[Gelöst] Build Problem mit tools
JohnDoe42
Aktives Mitglied
17 Mrz 2009
mit dem aktuellen Git-Repostatus ergibt sich bei mir ein Problem beim Bauen der host-tools:
---> tools/make-host ...
configuring ... (cd /home/john/Githubs/freetz-ng/source/host-tools/pseudo-cc1f6167cb5065daba1462056e2dce8ff72aa855/arch; rm -f config.cache Makefile; \
    CC="gcc" \
    CXX="g++" \
    CFLAGS="-Wall -O2" \
    CXXFLAGS="-Wall -O2" \
    LDFLAGS="" \
    ./configure \
    --prefix=/home/john/Githubs/freetz-ng/tools/build \
    --enable-xattr=no \
    --bits=32 \
    --cflags="-Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32" \
    --libdir=/home/john/Githubs/freetz-ng/tools/build/lib \
    --disable-nls \
warning: Unrecognized option '--enable---disable-nls=no'
SQLite header for version 3022000 found in /usr.
Enabling in-memory database by default.
touch /home/john/Githubs/freetz-ng/source/host-tools/pseudo-cc1f6167cb5065daba1462056e2dce8ff72aa855/arch/.configured
cmd() { make -j5  "$@"  || { [ "2" = "0" ] && echo && cat .build.log 2>/dev/null; kill $$ 2>/dev/null || kill $$$$ 2>/dev/null; printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };             mkdir -p source; [ -n "" ] && step="/" || step=""; [ -n "" ] && step="$step/"; case "" in BIN)    echo -n "package/"         >source/.echo_item_tmp ;; LIB)    echo -n "library/"         >source/.echo_item_tmp ;; HTL)    echo -n "tools/"           >source/.echo_item_tmp ;; KTC)    echo -n "toolchain/kernel$step" >source/.echo_item_tmp ;; TTC)    echo -n "toolchain/target$step" >source/.echo_item_tmp ;; KRN)    echo -n "kernel"                 >source/.echo_item_tmp ;; esac; if ! diff -q source/.echo_item_tmp source/.echo_item_new >/dev/null 2>&1 || [ ! -e source/.echo_item_1st ]; then     if [ -e source/.echo_item_end -a -e source/.echo_item_new -a -e source/.echo_item_1st ]; then echo -e "\e[48;5;26mdone\e[49m."; rm -f source/.echo_item_end source/.echo_item_1st; fi; [ -s source/.echo_item_tmp ] && cat source/.echo_item_tmp > source/.echo_item_new 2>/dev/null; [ -s source/.echo_item_new ] || cat source/.echo_item_old > source/.echo_item_new 2>/dev/null; if [ -s "source/.echo_item_new" ]; then echo -ne "\e[48;5;90m---> "; cat source/.echo_item_new 2>/dev/null | tee source/.echo_item_old; echo -ne "\e[49m ... "; [ "2" != "0" ] && echo; touch source/.echo_item_end; touch source/.echo_item_1st; fi; fi; echo -ne "\e[48;5;56mbuilding\e[49m ... "; cmd -C /home/john/Githubs/freetz-ng/source/host-tools/pseudo-cc1f6167cb5065daba1462056e2dce8ff72aa855/arch install-lib
done.
building ... CC="cc  -pipe -std=gnu99 -Wall -W -Wextra -Wno-deprecated-declarations -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32 -DPSEUDO_PREFIX='"/home/john/Githubs/freetz-ng/tools/build"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB  -DPSEUDO_PASSWD_FALLBACK='""'           -O2 -g " ./makewrappers "xattr=false"
./maketables enums/*.in
enums/debug_type.in: Flags: set for debug_type
type: debug_type_t (prefix 'PDBG_ENUM')
  extra column: unsigned char symbolic (default '\0')
  extra column: const char * description (default NULL)
   consistency        file               op                 pid
   client             server             db                 xattrdb
   profile            syscall            env                chroot
   path               sql                wrapper            ipc
   invoke             benchmark          verbose            xattr
enums/exit_status.in: type: exit_status_t (prefix 'PSEUDO_EXIT_ENUM')
  extra column: char * message (default "exit status unknown")
   general            fork_failed        lock_path          lock_held
   lock_failed        timeout            waitpid            socket_create
   socket_fd          socket_path        socket_unlink      socket_bind
   socket_listen      listen_fd          pseudo_loaded      pseudo_prefix
   pseudo_invocation  epoll_create       epoll_ctl
enums/msg_type.in: type: msg_type_t (prefix 'PSEUDO_MSG_ENUM')
   ping               shutdown           op                 ack
   nak                fastop
enums/op.in: type: op_t (prefix 'OP_ENUM')
  extra column: int wait (default 0)
   chdir              chmod              chown              chroot
   close              creat              dup                fchmod
   fchown             fstat              link               mkdir
   mknod              open               rename             stat
   unlink             symlink            exec               may-unlink
   did-unlink         cancel-unlink      get-xattr          list-xattr
   remove-xattr       set-xattr          create-xattr       replace-xattr
   closefrom
enums/query_field.in: type: query_field_t (prefix 'PSQF_ENUM')
   access             client             dev                fd
   ftype              gid                id                 inode
   mode               op                 order              path
   perm               program            result             severity
   stamp              tag                text               type
   uid
enums/query_type.in: type: query_type_t (prefix 'PSQT_ENUM')
  extra column: const char * sql (default "LITTLE BOBBY TABLES")
   exact              less               greater            bitand
   notequal           like               notlike            sqlpat
enums/res.in: type: res_t (prefix 'RESULT_ENUM')
   succeed            fail               error              abort
enums/sev.in: type: sev_t (prefix 'SEVERITY_ENUM')
   debug              info               warn               error
   critical
Writing datatypes...
done.  Cleaning up.
Considering template: templates/wrapper_table
Considering template: templates/wrapfuncs.c
Considering template: templates/func_deps
Considering template: templates/guts
Considering template: templates/pseudo_ports
Considering template: templates/port_deps
Considering template: templates/wrapfuncs.h
Considering template: templates/port_wrappers
common
ports/common/wrapfuncs.in: .......
cc  -pipe -std=gnu99 -Wall -W -Wextra -Wno-deprecated-declarations -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32 -DPSEUDO_PREFIX='"/home/john/Githubs/freetz-ng/tools/build"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB  -DPSEUDO_PASSWD_FALLBACK='""'           -O2 -g  -c -o pseudo_tables.o pseudo_tables.c
linux
ports/linux/wrapfuncs.in: .................................................................
unix
ports/unix/wrapfuncs.in: ......................................................................
uids_generic
ports/uids_generic/wrapfuncs.in: ........................
Checking for old/new clone mechanics... New clone.
linux/newclone
ports/linux/newclone/wrapfuncs.in: .
linux/noxattr
ports/linux/noxattr/wrapfuncs.in: ............
linux/statvfs
ports/linux/statvfs/wrapfuncs.in: .
linux/nostatx
linux/statx
ports/linux/statx/wrapfuncs.in: .
Writing functions...
Warning: lchown from linux overriding unix
Warning: mknod from linux overriding unix
Warning: mknodat from linux overriding unix
done.  Cleaning up.
cc -fno-strict-aliasing  -pipe -std=gnu99 -Wall -W -Wextra -Wno-deprecated-declarations -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32 -DPSEUDO_PREFIX='"/home/john/Githubs/freetz-ng/tools/build"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB  -DPSEUDO_PASSWD_FALLBACK='""'           -O2 -g  -D_GNU_SOURCE -c -o pseudo_wrappers.o pseudo_wrappers.c
cc -c   -pipe -std=gnu99 -Wall -W -Wextra -Wno-deprecated-declarations -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32 -DPSEUDO_PREFIX='"/home/john/Githubs/freetz-ng/tools/build"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB  -DPSEUDO_PASSWD_FALLBACK='""'           -O2 -g  pseudo_client.c
cc -c   -pipe -std=gnu99 -Wall -W -Wextra -Wno-deprecated-declarations -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32 -DPSEUDO_PREFIX='"/home/john/Githubs/freetz-ng/tools/build"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB  -DPSEUDO_PASSWD_FALLBACK='""'           -O2 -g  pseudo_ipc.c
cc -c   -pipe -std=gnu99 -Wall -W -Wextra -Wno-deprecated-declarations -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32 -DPSEUDO_PREFIX='"/home/john/Githubs/freetz-ng/tools/build"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB  -DPSEUDO_PASSWD_FALLBACK='""'           -O2 -g  pseudo_util.c
pseudo_util.c: In function 'pseudo_fix_path':
pseudo_util.c:825:24: warning: return discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
  825 |                 return path;
In file included from pseudo_wrappers.c:297:
pseudo_wrapfuncs.c:9417:49: warning: argument 2 of type 'const struct timeval *' declared as a pointer [-Warray-parameter=]
 9417 | lutimes(const char *path, const struct timeval *tv) {
In file included from pseudo_wrappers.c:25:
/usr/include/sys/time.h:140:62: note: previously declared as an array 'const struct timeval[2]'
  140 | extern int lutimes (const char *__file, const struct timeval __tvp[2])
pseudo_wrapfuncs.c:15582:48: warning: argument 2 of type 'const struct timeval *' declared as a pointer [-Warray-parameter=]
15582 | utimes(const char *path, const struct timeval *times) {
/usr/include/sys/time.h:135:61: note: previously declared as an array 'const struct timeval[2]'
  135 | extern int utimes (const char *__file, const struct timeval __tvp[2])
cc  -pipe -std=gnu99 -Wall -W -Wextra -Wno-deprecated-declarations -fPIC -D_LARGEFILE64_SOURCE -D_ATFILE_SOURCE -Wno-cast-function-type -Wno-nonnull-compare -fcommon -m32 -DPSEUDO_PREFIX='"/home/john/Githubs/freetz-ng/tools/build"' -DPSEUDO_SUFFIX='""' -DPSEUDO_BINDIR='"bin"' -DPSEUDO_LIBDIR='"lib"' -DPSEUDO_LOCALSTATEDIR='"var/pseudo"' -DPSEUDO_VERSION='"1.9.0"' -DUSE_MEMORY_DB  -DPSEUDO_PASSWD_FALLBACK='""'           -O2 -g  -shared -o lib/libpseudo.so \
    pseudo_client.o pseudo_ipc.o \
    pseudo_wrappers.o pseudo_tables.o pseudo_util.o  -ldl -lpthread
/usr/local/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/13/libgcc.a when searching for -lgcc
/usr/local/bin/ld: cannot find -lgcc: No such file or directory
collect2: error: ld returned 1 exit status
Makefile:123: recipe for target 'lib/libpseudo.so' failed
make[2]: *** [lib/libpseudo.so] Error 1
make/host-tools/pseudo-host/pseudo-host.mk:61: recipe for target '/home/john/Githubs/freetz-ng/tools/build/lib/libpseudo.so' failed
make[1]: *** [/home/john/Githubs/freetz-ng/tools/build/lib/libpseudo.so] Terminated
Makefile:47: recipe for target 'envira' failed
make: *** [envira] Beendet
Hat jemand einen Tip, was ich tun oder weiter analysieren könnte ?
JD.
Da wird wohl ein 32-bittiges make als Tool für den Build-Host gebaut, der ist aber offenbar ein 64-bittiges x86-System, wenn man dem Pfad, in dem der Linker (ld) nach der (statisch gelinkten) Bibliothek libgcc sucht, Glauben schenkt.
Ohne da genaueres zu wissen, würde ich als erstes mal nachsehen, ob die 32-Bit-Version (EDIT: bzw. die 32-Bit-Bibliotheken) des gcc 13 auch verfügbar/installiert ist - steht sie auch im (Linker-)Pfad, wird sicherlich auch die libgcc.a in der (für pseudo gesuchten) korrekten Version gefunden.
@PeterPawn : Danke für Dein aufmerksames Auge, ich habe nun einen älteren gcc (11) verwendet, der auf meinem Buildsystem (auch) installiert ist. Damit läuft zumindest das Bauen der Tools.
JD.
Hilbth
