asterisk.vim syntax highlighting
mac_7
25 Jan 2005
append to file /usr/share/vim/filetype.vim
" Asterisk config file
au BufNewFile,BufRead *asterisk/*.conf*         setf asterisk
create file /usr/share/vim/syntax/asterisk.vim
" Vim syntax file
" Language:	Asterisk config file
" Maintainer:	brc007
" Last Change:	2004 Jun 6
" version 0.1
" For version 5.x: Clear all syntax items
" For version 6.x: Quit when a syntax file was already loaded
if version < 600
  syntax clear
elseif exists("b:current_syntax")
  finish
endif
"testing only
syn sync clear
syn sync fromstart
syn keyword	asteriskTodo	TODO contained
syn match	asteriskComment		";.*" contains=asteriskTodo
syn match	asteriskContext		"\[.*\]"
syn match	asteriskExten		"^\s*exten\s*=>"
syn match       asteriskApp             "\s*,\s*\zs[a-zA-Z]*\ze"
syn match       asteriskPriority        "\s*,\s*\zs[0-9][0-9]*\ze\s*"
syn match       asteriskInclude		"^#.*"
syn match       asteriskVar		"\${[A-Za-z][A-Za-z0-9_]*}"
syn match       asteriskExp		"\$\[.*\]"
" Define the default highlighting.
" For version 5.7 and earlier: only when not done already
" For version 5.8 and later: only when an item doesn't have highlighting yet
:if version >= 508 || !exists("did_conf_syntax_inits")
  if version < 508
    let did_conf_syntax_inits = 1
    command -nargs=+ HiLink hi link <args>
  else
    command -nargs=+ HiLink hi def link <args>
  endif
  HiLink	asteriskComment	Comment
" not sure what type this should be, using String for testing.
  HiLink	asteriskExten	String
" same here
  HiLink	asteriskContext		Identifier
  HiLink        asteriskApplication     Statement
  HiLink        asteriskInclude		Preproc
  HiLink	asteriskPriority	Preproc
  HiLink        asteriskVar		Type
  HiLink        asteriskExp		Type
 delcommand HiLink
endif
let b:current_syntax = "asterisk"
" vim: ts=8 sw=2
http://www.voip-info.org/tiki-print.php?page=vim+syntax+highlighting
Knockout
