China,Taiwan Exoten Hardware
Anonymous
20 Feb 2004
HP 300 VoIP phone is a next generation intelligent communication device, delivering the essential business communications at a touch
Primarily designed as an IP-PBX feature telephone with LCD screen for business applications, and provides straightforward user customerization based on changing needs
It is also good for ITSP, multi-branch offices or SOHO applications combined with broadband access
Properties:
LCD screen: 2 x 16 characters
12 standard dialing keys: 0~9, *, #
10 feature keys: flash, redial, hold, speaker, mute, conf 10-speed dial keys (optional)
Adjustable speaker/ring/handset volume by button
Hearing aid compatible handset
Key characteristics:
LCD screen:
Date/time
Calling party name
Calling party number
Digits dialed
System information, and more
LED indication:
Hold, mute, speaker, message, and conf
Large indicator for message or voice mail
Additional features:
Remote configuration and upgrade through web browser
PPPOE auto redial capability
Support call forward/transfer function
One RJ-11 port (FXS) for analog telephone connection (optional)
One RJ-11 port (FXO) for PSNT connection (optional)
Primary Competitive Advantages:
Product Performance
Prompt Delivery
Quality Approvals
Service
Price
Main Export Markets:
Eastern Europe
Asia
Western Europe
Australasia
Easy interface to ADSL/cable modem or leased line equipment
Two 10/100Base-T Ethernet ports with switch/hub inside
One RJ-11 PSTN analog line interface
Support ITU-T H.323 V2/V3/V4 protocol
Supports SIP protocol (**)
Supports PPPoE
Behind NAT router or IP sharing device
Supports both fixed IP and DHCP
Supports fast start and H.245 tunneling
Supports H.235 security function
Provides H.450 services (hold, transfer, forward)
Supports ten E.164 (line numbers)
Automatically gatekeeper discovery
Alternative gatekeeper selection
Provides peer-to-peer mode (non-gatekeper needed) selection
2 x 24 dot-matrix LCD panel
Speakerphone and handset operation
Ring tone, speaker and handset volume adjustable
Supports 802-1P1Q (LP201 only)
Supports DNS server inquiry
LCD panel: displays time, date, caller ID, call duration
MS-Netmeeting V3.0 compatible
G.711 A/u-Law, G.723.1, G.279A, G.729, G.168/G.165 compliant echo cancellation
Programmable dynamic jitter buffer
Bad frame interpolation
Provides progress tone: dial tone, busy tone, call holding tone and ring-back tone
TFTP/FTP download
Two-in-one (analog phone and IP phone)
Password protection on LCD panel configuration
Configured by web browser Telnet and LCD front panel
Supports TTIC management center function
(**): contact TTIC for availability
Product Performance
Prompt Delivery
Quality Approvals
Service
Price
Worldwide
Voice:
Call control protocol: H.323 V4 or MGCP or SIP (option)
Voice compression: G.711 A/u-Law, G.723.1, G.729A/B/AB
Support silence suppression, VAD, CNG, acoustic echo cancellation, jitter buffering
Echo cancellation: G.165 16ms
Delayed (end to end): <100ms
Flow of the average: 10 to12kbps
DTMF tone detection
E.164 dial plan
LAN interface:
Interface: 10Base-T Ethernet
Connector type: RJ-45 connector
Networking protocol:
PPPoE
DHCP client/static IP
UDP/TCP
RTP/RCTP
FTP/HTTP/DNS
Dialing methods:
On-hook dialing
Redial key dialing the last dialed numbers
Extension number dialing through gatekeeper/SIP proxy server
Direct IP address dialing to IP phone or gatekeeper/ SIP proxy server
Management functions:
Web browser based management provided
Phone set configuration
Display: 32 characters LCD screen (2 lines with 16 characters each)
Environmental:
Operation temperature: 0 to 40 degrees Celsius (32 to 104 degrees Fahrenheit)
Storage temperature: -30 to 65 degrees Celsius (-22 to 149 degrees Fahrenheit)
Relative humidity: 10% to 95% non-condensing
Power:
Input AC range: 100VAC to 240VAC, 50Hz to 60Hz
Input DC range: 5VDC, 1A
Power consumption: 3W
Other information:
Headset connector
Earphone connector
NAT pass-through (SIP with STUN)
Feature keys: handsfree, mute, redial, speedy dial-up, caller ID, networking status, miss-call, dialed-call, call status, volume up/down, voice response, web configuration, firmware upgrade, LED indicators and others
Certification: UL, CE, FCC
Worldwide
Properties:
Telephone interface: one FXS RJ11 phone port
Network interface: 10/100Base-T RJ-45 port
LED indicators: power, LAN, phone
Software protocol: H.323 V3.0
Speech codec: G.711, G.723.1, G.729A/B (optional)
Signal processing: G.168 echo cancellation, DTMF detection
Power consumption : <500mW, 110VAC/220VAC
Characteristics:
Pocket-sized, portable
Easy setting by DTMF
Global Internet connection
Broadband residential and travel users
Hotline
Gatekeeper supported
Quality Approvals
Product Performance
Prompt Delivery
Service
Price
Worldwide
was willst du uns mit den bildern und featurelisten sagen ? bezugsquellen und typenbezeichnungen fehlen ..
2.Abbildung:
Taiwan Telecommunication Industry Co Ltd
No. 22
Chung-Shan N. Road, Sec. 3
Chung-Shan District
Taipei
Taiwan 104
Tel:  (886 2) 25963788  Ext : 500
Fax:  (886 2) 25988795
Email Address(es):
[email][email protected][/email]
Homepage: http://www.asiansources.com/twteleco.co
Other Homepage Address: http://www.ttic.com.tw
Key Contact:
Mr  Chen,  Stephen
General Manager
1.Abbildung:
Auto Telecom Co Ltd
10F, No. 3, Lane 16
Shih Chuan Road, Sec. 2
Pan Chiao City
Taipei
Taiwan 220
Tel:  (886 2) 29645752  Ext : 550 /  (886 2) 29645752  Ext : 321
Fax:  (886 2) 29645764
Email Address(es):
Homepage: http://www.asiansources.com/autotele.co
Other Homepage Address: http://www.hybrex.com
Email this Supplier
Key Contact:
Mr  Wei,  Jack
Director
Business Dept.
Mr  Hsieh,  Chaucer
Manager
Business Dept.
1st Branch Office Address
Auto Telecom (Australia) Pty Ltd
Unit 7, 3 Gibbes Street
Chatswood
New South Wales
Australia 2067
Tel:  (61 2) 94150100
Fax:  (61 2) 94176877
Key Contact:
Mr  Shao,  Hugh
Director
Business Dept.
2nd Branch Office Address
PT TRANSINDD INFOTEK (Indonesia)
Kamal Raya Outer Ring Road Taman
Palem Lestari Blk D 10 No. 3
Cengkareng - Jakarta Barat 11730
Jakarta
Indonesia
Tel:  (62 21) 5555788
Fax:  (62 21) 5555789
Key Contact:
Mr  Suwinto,  Manager
Business Dept.
Headquarters/Head Office
Auto Telecom Company Limited
10F, No. 3, Lane 16
Pan Chiao
Taipei
Taiwan
Key Contact:
Mr  Wei,  Jack
Director
Business Dept.
3.Abbildung:
ArtDio Company Inc
7F, No. 476
Min-Hu Road
Hsin Chu
Taiwan 300
Tel:  (886 3) 5295000 /  (886 3) 5295000
Email Address(es):
Homepage: http://www.globalsources.com/artdio.co
Other Homepage Address: http://www.artdioinc.com
Email this Supplier
Key Contact:
Mr  Wu,  Chris
(886 3) 5191580
Flash MP3 Players
Mr  Lam Bruce,  Africa/Asia/Australia/European
(886 3) 5295000 Ext. 260
VoIP Products-Sales Department
Mr  Cheng Jay,  America
(626) 3360369
danke ;)
Sobald ich schnurlos Telefon irgendwo sehe geb ich es hier bekannt.
Und auch hier der Tipp, die "Code"-Funktion für längere Produktbeschreibungen zu benutzen. ;-)
So, nun sieht es doch gleich viel aufgeräumter und übersichtlicher aus, nicht?
Bitte an die Editier-Funktion denken, dann könnt Ihr das selbst ändern. ;-)
Also ich finde das nicht übersichtlicher - als alter Querleser seh ich sonst sofort, was ich suche. So muß ich jetzt alles durchscrollen - und das nervt.
Nanu, was denn?
Du kannst so den ganzen Thread viel schneller durchscrollen und von den Beschreibungen scrollst Du das durch, was Dich wirklich interessierst bzw. 1x auf doppelten Pfeile nach unten klicken. ;-)
Ich weiß doch nicht ob da was steht was mich interessiert, das sehe ich doch erst, wenn ich den ganzen Text vor mir sehe - aber genug davon, ist hier nicht das Thema und da bin ich wohl der einzige mit dem Problem.
:wayne:
t0h0t4u
