testasterisk:/usr/src/packages/SOURCES/unixODBC-2.2.11 # ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gawk... (cached) gawk
checking for bison... bison -y
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for flex... flex
checking for yywrap in -lfl... yes
checking lex output file root... lex.yy
checking whether yytext is a pointer... yes
checking whether ln -s works... yes
checking whether make sets $(MAKE)... (cached) yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking sys/sem.h usability... yes
checking sys/sem.h presence... yes
checking for sys/sem.h... yes
checking Have we enabled using RTLD_GROUP ... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for ld used by GCC... /usr/i586-suse-linux/bin/ld
checking if the linker (/usr/i586-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/i586-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking how to recognise dependant libraries... pass_all
checking command to parse /usr/bin/nm -B output... ok
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for ranlib... ranlib
checking for strip... strip
checking for objdir... .libs
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.lo... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking whether the linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking whether -lc should be explicitly linked in... no
creating libtool
checking if we are using the included libltdl ... yes
checking which extension is used for shared libraries... .so
checking for iconv... yes
checking for iconv declaration...
extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for encoding to use for CHAR representations ... auto-search
checking for encoding to use for UNICODE representations ... auto-search
checking for crypt in -lcrypt... yes
checking for pow in -lm... yes
checking for readline in -lreadline ... no
checking for readline in -lreadline -lcurses ... no
checking Are we using flex ... yes
checking whether time.h and sys/time.h may both be included... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for long... yes
checking size of long... 4
checking if platform is 64 bit... No
checking for long long... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for vsnprintf... yes
checking for strtol... yes
checking for atoll... yes
checking for strtoll... yes
checking for endpwent... yes
checking for mutex_lock in -lthread ... no
checking for pthread_mutex_lock in -lpthread... yes
checking if compiler accepts -pthread... yes
checking for localtime_r in -lc... yes
checking for ftok... yes
checking for semget... yes
checking for shmget... yes
checking for semop... yes
checking for snprintf... yes
checking for semundo union... yes
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for X... configure: error: Can't find X includes. Please check your installation and add the correct paths or run configure with --enable-gui=no!
testasterisk:/usr/src/packages/SOURCES/unixODBC-2.2.11 # make
make: *** No targets specified and no makefile found. Stop.
testasterisk:/usr/src/packages/SOURCES/unixODBC-2.2.11 # make install
make: *** No rule to make target `install'. Stop.
