Asterisk nimmt keine Gespräche entegen
Haemmi
13 Jan 2006
Hallo.
Ich bin noch recht neu auf dem Gebiet, darum bitte ein bissel Nachsicht. ;)
Mein Asterisk 1.2.1 möchte sich nicht so recht dazu bewegen lassen, Anrufe die via ISDN (CAPI, AVM Fritz PCI, P2MP-Anschluss) anzunehmen.
Die Tipps hier im Forum habe ich alle durch, daher hier mal der CAPI-Debug-Log:
CONNECT_IND ID=002 #0x00b1 LEN=0046
  Controller/PLCI/NCCI            = 0x101
  CIPValue                        = 0x1
  CalledPartyNumber               = <c1>120xxxx
  CallingPartyNumber              = <21 81>7117216216
  CalledPartySubaddress           = default
  CallingPartySubaddress          = default
  BC                              = <80 90 a3>
  LLC                             = default
  HLC                             = default
  AdditionalInfo                  = default
    -- CONNECT_IND (PLCI=0x101,DID=120xxxx,CID=7117216216,CIP=0x1,CONTROLLER=0x1)
       > ISDN: msn='120xxxx' DNID='120xxxx' MSN
  == ISDN: Incoming call '07117216216' -> '120xxxx'
CONNECT_RESP ID=002 #0x00b1 LEN=0034
  Reject                          = 0x1
  BProtocol
   B1protocol                     = 0x0
   B2protocol                     = 0x0
   B3protocol                     = 0x0
   B1configuration                = default
   B2configuration                = default
   B3configuration                = default
   GlobalConfiguration            = default
  ConnectedNumber                 = default
  ConnectedSubaddress             = default
  LLC                             = default
  AdditionalInfo
   BChannelinformation            = default
   Keypadfacility                 = default
   Useruserdata                   = default
   Facilitydataarray              = default
   SendingComplete                = default
INFO_IND ID=002 #0x00b2 LEN=0017
  InfoNumber                      = 0x1e
  InfoElement                     = <81 83>
INFO_RESP ID=002 #0x00b2 LEN=0012
    -- ISDN: info element PI 81 83
       > ISDN: Origination is non ISDN
INFO_IND ID=002 #0x00b3 LEN=0023
  InfoNumber                      = 0x70
  InfoElement                     = <c1>120xxxx
INFO_RESP ID=002 #0x00b3 LEN=0012
    -- ISDN: info element CALLED PARTY NUMBER
       > ISDN: INFO_IND DID digits not used in this state.
INFO_IND ID=002 #0x00b4 LEN=0016
  InfoNumber                      = 0x18
  InfoElement                     = <89>
INFO_RESP ID=002 #0x00b4 LEN=0012
    -- ISDN: info element CHANNEL IDENTIFICATION 89
INFO_IND ID=002 #0x00b5 LEN=0016
  InfoNumber                      = 0xa1
  InfoElement                     = <a1>
INFO_RESP ID=002 #0x00b5 LEN=0012
    -- ISDN: info element Sending Complete
  == ISDN: pbx already started on channel CAPI/ISDN/120xxxx-3
DISCONNECT_IND ID=002 #0x00b8 LEN=0014
  Reason                          = 0x0
DISCONNECT_RESP ID=002 #0x00b8 LEN=0012
    -- ISDN: DISCONNECT_IND on incoming without pbx, doing hangup.
  == ISDN: CAPI Hangingup
  == ISDN: Interface cleanup PLCI=0x101
       > CAPI devicestate requested for ISDN/120xxxx
Vielleicht noch meine capi.conf:
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
language=de
; interface sections ...
[ISDN]
isdnmode=MSN
incomingmsn = 120xxxx    ;ISDN Amt
;incomingmsn = *
group = 1
immediate = yes
controller = 1
softdmf = on
relaxdtmf = on
accountcode =
context = incoming
immediate = yes
echocancelold = yes
devices = 2
Und der wichtige Teil in der extensions.conf:
[incoming]
    exten => s,1,Answer( )
    exten => s,2,Playback(hello-world)
    exten => s,3,Hangup( )
Danke schonmal.
Ciao, Haemmi.
Deine MSN, also ankommende Nummer ist 120xxxx, aber in der extensions.conf hast du nur einen Eintrag fuer 's'. Das kann also nicht gehen.
Armin
ersetze mal "s" durch "_X."
edit - ups, da war jemand schneller :wink:
Danke für eure Antwort, genau das wars. Ich bin auch gerade selbst drauf gekommen...
Oh mein Gott, wo stand eigentlich, dass man das s nehmen soll.
Ciao, Haemmi.
Keine Mitglieder online.
christinej8
