Capi Problem + Externe anwahl
Sunnyboy_81
7 Feb 2006
Mei Asterik nimmt Anrufe entegegen und leitet diese dann auch ordnungsgemäß an ein sip bzw iax Tel weiter. Nur wenn ich von einen SIP / IAX Tel ins Festnetz wählen möchte bringt er folgendes:
Dial ("IAX2/401-2"2 "CAPI/:539") in new stack
didn't find capi device for interface ':539'
Unable to create channel of type 'Capi' ( Cause 44 Requested channel not available)
hoffe mal mir kann jm hier weiterhelfen!?
; CAPI config
; general section
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
language=de ;set default language
;ulaw=yes ;set this, if you live in u-law world instead of a-law
; interface sections ...
[ISDN1] ;this example interface gets name 'ISDN1' and may be any
;name not starting with 'g' or 'contr'.
;ntmode=yes ;if isdn card operates in nt mode, set this to yes
isdnmode=msn ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
;when using NT-mode, 'DID' should be set in any case
incomingmsn=* ;allow incoming calls to this list of MSNs/DIDs, * = any
;defaultcid=123 ;set a default caller id to that interface for dial-out,
;this caller id will be used when dial option 'd' is set.
;controller=0 ;ISDN4BSD default
;controller=7 ;ISDN4BSD USB default
controller=1 ;capi controller number to use
group=1 ;dialout group
;prefix=0 ;set a prefix to calling number on incoming calls
softdtmf=on ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on ;in addition to softdtmf, you can use relaxed dtmf detection
accountcode= ;Asterisk accountcode to use in CDRs
context=capi-in ;context for incoming calls
;holdtype=hold ;when Asterisk puts the call on hold, ISDN HOLD will be used. If
;set to 'local' (default value), no hold is done and Asterisk may
;play MOH.
;immediate=yes ;DID: immediate start of pbx with extension 's' if no digits were
; received on incoming call (no destination number yet)
;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
; info like REDIRECTINGNUMBER may be lost, but this is necessary for
; drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
;echosquelch=1 ;_VERY_PRIMITIVE_ echo suppression
;echocancel=yes ;EICON DIVA SERVER (CAPI) echo cancelation
;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64 ;echo cancel tail setting
;bridge=yes ;native bridging (CAPI line interconnect) if available
;callgroup=1 ;Asterisk call group
;language=de ;set language for this device (overwrites default language)
devices=2 ;number of concurrent calls on this controller
;(2 makes sense for single BRI, 30 for PRI)
[interface]
msn=179
incomingmsn=*
controller=1
softdtmf=1
accountcode=
context=default
;echosquelch=1
;echocancel=yes
;echotail=64
;callgroup=1
;deflect=12345678
devices=2
msn=401
incomingmsn=*
controller=1
softdtmf=1
accountcode=
context=default
;echosquelch=1
;echocancel=yes
;echotail=64
;callgroup=1
;deflect=12345678
devices=2
msn=402
incomingmsn=*
controller=1
softdtmf=1
accountcode=
context=default
;echosquelch=1
;echocancel=yes
;echotail=64
;callgroup=1
;deflect=12345678
devices=2
msn=403
incomingmsn=*
controller=1
softdtmf=1
accountcode=
context=default
;echosquelch=1
;echocancel=yes
;echotail=64
;callgroup=1
;deflect=12345678
devices=2
msn=404
incomingmsn=*
controller=1
softdtmf=1
accountcode=
context=default
;echosquelch=1
;echocancel=yes
;echotail=64
;callgroup=1
;deflect=12345678
devices=2
msn=405
incomingmsn=*
controller=1
softdtmf=1
accountcode=
context=default
;echosquelch=1
;echocancel=yes
;echotail=64
;callgroup=1
;deflect=12345678
devices=2
msn=406
incomingmsn=*
controller=1
softdtmf=1
accountcode=
context=default
;echosquelch=1
;echocancel=yes
;echotail=64
;callgroup=1
;deflect=12345678
devices=2
extensions.conf
[general]
static=yes
writeprotect=no
[globals]
ICT_IAXSERVER=ict-asterisk
ICT_Remote_IAXSERVER=remote-asterisk
; Hauptkontext fuer lokale und iaxtel Anrufe.
[local]
include => default
[macro-ruf]
; Standard Extension fuer einen Anrufbeantworter:
; ${ARG1} - Teilnehmer
;exten => s,1,Dial(SIP/${ARG1},30,Ttr) ; 30 Sekunden maximal klingeln lassen
exten => s,1,Dial(IAX2/${ICT_Remote_IAXSERVER}/${ARG1}&SIP/${ARG1}&IAX2/${ARG1},60)
exten => s,2,Goto(s-${DIALSTATUS},1)
exten => s-BUSY,1,Playback(vm-nobodyavail)
exten => s-BUSY,2,Congestion
exten => s-BUSY,3,Hangup
exten => s-NOANSWER,1,Playback(vm-nobodyavail)
exten => s-NOANSWER,2,Congestion
exten => s-NOANSWER,3,Hangup
exten => s-CHANUNAVAIL,1,Playback(vm-nobodyavail)
exten => s-CHANUNAVAIL,2,Congestion
exten => s-CHANUNAVAIL,3,Hangup
exten => s-.,1,Hangup
; Zuordnungen wenn ein Anruf herreinkommt
[InComing]
exten => 179,1,Macro(ruf,179)
exten => 401,1,Macro(ruf,401)
exten => 402,1,Macro(ruf,402)
exten => 403,1,Macro(ruf,403)
exten => 404,1,Macro(ruf,404)
exten => 405,1,Macro(ruf,405)
exten => 406,1,Macro(ruf,406)
;********************************* Test Nummer(n) ******************************************
[Zeit]
exten => 4000,1,SayUnixTime
exten => 4000,2,Hangup
;Mit 8000 Laesst sich die Mailbox abhoeren
[VoiceMail]
exten => 8000,1,VoicemailMain
exten => 8000,2,Goto(default,s,6)
;Die Extension 8001 ist fuer den Echotest.
[EchoTest]
exten => 8001,1,Playback(demo-echotest) ; Gibt eine Ansage zum Echotest.
exten => 8001,2,Echo ; Echotest
exten => 8001,3,Playback(demo-echodone) ; Bedankt sich fuer den Echotest.
exten => 8001,4,Hangup ; legt auf
; Wenn 8888 gewaehlt wir eine Demo abgespielt
[Demo]
exten => 8888,1,BackGround(demo-congrats) ; Spielt eine Begrüssungsnachricht
exten => 8888,2,Playback(demo-thanks) ; Die Demo bedankt sich und
exten => 8888,3,Hangup ; legt auf
[Intern]
exten => _9XXX,1,Macro(ruf,${EXTEN:1})
[Extern-InHouse]
exten => _XXX,1,Dial(CAPI/${CALLERIDNUM}:${EXTEN})
[FestNetz]
exten => _XXXXX.,1,Dial(CAPI/${CALLERIDNUM}:0${EXTEN})
[default]
include => Demo
include => Zeit
include => EchoTest
include => VoiceMail
include => InComing
include => Intern
include => Extern-InHouse
include => FestNetz
a) bitte benutze das nächste mal Code-Blöcke
b) Die Beispiel-capi.conf von chan_capi schickst do vorne mit, machst es aber trotzdem total anders. welches chan_capi nutzt Du denn nun? (und welchen Asterisk?)?
c) Wie man es richtig macht (sogar für verschiedene Versionen) steht hier ganz oben drin. Ist sogar als wichtig markiert. Vielleicht solltest Du das erstmal lesen.
Hallo nochmal,
ok für meine weitere post werde ich mir das merken dass ich diesen in einen code block setze. Bin nun nicht im Geschäft aber müßte die Asterisk Version die neuste Asterisk mit Chan-Capi cm sein. Kann ich dir leider erst morgen ganz genau sagen.
Hallo Hupe,
danke für den Tipp meine config geändert nun funktioniert die anwahl!
Hab nun nur noch mein anderes Problem das keine sprache übertragen wird sprich wenn ich auf meinem handy anrufe höre ich den IAx Client.
Der Iax Client empfängt aber die sprache vom handy!
Hast da auch ne idee!?
Besteht das Problem nur mit dem IAX-Client, und nur von deinem Handy aus. Wo hört man nun nix beim Iax-Client, oder beim Handy?
Was für ein chan_capi, welche Version von Asterisk und welchen Keinel benutzt Du?
Also habe Asterisk 1.2.1 und habe gerade etwas über ein update auf 1.2.4 gelsen da die anderen irgendwie stumm geworden wären.
Von chan-Capi benutze ich die version 0.6.3.
Jetzt ist nur die Frage wie ich den asterisk nun am besten update da ich ihn zuvor aus dem debian packet installiert habe.
Wenn ich den wirklich updaten muss habe ich noich eine frage hab mir noch einen anderen asterisk gemacht mit dem bristuff script und einer hfc karte im nt modus und das ist auch die version 1.2.1
und das hat eine ganze zeit gedauert bis der lief!
Sichere das Verzeichnis /etc/asterisk und installiere den Asterisk nach der Anleitung:
http://www.ip-phone-forum.de/showthread.php?t=91217
Eventuell musst Du den Priority-Jump für die extensions.conf aktivieren. Und einige (kleinere) Anpassungen in den config-Dateien machen.
ToniSI
