Cisco 7960 => Netgear FVS318 => SipGate funzt nit
elimn
6 Sep 2004
Moin,
ich hab tierische Probs das Cisco 7960 zum laufen zu bekommen,
es kommt keine Verbindung zu stande. (weder raus noch rein)
(Port-Forwarding / DynDNS / etc. ist alles eingestellt)
Vielleicht könnte einer so nett sein und sich diese configs mal angucken ;)
SIPDefault.cnf
# SIP Default Generic Configuration File
# Image Version
image_version: P0S3-07-2-00
# Proxy Server
p<roxy1_address: "217.10.79.9"		; Can be dotted IP or FQDN
# Proxy Server Port (default - 5060)
proxy1_port: 5060
# Proxy Registration (0-disable (default), 1-enable)
proxy_register: 1
# Phone Registration Expiration [1-3932100 sec] (Default - 3600)
timer_register_expires: 300
# Codec for media stream (g711ulaw (default), g711alaw, g729a)
preferred_codec: g711ulaw
# TOS bits in media stream [0-5] (Default - 5)
tos_media: 5
# Inband DTMF Settings (0-disable, 1-enable (default))
dtmf_inband: 0
# Out of band DTMF Settings (none-disable, avt-avt enable (default), avt_always - always avt )
dtmf_outofband: avt
# DTMF dB Level Settings (1-6dB down, 2-3db down, 3-nominal (default), 4-3db up, 5-6dB up)
dtmf_db_level: 3
####### New Parameters added in Release 2.0 #######
# Dialplan template (.xml format file relative to the TFTP root directory)
dial_template: dialplan
# TFTP Phone Specific Configuration File Directory
tftp_cfg_dir: "./"		; Example:  ./sip_phone/
# Time Server (There are multiple values and configurations refer to Admin Guide for Specifics)
sntp_server: "192.53.103.103"			; SNTP Server IP Address
sntp_mode: unicast	; unicast, multicast, anycast, or directedbroadcast (default)
time_zone: CET			; Time Zone Phone is in
dst_offset: 1			; Offset from Phone's time when DST is in effect
dst_auto_adjust: 1		; Enable(1-Default)/Disable(0) DST automatic adjustment
time_format_24hr: 1		; Enable(1 - 24Hr Default)/Disable(0 - 12Hr)
date_format: D/M/Y
# Do Not Disturb Control (0-off, 1-on, 2-off with no user control, 3-on with no user control)
dnd_control: 0			; Default 0 (Do Not Disturb feature is off)
# Caller ID Blocking (0-disbaled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
callerid_blocking: 0		; Default 0 (Disable sending all calls as anonymous)
# Anonymous Call Blocking (0-disabled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
anonymous_call_block: 0		; Default 0 (Disable blocking of anonymous calls)
# DTMF AVT Payload (Dynamic payload range for AVT tones - 96-127)
dtmf_avt_payload: 101		; Default 101
# Sync value of the phone used for remote reset
sync: 1				; Default 1
####### New Parameters added in Release 2.1 #######
# Backup Proxy Support
proxy_backup: "217.10.79.9"		; Dotted IP of Backup Proxy
proxy_backup_port: 5060		; Backup Proxy port (default is 5060)
# Emergency Proxy Support
# proxy_emergency: "" 		; Dotted IP of Emergency Proxy
# proxy_emergency_port: 5060	; Emergency Proxy port (default is 5060)
# Configurable VAD option
enable_vad: 0			; VAD setting 0-disable (Default), 1-enable
####### New Parameters added in Release 2.2 ######
# NAT/Firewall Traversal
nat_enable: 1                   ; 0-Disabled (default), 1-Enabled
nat_address: "xxxxxxxxxxx"		        ; WAN IP address of NAT box (dotted IP or DNS A record only)
voip_control_port: 5060      	; UDP port used for SIP messages (default - 5060)
start_media_port: 20000 	; Start RTP range for media (default - 16384)
end_media_port: 20200   	; End RTP range for media (default - 32766)
nat_received_processing: 1	; 0-Disabled (default), 1-Enabled
# Outbound Proxy Support
outbound_proxy: "217.10.79.9"	 	; restricted to dotted IP or DNS A record only
outbound_proxy_port: "5060"       ; default is 5060
####### New Parameter added in Release 3.0 #######
# Allow for the bridge on a 3way call to join remaining parties upon hangup
cnf_join_enable : 1		; 0-Disabled, 1-Enabled (default)
####### New Parameters added in Release 3.1 #######
# Allow Transfer to be completed while target phone is still ringing
semi_attended_transfer: 1	; 0-Disabled, 1-Enabled (default)
# Telnet Level (enable or disable the ability to telnet into the phone)
telnet_level: 2			; 0-Disabled (default), 1-Enabled, 2-Privileged
####### New Parameters added in Release 4.0 #######
# XML URLs
services_url: ""		; URL for external Phone Services
directory_url: ""		; URL for external Directory location
logo_url: ""			; URL for branding logo to be used on phone display
# HTTP Proxy Support
http_proxy_addr: ""		; Address of HTTP Proxy server
http_proxy_port: 80		; Port of HTTP Proxy Server (80-default)
# Dynamic DNS/TFTP Support
dyn_dns_addr_1: ""              ; restricted to dotted IP
dyn_dns_addr_2: ""              ; restricted to dotted IP
dyn_tftp_addr: ""               ; restricted to dotted IP
# Remote Party ID
remote_party_id: 0		; 0-Disabled (default), 1-Enabled
####### New Parameters added in Release 4.4 #######
# Call Hold Ringback (0-off, 1-on, 2-off with no user control, 3-on with no user control)
call_hold_ringback: 0		; Default 0 (Call Hold Ringback feature is off)
####### New Parameters added in Release 6.0 #######
# Dialtone Stutter for MWI
stutter_msg_waiting: 0		; 0-Disabled (default), 1-Enabled
# RTP Call Statistics (SIP BYE/200 OK message exchange)
call_stats: 0			; 0-Disabled (default), 1-Enabled
4
SIPmac.cnf
# SIP Configuration Generic File
# Line 1 appearance
line1_name: "1234567"
line1_shortname: "sipgate"
# Line 1 Registration Authentication
line1_authname: "1234567"
# Line 1 Registration Password
line1_password: "xxxxxx"
# All user_parameters have been removed
# Phone Label (Text desired to be displayed in upper right corner)
phone_label: ""	; Has no effect on SIP messaging
# Line 1 Display Name (Display name to use for SIP messaging)
line1_displayname: "Xxxxx Xxxxxxxxx"
####### New Parameters added in Release 3.0 ######
# Phone Prompt (The prompt that will be displayed on console and telnet)
phone_prompt:   "cisco7960"      ; Limited to 15 characters (Default - SIP Phone)
# Phone Password (Password to be used for console or telnet login)
phone_password: "cisco" ; Limited to 31 characters (Default - cisco)
Bin für jeden Tip Dankbar !!
Danke & Gruß,
Elimn
Default.cnf
Kann ned funktionieren: p<roxy1_address: "217.10.79.9", ausserdem gehört diese zeile in die mac.cnf genauso wie proxy1_port
nat_address muss "" sein.
und den control und die media ports müssen vom router auf das telefon weitergeleitet werden.
outbound_proxy auf "" setzen
4 am ende passt ned
mac.cnf
Passt, nur nicht vergessen die beiden Zeilen von oben hier rein zu ziehen.
ok, danke erstmal für die schnelle antwort !
hab den typo beseitigt und die besagten zeilen umkopiert,
jedoch brachte dies auch nicht wirklich erfolg ;(
geh mal ins telefon auf settings-5-1 und sag was dort als oberste Meldung steht.
btw, line1_name und line1_authname müssen deine SIP-Account-Nummer sein, hab daran auch tage getüftelt bis ich das rausfand :)
hm hab mir kurzer hand n linksys-router (wrt54g) gekauft
und damit tut alles einwandfrei !?! sch... netgear
das kanns ja normal net sein son mist
josephezra7
