 07 15:01:25.67: [ 5950]: RECV received frame number 47 Jan 07 15:01:25.82: [ 5950]: RECV received frame number 48 Jan 07 15:01:25.96: [ 5950]: RECV received frame number 49 Jan 07 15:01:26.07: [ 5950]: RECV received frame number 50 Jan 07 15:01:26.22: [ 5950]: RECV received frame number 51 Jan 07 15:01:26.49: [ 5950]: RECV received frame number 52 Jan 07 15:01:26.62: [ 5950]: RECV received frame number 53 Jan 07 15:01:26.78: [ 5950]: RECV received frame number 54 Jan 07 15:01:26.93: [ 5950]: RECV received frame number 55 Jan 07 15:01:27.05: [ 5950]: RECV received frame number 56 Jan 07 15:01:27.20: [ 5950]: RECV received frame number 57 Jan 07 15:01:27.40: [ 5950]: RECV received frame number 58 Jan 07 15:01:27.45: [ 5950]: RECV received frame number 59 Jan 07 15:01:27.60: [ 5950]: RECV received frame number 60 Jan 07 15:01:27.87: [ 5950]: RECV received frame number 61 Jan 07 15:01:28.00: [ 5950]: RECV received frame number 62 Jan 07 15:01:28.16: [ 5950]: RECV received frame number 63 Jan 07 15:01:28.27: [ 5950]: RECV received frame number 64 Jan 07 15:01:28.32: [ 5950]: RECV received frame number 65 Jan 07 15:01:28.55: [ 5950]: RECV received frame number 66 Jan 07 15:01:28.70: [ 5950]: RECV received frame number 67 Jan 07 15:01:28.83: [ 5950]: RECV received frame number 68 Jan 07 15:01:28.98: [ 5950]: RECV received frame number 69 Jan 07 15:01:29.10: [ 5950]: RECV received frame number 70 Jan 07 15:01:29.39: [ 5950]: RECV received frame number 71 Jan 07 15:01:29.50: [ 5950]: RECV received frame number 72 Jan 07 15:01:29.63: [ 5950]: RECV received frame number 73 Jan 07 15:01:29.77: [ 5950]: RECV received frame number 74 Jan 07 15:01:29.90: [ 5950]: RECV received frame number 75 Jan 07 15:01:30.06: [ 5950]: RECV received frame number 76 Jan 07 15:01:30.17: [ 5950]: RECV received frame number 77 Jan 07 15:01:30.39: [ 5950]: RECV received frame number 78 Jan 07 15:01:30.44: [ 5950]: RECV received frame number 79 Jan 07 15:01:30.57: [ 5950]: RECV received frame number 80 Jan 07 15:01:30.86: [ 5950]: RECV received frame number 81 Jan 07 15:01:30.98: [ 5950]: RECV received frame number 82 Jan 07 15:01:31.05: [ 5950]: RECV received frame number 83 Jan 07 15:01:31.24: [ 5950]: RECV received frame number 84 Jan 07 15:01:31.31: [ 5950]: RECV received frame number 85 Jan 07 15:01:31.51: [ 5950]: RECV received frame number 86 Jan 07 15:01:31.64: [ 5950]: RECV received frame number 87 Jan 07 15:01:31.75: [ 5950]: RECV received frame number 88 Jan 07 15:01:31.90: [ 5950]: RECV received frame number 89 Jan 07 15:01:32.06: [ 5950]: RECV received frame number 90 Jan 07 15:01:32.34: [ 5950]: RECV received frame number 91 Jan 07 15:01:32.45: [ 5950]: RECV received frame number 92 Jan 07 15:01:32.57: [ 5950]: RECV received frame number 93 Jan 07 15:01:32.71: [ 5950]: RECV received frame number 94 Jan 07 15:01:32.83: [ 5950]: RECV received frame number 95 Jan 07 15:01:32.98: [ 5950]: RECV received frame number 96 Jan 07 15:01:33.06: [ 5950]: RECV received frame number 97 Jan 07 15:01:33.25: [ 5950]: RECV received frame number 98 Jan 07 15:01:33.34: [ 5950]: RECV received frame number 99 Jan 07 15:01:33.52: [ 5950]: RECV received frame number 100 Jan 07 15:01:33.65: [ 5950]: RECV received frame number 101 Jan 07 15:01:33.92: [ 5950]: RECV received frame number 102 Jan 07 15:01:34.07: [ 5950]: RECV received frame number 103 Jan 07 15:01:34.17: [ 5950]: RECV received frame number 104 Jan 07 15:01:34.39: [ 5950]: RECV received frame number 105 Jan 07 15:01:34.45: [ 5950]: RECV received frame number 106 Jan 07 15:01:34.60: [ 5950]: RECV received frame number 107 Jan 07 15:01:34.73: [ 5950]: RECV received frame number 108 Jan 07 15:01:34.85: [ 5950]: RECV received frame number 109 Jan 07 15:01:35.00: [ 5950]: RECV received frame number 110 Jan 07 15:01:35.13: [ 5950]: RECV received frame number 111 Jan 07 15:01:35.42: [ 5950]: RECV received frame number 112 Jan 07 15:01:35.54: [ 5950]: RECV received frame number 113 Jan 07 15:01:35.67: [ 5950]: RECV received frame number 114 Jan 07 15:01:35.82: [ 5950]: RECV received frame number 115 Jan 07 15:01:35.93: [ 5950]: RECV received frame number 116 Jan 07 15:01:36.07: [ 5950]: RECV received frame number 117 Jan 07 15:01:36.22: [ 5950]: RECV received frame number 118 Jan 07 15:01:36.39: [ 5950]: RECV received frame number 119 Jan 07 15:01:36.47: [ 5950]: RECV received frame number 120 Jan 07 15:01:36.62: [ 5950]: RECV received frame number 121 Jan 07 15:01:36.75: [ 5950]: RECV received frame number 122 Jan 07 15:01:37.02: [ 5950]: RECV received frame number 123 Jan 07 15:01:37.15: [ 5950]: RECV received frame number 124 Jan 07 15:01:37.29: [ 5950]: RECV received frame number 125 Jan 07 15:01:37.42: [ 5950]: RECV received frame number 126 Jan 07 15:01:37.55: [ 5950]: RECV received frame number 127 Jan 07 15:01:37.69: [ 5950]: RECV received frame number 128 Jan 07 15:01:37.82: [ 5950]: RECV received frame number 129 Jan 07 15:01:37.95: [ 5950]: RECV received frame number 130 Jan 07 15:01:38.09: [ 5950]: RECV received frame number 131 Jan 07 15:01:38.22: [ 5950]: RECV received frame number 132 Jan 07 15:01:38.49: [ 5950]: RECV received frame number 133 Jan 07 15:01:38.62: [ 5950]: RECV received frame number 134 Jan 07 15:01:38.75: [ 5950]: RECV received frame number 135 Jan 07 15:01:38.89: [ 5950]: RECV received frame number 136 Jan 07 15:01:39.02: [ 5950]: RECV received frame number 137 Jan 07 15:01:39.16: [ 5950]: RECV received frame number 138 Jan 07 15:01:39.29: [ 5950]: RECV received frame number 139 Jan 07 15:01:39.44: [ 5950]: RECV received frame number 140 Jan 07 15:01:39.57: [ 5950]: RECV received frame number 141 Jan 07 15:01:39.69: [ 5950]: RECV received frame number 142 Jan 07 15:01:39.84: [ 5950]: RECV received frame number 143 Jan 07 15:01:40.09: [ 5950]: RECV received frame number 144 Jan 07 15:01:40.24: [ 5950]: RECV received frame number 145 Jan 07 15:01:40.43: [ 5950]: RECV received frame number 146 Jan 07 15:01:40.49: [ 5950]: RECV received frame number 147 Jan 07 15:01:40.64: [ 5950]: RECV received frame number 148 Jan 07 15:01:40.77: [ 5950]: RECV received frame number 149 Jan 07 15:01:40.89: [ 5950]: RECV received frame number 150 Jan 07 15:01:41.04: [ 5950]: RECV received frame number 151 Jan 07 15:01:41.17: [ 5950]: RECV received frame number 152 Jan 07 15:01:41.39: [ 5950]: RECV received frame number 153 Jan 07 15:01:41.44: [ 5950]: RECV received frame number 154 Jan 07 15:01:41.70: [ 5950]: RECV received frame number 155 Jan 07 15:01:41.84: [ 5950]: RECV received frame number 156 Jan 07 15:01:41.97: [ 5950]: RECV received frame number 157 Jan 07 15:01:42.10: [ 5950]: RECV received frame number 158 Jan 07 15:01:42.24: [ 5950]: RECV received frame number 159 Jan 07 15:01:42.41: [ 5950]: RECV received frame number 160 Jan 07 15:01:42.50: [ 5950]: RECV received frame number 161 Jan 07 15:01:42.66: [ 5950]: RECV received frame number 162 Jan 07 15:01:42.77: [ 5950]: RECV received frame number 163 Jan 07 15:01:42.90: [ 5950]: RECV received frame number 164 Jan 07 15:01:43.17: [ 5950]: RECV received frame number 165 Jan 07 15:01:43.40: [ 5950]: RECV received frame number 166 Jan 07 15:01:43.46: [ 5950]: RECV received frame number 167 Jan 07 15:01:43.57: [ 5950]: RECV received frame number 168 Jan 07 15:01:43.72: [ 5950]: RECV received frame number 169 Jan 07 15:01:43.86: [ 5950]: RECV received frame number 170 Jan 07 15:01:43.97: [ 5950]: RECV received frame number 171 Jan 07 15:01:44.12: [ 5950]: RECV received frame number 172 Jan 07 15:01:44.25: [ 5950]: RECV received frame number 173 Jan 07 15:01:44.40: [ 5950]: RECV received frame number 174 Jan 07 15:01:44.65: [ 5950]: RECV received frame number 175 Jan 07 15:01:44.77: [ 5950]: RECV received frame number 176 Jan 07 15:01:44.92: [ 5950]: RECV received frame number 177 Jan 07 15:01:45.05: [ 5950]: RECV received frame number 178 Jan 07 15:01:45.18: [ 5950]: RECV received frame number 179 Jan 07 15:01:45.44: [ 5950]: RECV received frame number 180 Jan 07 15:01:45.44: [ 5950]: RECV received frame number 181 Jan 07 15:01:45.56: [ 5950]: RECV received frame number 182 Jan 07 15:01:45.72: [ 5950]: RECV received frame number 183 Jan 07 15:01:45.98: [ 5950]: RECV received frame number 184 Jan 07 15:01:46.12: [ 5950]: RECV received frame number 185 Jan 07 15:01:46.23: [ 5950]: RECV received frame number 186 Jan 07 15:01:46.40: [ 5950]: RECV received frame number 187 Jan 07 15:01:46.51: [ 5950]: RECV received frame number 188 Jan 07 15:01:46.65: [ 5950]: RECV received frame number 189 Jan 07 15:01:46.78: [ 5950]: RECV received frame number 190 Jan 07 15:01:46.91: [ 5950]: RECV received frame number 191 Jan 07 15:01:47.04: [ 5950]: RECV received frame number 192 Jan 07 15:01:47.20: [ 5950]: RECV received frame number 193 Jan 07 15:01:47.41: [ 5950]: RECV received frame number 194 Jan 07 15:01:47.60: [ 5950]: RECV received frame number 195 Jan 07 15:01:47.71: [ 5950]: RECV received frame number 196 Jan 07 15:01:47.86: [ 5950]: RECV received frame number 197 Jan 07 15:01:48.00: [ 5950]: RECV received frame number 198 Jan 07 15:01:48.13: [ 5950]: RECV received frame number 199 Jan 07 15:01:48.26: [ 5950]: RECV received frame number 200 Jan 07 15:01:48.44: [ 5950]: RECV received frame number 201 Jan 07 15:01:48.53: [ 5950]: RECV received frame number 202 Jan 07 15:01:48.66: [ 5950]: RECV received frame number 203 Jan 07 15:01:48.79: [ 5950]: RECV received frame number 204 Jan 07 15:01:48.92: [ 5950]: RECV received frame number 205 Jan 07 15:01:49.19: [ 5950]: RECV received frame number 206 Jan 07 15:01:49.44: [ 5950]: RECV received frame number 207 Jan 07 15:01:49.48: [ 5950]: RECV received frame number 208 Jan 07 15:01:49.59: [ 5950]: RECV received frame number 209 Jan 07 15:01:49.74: [ 5950]: RECV received frame number 210 Jan 07 15:01:49.87: [ 5950]: RECV received frame number 211 Jan 07 15:01:49.99: [ 5950]: RECV received frame number 212 Jan 07 15:01:50.14: [ 5950]: RECV received frame number 213 Jan 07 15:01:50.27: [ 5950]: RECV received frame number 214 Jan 07 15:01:50.44: [ 5950]: RECV received frame number 215 Jan 07 15:01:50.67: [ 5950]: RECV received frame number 216 Jan 07 15:01:50.82: [ 5950]: RECV received frame number 217 Jan 07 15:01:50.93: [ 5950]: RECV received frame number 218 Jan 07 15:01:51.07: [ 5950]: RECV received frame number 219 Jan 07 15:01:51.22: [ 5950]: RECV received frame number 220 Jan 07 15:01:51.39: [ 5950]: RECV received frame number 221 Jan 07 15:01:51.46: [ 5950]: RECV received frame number 222 Jan 07 15:01:51.62: [ 5950]: RECV received frame number 223 Jan 07 15:01:51.73: [ 5950]: RECV received frame number 224 Jan 07 15:01:51.88: [ 5950]: RECV received frame number 225 Jan 07 15:01:52.13: [ 5950]: RECV received frame number 226 Jan 07 15:01:52.28: [ 5950]: RECV received frame number 227 Jan 07 15:01:52.44: [ 5950]: RECV received frame number 228 Jan 07 15:01:52.54: [ 5950]: RECV received frame number 229 Jan 07 15:01:52.68: [ 5950]: RECV received frame number 230 Jan 07 15:01:52.81: [ 5950]: RECV received frame number 231 Jan 07 15:01:52.96: [ 5950]: RECV received frame number 232 Jan 07 15:01:53.08: [ 5950]: RECV received frame number 233 Jan 07 15:01:53.21: [ 5950]: RECV received frame number 234 Jan 07 15:01:53.40: [ 5950]: RECV received frame number 235 Jan 07 15:01:53.60: [ 5950]: RECV received frame number 236 Jan 07 15:01:53.76: [ 5950]: RECV received frame number 237 Jan 07 15:01:53.89: [ 5950]: RECV received frame number 238 Jan 07 15:01:54.02: [ 5950]: RECV received frame number 239 Jan 07 15:01:54.15: [ 5950]: RECV received frame number 240 Jan 07 15:01:54.29: [ 5950]: RECV received frame number 241 Jan 07 15:01:54.45: [ 5950]: RECV received frame number 242 Jan 07 15:01:54.55: [ 5950]: RECV received frame number 243 Jan 07 15:01:54.70: [ 5950]: RECV received frame number 244 Jan 07 15:01:54.82: [ 5950]: RECV received frame number 245 Jan 07 15:01:54.95: [ 5950]: RECV received frame number 246 Jan 07 15:01:55.23: [ 5950]: RECV received frame number 247 Jan 07 15:01:55.41: [ 5950]: RECV received frame number 248 Jan 07 15:01:55.50: [ 5950]: RECV received frame number 249 Jan 07 15:01:55.63: [ 5950]: RECV received frame number 250 Jan 07 15:01:55.76: [ 5950]: RECV received frame number 251 Jan 07 15:01:55.89: [ 5950]: RECV received frame number 252 Jan 07 15:01:56.02: [ 5950]: RECV received frame number 253 Jan 07 15:01:56.16: [ 5950]: RECV received frame number 254 Jan 07 15:01:56.29: [ 5950]: RECV received frame number 255 Jan 07 15:01:56.29: [ 5950]: RECV received RCP frame Jan 07 15:01:56.38: [ 5950]: --> [10:NO CARRIER] Jan 07 15:01:56.38: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:01:56.57: [ 5950]: --> [7:CONNECT] Jan 07 15:01:57.76: [ 5950]: --> [2:OK] Jan 07 15:01:57.76: [ 5950]: RECV recv PPS (partial page signal) Jan 07 15:01:57.76: [ 5950]: RECV recv NULL (more blocks, same page) Jan 07 15:01:57.76: [ 5950]: RECV received 256 frames of block 1 of page 1 Jan 07 15:01:58.77: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:01:58.79: [ 5950]: --> [2:OK] Jan 07 15:01:58.79: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:01:58.80: [ 5950]: --> [7:CONNECT] Jan 07 15:01:58.80: [ 5950]: <-- data [3] Jan 07 15:01:58.80: [ 5950]: <-- data [2] Jan 07 15:01:59.06: [ 5950]: RECV: 65536 bytes of data, 0 total lines Jan 07 15:01:59.82: [ 5950]: --> [2:OK] Jan 07 15:01:59.82: [ 5950]: RECV send RNR (receive not ready) Jan 07 15:01:59.82: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:02:05.70: [ 5950]: --> [7:CONNECT] Jan 07 15:02:06.92: [ 5950]: --> [2:OK] Jan 07 15:02:06.92: [ 5950]: RECV recv PPS (partial page signal) Jan 07 15:02:06.92: [ 5950]: Ignoring invalid response to RNR.
Jan 07 15:02:06.92: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:02:06.98: [ 5950]: --> [2:OK] Jan 07 15:02:06.98: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:02:06.99: [ 5950]: --> [7:CONNECT] Jan 07 15:02:06.99: [ 5950]: <-- data [3] Jan 07 15:02:06.99: [ 5950]: <-- data [2] Jan 07 15:02:08.02: [ 5950]: --> [2:OK] Jan 07 15:02:08.02: [ 5950]: RECV send MCF (message confirmation) Jan 07 15:02:08.02: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:02:13.90: [ 5950]: --> [8:+FCERROR] Jan 07 15:02:13.90: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:02:14.12: [ 5950]: --> [8:+FCERROR] Jan 07 15:02:14.12: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:02:14.27: [ 5950]: --> [7:CONNECT] Jan 07 15:02:15.12: [ 5950]: --> [2:OK] Jan 07 15:02:15.12: [ 5950]: RECV recv PPS (partial page signal) Jan 07 15:02:15.12: [ 5950]: RECV recv NULL (more blocks, same page) Jan 07 15:02:15.12: [ 5950]: RECV received 0 frames of block 1 of page 1 Jan 07 15:02:15.12: [ 5950]: <-- [9:AT+FRS=7\r] Jan 07 15:02:15.20: [ 5950]: --> [2:OK] Jan 07 15:02:15.20: [ 5950]: <-- [9:AT+FTH=3\r] Jan 07 15:02:15.22: [ 5950]: --> [7:CONNECT] Jan 07 15:02:15.22: [ 5950]: <-- data [3] Jan 07 15:02:15.22: [ 5950]: <-- data [2] Jan 07 15:02:16.23: [ 5950]: --> [2:OK] Jan 07 15:02:16.23: [ 5950]: RECV send MCF (message confirmation) Jan 07 15:02:16.23: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:02:21.92: [ 5950]: --> [8:+FCERROR] Jan 07 15:02:21.92: [ 5950]: <-- [11:AT+FRM=146\r] Jan 07 15:02:22.12: [ 5950]: --> [8:+FCERROR] Jan 07 15:02:22.12: [ 5950]: <-- [9:AT+FRH=3\r] Jan 07 15:02:22.29: [ 5950]: --> [7:CONNECT] Jan 07 15:02:23.01: [ 5950]: --> [2:OK] Jan 07 15:02:23.01: [ 5950]: RECV recv DCN (disconnect) Jan 07 15:02:23.01: [ 5950]: COMREC received DCN (sender abort) Jan 07 15:02:23.01: [ 5950]: RECV: 0 bytes of data, 1731 total lines Jan 07 15:02:23.01: [ 5950]: RECV keeping unconfirmed page Jan 07 15:02:23.01: [ 5950]: RECV FAX (000000076): from , page 1 in 0:02:11, INF, 7.7 line/mm, 2-D MMR, 14400 bit/s Jan 07 15:02:23.01: [ 5950]: RECV FAX (000000076): recvq/fax000000062.tif from , route to <unspecified>, 1 pages in 0:02:11 Jan 07 15:02:23.01: [ 5950]: RECV FAX: COMREC received DCN (sender abort) Jan 07 15:02:23.01: [ 5950]: RECV FAX (000000076): session with  terminated abnormally: COMREC received DCN (sender abort) Jan 07 15:02:23.01: [ 5950]: RECV FAX: bin/faxrcvd "recvq/fax000000062.tif" "ttyIAX0" "000000076" "COMREC received DCN (sender abort)"
Jan 07 15:02:23.02: [ 5950]: RECV FAX: end Jan 07 15:02:23.02: [ 5950]: COMREC received DCN (sender abort) Jan 07 15:02:23.02: [ 5950]: SESSION END
Ich hab keine Ahnung mehr woran es liegen kann wenn ihr logs braucht bescheid sagen....
Würde mich auch freuen wenn jemand mal ein Testfax schicken kann... Nr per PN!
Anbieter ist Sipgate Trunking
Das wird leider nix. Stichwort "T.38" Und Sipgate macht leider kein T.38. Such dir einen SIP-Provider der T.38 kann, binde den Asterisk per T.38 und lass Asterisk mittels der spandsp library (aktuelle Versionen!) die Fax annehmen. das funktioniert besser als iaxmodem+Hylafax.
vielen Dank für deine Antwort.
Kannst du mir einen Anbieter empfehlen der 10er Blöcke anbietet und T.38 unterstützt ?
bin gerade am Testen mit Easybell http://www.easybell.de/business-VOICE/business-easy.html. Dieser bietet 10/100er Blöcke,T.38,tls und srtp.
Mit res_fax_spandsp funktioniert der Faxempfang direkt in der Asterisk gut. Der Versand als t.38 Gateway scheint im Moment nicht immmer zu funktionieren. Bislang sind aber alle Faxe nach mehreren Versuchen durchgegegangen. (Asterisk 11.7.0)
Hi Danke für die Antwort.
Ich habe mir bei dus.net ein Starterpaket gebucht und die haben mir das Testweise auf T.38 (Trunk) umgestellt und siehe da . Alles funktioniert bestens ! Das heißt das Problem ist definitiv Sipgate und meine Config funktioniert einewandfrei.
@mabikus
aber schon mit res_fax_spandsp jetzt, oder? weil bei iaxmodem+hylafax bringt t.38 nur was in Verbindung mit T.38 Gateway "Set(FAXOPT(gateway)=yes)"
DerAndiBOT
