Asterisk in FBF and gui
binary_dreamer
24 Jul 2009
Hi. i managed to install asterisk in a usb flash disk in a Fritz 7140.
i would like to ask if there is any gui available.
You can get the Asterisk gui compiled and installed.
It is of very limited use due to the proprietary configuration of the FBF CAPI, though.
As such we decided not to further pursue the use of the GUI for "Asterisk on FBF".
However anyone is welcome to spend time & effort to make the necessary adjustments on the gui to use it.
Regards
dynamic
hi. thanks a lot for your reply.
my question is how do i compile it on FBF?
Actually you don't compile it on the FBF but rather use a cross-compiler. I suggest to either use the buildroot/toolchain provided with the freetz einvornment or download and install the OpenWRT toolchain ( see here for more details )
Regards
dynamic
Protonator
