Asterisk spandsp txfax hangup?
macsea
27 Dez 2004
Hi Leute!
Habe jetzt schon länger spandsp am laufen, aber immer Probleme beim empfang von einzelnen Faxes. Leider konnte ich noch erkennen ob es ein Schema gibt, warum manche Faxes kommen und andere sofort einen Hangup machen. Hier mal eine Auswertung von einem Fax was sofort hangup macht.
Bitte um eure Hilfe, wäre dringend.
< Protocol Discriminator: Q.931 (8) len=4
< Call Ref: len= 1 (reference 1/0x1) (Originator)
< Message type: RELEASE COMPLETE (90)
NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Null, peerstate Null
NEW_HANGUP DEBUG: Destroying the call, ourstate Null, peerstate Null
< Protocol Discriminator: Q.931 (8) len=36
< Message type: SETUP (5)
< [04 03 90 90 a3]
< Bearer Capability (len= 5) [ Ext: 1 Q.931 Std: 0 Info transfer capability: 3.1kHz audio (16)
< Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
< Ext: 1 User information layer 1: A-Law (35)
< [18 01 89]
< Channel ID (len= 3) [ Ext: 1 IntID: Implicit, Other Spare: 0, Exclusive Dchan: 0
< ChanSel: B1 channel
< [1e 02 84 83]
< Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Public network serving the remote user (4)
< Ext: 1 Progress Description: Calling equipment is non-ISDN. (3) ]
< [29 05 06 03 09 08 38]
< Time Date (len= 7) [ 06-03-09 08:56 ]
< [6c 0b 21 83 32 39 34 32 32 38 33 38 37]
< Calling Number (len=13) [ Ext: 0 TON: National Number (2) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
< Presentation: Presentation allowed of network provided number (3) '294228387' ]
-- Making new call for cr 1
-- Processing Q.931 Call Setup
-- Processing IE 4 (cs0, Bearer Capability)
-- Processing IE 24 (cs0, Channel Identification)
-- Processing IE 30 (cs0, Progress Indicator)
-- Processing IE 41 (cs0, Date/Time)
-- Processing IE 108 (cs0, Calling Party Number)
> Protocol Discriminator: Q.931 (8) len=11
> Call Ref: len= 1 (reference 129/0x81) (Terminator)
> Message type: SETUP ACKNOWLEDGE (13)
> [18 01 89]
> ChanSel: B1 channel
> [1e 02 81 82]
> Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
> Ext: 1 Progress Description: Called equipment is non-ISDN. (2) ]
-- Executing WaitExten("Zap/1-1", "4") in new stack
-- Accepting voice call from '294228387' to 's' on channel 0/1, span 1
< Protocol Discriminator: Q.931 (8) len=8
< Message type: INFORMATION (123)
< [70 02 81 31]
< Called Number (len= 4) [ Ext: 1 TON: Unknown Number Type (0) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1) '1' ]
-- Processing IE 112 (cs0, Called Party Number)
< [70 02 81 38]
< Called Number (len= 4) [ Ext: 1 TON: Unknown Number Type (0) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1) '8' ]
== CDR updated on Zap/1-1
-- Executing Answer("Zap/1-1", "") in new stack
> Message type: CONNECT (7)
> [18 01 89]
> ChanSel: B1 channel
> [1e 02 81 82]
-- Executing Wait("Zap/1-1", "3") in new stack
< Message type: CONNECT ACKNOWLEDGE (15)
-- Executing Macro("Zap/1-1", "faxempfang") in new stack
-- Executing SetVar("Zap/1-1", "FAXFILE=/var/spool/asterisk/fax/asterisk-4416-1141890844.3772") in new stack
-- Executing SetVar("Zap/1-1", "[email protected]") in new stack
-- Executing RxFAX("Zap/1-1", "/var/spool/asterisk/fax/asterisk-4416-1141890844.3772") in new stack
-- Redirecting Zap/1-1 to fax extension
-- Executing System("Zap/1-1", "/etc/asterisk/faxmail "0294228387" "[email protected]" "/var/spool/asterisk/fax/asterisk-4416-1141890844.3772"") in new stack
NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Active, peerstate Active
> Message type: DISCONNECT (69)
> [08 02 81 90]
> Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
> Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
-- Hungup 'Zap/1-1'
Kraehe82
