AVM Fon 5012: two questions
tommmy.leee
3 Feb 2005
hello,
my 2 questions about this FBF 5012:
1) is this possible to have 2 concurrent VoIP talks on two connected to both S0 ports telephones? also if only one is (Siemens 353) connected but having 2 headsets?
2) how to change SIP/RTP ports in use?
thank you,
Tom
PS. i have 5012 from GMX
hello,
1. yes ist is possible to have 2 concurrent VoIP talks, but only with two phones connected to the S0 port. I don't think that it's possible with only one telephone with two headsets. But as this depends on this phone, you should consult the manual of your Siemens 353.
2. I don't think that it is possible to change these ports.
radio_junkie
radio_junkie schrieb:
hello,
It is possible if you use the Sx353 with one extra DECT-Handset or you use more DECT-Handsets on the Sx353. With these Handsets you can make two calls at the same time.
thank you very much! exactly what i wanted to know!
question about SIP/RTP ports range i will ask in "AVM Mod" subforum, thanks again!
nikitarajusa
