- Mitglied seit
- 17 Mrz 2009
- Beiträge
- 1,454
- Punkte für Reaktionen
- 1
- Punkte
- 38
mit der aktiuellen Github-Version ergibt sich beim Bau ein cmake-Problem:
Hat jemand eine Idee, was da zu tun ist?
JD.
---> toolchain/kernel/ccache ...
configuring ... (cd /home/john/Githubs/freetz-ng/source/toolchain-mips_gcc-5.5.0/ccache-4.7.3; rm -f CMakeCache.txt; \
CC="gcc" \
CXX="g++" \
CFLAGS=" -D_GNU_SOURCE -fno-stack-protector --std=c++03" \
CXXFLAGS=" -D_GNU_SOURCE -fno-stack-protector --std=c++03" \
cmake . \
-DCMAKE_C_COMPILER_TARGET=x86_64-pc-linux-gnu \
-DCMAKE_CXX_COMPILER_TARGET=x86_64-pc-linux-gnu \
-DCMAKE_INSTALL_PREFIX=/usr \
-DENABLE_DOCUMENTATION=OFF \
-DENABLE_TESTING=OFF \
-DREDIS_STORAGE_BACKEND=OFF \
-DCMAKE_MESSAGE_LOG_LEVEL=status \
Re-run cmake no build system arguments
-- The C compiler identification is GNU 7.5.0
-- The CXX compiler identification is GNU 7.5.0
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/gcc
-- The ASM_MASM compiler identification is unknown
-- Found assembler: ml
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Ccache version: 4.7.3
-- Ccache dev mode: OFF
-- Performing Test std_atomic_without_libatomic
-- Performing Test std_atomic_without_libatomic - Success
-- Performing Test std_filesystem_without_libfs
-- Performing Test std_filesystem_without_libfs - Failed
-- Performing Test std_filesystem_with_libfs
-- Performing Test std_filesystem_with_libfs - Failed
CMake Error at cmake/StdFilesystem.cmake:22 (message):
Toolchain doesn't support std::filesystem with nor without -lstdc++fs
Call Stack (most recent call first):
cmake/StandardSettings.cmake:57 (include)
CMakeLists.txt:70 (include)
-- Configuring incomplete, errors occurred!
See also "/home/john/Githubs/freetz-ng/source/toolchain-mips_gcc-5.5.0/ccache-4.7.3/CMakeFiles/CMakeOutput.log"
$ cmake --version
cmake version 3.24.3
CMake suite maintained and supported by Kitware (kitware.com/cmake).
JD.
