asterisk + sipgate -> leeres fax
another-way
4 Sep 2004
ich hab grad mal asterisk mit spandsp kompiliert und versucht ein fax über sipgate zu versenden.
der fax piep kommt... nur das eigentliche fax was übertragen wird ist komplett weiss
folgendes spuckt asterisk aus
       > Channel SIP/sipgate-fcd0 was answered.
       > Lauching TxFax(/tmp/faximage.tif|caller) on SIP/sipgate-fcd0
File name is '/tmp/faximage.tif'
Changed from phase 0 to 2
Slow carrier up
Slow carrier down
Slow carrier up
<<< NSF: 20 20 81 80 80 c0 04
NSF without final frame tag
<<< CSI: 40 39 33 33 38 32 20 32 36 34 37 33 20 39 34 2b 20 20 20 20 20
CSI without final frame tag
Remote fax gave CSI as: "+49 37462 28339"
<<< DIS: 80 00 ee f8 44
DIS with final frame tag
In state 10
DIS:
Preferred octets: 256
Can receive fax
Supported data signalling rates: V.27ter, V.29 and V.17
R8x7.7lines/mm and/or 200x200pels/25.4mm OK
2D coding OK
Scan line length: 215mm
Recording length: A4 (297mm) and B4 (364mm)
Receiver's minimum scan line time: 0ms at 3.85 l/mm: T7.7 = T3.85
Error correction mode
T.6 coding
DCS:
Selected data signalling rate: V.29, 9600bps
2D coding OK
Minimum scan line time: 0ms
Start sending document
Start tx document - compression 2
Standard mode
Changed from phase 2 to 4
Sending ident
>>> TSI: 43 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
>>> DCS: 83 00 84 70
HDLC underflow in state 3
Changed from phase 4 to 6
Changed from phase 6 to 3
Slow carrier up
<<< CFR: 84
CFR with final frame tag
In state 4
Trainability test succeeded
Start tx page
Page 1 of /tmp/faximage.tif
842 rows/3968 bytes to send
Changed from phase 3 to 6
Changed from phase 6 to 4
Start tx page
>>> EOP: 2f
HDLC underflow in state 14
Changed from phase 4 to 3
Slow carrier up
<<< RTN: 4c
RTN with final frame tag
In state 14
Changed from phase 3 to 4
>>> DCN: fb
HDLC underflow in state 2
Disconnecting
Changed from phase 4 to 7
Changed from phase 7 to 8
hat vielleicht jemand ne idee woran das liegen könnte??
Das ist aber ärgerlich! Wie sieht das mit den codecs aus? Wurde zur übertragung alaw oder ulaw gewählt? Sonst wird das mangels Qualität der Übertragung wohl nix!
dann sollte zumindest nen übertragungsfehler kommen....
nachdem das fax raus is lässt sich asterisk auch net mehr beenden und fährt sich fest....
hmm... bug in spandsp? fehler in der libtiff? inkompatible * / spandsp-versionen?
ja die punkte gingen mir auch schon durch den kopf....
welche spandsp is denn fürdie neueste cvs vom * kompatibel bzw gibts da schon eine?
hab nun neues spandsp installiert... nun bleibt er zumindesmehr hängen
trotzdem leeres fax :(
edit: zu früh gefreut... das teil fährt sich nach wie vor fest
zusätzlich kommt nen segmenttion fault
mittlerweilehabe ihc mir ne neue libtiff gezogen... empfangen geht nun
nur leider geht das senden noch immer nicht :(
asterisk spuckt folgendes aus
    -- Attempting call on SIP/03746228339@sipgate for application txfax(/tmp/faximage.tif) (Retry 1)
       > Channel SIP/sipgate-86ac was answered.
       > Lauching txfax(/tmp/faximage.tif) on SIP/sipgate-86ac
In state 9
Start tx document
FTT with final frame tag
In state 4
XCN with final frame tag
In state 4
Feb 15 14:23:13 NOTICE[7954]: pbx_spool.c:242 attempt_thread: Call completed to SIP/03746228339@sipgate
keiner ne idee?
edit:
jetzt schaffe ich es mittlerweile durch ständiges probieren das 3cm des ersten faxes ankommen, dann aber die übertragung abbricht.
wie zwinge ich asterisk dazu bei sip verbindungen nen speziellen codec zu nehmen?
mit allow=ulaw?? das hab ich gemacht dennoch kommt es zu ü-fehlern
akasa
