cannot switch on WLAN
hrust_ray
11 Jan 2007
Hi.
On my FB 7141 I got troubles while switching on WLAN via telefoneCode or via button(near WLAN antenna). If FB is just rebooted - all works fine.
If it was working for several hours, it cannot be switched on. If I try to switch via telefoneCode, Led all time off. In webinterface I see that WLAN is on, but I cannot communicate fron Notebook.
If I press small button near antenna, WLAN led is blinking all time and also no connection from NB.
If I reboot FB, WLAN Led activates and all stuff is working correct.
Somebody has idea, what is the problem and how I can check logfiles f.e.?
matzzor
